AMB - a product which seems to be there :)
Re: AMB - product of which seems to be there :)
Post by Михаил_ » Tue Jun 24, 2014 23:37
it might not be to the AMB of the user at all in fact this phenomenon is a tool with great potential but you are the pilot bracelet but yourself, so the instructions need to you and I am not the manufacturer :) so don't matter to me :)
Алсемо
Been thanked: 21 times
Post by Алсемо » Wed Jun 25, 2014 4:27
Михаил_ wrote:can not be to the AMB of the user at all in fact this phenomenon is a tool with great potential but you are the pilot bracelet but yourself, so the instructions need to you and I am not the manufacturer :) so don't matter to me :)
Then a more detailed system description effective piloting, there are also algorithms (so do be).
Got the manufacturer to contact if you are able to? Invite here.
I for example feel the essence of the SBA (if not mistaken), and there are those who are not clear, not clearly understand the principle, they need supporting, so please, make it happen!!! This time, platitudes will not be enough.
Post by Михаил_ » Wed Jun 25, 2014 5:33
You actually hear me ? who is your manufacturer ? You do (including the incarnation)and your parents can be here... and invite myself to her...and parents at the same time :) discuss what's there and how you work...
Nothing but platitudes will not, I don't understand what exactly you expect and why. There is no "this one time" there is one and final time - a description of the AMB is given in excessive quantities, stop to philosophize is still to require a description at my life from birth on, every person unique all 1000 percent!
AMP is the activator and catalyst and protagonist - You. There are no special principles of management. Live (want to insert capacious people's word!) and that will be necessary....
Not efficacy may be due to a replacement of the false by the actions and targets.
Post by Михаил_ » Wed Jun 25, 2014 6:05
For a better understanding of SBA should (or could) understand what people do and what a PC, but this is material for a lecture long in life and not just one. And it will not give the full picture ....
Алсемо
Post by Алсемо » Wed Jun 25, 2014 8:30
Thank you Michael for the information.
Many of the things we are not clear not because our concepts are weak, but because these things do not belong in the circle of our concepts. K. Prudkov said. And so the same conceptual apparatus at all desynchronisation.
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Tue Jul 01, 2014 23:42
Appeared aversion to the AMB that I wear on my hands. Body highly require to remove them. That's what I did 2 days ago. How to understand this? What to do in this case? To wear or put it off?
Post by Михаил_ » Wed Jul 02, 2014 0:33
it's up, well, maybe overload try to make the commercial break,
But there is another option - outside navedene to weaken the protection of your. It happens....
Нина Жемчуг
Post by Нина Жемчуг » Sun Jul 20, 2014 18:01
Tell me, please, AMB in the generator images is in section PC, it does not mean that the PC is also automatically superimposed:) Want to impose on AMB, and PC while I wait.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Sun Jul 20, 2014 18:47
No, PC will not automatically overlap. They are in the same partition because the SBA contains a little PC :) But does not give rise to a full buffer zone as the PC.
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Sun Jul 20, 2014 20:42
And somebody did something with the AMB probes, which were distributed to the test? What is their fate do you have? :))
Нина Жемчуг
Post by Нина Жемчуг » Mon Jul 21, 2014 0:38
Andrew S. thanks for the reply. I understand that if I generate images on the SBA applied this process is, so to speak irreversible:) Well, for example, the bracelet I can shoot broadcast disable, and it's not clear... And the question of whether multiple options at the same time to impose on themselves. For example, while the Panacea of video, matrix, Panacea, Panacea-Youth Pill and AMB. Or is it done separately?
Post by bofara » Mon Jul 21, 2014 0:42
Нина Жемчуг wrote:if I generate images on the SBA applied this process is, so to speak irreversible:) Well, for example, the bracelet I can shoot broadcast disable, and it's not clear...
Why is unclear - I will be as you want - this is, in fact, Your cocoon - if you think that
Нина Жемчуг wrote:is the process obtained, so to speak irreversible
well it will be..
And by the way, if
Нина Жемчуг wrote:broadcast disable
UTB does not mean by far that already running processes prekratyatsya.. :?
Андрей С.
Post by Андрей С. » Tue Jul 22, 2014 6:22
Нина Жемчуг wrote: And another question, is it possible several options at the same time to impose on themselves. For example, while the Panacea of video, matrix, Panacea, Panacea-Youth Pill and AMB. Or is it done separately?
Where you can mark several options there at the same time, where it is impossible - there at a time.
Disable you mentally.
Аиша
Has thanked: 56 times
Been thanked: 14 times
Post by Аиша » Thu Jul 24, 2014 17:29
Ask for advice! My friend's mother is in a coma since April of this year. Without devices. Physics works independently. To get to her in the hospital I have no. Use of SBA for this woman remotely? Someone above in the posts wrote that mental 10 AMB was used. And what will the effect of AMB in this case...the Soul is like a body left. I ask to respond those who faced with similar, and who can really help..
