http://fototelegraf.ru/wp-content/uploa ... 30x579.jpgМихаил_ wrote:Yes? are talking about the globes? okay... will consider, will consider... thanks for the info.
And operatorsthe do that who and yeah.
Panacea or product "P"
Re: .Panacea or product "P"
So, operatorsthe man. Their own methods in the selected scope.
Processing of planetary energies in his "fit" model of the Earth... It was something like the iterative process with positive feedback(if there is a thread somewhere in the chain "phase inverter" is not necessary)
Well, as live called, not turning off the receiver.
If you don't "boomed" imagineasia, the coeff. feedback is acceptable - so, some increase of power and "chime"
I do not remember, in the earlier written was not like...
And how in a sealed holo-stickers(or even downloaded the program "House") the premises are Geopatogene from inhomogeneities in the earth, and from nodes to nets Hartman-Curry? Not resolve?
And then there are extensive areas of bredyatiny, couch does not move:
"...Curry. Formed by parallel strips (walls), designed with u-Z In and perpendicular to this direction with NW to the se, crossing diagonally to the rectangular grid Hartman. There are several orders of strips of a diagonal mesh. Every 14 parallel thin strips of the first order, of a width of a few cm, is the 15th band of the second order, a width of about 30 cm. In subsequent this alternation continues, so that after 14 lines of the second order is the 15th band of the third order, of a width of about 1 m after 14 bars of the third order the band passes of the fourth order, a width of about 3 m and Thus the cells are formed of strips of the first order, size 4-6 x 4-6 m; the second order of 90 x 90 m, and the third 1250 x 1250 m fourth – 17500 x 17500 m, etc. On the intersection of the strips formed the nodes of Curry or D-zone, has a strong geopathic action."
Exposed dudes easily tested(if you want), on a grid sleep, Yin or Yang influence get. And there already and there are statistics that probably shines(but not warm) - was TB or cancer.
a particular line, it is best to neutralize shungite filling... enough rather thin.
Neutralize whether pan-Dom - I just checked, my house is comfortable.
This, of course, capitaline than sponges made of copper wire that recommends one academician "frivolous" Academy in a simple embodiment. Work something how strongly and widely the issue. Tried the area in the house to find, really could not find a clear line - flicker frame(maybe pan react), though the stream of water for future wells in the country has clearly fought as a Pro.
Anyone who tried to check the "House" in light of the GPP?
should work, but no performance measures and so on, you need to have a blank test platform for experiments.
In General I took at the office the bracelet Panacea probe,immediately his tape salamangrill in order to prolong his mortal existence...Through 2 a day socks appeared unusual(there was a stabbing or a feeling of heaviness ,and this was not yet)the pain in the liver,if someone with two hands with full force shrinks...and the pancreas is also aching...Salvaged for restoration More...When I went,there was a desire to go for a run,felt a surge of strength,run - after that was awesome
...But the main thing is everything seen in the pictures GDV
http://content.foto.mail.ru/mail/tetrag ... 9/s-60.jpg
http://content.foto.mail.ru/mail/tetrag ... 9/s-74.jpg
http://content.foto.mail.ru/mail/tetrag ... 9/s-75.jpg
Such detail for me 3.0 n 2.7 and 2.1 but they are alone,before addition of panacea, such a "seal" cocoon was not...and in this period I АСД2 began to drink 1.5 cube today 2 put
Could АСД2 to do(drink all week,started with 5 points(units)),or N+3.0 n+2.1(h on)?Really feel very great
...Atoms too was to rest was going
In fact, it is probably the most "complex" effect, and bracelets and ASD.
Panacea has a different emphasis on the rigidity of the recovery (which could be felt - the liver, poceluyka). ASD - actually, too.
Bracelets that already have - worked just softer.
During the state of lowered health, your self-made 3.0 N worked just as the carrier signal of the Etalon, a 2.1 as 2.1, but its obviously not enough, and 2.7 lived in difficult conditions (under certain problems he was nowhere to "open up").
Panacea and ASD has launched a more intense cleaning and then partially revealed the potential of other products (especially since the panacea was used in a sample).
The state of the "lowered health"
...well, Yes...it was...
