Ring. Workshop
Мицкле
Re: The Ring. Workshop
Post by Мицкле » Wed Mar 08, 2017 23:38
Post by Шалтай Балтай » Sun Mar 19, 2017 22:56
not enough experiments with brass, heavy material, very fragile
only time takes away
Post by Шалтай Балтай » Sun Mar 19, 2017 22:57
Copper F5, A Half-Forgotten Measurements
Post by Шалтай Балтай » Sun Mar 19, 2017 22:58
It is the same in a different perspective
for those who watch remotely
Артфан
Post by Артфан » Mon May 01, 2017 17:27
Шалтай Балтай wrote:Copper F5, a Half-Forgotten Measurements
Hello, dear Humpty. I'm a fan of loops. Whether You made the pendants loop continuous wear?
Post by Шалтай Балтай » Sun May 07, 2017 15:16
Артфан wrote: Hello, dear Humpty. I'm a fan of loops. Whether You made the pendants loop continuous wear?
Good zdraveska, Artfan
I think on the subject, there is the idea....
Post by Шалтай Балтай » Sat May 13, 2017 17:18
Spilo hot, still warm
this pendant in 1/4 merecki, F1.5, Three (triple wiring)
the above - 177, those that are bottom - 144
Post by Шалтай Балтай » Sat May 13, 2017 17:19
Post by Шалтай Балтай » Sat May 13, 2017 17:20
Kuvak, Basic, No. 308
Post by Шалтай Балтай » Sat May 13, 2017 17:21
Colonel, 1 Scoop 144
Post by Шалтай Балтай » Sat May 13, 2017 17:22
Oh, che is the magnifier dusty what :oops:
тундра
Post by тундра » Mon May 15, 2017 12:29
:) Humpty Baltay Thanks for your work !
you have begun experiments using enameled magnet wire - a question of how these rings worked in comparison with products manufactured by wire without insulation ?
should I remove the insulation ? or they have their additional effects
Post by Шалтай Балтай » Mon May 15, 2017 12:40
Good zdraveska, tundra
тундра wrote:you started the experiments using enameled magnet wire
accurate, is what was at hand
тундра wrote:how those rings worked in comparison with products manufactured by wire without insulation ?
emalirovanaya wire - better not to use. Better to do as slim.
Max diameter enameled wire - 2mm is not much.
Better to take 2.5 - 3mm f
тундра wrote:do I need to remove insulation
this is a very brutal operation, I would not have taken....
advice, don't reinvent leaped. Dalite like slim. Will make a certain amount of rings will have an understanding of maetrial, work with vibration, will get the return. Picture and going....
Post by Шалтай Балтай » Sat Sep 16, 2017 16:42
[youtube]http://www.youtube.com/watch?v=z---S8sO4MM[/youtube]
Link Linear Measurements
Information on them a little - don't torture me :)
Post by Шалтай Балтай » Fri Jan 05, 2018 19:30
Blank Aku-Waka: Ф4мм
Post by Шалтай Балтай » Sat Jan 13, 2018 21:12
I welded Kuvak F4:
The one that vinsu is a pendant, Pigtail F2, Kuvak New Dimension, 144 Main Measure, the First Size
Pendants is a good thing, always. It is very effective. If, for example, not in the mood for any person to communicate, the impression that the person is "flying" to a distance of a few miles, and completely can't see You 8)
Post by Шалтай Балтай » Wed Jan 17, 2018 16:28
Finishing transfer "TECHNOLOGY SLIM SPARLING"found an interesting paragraph:
In some of my last conversations with Slim, he told me that he had begun to
experiment with three and four twists of wire, instead of two. The idea came from
one of the men who worked in the shop with him. At the time, Slim decided to call
that ring the ‘Freedom Ring’ but his death interrupted its development and there are
very few reports on what it can do. Where that project will go is up to fate and time at
this point.
translation:
In some of the latest conversations of slim mentioned that he began experimenting with three and four wire strand wire, instead of two as obyachno. The idea came from one of the men who worked with him in the Studio. Slim decided to call the ring "rings of freedom", but his death interrupted his Razorback, and there is not enough material on the practical use of these rings.
Well, my otzyvaetsya To three Hundred Rings of Freedom on the slim :)
No, it sounds cool, but disappointing at the same time, well, no creativity, everything is already invented to us! :cry:
Post by Шалтай Балтай » Sat Jan 20, 2018 19:06
Not very successful attempts to increase the density of lay
Post by Шалтай Балтай » Sat Feb 10, 2018 19:15
Decided to use a pigtail yielded the following rings:
for sale of these products will not go, of course. This is for me... for the cobbler. :)
By the way, I'd say that Jola is funny, petal, like a flower of chamomile....
Post by Шалтай Балтай » Sat Feb 10, 2018 19:16
this "classic" 144, 177 and 188
144 - F3
177, 188 - F2.5
Post by Шалтай Балтай » Sat Feb 10, 2018 19:17
This seam 177, under a magnifying glass
Александр Н.
Post by Александр Н. » Sun Feb 11, 2018 16:53
Hello, Humpty!
If not a secret, tell me where you take the wire with such diameters. Those wires are sold in elektrotovary, categorized by section. The diameter of the wire of the same cross section according to GOST and TU can vary greatly.
the cross section of the cable diameter table:
https://yandex.ru/images/search?text=%D ... source=wiz
Maximum cross section that I could find is a 16 - wire diameter of slightly more than 4mm. to Weld such thick rings turned out and want to try bigger diameters. Where you take the wire for example with a diameter of 5mm? Tell me, if not a secret, thanks in advance.
Post by Шалтай Балтай » Sun Feb 11, 2018 17:53
Alexander N.
that thicker F4 - it is called the rod:
https://nova.rambler.ru/search?query=%D ... dGVzdDs7Ow
that before choosing a particular vendor, this is determined by Your appetite :)
the wire comes in coils of 5kg. the rod piece. it can you chop length.
PS
Do not look for a cable, the Key words here are: Copper, wire, rod buy <your city>
Hope I helped. :?
Good luck
