The magic of biochemistry or biochemistry magic
Логия
Has thanked: 111 times
Been thanked: 47 times
Re: the Magic of biochemistry or biochemistry magic
Post by Логия » Tue Sep 12, 2017 21:57
.по. wrote:If you are scared and you are defending his immortality
so it's not immortality...
the desire to know ourselves...
not to count and identify only with the Body....
.по.
Has thanked: 11 times
Been thanked: 46 times
Post by .по. » Tue Sep 12, 2017 22:00
Need to think with an open mind. So that it does not contradict the known facts. Facts about something besides the body - no, there is only speculation. But speculation can be endless, imagination is limitless... And to avoid confusion, we need to build these conjectures, step by step, but based on logic and given the consistency of the facts... Just make up something - to no avail.
.по.
Post by .по. » Tue Sep 12, 2017 22:03
Oh????
))))no-one....
If you study the history of the emergence of mysticism - that it originated around the time of Blavatsky. The Theosophical society of the elect, who was snorting cocaine on the mysteries, catching bugs and described fantasies of the unconscious... And described as a hit - here in fact it's all in the interpretations, how close they are to describe perception. To correctly interpret - you need to know many scientific facts about the world, not to invent non-existent. And before that, you need at least to perception, and not to quote someone else (it is not yours, you no sense of it). And perception it is advisable to without psychedelics, there is no sense - just glitches the unconscious, the strain on the nervous system and closer to death.
Хорошо
Has thanked: 24 times
Been thanked: 19 times
Post by Хорошо » Tue Sep 12, 2017 22:03
Логия wrote:I got something to tell)))))this is a private matter of each.... :wink:
where I don't need to assure you'll take on faith the soul/consciousness and attempts to explain the mechanics of more about the aliens remembered )) I'll say that I should just "believe" and not try as it is to rationally explain :)
Логия
Post by Логия » Tue Sep 12, 2017 22:06
and what the human Imagination???
to be able to move away from the dogmas that hinder the development of...
.по. wrote:So that it does not contradict known facts
it seems you wrote it yourself-you need to consider views from all sides...even when they are contradictory, in order to get closer to the Truth...
or I'm wrong and that someone else wrote?
Логия
Post by Логия » Tue Sep 12, 2017 22:07
.по. wrote:The Theosophical society of the elect, who was snorting cocaine on the mysteries, catching bugs and described fantasies of the unconscious...
.по.
Post by .по. » Tue Sep 12, 2017 22:09
you wrote yourself-you need to consider views from all sides...even when they are contradictory, in order to get closer to the Truth...
Yes, that's right. But the key point here - you need to look for the ball, and you just rush to the other pole (tilt). The intersection is where both poles is not a contradiction. This means that all you came up with a rich imagination - must be confirmed in the matter.
Wise, I don't use psychedelics, although I tried very long-time.
Логия
Post by Логия » Tue Sep 12, 2017 22:10
Хорошо wrote:I'll say that I should just "believe" and not try as it is to rationally explain
you're better off....and my analogies...I may not immediately explain myself..but I will do small steps...
rather than drive themselves into the framework of dogma and foundations...and wait....when everything happen..and come to a rational explanation...
Логия
Post by Логия » Tue Sep 12, 2017 22:17
.по. wrote:This means that all you came up with a rich imagination - must be confirmed in the matter.
and if strivings not only of matter/solid....what they can confirm?
how can you confirm that if the fan blade spins fast..and at some point he disappears from sight and you see the objects through it?
.по. wrote:But the key point here - you need to look for the ball, and you just rush to the other pole (tilt).
this is a view from the outside...inside it looks like a lot of scattered vectors /not finished....in order not to limit your perception...and leave the stock/ from a single point...at any moment I can continue any started..sometimes they overlap....
here seems to sharply drop one subject and go to another-this is actually a continuation of the same...just the other part....
Логия
Post by Логия » Tue Sep 12, 2017 22:19
.at.
and so I was rushing, reality
Believe)))
.по.
Post by .по. » Tue Sep 12, 2017 22:19
but if the pursuit not only of matter/solid....what they can confirm?
perception. It either is or it is not... If you know how to fail on their own (enter the nervous system in unusual modes) - learn them, maybe something interesting will show up... But it is still necessary to correctly interpret... And to learn something in foreign words only with no result. Just did not understand - as it's what you can only imagine something else, but avail...
