Please read my article on the website "Affirmatsii - the way to God"Лесёнок wrote:Thank you! But I at the expense of affirmati: if affermazioni all clear, what is the value of affirmatsii how these issues affect the subconscious?
The Program Of Andrey Patrushev Raduga
Елена1974
What age is it appropriate to use? My son is 10 years old, was transferred to another school. The child had a fear, suspicion, and often irritable. If possible the child to use the program, how often and for how many minutes? Another question: what phrase to put in the center? Can someone tell me, and I'm afraid to write, in these matters I am a complete zero, I'm afraid to get hurt. Proposed BSFF-the text the child is easy to master, this is my opinion. Elena.
Елена1974
Since the age of 14.Елена1974 wrote:what age you can use? My son is 10 years old, was transferred to another school. The child had a fear, suspicion, and often irritable. If possible the child to use the program, how often and for how many minutes? Another question: what phrase to put in the center? Can someone tell me, and I'm afraid to write, in these matters I am a complete zero, I'm afraid to get hurt. Proposed BSFF-the text the child is easy to master, this is my opinion. Elena.
With the physiological and psychological addictive (not to be confused with addiction), as well as needs time for implementation.Anonymous wrote:Andrei Patrushev
Tell me what caused the break between courses of the Rainbow 15-15-15 and then the next course in only 3 months??
Although it is not for the Rainbow was written, and for the Conductor...
Андрей Патрушев wrote:Anonymous wrote(a):
Andrei Patrushev
Andrei Patrushev
Yes, all right, I was wrong..... Made a little note when I read konfu, but I have not misrepresented the place stuck ;(
Break for 3 months only for Explorer need or for others too nepomeshaet for best results, or vsetaki not needed?
баклан
Hello.Мит wrote:a Good hour, Andrei Patrushev.
Put Your programme rainbow-arch. All it affects that laptop is weak.
1.I never faced 25 overs live. When viewing costco can read everything that POPs up on the screen is as it should be?
And it's not the 25th
And the entrance into the unconscious then does not affect the psyche, and in General to "normality"?After all, we hypnotized the organism for certain behavior(force).
For example, the encoding of alcoholize, Smoking, etc. First of course valid, but then the person breaks down and it turns out even worse(I have never seen a positive effect).
Very interesting...
Very interesting...
Where You enter when making love, read interesting book, watch an exciting movie???Гость wrote:And the entrance into the unconscious then does not affect the psyche, and in General to "normality"?After all, we hypnotized the organism for certain behavior(force).
Very interesting...
And what this all has to do with the encoding???
@нн@
Spivak, "How to become a polyglot" excerpt:
"And once, when it seemed that everyone here already knows, something unexpected happened. A teacher in one of my classes put a recording of quiet music and at the same time recording quiet voices, reading the words that should have remembered, and itself somewhere has left. During his absence, was read around 2 thousand words. Imagine his surprise when he found that the unsuspecting students remembered almost all the words! Such requirements before even serpollet not be charged. And the point here is obviously not only in the team and recorder, there were clearly involved a "Mr. X".
For a mysterious stranger came from really. In the Moscow Institute of higher nervous activity and neurophysiology of steel seated man with headphones in front of a screen and simultaneously display and read him a list of foreign words with translations – so that each pair accounted for 1/10 of a second. During this time, not to read, but even to know prusnikova the word impossible. And so for many hours. And the results turned out great. An hour of such work or, rather, the race regardless of the target language to be utilized not less than 6 of every ten of these words and phrases. In total for 10 days was remember up to 6 thousand words! Can be obtained in such an unusual way knowledge and quickly erode out of your head? Yes and no. When these same groups were tested through a year and a half, it appeared that at least half of the words stayed in memory. And about 3 million words – more than enough for any purpose."
Hello, Andrey!
There was a desire to poeksperimentirovat with the Rainbow putting the values in the program for learning words, where "every couple had 1 / 10th seconds". How can I change settings to get the speed that is displayed on the screen if this is possible? That's only an hour, or more, in front of the monitor over the Rainbow is probably a bit too much...
Hello!@нн@ wrote:hi Andrea!
In the settings there is "frequency", put it there 10. But, in my opinion, there is initially the optimal frequency of 6.6.
All's well that in moderation (no more than 45 minutes)...
- Вадим Перелыгин
- Been thanked: 7 times
Criticism of the program, the rainbow-arch:
1. When clicking "Save" opens the window "Open" instead of "Save". This is misleading.
Not described the purpose of the check boxes, the Background of “Top”, “Active”, “Focus”.
2. Background settings are not saved after Alt. They need to be made manually.
3. Files with affirmations, names and audio program sees only in the current directory.
4. Affirmations is more than 186 characters takes. Do not fit the formula of A. V. Cab.
5.Technology 25 frame includes a short affirmation imperceptible to consciousness, repeating a certain time required for the perception of her subconscious. Same here - the text is always visible and with increasing frequency - even more noticeable.
6. Long formula of self-hypnosis is best used via the audio channel.
7. Criticism formulas of auto-suggestion of Professor A. V. Scorcher.
Formulas of the type
"Disappear discomfort: pain, stinging in the eyes, trembling eyelids"
"Are nausea, belching, heartburn"
"Skin rashes are reduced. Are itching, redness"
"New lesions on the skin due to irritants (powder, paint, etc.) will not be"
"Stop a headache. Stop the dizziness, nausea, vomiting"
"No physical exertion, excitement, anxiety, sorrow will not have an adverse effect on my body"
it is better not to use because they work up to "contrary". The subconscious does not perceive the particle "not". It is necessary to formulate a specific desired result in the form of a picture, an image, and not to remember their sores.
8.Similarly in formulas Sedona. Attention grabs only the main words – pretty nasty!
And the fact that I "let go..." I don't believe it!
With apologies and best wishes, Vadim.
- Вадим Перелыгин
I recommend a good combination of the use of the Rainbow.
Disconnected Phrases and Names.
A file with the text in the center "of Affirmatsii for Радуги.txt"
Font 48. Built-in background: Height=140, DeltaY=40
Soundtrack: "1 Awakened Mind System.mp3"
Launched in BWGEN3.1.5 session BUILTIN: The awakened mind by Anna wise is a template of the Active intellect and Enjoyed affermazioni "How good I am!"
