Radionic devices Karl Welz.
Such a confrontation on your part is quite logical.If people think about it,any business will die. Money is a good thing,but fraud is a definite evil!You have the only excuse that if you do not feel little or not work correctly.In other words-"the fool!".Or-"Given to-wear!".Technique of manipulation is simple...
So still, how about educating people guessing, under which thimble is the little stone?Anonymous wrote:This opposition on your part is quite logical.If people think about it,any business will die. Money is a good thing,but fraud is a definite evil!You have the only excuse that if you do not feel little or not work correctly.In other words-"the fool!".Or-"Given to-wear!".Technique of manipulation is simple...![]()
And against you and other "caring", everything is fine. Life experience and life experience. All of it different. And the belfry, which argue different subjects, have different height.
And pay attention. No one even reacts. All long everything is clear. That is. The dog barks - the caravan goes.
Boring. Even if someone else came up with any more original accusation. And then, all the same. Divorce Fuckers manipulation. A broken record. You have no idea how lazy to respond to these pieces of music.
Heat.
Бывший фанат.
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
Humpty Baltay can look for understanding along?
Help to translate:
The back panel has input and output jacks for exterior stick pads and exterior wells, These jacks can also serve to connect several Orgon regarding devices to each other for more power and versatility.
It's here: http://www.hscti.net/c_radionics_2400_1.html
The RI 2400 CD regarding the Program is certainly a great help for persons who experience some difficulties in getting a stick on the rubbing plate, or stick pad, of their regarding device.
It's here: http://www.hscti.net/c_manifestationprogram.html
PBT 2400 power booster with transfer couple - see above. With this accessory, you can add to the power of the RAD 2400 HD Chi Generator®. You can slide one part of your PBT 2400 over the output pipe of your RAD 2400 HD and carry the small disk on you. Ideally, attach it to your key chain. This will provide you with a continuous boost to your energy levels. Both parts are made of super orgonite®.
It's here: http://www.hscti.net/c_radionics_2400.html
On the optional Stick Pad the text in the flash movies.
About the placement of the trasfert on target, the Trend in the fields, there were thoughts after seeing the photos here: http://www.hscti.net/c_radionics_2400.html
I can not correctly translate? Help to find understanding.
Sincerely, MAG.no<
All in good time...Шалтай Балтай wrote:Guest wrote(a):
With German (which I perceive may be in appearance) device to be in German - EVERYTHING has ITS PLACE.
This is exactly from the MAG.neta
Guest wrote(a):
Question 1: for what purposes in the 2400HD additional Stick Pad?
additional Stick Pad? Never even heard of
Guest wrote(a):
Question 2: pulse generator - strengthening? if set to "befitting" (according to Trend) frequency - gain greater?
I do not understand.
Guest wrote(a):
Question 3: does the power (efficiency) when connecting to a RAD 2400HD - PBT 2400 HD Power Booster for HD-Devices?
For HD devices Powerbooster is not actually needed
Guest wrote(a):
Question 4: One of a pair of transfer-washers feature field target, the second of the pair passing the puck - direct the Trend for a temporary target object?
Question 5: the target operator, the Trend is one of a pair of transfer-washers, the second "host in your pocket", the application to the second "card Trend" carries "the algorithm of this Trend" in the field of Trend?
sorry - I don't understand.......
Guest wrote(a):
Sincerely, MAG.no
and Yes, prop-but
don't get me wrong, I really wrote to You - I don't understand what You are saying.
Help to translate:
Sincerely, MAG.no<
Alas. I'm not here earn. I spend here. Based on the fact that using these technologies for self-improvement, another place I'll make more. What You (believe me, very sincerely) wish.Бывший фанат. wrote:Yes, what I'm against what? Earn.Any trade-the path of deception... and the original there is nothing to invent.But we must pay tribute,here it is done quite gracefully and "pseudosarcoma".While there FUCKERS ,your caravan with the money(though small) will go...![]()
Good luck to everyone and improve well-being!
- Шалтай Балтай
the rear panel has input and output jacks for exterior stick pads and exterior willow (plates for affirmations), these jacks can also serve to link orgone generators medzhdu with the aim of obtaining more power and versatilityМаг.нет wrote:The back panel has input and output jacks for exterior stick pads and exterior wells, These jacks can also serve to connect several Orgon regarding devices to each other for more power and versatility.
