Solar wind
as I understand it, this CD is impossible to listen to "passively": it is necessary to do special yoga exercises, but what about the tracks "solar Wind" and "Song of Chakramov"? Is it possible to listen to just rasslablenno condition? and whether you can harm your health when you exercise without experience?
You can listen to all without any danger. You can perform the exercise (no voltage) "Chabrowy vocalization", also without danger. Any other exercises without experience or an experienced mentor to perform not recommend.Экко wrote:as I understand it, this CD is impossible to listen to "passively": it is necessary to do special yoga exercises, but what about the tracks "solar Wind" and "Song of Chakramov"? Is it possible to listen to just rasslablenno condition? and whether you can harm your health when you exercise without experience?
Саулюс
The only difference in the original volume, placed on a disk.Саулюс wrote:Hello to All:)
noticed that the track "solar wind" wind or sun is significantly different from that applied in the album "star wanderer", in the latter it is more "violent" or something, so to speak. And the album with the chakras pleased with the quiet motive. Why? and why is their effect?
Алекссей
I want to share my impressions!
Here, it took about two months after the beginning of the disk "solar wind".
After about 1.5 months of daily sessions, noted the following results:
- became much more balanced (it was noted by all those who know me, people);
noted a significant increase of self-confidence;
thinking became more flexible and wider - began to consider more solutions and choose the best (with absolutely no straining).
... after 1.5 months of classes ended with the drive - the result was incomprehensible maloobespechennye psychopathic phenomena - began to "fall" for nothing!
Lasted such a psychopath for about a week - then went on the decline.
Now I'm afraid to even start again to listen to the disc!
Here are the pies!
Here are the pies!
Идущая вперед
- Been thanked: 6 times
Идущая вперед
very good effect from the consumption of the disk of the solar wind and practicing Kundalini yoga.
ie first - solar wind
after an hour of Kundalini yoga (a complete set of exercises, meditation and breathing exercises takes about 1 hour)
and be sure to drink water as much as possible...
previously, Kundalini energy literally burned and corroded my spine, it is pounded with hammers, after they combined - the problem disappeared
Reread the thread and then, suddenly, it dawned on meЕвгений Кош wrote:Add cool effects..
after going through the second chakra and start to work with third - starting to see a lot of visual images.. as if before my eyes with a high speed scroll through different photos and not a few images which I (think) never seen.
The speed of displaying "pictures" are very high.. some do not even have time to consider.. photos surrounded like an aura.. ( you see them as if through colored fog, but the center - that there's no fog and the visibility is clear).. most of the photos - black-and-white.
Конструктор
лёша я
Yesterday was the first contact with ST had previously worked with the conductor, feeling:
as if moved inward and from this distance, watched the whole process;
- when I listen Vishudha the skin surface of the throat glowed a warm-heat "in the bath" (it means there are problems will continue to engage will dissolve).
Had previously read to understand what is chakra, the author does not remember it said that out of 144, 12 of which main 5 the secret one is HIT, the rest are in the middle of palms and in the middle of the foot.
Question to Andrew: what do you think about the centers in the palms and soles, are there any measurements on the sly devices
Идущая вперед
Мария2000
all yoga systems are directed at one goal only - to learn to understand and improve yourself, your body, mind and SPIRIT... the last is the most important... it is the development of the SPIRIT (through nehochu, through overcoming, through the working out of their disparate and non-integrated such particles, through the transition of the edge which is called - I can't,lazy, worthless, excuses and excuses are always, etc.)
the solar wind itself is a strong enough drive and him a special app is needed... just together with classes, any yoga chakras are worked at a deeper level
- Дмитрий В.
- Been thanked: 2 times
if you listen to only the song of chakramov, whether it is necessary to listen to solar wind?Андрей Патрушев wrote:The 12th is also the solar Wind.Валерий Юрьевич wrote:Dear friends, please tell me, what it is track 11 on the CD "solar Wind"?
The description States that track 1 is the solar wind, 2-10 chakra, then the Song of chakramov. Whence then the extra track? And what is it?
if you listen to the chakras, it is necessary to listen to solar. the wind chakra? or Sunny. the wind chakra and solar. the wind?
The solar wind is always necessary. In the beginning he helps you tune, if too tired (or worried) for the day, and after a few to reduce the too strong effect of the work with the chakras, or the song of chakramov.Дмитрий В. wrote:if you listen to only the song of chakramov, whether it is necessary to listen to solar wind?
- Дмитрий В.
No, standard-36dB (for starsignal). On my inner and Nova all work clearly...Экко wrote:Andrew, You are too low volume on disk is made, the decoder does not react, it is necessary in audio editor to increase it 3 times. In the editor, the graph shows a narrow strip somewhere 1/5 of the total scope, too quiet IMHO.
Yes, normal sound.Экко wrote:well, there is not only the gate, the sound in the headphones is too weak even at maximum volume. And not all of inner isno, standard-36dB (for starsignal). On my inner and Nova all work clearly...
In addition, the efficiency is maintained even at the threshold of audibility.
Good Luck To You !
When proslushivanii Conductor, was vaginal, pulling middle fingers up, very distracted from listening, the impression I want to touch, do hands lie exactly on the bed, and from Drive C. V. move the toes as if playing the piano
even the feeling of the pole in the back, as if aspili on the needle along the spine, (well, all the above description in the forum, the feeling was also, in one day, in another session, the session does not like). The feeling is very distinct, I wonder what that would mean?
I was told that there are ukloneniya in "green coridor" what does that mean?
And another question points(color) while listening to To put on white color, it gives red, blue, green, listening to the light changing constantly, it is my personal impression, or these color changing machine in accordance with the signal?
