Woof! BU-ha-ha...
Integrated control technology a reality
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Re: Neocolor II. The library programs. Reviews. Discussion.
Post by мимоходом » Wed Jan 04, 2017 23:50
Not convincing ))) because if you try to convince - then do the reflex arc closes and will not razmoknet ever.
Гуфест
Has thanked: 125 times
Been thanked: 120 times
Post by Гуфест » Thu Jan 05, 2017 0:02
Galkin master, you can be sure.
мимоходом
Post by мимоходом » Thu Jan 05, 2017 0:02
who would doubt )))
Гуфест
Post by Гуфест » Thu Jan 05, 2017 0:07
Not convincing )))
This is what followers do not have.
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 0:11
let's softinku distribute :) any ideas?
мимоходом
Post by мимоходом » Thu Jan 05, 2017 0:41
for example, there are softinkoy (that you write is not a problem, the problem is - what) ))) How would you answer the following questions:
- where it is performed
- how it receives incoming data, such as rfid
- how it passes the result of the computation on rfid
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 1:00
мимоходом wrote:let's have softinkoy (that you write is not a problem, the problem is - what) ))) How would you answer the following questions:
1/ C#
2/3 file:///C:/Documents%20and%20Settings/Admin/%D0%9C%D0%BE%D0%B8%20%D0%B4%D0%BE%D0%BA%D1%83%D0%BC%D0%B5%D0%BD%D1%82%D1%8B/Downloads/kriptograficheskiy-protokol-obmena-dannymi-dlya-rfid-metok-so-vstroennym-generatorom-psevdosluchaynyh-chisel.pdf
alternatively, you can
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:02
1/ C#
no where it is physically performed? And as the place of performance may be associated with rfid? The fact that rfid is passive, does not have its own power source and uses the energy from the wave transmitter to send a passive response in the Protocol. The easiest way to describe the card works in the subway near the turnstile, not at the entrance to the subway. Because rfid has a range of a few meters, because the energy of electromagnetic radiation decreases quadratically to the distance, and this energy is not enough to feed the rfid to respond from afar.
Now imagine that you have a flat is the server on which the program is executed in c#. How is it that any of the said rfid user for 1000 km or even 1km? What she believes? How to send back? In other words, the first question depends on the physical channel.
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 1:07
in the computer,and transfer to the reader via the RS232 USART or UART
if you can read this article in my opinion an interesting experiment successfully, http://embedders.org/blog/teap0t/fonovy ... l?page=0,5
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:09
and the transfer to the reader
The question is what kind of reader ))) It must be an incredible power of radiation to kill to rfid at any distance - otherwise rfid will not be able to send him / her the answer is not being energized. In addition rfid in the passive Protocol. Request he sends a "reader" and only if the signal of the reader came to the rfid and was able to bring in this microflow, only then rfid will answer. And even in this case, the response from the rfid it will be possible to capture at a maximum distance of several meters, so he is weak, is generated by microcurrents. That is, even if you have a reader capacity of the TWh - rfid will not be able to give your answer at a great distance.
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:13
well, this is the essence of rfid technology. And it works for a maximum distance of several meters ))) and write About it. The physics of this... your article, the distance of 25mm. In classical schemes the limit for rfid is the metre.
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 1:14
start here and next below, the transition at the page http://embedders.org/blog/teap0t/fonovy ... l?page=0,5
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:16
I read how it works and doing professional including this area (receiving the transfer) more than ten years )) Just try to understand what's the catch, on the last page wrote
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:18
if you don't believe me, here: https://ru.wikipedia.org/wiki/RFID
for passive rfid without power:
the Range of labels is 1-200 cm (HF-tag) and 1-10 meters (UHF and microwave tags).
for active rfid powered
Active tags typically have far greater read range (up to 300m)
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 1:19
all the same, since there is no possibility to read the full 6 page
You main text
6 Tests
The tests were carried out in urban areas in the Seattle area receive television signals frequency 536-542 MHz. Testing was conducted at six points to account for attenuation and multipath effects in a variety of settings. A bandwidth of 6MHz signal strength was in the range from -24 dBm to -8 dBm. As the ground has been chosen the following places:
The first point (inside close): the apartment on the eighth floor of an apartment building in the area of intensive development at a distance 0.31 mi (0.5 km) from the TV tower.
