Ring. Workshop
Re: The Ring. Workshop
Post by Шалтай Балтай » Thu Dec 08, 2016 10:30
yesterday gave some rings to the office of the MM
that, apparently, I have a workshop this year. :oops: see you in the new! az
good job, it's time to relax!
Humpty on vacation :D
PS
on the forum I intend to be
I'll try to publish a few audio sessions to ng.
Малика
Post by Малика » Sat Dec 31, 2016 16:58
Sorry a little off, but not know where to post it:
Happy New Year!
All wish fulfillment that all the good)))
Post by Шалтай Балтай » Fri Jan 27, 2017 10:40
All good zdraveska.
I had time quietly to review the technology.
One moment haunts me. It is not clear to me why the pigtail Amerada MADE AFTER the twisting. It is clear that the length of each conductor/wire in this case is longer than the MERC. This confuses me. But so did slim. In this sense I am nothing more than a careful copier. But this fact alone does not give me.
The rest - all very respectable.
I like the knots. With a merc they just all right.
I'll try to do pendants/nodes of bronze.
There is brass.
And most importantly - have the desire to work hard! :)
Малика
Post by Малика » Fri Jan 27, 2017 13:47
Good day, Humpty)))
About
Шалтай Балтай wrote:One moment haunts me. It is not clear to me why the pigtail Amerada MADE AFTER the twisting. It is clear that the length of each conductor/wire in this case is longer than the MERC.
I have a feeling that it would be wrong to measure a pigtail To twist.. there is a strong feeling of inferiority of the product.. Probably slim was doing the Right thing..
Post by АндрейКо » Fri Jan 27, 2017 21:41
Шалтай Балтай wrote:All good zdraveska.
Because the pigtail is a single whole for the process that is happening in the rings.
If we are to measure up to the twist, then immediately cook the ring (and will work, but the + and - side to determine then necessary) - and it will be a step back.
P. S. this was written and wondered if without the twist there is a + and - side, why no difference to the odometer as 2 cut to take - in one direction or the opposite(we need to check, he did just the opposite)... but assuming that they become unified and there is no contradiction. and because the film inside of these rings I see one...
and I wonder - if after twisting the braid trim by the standards and one wire to twist (the second is not possible to touch), and the second left and solder to the ring that will... - (the fastest of course, garbage out - snap ring)
Post by Шалтай Балтай » Mon Jan 30, 2017 12:02
Karash, vapros tricky
I want for example to do elementalist, well: Chassell, for example, elemental fire
and I want him on the sacred mirocke to do well, assume linear
and that's how I measure Marocco if there is Kosicka?
Post by Шалтай Балтай » Mon Jan 30, 2017 12:09
АндрейКо wrote:and I wonder - if after twisting the braid trim by the standards and one wire to twist (the second is not possible to touch), and the second left and solder to the ring that will... - (the fastest of course, garbage out - snap ring)
PTS. good question.
answer. take the wire, measure out Marocco. Twist spiral, the ends sealed. The resulting tensor ring. Why think.
Tip: in fact, a degenerate kuvak with an external terminal, or loop, just a rod with zero length
Post by Шалтай Балтай » Mon Jan 30, 2017 16:55
Post by Шалтай Балтай » Sat Feb 04, 2017 14:14
While experiments with pendants in bronze failed:
But I understand why slim did not bind to bronze, I now know:
coils of uneven, where it is thickest where it is thinner, it's not on sale, sorry, klonoff bronze is not expected :?
try to go back to copper
Post by Шалтай Балтай » Sat Feb 04, 2017 14:16
but it zagotovochka of copper rod and a half of the lost Measurements with external web:
Post by Шалтай Балтай » Sat Feb 04, 2017 14:17
the same size only the brass:
reeling it straight it is not possible yet, but it looks ... not for nothing, the brass called false gold
let's see how will be after welding
Вале
Post by Вале » Wed Feb 22, 2017 2:04
ПОКО wrote:She was at work and the wood. According to later sit down at the computer and draw a sketch...
Well, that's it
As can be seen from the sketch -the ends of the wire near the caps will go to the scrap, in consequence, the diameter of the covers is better to do as little as possible, the main thing that was strong enough to twist. Well, or can be a gas key to turn. And at the ends, the torsional angle more, it can be seen in the photo of the ring.
I did so but without the Central wire, and now will do with the Central. While a maximum of 16 wires – 8(0.7) braids, from wire enamel.
Now I think in the furnace to burn the enamel...
And Aku this made from 5 measurements or Shaw is not necessary? Only 3.5?
Post by Шалтай Балтай » Wed Feb 22, 2017 12:23
Вале wrote: I did so but without the Central wire, and now will do with the Central. While a maximum of 16 wires – 8(0.7) braids, from wire enamel.
wonder photo Studio!
Вале wrote: And Aku this made from 5 measurements or Shaw is not necessary? Only 3.5?