Хорошо
Post by Хорошо » Tue Sep 12, 2017 22:21
Логия wrote:you're better off....and my analogies...I may not immediately explain myself..but I will do small steps...
how is it better - is it just your imagination, but the fact that you're one strange thing began to explain the more baffling thing is the fact, recorded in the pages of this forum )) I'll say - it is better to wait "when everything will happen and come to a rational explanation" in the meantime, just honestly say "I don't know" or "I believe" )
Логия
Post by Логия » Tue Sep 12, 2017 22:23
.at.
and yet....
you wonder-where does the images of Imagination?
Fiction where to find *inspiration????
and after all, they are...repetitive....nothing new came up...all based on already known...because imagination is based on something....one...
Логия
Post by Логия » Tue Sep 12, 2017 22:27
.по. wrote:And to learn something in foreign words only with no result.
again, your old record...someone else...someone else's words....
there is nothing alien....there's you and the universe that you are talking to..accessible language....
it's a movie..the movie...the book...
can tell another is you write...off...to myself....to Wake yourself
what about the crowd-illusion)))is stable enough......and notice ...how the Mind reacts to these words....)))
.по.
Post by .по. » Tue Sep 12, 2017 22:28
Yes, this is the most elusive source for the thinking of "not brain." Just, you know, if fiction can do that, to take out of nowhere... understanding you is not concerned, if you don't know how... the Role of imagination, you exaggerate - give a hundred people the job to write fiction story and 50 do not write anything, and write 49 a compilation of the known facts...
To create something new, unknown is already to Create. Pre still need to learn how to think and perceive )))
Логия
Post by Логия » Tue Sep 12, 2017 22:29
Хорошо wrote:how can I get better - this is just your imagination
every man amuses himself as best he can)))) :wink:
Логия
Post by Логия » Tue Sep 12, 2017 22:31
.по. wrote:Pre still need to learn how to think and perceive )))
well, what prevents it ?learn....
.по.
Post by .по. » Tue Sep 12, 2017 22:32
If I know physics, astronomy, biology, genetics, etc... Then this is Ya Not you )))
If I knew how to fix a broken iron - it is Ya Not you )))
If I can write fairy - tales that I and My imagination. Not your ))) You do not know how.
You know the difference? As many can tell you how to fix the irons, but until you fix yourself - you'll never know how it is.
But we are done, since you have already started just to write about anything, already trying intentionally to hurt, and then go into a blowout...
Логия
Post by Логия » Tue Sep 12, 2017 22:32
.по. wrote:To create something new, unknown is already to Create.
what and what????are you going to do? if your man is only a Biological entity?
Логия
Post by Логия » Tue Sep 12, 2017 22:35
.по. wrote:already trying to hurt
but started you....since you only know how, not me)))) :lol:
_____________________________________________________
that's so..and then talk...no one to... :? :oops: :)
.по.
Post by .по. » Tue Sep 12, 2017 22:54
This topic is not for to talk, if not set out thoughts, for example, as did the Slider.
And, in General, is a very dangerous topic. When a person, without something, you'll hear the songs of dozens of singer-songwriters and will automatically copy as if he has it in him... But he may not be, it is only a possibility, the horizon... the authors are the Creators, it's a different level of consciousness, who still need to achieve on their own. For me that clearly differentiate and not induced by other people's experiences.
When you learn how to do - you can explore other people's creations on the subject of understanding them. Get topic, show that you are able to create your own. Show personality... Otherwise where did it come from? This can be learned only by practice.
Логия
Post by Логия » Tue Sep 12, 2017 23:15
.at.feel free to ask......you a cardboard crown case is not too tight??? :wink:
.по. wrote:And, in General, is a very dangerous topic.
I guess after your words....I have to feel the fear....and the wretchedness of their existence???
yeah...apparently this is the top of ...your awareness.... :lol:
and since you started to give me advice....allow yourself.....
can you again apply spice.....and something like that...began to curl .... back to the Body))))
:ap
.по.
Post by .по. » Tue Sep 12, 2017 23:19
That slid on reflexes... the Program "revenge" and "try to hurt out of a desire to hurt". There will be enough awareness to understand this and not continue?
Логия
Post by Логия » Tue Sep 12, 2017 23:23
and you thought I'd be modestly silent on the sidelines?and quietly watch your reflexivity?need to you someone showed..and since I...passed by..... :lol:
and that...hurt?seriously??
.по.
Post by .по. » Tue Sep 12, 2017 23:25
Not hurt in any way, it's impossible. Just once again convinced that everything is useless... whatever was written... it is Impossible to understand that this is not for you unpleasant, and the program that you did not respond, and the program you
