I'M BUILDING A PYRAMID
Искатель-2
Re: I'm building a PYRAMID
Post by Искатель-2 » Thu Feb 21, 2013 14:09
thanks calculator, for the calculation of the Pyramids.
standard - the pyramid of Cheops according to Herodotus (the Golden ratio) and there is up to 7 different dimensions of Cheops was
http://yadi.sk/d/G-wiavN-2lw1L
Искатель-2
Post by Искатель-2 » Thu Feb 21, 2013 14:36
QUESTION:
what is the radius of influence of the pyramids ?
let's say 20 cm how many meters will be affected ? and 50 cm tall ?
it is clear that there is a subtle influence, is dense.
but at least some of the data is ?
Викторович
Post by Викторович » Thu Feb 21, 2013 20:50
Вадим Перелыгин wrote:Gabrielle Silva textbook "FUNDAMENTALS of PYRAMIDOLOGY" :
“Should NEVER be used for the manufacture of the pyramids ferromagnetic or diamagnetic materials. Should NEVER be used for the treatment of a pyramid made of copper, for living organisms they are very dangerous. Paramagnetic materials eliminate any risk with judicious use. Aluminium is the only metal acceptable for the pyramids, and only in the alloy with silicon, but in any case not with iron. You can use glass (it would be best if not for its fragility), wood and derivatives (secondary derivative), natural resins, fiber-reinforced plastics”.
Funny... Glass, wood, and plastics - diamagnetics... :) How so?
By the way, case do You have ORP is the measure? Quality pyramid ORP drops below zero.
Вадим Перелыгин
Been thanked: 7 times
Post by Вадим Перелыгин » Sat Feb 23, 2013 17:53
Викторович wrote:ferromagnetic or diamagnetic material
Great that You spotted the mistake from Silva or the translator!
Indeed, the paramagnetic and especially ferromagnetic materials possess a spontaneous magnetization even in the absence of magnetic fields (iron, Nickel, cobalt, platinum, manganese, chrome ...) in the presence of a magnetic field, they are installed along it.
Diamagnetics are installed across the magnetic field have no magnetic moments, so the position of the body in the field is unstable (copper, aluminum, silver, glass, plastic, wood).
I saw in the store the German self-adhesive film color "glossy silver" width 45cm. Bought 5m. Stripped the foil from the pyramid of Cheops above the bed. Took apart the face and the base, sanded and glue-free. On all edges glued tape (because plywood, film badly glued). Glued plywood side of the pyramid new film (diamagnetic) inside and outside. Shines like new!
The other pyramid of Cheops (from 15mm al. area and polycarbonate) used for chickens could not resist the pressure of masses of snow and all pakaraimas. The area must be more and stronger to take.
What is ORP-Mer? Where to take it or to do and how to use it?
Искатель-2
Post by Искатель-2 » Sun Feb 24, 2013 1:16
Викторович wrote:Aluminum - the only acceptable metal for the pyramids
so the same foil - ALUMINUM actually.... :(
anyways spoil the thread.... but it's a rough draft
not quite ready yet
it will be even torsionic, Organika, and a couple of ideas... the magnets.. cone...
a polycarbonate, honeycomb aluminium foil from both sides, height 45 cm
not finished yet. as will be fully working will details
Искатель-2
Post by Искатель-2 » Sun Feb 24, 2013 1:36
Викторович wrote:by the Way, case do You have ORP is the measure? Quality pyramid ORP drops below zero.
there are ORP meter, and the pyramid. It will be ready - check.
only one issue - quality is all that ? 1. height 2. form 3. material ?
10 cm or 10 meters ? in the pyramid of Hunger did measure water ORP meter ? although the pyramid of Hunger - the pyramid of death I think. hurricanes has increased, and the energy there is strange. I was there.
actually I am the subject of water has long been engaged in - http://iskateli.info/showthread.php?t=370
who monitors the subject structs. water here - see me there. + are a partner of Icarus (osmotic filter with ORP water) who should do a 10% discount, well, it's just a word. I mean that you can subject generators on a serious level to explore.
For example, you can examine under a microscope. Taken saline. Charged in the pyramid. Then on the whistle visuaide lighter, looks structure. Compared with the benchmark.
