Tranlate - remote virtual artifact(test dir)
Re: Tranlate - remote virtual artifact(test
Yeah, now fix it
at night, when listening to the conductor, put the anchors at this time, the next morning, barely awake, eyes it was even hard to open
expensive process happened, however, and the anchor was with a serious purpose
It's not about costs (in the literal sense) and that the work itself with such a powerful stabilizer is a definite and fairly rigid machine, like its conjunction with the operator).
The last couple of days, I easily solved the case. One for a couple of years hanging in the background was not the time to do it, and today it decided of course. And one was lying on a makeshift SK, for me, is quite costly in terms of money, yesterday decided almost nothing.
here's how to do this with a job
I sit as a Navigator in the car and also affect the route, but if I sit behind the wheel and at the same time as a Navigator
maybe not the best example
Stavr, SK4 Евген412 added instead of what was indicated above.
Replace I dream to SK4 if you can
Thank you
Thank you
I want to note that broadcast the stabilizer is very easily controlled, and generally very comfortable. Happens, set the anchor, make it... and then abruptly rolls ISS, then the whole wording is forgotten, sit in a 'Nirvana'.
yeah, I would generalize to the more complex - all broadcast products are very easily managed and very comfortable
write to me about SK someone what, but....
Master, now do it.
Master, now do it.
Master replaced the CV.dreams on SK4
after the connection started cleaning
Michael, please: please replace the dream in the UK!
Strangely all came SK4
for some reason no one исн4 not trying
well, firstly I haven't include
and then maybe people want to have time to try all in turn
(anautica true... there's a list of non-standard products swollen already).
Michael_, and after this broadcast, the us will remain Stabilizer, SK4, ИСН4, Y4... minimized in your personal space?
Special program broadcast when activated? because it takes 1 slot, I think, is 3.1 it will be, I would like to place 3.1 ИСН4 to put, at least for a bit.
well, the special program must now turn on, hold it some time... so you can see the difference ...
as for leaving you with stabilizers, SK, Iim-s, as well as different BZ channels, I do not promise, or rather to what extent exactly remains. But it individually. Ie I believe that the MAXIMUM time to let it all stay with you, from 6 to 12 months. Real (for most) for 3-6 months. I don't know how long I'll keep the experimental stream (don't remember when it was included) well, I think a month will keep around for sure
I think many of the group a lot of broadcast or remain in full or leave a very nice trail close to pornocasalinga.
More precisely it will be visible after disconnecting
Thank you for the connection. Head so can't even say what sort of increased. Get used to it. Negative feelings not.
Kona, changed color dreams on SK4
Can I get a FRM in the UK to replace a temporarily, to understand the operation of the device. For me, a very difficult decision became greedy and FRM is not yet fully worked out, but experimen - there experimentation!
Yeah, now replaced. Here I brought the people....
Here I am with the same feeling awake, ISS half a day was definitely. But beyond that in my head very clearly, and I finally spread out some of the "things on the shelves."Евген412 wrote:After connection of SK from a little covered. The head is slightly floated.