RI 2400 CD regarding the Program is undoubtedly a big help to those people who are experiencing problems with using the stick-pad on his radionicaМаг.нет wrote:The RI 2400 CD regarding the Program is certainly a great help for persons who experience some difficulties in getting a stick on the rubbing plate, or stick pad, of their regarding device.
PBT 2400 power booster with transfer couple - see above. With this accessory you can add power to the RAD 2400 HD Chi Generator®. You can wear one part of your PBT 2400 to the output pipe of your RAD 2400 HD and carry only drive with him. Very comfortable to wear umetsu with the keys. This will provide You with a constant supply of energy. Both parts are made of super orgonite®Маг.нет wrote:PBT 2400 power booster with transfer couple - see above. With this accessory, you can add to the power of the RAD 2400 HD Chi Generator®. You can slide one part of your PBT 2400 over the output pipe of your RAD 2400 HD and carry the small disk on you. Ideally, attach it to your key chain. This will provide you with a continuous boost to your energy levels. Both parts are made of super orgonite®.
I honestly don't know - have not watched.Маг.нет wrote:About the optional Stick Pad the text in the flash movies.
Even I don't understand why this is necessary
Why do You need it by the way?<
Humpty, don't want to seem once again in front of You silly, but I already asked a similar question just above. If I'm carrying one washer from the kit TC-99, the second on the device. Before the output tube. I get a certain dose of energy. Stick Pad is also made of energy. If I lay there one part of the PBT 2400 power booster, the second part of the carry (so I have two second washers of the two sets), the dose of energy received by me, becomes more?Шалтай Балтай wrote:Маг.нет wrote:
- Шалтай Балтай
of course do not believe, though it is possible and device to measure, for example the same YOKE-1, but long and tedious.
It will be clear where the outlier.
At least when I was shooting the geomagnetic grid in the flat with the YOKE, the final painting coincided with the theory (the cell size) and the nodes coincided with removed with the help of the pendulum before it.
However I write this for those who read, not for those who comment on seals with "Nah", on the site of the moderators I would have sent to the trash.
- Шалтай Балтай
Michael, good day!Михаил_ wrote:where is it written? find the seer and not explaining what this device ask where is the flow. Next will be surprised.
Can repeat this experiment many times.
If you do certainly not feel.
Glad You found the time to read these posts. That Stick Pad emits energy, I read in the MAG. neta You. Because sensitivity to energies, just held hands on the table and felt the output stream. I keep you, the professionals, asking the question with his narrow-minded point of view.
From the device, the energy is radiated via two outputs. With the device received a Transfer couple TC-99. Working with her through the output tube. It don't get ordered Device PBT2400 HD. One washer will be placed on Stick Pade, the second in his pocket. Thus, I will wear two goals. There is a difference in the flow of energy when wearing one or two washers or not, I feel sure. Thus, as a simple layman I assume that if you add two flows of energy will be more. If you take the energy from one output, you only take part of it. Maybe I'm wrong. Check up on yourself.
Humpty Baltay thank you!
Dear Users of Radionics (current and potential future) fluent in spoken (!) English, on the website of Karl hosted flash videos explaining the Rules more effective (!) the use of Instruments and Manifesto programs, clarifying principles. Translate them for yourself and verbalize Your formed after watching the clips, opinion on the use.
By the way, Brave of the rollers drew the following, when working on external Goals (not for themselves), washers is better to remove the side (to exclude from the scheme) due to the direct consumption of energy by the Operator itself, and thus reduce the energy at the "prescribed" Purposes. Also in one of the clips shows the adjustment of "tactile feel" as using a Stick Pad, and using washers when one is placed under the tube, and the second "catch" these sensations (i.e., external Stick Pad). Draw your own conclusions.
If you feel these energies, Carl offers the experiment of the transfer point "broadcast" source of energy in space through a binding this point through the photo. Approximately, photographed place, the photo referred to (marked) point, have this image on the target field Device and... feel the energy in this (highlighted)point in space. More understanding arises when comparing Devices of different modifications (as Radionics and Orangenation), by adding the description of properties in the older model.