Mr. with full name, Hunger decided that he was not like everyone else, that he is a person that you need to make your pyramid, not like the others... yeah with this form of current stelae do... prikladyvaya spirits
Искатель-2
Post by Искатель-2 » Sun Feb 24, 2013 1:45
ORP meter buy either in alunite or on ebay
extech re300 - look
Вадим Перелыгин
Post by Вадим Перелыгин » Sun Feb 24, 2013 20:08
Искатель-2 wrote:what is the radius of influence of the pyramids ?
the radius of influence of the pyramids – murky mystery to me. :)
Foil hard to stick evenly, so I used self adhesive reflective tape.
I think it is proper for the pyramid of Cheops
If the height of the pyramid H= 39,95 cm
Then the side length of B = N x 1,57232 = 62,81 cm
Apofema faces A = Root of ((H)square + (W/2) squared) = 50,82 cm
An edge of a face of C = Root of ((A)square + (W/2) squared) = 59,74 cm
This hangs above my bed. To get out from under her not want to.
Need more to read about the measurement of redox potential (ORP)meter
By the way
If the height of the pyramid H= 45cm
Then the side length of B = N x 1,57232 = 70,75 cm
Apofema faces A = Root of ((H)square + (W/2) squared) = 57,24 cm
An edge of a face of C = Root of ((A)square + (W/2) squared) = 67,29 cm
Wavelength 572,36 Sector - 20 dissonant.
But all that being said, "up in the air". The experiments continue! az
Искатель-2
Post by Искатель-2 » Mon Feb 25, 2013 1:17
I Think it is proper for the pyramid of Cheops
why are these calculations ?
for example here I've met 8 of proportions. Herodotus took because he has the Golden ratio.
http://www.magiclab.biz/ratios.htm
according to Herodotus if the height 39,95 then:
Length of base 62,81349668
The length of the edge 59,73918465
Apofema 50,81718549
calculator - here http://yadi.sk/d/G-wiavN-2lw1L
yeah, converges almost
Искатель-2
Post by Искатель-2 » Mon Feb 25, 2013 1:21
Vadym Perelygin
in vain the tip is not cut. her negativity is accumulated. because there's the main exhaust energy. and she out in a thin stream going. need the tip to cut off a bit at the pyramid
XUPOH
Been thanked: 10 times
Post by XUPOH » Mon Feb 25, 2013 8:44
Искатель-2 wrote:Herodotus took because he has the Golden ratio
Options for the use of Golden section in calculating the geometry of the pyramids is much more than is traditionally considered to be not less than sixteen only at the main harmonic. The choice of size, just like music or optics, is determined by the frequency response of the instrument. Not deserved by anyone not mentioned in this case the dimension of the Hartman grid, can be extremely unpleasant resonances.
Троечник
Post by Троечник » Mon Feb 25, 2013 11:34
the Seeker-2 and can be a little more about Your vision of accumulation of negativity in the pyramid, and as an uncut tip prevents his exit? No intelligible explanation is not met, can only see that someone cuts off the top and what not. And the results are wonderful and those and others.
Вадим Перелыгин
Post by Вадим Перелыгин » Mon Feb 25, 2013 13:02
Искатель-2 wrote:why are these calculations ?
The measurements of the actual parameters of the pyramid of Cheops different authors are approximate and worn by time.
So I prefer the proportions of the pyramids is calculated mathematically from the Cold, V. Y. "Pyramid Golden section" using a sequence of spheres is inscribed in these pyramids. Is determined by the number of the Golden section f=1,618... in a relevant degree. Justified this on the very first page of this topic and the previous one.
At the great pyramids, the tops are cut more for ventilation. Small especially no thread inside for better structuring of penopolymer water.
I read somewhere that p. Cheops to the upper platform installed the pyramidion of an unknown material for precise focusing of the beam transmitter or weapons. The feast - fire, mid - middle. Pyramid - fire from the middle.
But it's all conjecture. :roll: :?
Искатель-2
Post by Искатель-2 » Mon Feb 25, 2013 16:47
[24.02.2013 23:50:37] Seeker: what do you think about the pyramids and ORP ? i.e. the influence of the generator forms
[10:30:34] Valentin Shironosov: 1:10^6
need to test just such a miserable chance
where do infa that there ORP is changing ?
Вадим Перелыгин
Post by Вадим Перелыгин » Mon Feb 25, 2013 23:26
Искатель-2 wrote:phone FSMP where to buy
Thanks for the phone advice.
One thing I do not understand - it lowers the redox potential or not?
Искатель-2
Post by Искатель-2 » Tue Feb 26, 2013 14:40
Vadym Perelygin
to think useful - no, of course, the expense of what ?