Mental broadcast 1.0 and panacea gave only the muscle twitching in my legs...the Use of certain modules too does not lead out of the coma.
Андрей С.
Post by Андрей С. » Thu Jul 24, 2014 19:35
Well, it is possible AMB-Lite (which is digital) to impose. But I would have thought over the stream then.
Post by Михаил_ » Fri Jul 25, 2014 0:06
Afirca-cells-cure-all broadcasts (maybe).
More details need to deal with the situation, I don't know.
Аиша
Post by Аиша » Fri Jul 25, 2014 0:46
Thank you for your answer! :)
Аиша
Post by Аиша » Fri Jul 25, 2014 0:57
Michael! True if more to write on the test AMB? And what price for your proposed translation. Found only a panacea, but there is a commitment for a year.
Андрей С.
Post by Андрей С. » Fri Jul 25, 2014 1:20
Afirca and cells the access. With Panacea - Yes, the obligation of repurchase for the year.
Post by Михаил_ » Fri Jul 25, 2014 1:58
test for AMB - is long gone.
afirca and cells cannot be enabled through the interface. In General, it should take care of those whose family ....
Аиша
Post by Аиша » Fri Jul 25, 2014 3:27
Thank you, Michael, for your reply.
Михаил_ wrote:In General, it should take care of those whose family ....
I can't explain why, I go in such situations. Moreover, it happens that different people , but with the same problems in the same period of time. Apparently, it's me.
I recently started using your test AMB. Perhaps the subconscious is something processes. The condition of internal stability, such as in the tank). Children of friends are trying to play or to occupy my attention. Anomalies in my understanding, is not seen. If you don't count that in the yard knocked the car into the wing. Even my husband had a calm reaction! But in the early days, how to put on AMB, went a lot of calls, the relatives started questioning me about my Affairs. Alone, distant even came from another city, but did not stay.Family relationships become warmer. A lot of intimate conversations. Very quiet solution.
Some long pending case were finally done. In particular long ago to the dentist going. Now I sit watching the place after the tooth heals. Aggravated sores. Increased appetite, and raw food products, and vrednenkoe fly to cheer. It is strange that I do not want to drink water. Although pushing yourself.
Continue the studies further.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Mon Jul 28, 2014 23:07
Good evening!
Михаил_ wrote:afirca and cells cannot be enabled through the interface.
1. Does AMB afirca?
2. if not - then it turns out maybe afirca to learn!
PS - the truth is manifested locally (where to restore something)
Post by Михаил_ » Wed Jul 30, 2014 0:52
AMB does not contain
will be in the club broadcasts
ММ
Post by ММ » Thu Aug 07, 2014 22:49
Went powerful "bounce" in all imaginable and unimaginable directions. 1)at First out of hand "accidentally" fell and broke my favorite plate from under expensive tea set. :evil: 10 years served me in the kitchen! 2) Then fell off a little screw with the fridge door, and the door doesn't close properly. :evil: And the money for a new refrigerator, there is not expected. :evil: 3) Two days later came off the tap in the kitchen that served 8 years. :evil: 4) Further more. At the same time started to have strange problems with the Internet. The first was blocked from my page in contact :evil: . For the first time in 5 years. The administration of the site said that I had allegedly posted on his page advertising. Which actually is nonsense. The next day my page on Facebook was hacked by unknown hackers, changed my name and photo. :evil: 5) Well, this morning I to my horror saw on the wall a large wet spot. Leaking shower cabin. Perhaps a pipe burst. :evil: :evil: :evil: This ugliness is not over. My mom, who lives thousands of miles away from me, the house burned down 2 lamp cartridges. :evil: Then bad TV. :evil: Had to buy a new one. Now an elderly woman, a pensioner sitting with no money. :? What can be done about this stupid situation? What do I do? To remove AMB or wear? What team it is better to give? It seems I panic. :(
Василий
Been thanked: 3 times
Post by Василий » Fri Aug 08, 2014 0:58
Apparently You subconscious begins to shake out of comfort zone and from that, probably not optimal from the point of view of the subconscious = your passed life experiences, life situations in which You are located.
Try with humor to treat all those stuff. At the same time, pay attention to health and related practices (the raw food diet, Goltis, su Jok, etc) and start to slowly review your life. If You realized your childhood dreams? Has not betrayed You at some point? Do not rape do You? Happy is Your soul? And if not - what Your soul wants?
Apparently sooner or later You have to stop and think over these questions.... AMB - it's so... forced :)