Why? Maybe (I almost sure) that the 5th Measure is a working version. Maybe, in another aspect, only. Can be in the photo to look?
Just not everyone does that. 5th measurements not on the list of slim, and brown with her, too, it seems, is not experimenting.
What to Kuvakov I'm doing 3.5 Scoops, like slim, and I do Caduti 7th Measurements. The spiral in the Spiral.
Вале
Post by Вале » Wed Feb 22, 2017 14:29
1. Humpty you've vikladivai of elemental fire, and can spread and earth and air and ether? And they say that the vortices have already traveled to us – can help these delays to mitigate damage (though they are talking about it for 20 years – maybe another horror movie)
2. Now I put 3 rings in the oven to char the enamel,
3 .Aku HAK I have soldered in the form of a spiral 25 cm – is that a lot?
4. I just a week ago to do it and didn't know about this forum
I love the abstract 10 years ago, there was only one merc first
And the other measurements were looking for pendulum and now when I read the forum was a big error – I redo!
The pendulum said that they (my) work but 60% is already 3-4 days can't sleep – movie goes on and on.
5So that would sleep without dreams (which is the goal of yoga for parabody napreryvnuyu consciousness) you need a drill to spin counter-clockwise?
6 dovno I did AL the sphere – to 2-liter bottle fit, so the pendulum said that if this area is to make the standards she wakes up to 360 times stronger than the harmonizers of the rings!
(I'm already 7 years considering how to make ASH sphere – a dodecahedron with Zvezdochka sizes 2.5 meters....)
Post by Шалтай Балтай » Wed Feb 22, 2017 15:20
figase :shock:
Вале wrote:1. Humpty you
If it is possible for You, I would be grateful. After the incident with the bee I'm all on you. :?
Вале wrote: and can you put earth and air and ether?
http://twistedsage.com/elementals/
Вале wrote: 3 .Aku HAK I have soldered in the form of a spiral 25 cm – is that a lot?
and the wire what section? the photo is?
Вале wrote: 4. I just a week ago to do it and didn't know about this forum
rispekt! :ay
Вале wrote: 5So that would sleep without dreams (which is the goal of yoga for parabody napreryvnuyu consciousness) you need a drill to spin counter-clockwise?
do not give personal advice. viewtopic.php?t=6236
only on the products.
Вале wrote: 6 dovno I did AL the sphere – to 2-liter bottle fit, so the pendulum said that if this area is to make the standards she wakes up to 360 times stronger than the harmonizers of the rings!
Mmmm..... nightime. :?<
Вале
Post by Вале » Wed Feb 22, 2017 16:41
Thank you very much!
Wire 0.7 in 2 braids then these pigtails up to 8 were recruited.
In the 16th volume of "Tao way of the assumption" Mother Earth explains the meaning of crop circles.
- now I think to do the harmonizers according to this geometry...
Post by Шалтай Балтай » Fri Feb 24, 2017 15:36
Continuing the conversation
The pendants of copper apparently is to be:
Post by Шалтай Балтай » Fri Feb 24, 2017 15:38
The bronze option will probably be back later, most likely they will be to external web
the main secret of all this rigging, of course
In General,-TTA, I like the case, rings and knots sculpting, :oops:
Let me ischo pile of something! :)
Post by Шалтай Балтай » Sun Feb 26, 2017 1:56
Bronze pendants
and the first and generally the second and the pancakes until lumpy, bronze is a very capricious material
Post by Шалтай Балтай » Sun Feb 26, 2017 1:59
lower down - to the scrap :?
the top is bronze, not copper
the sensation of wearing, by the way - very nice, + he knows how to ring :) Etta funny :)
while in General stops at copper, it is easier and more practical
Post by Шалтай Балтай » Sun Feb 26, 2017 2:03
Шалтай Балтай wrote:: Chassell, for example, elemental fire
Chisel.... hmm.... The rod?
interesting.....
Post by Шалтай Балтай » Sun Feb 26, 2017 2:07
Шалтай Балтай wrote: Chisel.... hmm.... The rod?
interesting.....
https://translate.yandex.ru/?lang=ru-en ... 0%B7%D0%BB
Oh, I am going to start digging in the family archives
rod things
the scepter · staff · the caduceus · the cane
Post by Шалтай Балтай » Sun Mar 05, 2017 14:36
kulonchiki, or rather of the workpiece
Kuvak with the internal rod 144 measurement, 1st Size, Ф3мм
Post by Шалтай Балтай » Sun Mar 05, 2017 14:37
I wear this:
Post by Шалтай Балтай » Sun Mar 05, 2017 14:40
in combination with stones - double effect
on the top is the node from Lujan city, in fact, inside a pebble
but the one downstairs is kuvak with pebble
I liked the feeling of the device and the fact that it can be a long time to wear next to the body, it gives additional effects, depth
intends to continue in this direction