Sincerely, MAG.no
P. S. Bold, on the FR TDI 2400HD, please Your feedback about the effectiveness and feasibility of inclusion in the scheme.
Sincerely, MAG.no
Feel free to ask! Can't even begin to articulate just. I set a goal. Now, the outer target, where's she? On the moon, Mars, on the next continent? Or maybe somewhere nearby?Маг.нет wrote:Humpty Baltay thank you!
Sincerely, MAG.no
There is a purpose invented by man. To perform it is man (or the operator) who invented it. And for that, he needed energy to obtain conceived. In the thought processes, awareness, phone calls, movement, etc. Michael probably already tired to explain here that man is the most powerful machine for the fulfillment of desires. No external filling of the target with energy. There is a content person, or operator, of the energy for the fulfillment of THIS purpose. In this case, the bundle through the TREND and TARGET and carrying on to himself of the Transfer goals with the help of Radionics allow the operator, on the one hand, stronger focus on this particular situation spelled out and located on the Trend, on the other hand, have a greater amount of energy to perform mental and physical actions to achieve what is spelled out and is on Trend. And everything else, arms, legs, head. Because (here already about it wrote) "God has no other hands but ours." Pump up the thoughtform energy and wait for it nakachatsya, hopefully it will arrive in our hands......
What?
How is it in Soviet times, the Komsomol song was sung:
"To dream, we should dream.
Children of the eagle tribe.
Has will, courage,
We have to become,
Heroes of our time".
Good luck, the constant growth of prosperity and slavemaster the most outrageous fantasies.
P. S. I have this amplifier still did not get it just ordered.
But popolazioni will accomplish your goal.<
Some need more energy quickly and implemented quickly. But on business,the cat.there is 18 years of age need 3-4 months of pumping energy, apparently the failure energy was significant.Although I, naively, thought that in the first place will easily be pumping energy business..Carefully read and reread all the posts in all topics of the forum. With the filing of the MAG.neta I began to put the cartons with a description of the tasks and the stick pad, which significantly accelerated the implementation timeline. Separate You, Mage.no., this idea - thank you! In General in life, I always considered myself a happy person, but once on this forum felt in the circle of friends, and it made my life filled completely. THANK you all so much! Gathered here are smart and wise people, well, except sometimes puts here some "uninvited guests", but in "funnel flow"..,so..
Regards M
Regards M
Malik I really appreciate Your gratitude
Brave, I trust the opinion Mihaila, but or Products Mihaila just so different, "sharpened", or I do not correctly understand Karl, only Karl, I see the removal of the entire process on Radionic form the thought himself, and it scrolls without the participation of the subconscious... and so he shared the work with washer (contact to transfer thought forms and more energy), and work without the puck and when the energy is released in the device's field ("the player thought forms" running in a loop). Moreover, structural relationships are preserved and work there for some time without additional support. Can "good" (with understanding) translate Carl and then indeed it will become clear how the devices Carla, how to effectively to use it. By the way, the Product Mihaila I feel very good, and Radiant as it is... or near, when the puck is close (still not shown). Two, in my opinion, different way of using Radionica. And with Products Mihaila notice some difference of principle. Certainly not worse, but different.
Bold, and what is the delivery time ВРТ2400?
Success!
Sincerely, MAG.no
Success!
Sincerely, MAG.no
Bold!
If the task is simply increasing the amount of energy, it is necessary to check these assumptions:
-work with photos, Carl gives the example of the possibility of energy transfer at a specified point in the photo. Since communication is two-way, you can try to extract energy from a given point (for photos) and transfer using the device itself (power and quality). If you feel energy, try a photo of the branches of the "Club", "Wonderful places of Russia." There are interesting threads... you Copy photos, you should indicate the point of attachment and by posting on the pitch Trend set structural relationship with the Target (a). Start the process...
-work with source energy using the Transfer-washers, the principle is the same, place one of the washers close to the source, the second field of the Trend... (some pictures of Radionics shown that the placement of the washers).
I note the cartridges Mihaila (Receiver/Transmitter a very good job with this task, take energy to transfer more than goals, at the expense of access will be algorithm - "vampires") and interact with Radionica. Transmitter source, the Receiver - field Trend setting (adjust) the scrolling of the energy transfer to the target.