Вадим Перелыгин
Post by Вадим Перелыгин » Tue Feb 26, 2013 15:30
the Seeker-2
Искатель-2 wrote:to think useful - no, of course, the expense of what ?
Untranslatable play on words or the desire to stab? :roll:
By the way, telefonchik twisted 25000 :(
Look for other options.
Искатель-2
Post by Искатель-2 » Wed Feb 27, 2013 3:40
Vadym Perelygin
if twisted 25 000, I personally 3 times bought for 4000 ?
for what kind of model 25 000. don't know what you he was there on the phone asked.
Искатель-2
Post by Искатель-2 » Wed Feb 27, 2013 3:41
slight desire to prick untranslatable play on words ))))
I mean that redox changes either electricity or special minerals
where are they in FSMP
Викторович
Post by Викторович » Wed Feb 27, 2013 10:37
Вадим Перелыгин wrote:what is ORP-Mer? Where to take it or to do and how to use it?
Measuring the redox potential: http://moemgorod.com/index.php?ukey=pro ... ductID=703
The internal environment of the body has an ORP of the order of 100mV, normal water is almost always a plus. A good pyramid or contactless electroactivity temporarily shift the ORP of minus due to the increase in the number of molecular associates...
Вадим Перелыгин
Post by Вадим Перелыгин » Wed Feb 27, 2013 14:30
Викторович wrote:Good pyramid or contactless electroactivity temporarily shift the ORP of minus due to the increase in the number of molecular associates...
Please tell us about your experience of the change of the ORP with Your pyramid.
Here is an interesting read: :)
"Water has a unique property - information memory. She remembers everything! Each organism has its own frequency of radiation. Every virus, bacteria also have their frequency. All types of these radiations "written" on the water molecules. Poisoned water "remember" about all the poisonous processes, the heavy metals, the nuclei with which they had contact. When ingested this water, sooner or later, will evoke different kinds of painful reactions. To erase the previous information is very difficult. But, as recently revealed, the process of freezing erases the previous information with water. When the water is completely frozen, and then thawed, it becomes a pure information sense." :ay
So I use wipe the freezing water and give structure to it under the pyramid.
We are now interested in the influence of water in different places of palamidi and measuring some of the available options.
I want to buy a monitor KL-027 which serves not only to display the pH of the liquid in real time, but also a number of other indicators, such as: temperature, electrical conductivity, hardness, concentration of salts, and oxidation-reduction potential (ORP)".
Maybe someone already had a similar device? Please share your impressions.
Искатель-2
Post by Искатель-2 » Wed Feb 27, 2013 15:10
personally, you yourself took it ? I talked to Shironosova - he said it was impossible.
What is the height and the parameters of the pyramid must be to, let's say with +200mv to offset to - 100mv ?
many people like the theoretical blah-blah-blah to breed, but when specifics are asked, all somewhere to run.....
if you have measured and not read the book , then please give the parameters of this pyramid, I want to repeat your experience
(in science it is accepted repeatability of experiments)
Викторович
Post by Викторович » Wed Feb 27, 2013 19:29
Вадим Перелыгин wrote:please Tell us about your experience of the change of the ORP with Your pyramid.
Yes, easily. Put the glass under the correct poluchaet of Plexiglas of 4 mm, a rib 533 mm, and the water seminola 35 mV. :)
Искатель-2 wrote:I talked to Shironosova - he said it was impossible.
If Shironosov said impossible means impossible. :) Here http://biorezonans.3bb.ru/viewtopic.php?id=377 we can even "communicate".
Вадим Перелыгин
Post by Вадим Перелыгин » Thu Feb 28, 2013 18:28
"Shmakov"thank you. Have You tried to measure ORP for different types and sizes of the pyramids?
Is there a dependence on the size or other parameters? And ORP changes if stirred vortex in the Bank right or left?
I read Your link, interesting scientific and commercial attack icarousel on your forum. :)
I need to read more scientific papers Shironosova. :roll:
Calculated sizes of shelves for display of objects in the active area.
Викторович
Post by Викторович » Thu Feb 28, 2013 18:42
Вадим Перелыгин wrote:have You tried to measure ORP for different types and sizes of the pyramids?
No, of course. :) I have only two. ;)
Вадим Перелыгин wrote:And ORP changes if stirred vortex in the Bank right or left?
Not tried, but with no magnetic or electric fields are unlikely to change.
Вадим Перелыгин wrote:Need to read more scientific papers Shironosova. :roll:
Just be careful, it is very sobachkoi reading. :)
