Stabilizer.
Re: The Stabilizer.
Announcement.
We have produced S2+
in other words, the stabilizer версии2 greatly enhanced(+).
Technology use and programs - the same.
More at power and manufacturing technology field.
It is much more powerful.
Re: The Stabilizer.
To my great regret, the technology to create kopeck piece I can't make public because it is not purely home technical cycle. For homebrew, as in the case of the UK, remains the extensive option (increase the size if needed more power).
Re: The Stabilizer.
The reason for the release of more powerful versions - some changes in the world ( higher mobility thereof) that make this version more relevant.
Re: The Stabilizer.
Voffkaif not difficult, perezaleyte file, deleted it again...
Re: The Stabilizer.
VoffkaThank you! Just me still says "file deleted". The link is the same? http://exfile.ru/219960
Re: The Stabilizer.
if I'm on one 2.5 Druze clothe and wrap in foil because she is charged as 2.0 or as 1.0
and the same situation 2.6
thank you
thank you
Re: The Stabilizer.
well as a weak 2.0
Re: The Stabilizer.
We completely discontinued the manufacture of Stabilizers.
Instead, they will be made Stabilizers version 2.
Two sizes, large and small, as before.
Prices remain the same, 120 and 60
The number of anchors and programs in the standard delivery will now be the same 25pcs. and so and so.
Photo lay out later ( does not need the client version not busy I have an important work but the "product type", ie minimally different from serial, to photo like the serial
Both units are MUCH STRONGER!
Re: The Stabilizer.
New C2 (Стабилизатор2) comes in a variant without housing. Ie is a kind of molded design.
Bottom he is.... rounded... This bottom part, you can just put on the table, although in this state it is slightly not stable (anchors as always I recommend to secure with tape or double sided sticky tape, plaster and so on). But you can drop in a big plate, a bowl with water (or another suitable container of water) Will significantly impact the finding in this water washers KV.
These three modes (without water, with water and with water with KV) differ from one another according to the dynamics of the processes.
How? It is easier to try to tell....
Re: The Stabilizer.
Good evening. What shape is better to make the armature round or square?
I can not go to openlogic. search engine it finds the link.
Re: The Stabilizer.
As You deem convenient and necessary. I personally liked the oval /ellipse type - worked very well/ when karastan Stabilizer, but everyone has their own preferences. Only it is recommended not to cut part of the image Anchor. By the way, as far as I remember, I think, recommended square shape with dimensions of 2.54 cm to 1 inch.Машина wrote:What shape is better to make the armature round or square?
Re: The Stabilizer.
recommended for example a round size 1 inch, but can be oval, as it's better square.
Re: The Stabilizer.
In my experience I can say that Yes, it does. Myself tested. Different shape different shape of the exposure and the distance from it. All I want to describe it on the forum, but did not intend to.Воффка wrote:So the mandala itself is square... Has the value form of the paper on which it is printed?
Re: The Stabilizer.
Not very clear - square mandala anchors must be printed on a round piece of paper? or the mandala to make a round diameter in inches?
Re: The Stabilizer.
on a round piece of paper.
Re: The Stabilizer.
Hello!
My last big stab of the first edition.
Blew the dust off it.
Raised anchor six months lying on the Druze(of NATO).
And friends,at the place of contact with the anchor appeared a white speck.That is a small part of the Druze(3 mm by 5 mm) was white.
Initially,when the instrument came to me to friends there was not a speck.
Please tell me :
From which appeared a white spot on friends?
Please tell me :
Re: The Stabilizer.
obviously active interaction with the anchor.
Not scary
(in the second generation by the way we druso not put in General, there is a plane in this place operable to move the anchor)
well, just did apparently not bad
Not scary
Re: The Stabilizer.
Thank you,Michael! Second generation big stub I of course did purchase.Soon I will be ready to order!
Thank you very much!!!
Re: The Stabilizer.
Is it possible instead of an anchor, you could use something like BioLink, or organization's logo, photos, etc.?