Success!
Sincerely, MAG.no
Success!
Sincerely, MAG.no
Bold! Ready to add arguments in favor of this understanding. Studied theoretically the difference between the Devices. Again complementing understanding (watching the processes in the program) Manifest program. The devices have the same number of concurrent processes (i.e. in the subconscious mind of the Operator?) One, two is okay, well, five, but if it is 12 - 36? So in my opinion Radionic two separate functions, or the Instrument is "out" and turns a "song" for adjusted the tuning of channel, on the General wave (frequency), and the "correct" (according to Purpose) set the frequency, the stronger the effects of the Device on the situation (probably less than losses). And a second functionality - mental treatment to the device through a Transfer-the puck (as an external "object table") and the generation of energy on the General wave (frequency) for "live" feed of current intentions. I switch these functions ordered ("agreed" with the unit) mental - switching as needed.Маг.нет wrote:I just seen Carl - the removal of the entire process on Radionic
This is not a dream, and the principles of work, again the "full transfer" will clarify much more. Have a page where the content of commercials "in the text" posted. Still "understanding the subject" translator can help, and "not understanding" can only confuse.
Continue to study the properties of the RAD 2400 HD.
Success!
Sincerely, MAG.no
I will not argue. Maybe so, without the work of the subconscious. Then this energy needs to obtain the corresponding egregor. I just know that egregors are tied to the conscious (and perhaps subconscious) of a person. You need to experiment. In any case, wealth is distributed egregors. Maybe in this case, the egregore realizes that he receives a portion of clean energy thanks to the device and its owner and the equivalent throws in the opposite direction stuff. In this world, anything can happen.Маг.нет wrote:Malik I really appreciate Your gratitude![]()
Success!
Sincerely, MAG.no
ВРТ2400 promise to send within two weeks after receipt of payment + email EMC.
On the formation of thought forms. On the Deir we were doing quite well. It is necessary to raise the record. If preserved, will unsubscribe. But there really is a careful study and creation of thought forms, taking into account of any related options, then fill thoughtforms with energy and then ethereal (virtual) hands through the Manipura put her in your etheric body. As soon as the you see your target, immediately begins the internal energy. It is necessary to lift and use when setting goals. Completely forgot about this technique.
Good luck to everyone!<
- Шалтай Балтай
Yes, I ask everyone, including You. Just believe that you three, here are the most savvy. For me, everything related to electronics (that is, where there are micro or wiring) - Les full. Said Stick Pad emits energy, put his hand to the instrument used. Is. Feel the movement of energy. Next came a simple logic. Charge through transferable energy with only one exit, so only take part. Portion through the second exit means is in the surrounding space. Or is it not so? I ask the question in this plane, the responses are incomprehensible to SIMPLE LAYMAN's LANGUAGE. What is clear to the specialist, not necessarily clear scoop from the electronics.Шалтай Балтай wrote:Why ask me?Смелый wrote:that Stick Pad emits energy, I read in the MAG. neta You.![]()
I would have said their source of information.
1. connection with electronics there is no direct.
2. stiked it's a straightforward piece of material proper maintenance, physically and mentally, glued to the body of the instrument (for all Radionics will not speak on the topic рад5 100% sure, similar to tables, i.e. they are NOT included in the electronic circuit).
3. no, on the topic of the energy there, some of the energy there - not quite right. Energy has a tendency to stick to each other flow to the goal.
I once again put forth a riddle, which was asked already a couple of times.
Here the energy channels. What's that? This is a physical "cable" in a three dimensional world? for example, from person to person generic channels (example - father-children mother-children), they like going ? on the shortest path? in what direction?
well, on the same interesting questions from your own topic about the "exit" of the device. I.e. here the person feels a flow in the form of "jets" ? but really why?
A transfer it transmits a null transport? why?
Here the diagnostician diagnoses a vampire the intake of energy from the back of the person, and a real vampire is in front of the man, but the channel feels like going back. Why?
well, there is a lot of interesting questions from the spatial configuration and territorial distributions.
I know the answer, but it's premature to suggest I will not.
Tips partially have Karl.
And to think this topic is useful. Better picture of the world blind.