The second point (inside and away): seventh floor office complex in 2.57 mi (4.1 km) from the tower.
The third point (outside and close): the roof of the same apartment building.
The fourth dot (outside far): the roof of the office complex.
The fifth point (outside and then): street corner at a distance 5.16 mi (8.3 km) from the tower.
The sixth point (the outside and furthest): upper-level multi-storey garage on the distance 6.50 mi (10.5 km).
and still iznachalno I wrote in my opinion this is all if running high as a good structural link is not more, and according to other laws :? but I want to think otherwise
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:26
Generally, these rfid used in various conventional plastic cards in trade networks - in many places. Why do you think the squeak sentry turnstiles when someone tries to steal something from a shop ))) this is an area of rfid - whether it otherwise, it would have saved a lot of money and would put one reader in the entire Mall, it would be in the speaker and squeaked with a particular shop, when the offender is outside the walls of the store. And how easy it would be to do anti-theft system without power... But for some reason they are not, the limitations of physics.
Let's imagine that it works under other laws. And try to think of what you will have in the program on c# as incoming data? Considering that no physical rfid data can not get the reader, because of the large distances. I failed to think of, but maybe together we will be able to do it?
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 1:32
мимоходом wrote:
maybe it's the technology samm, neocolony well-thought-out commercial course and nothing ball, and no matter how much we tried to solve, the result will be nulevoy ?
мимоходом
Post by мимоходом » Thu Jan 05, 2017 1:40
I don't think the commercial in the first place, because the names of programs and their descriptions is in a way that works. It works when a person reads and tries to understand "what", "how" and "why." And works also on the level of perception in the form of a placebo "I think that should work, so it must be working". This project information in the first place )))
But still, to order, consider how it would have worked under other laws. Antenna in the rfid can catch not only RF and microwave but also allow the radiation of the body (3 orders of magnitude higher frequency). Suppose that it is somehow their thickens, concentrates and radiates into the surrounding space where the radiator is the man himself. Theoretically - why not, after all, the em-wave is infinite in distance, though ultraclave. Now think how could a computer program in c# to get some data. There comes to mind only the "chaos theory", which States "all in all". That is, the computer connects psyleron (generator completely random number), which hypothetically produces pure chaos on the input of the program. And here the most interesting point - try to come up with a program that of pure chaos allocates something. Because psyleron gives exchange rates for tomorrow, the name of the President in 2030, the day of victory of communism over world imperialism and so forth, any information about everything - all in a stream of totally random data, perekalivatsja which you can get "War and Peace", for example... And if a man write a program that accurately reports any unknown information from a stream of totally random data (level of God)... Then you can think about. And believe in the developer the level of God or to believe in themselves - both will work ))
In General, there is a choice between the first and second paragraph.
аВАЛОН
Post by аВАЛОН » Thu Jan 05, 2017 2:29
on angloyazychnyh sites tion info the truth more and more chatter when driving in the search engine the words "rfid haarp" :? :? :? :? I think for a reason too :) :)
Гуфест
Post by Гуфест » Thu Jan 05, 2017 16:24
do a professional including this area (receiving the transfer) more than a decade
And not created су3пер antenna ?In America one person in a year has created the antenna which turned green and glowed in day and emit electric discharges.
Гуфест
Post by Гуфест » Thu Jan 05, 2017 16:39
I bet it's not.
For example go to the dumpster on the street which has a lot,but that's what you need ,no .
мимоходом
Post by мимоходом » Thu Jan 05, 2017 17:00
Each dumpster has molecules and atoms that were part dinosaur, and even the long-dead stars. And former millions of other things and creatures who practiced "magic" based on the level of their understanding ))
Гуфест
Post by Гуфест » Thu Jan 05, 2017 18:22
So what? If you have the dump you need molecules and atoms that take them for themselves and who do not give.))
мимоходом
Post by мимоходом » Thu Jan 05, 2017 20:19
They are not only a dump, but in your body including those the atoms of the substance, n was created billions of years ago, now think what you want to write )))
Гуфест
Post by Гуфест » Fri Jan 06, 2017 17:00
I regarding your next verbiage)) about chaos,are you saying that in the chaos of atoms and molecules,then it is not chaos,as chaos does not contain a structure on the contrary he denies structure,and the atoms and molecules have the opposite structure,hence the structure containing chaos is no longer chaos.