By the way I had 3.0 n to remove again....At the time of the snapshot(2.7+pan(Lev.hand) and 2.1(right)) I've already taken it out(day 4)...Atoms is something pressed on the psyche,complexes some had etc....Took it off ,and everything fell away.
But the probe is more powerful or what?(much less a panacea used in the probe)
1.well, no wonder Pro 3.0 is a strong warning... I now its not interpreted as mandatory, but it's okay to place and time....
2. no, probe a little weaker..... for there is no difference, but at high loads the material and weight can slightly influence, and I think that your health there was a large load.
Summing up the interim results...After the positive effects from the probe,the panacea, the question of buying wide rose sharply
However it is solved...I admit was a little shocked
it really is massive(the size of the link exactly as 2 from 2.1), But now already used to it and loved it
...At the time of the snapshot, the left hand-panacea wide h/d(everything else stopped wearing),right-2.1.Compare snapshots with snapshots from 25.04.13 20.04.13
http://content.foto.mail.ru/mail/tetrag ... 9/s-71.jpg
http://content.foto.mail.ru/mail/tetrag ... 9/s-72.jpg
http://content.foto.mail.ru/mail/tetrag ... 9/s-73.jpg
Nui chakra too, just in case
http://content.foto.mail.ru/mail/tetrag ... 9/s-70.JPG
This is after 5 days of wearing the panacea.
Sent from the phone Mlyn
Maybe not necessary so to do in the room is really good, but the wife says that as something separated from the space feeling... in her words hanging in the air a feeling (but happy)АндрейКо wrote:to operativniy - noticed for a such a feature:
when all the walls and mental openocean boundary delineated
I somehow, in the center of the room (in the air) mentally draw a matrix in 3D and twist it clockwise. (sane I do not remember that I was taught and not in all cases apply) - I don't know if so? but on subsequent visits to stay in these rooms I like.
Wear BJ P. I am constantly in ASCS. As if drunk and go for a pretty long time, two months probably )) (these two months I didn't drink) Once there was a time when I read the forum here, the consciousness hovered for 2-3 seconds, in my head there was a pulse on his head like microtack not of a physical nature, likely macrobiotic. To describe it is very difficult because it hasn't happened. In these 2-3 seconds felt like the thought process completely disappeared the picture in front of me where I looked, and I looked at the monitor, beginning to twist from right to left. Then there was light fright and it was all over, immediately sweating. Then a friend called, but when talking to a friend on the phone the tone of my voice has changed, but after some time came back to normal. The experience really goes beyond everyday life and is very interesting to me. Whether there was at whom such or at least similar ?
Still, the may holidays were Smoking in the stairwell...АндрейКо wrote:Today was a bit of a curiosity:
Decided operateit entrance. Writing on the walls somehow uncivilized - picked labels (thermal transfer 40*60mm, white relatek sort of), written in pencil and neatly pasted. Thought - tomorrow night is a rip off - come on the next day, and we have the repairs to the porch and painted the walls directly on labels... as the legendary quote was "Wanted as better - it turned out as always"
Had a digital panacea to paint + program to harmonize the space to put not to smoke in the stairwell. On the labels have added a picture of a cigarette emitting smoke crossed out - as a hint.
PS - on experiments digital panacea is much more potent - for example in the Guinea pig of steel grain to germinate (have not seen such effects...)
05-05-2013 it Seems to be working! found a few cigarettes smoked by 1/4-1/3 - but still attempts don't leave...
And in the street drinking beer - like elixir of life... (although it's even beer can't be called...)
Андрей Ермаков
- Has thanked: 3 times
- Been thanked: 15 times
I last summer all the Windows at work plastered, and guess what... I was laid off, and the Windows have changed
. However I came back as a representative of the contractor.
ВикторРусс
a small report on the application of the matrix: in the spring wrote in the Park at the subway token on the benches matrix "panacea", 3 days later, benches were painted, maybe a coincidence? caused matrix not on all the benches, and painted everything and always paint in the spring, perhaps as I guessed at the time to apply pre-matrix. In the field , on the way home going through the forest debris as the landfill, not overgrown popular trail from the nearest settlement "in the kebabs" with or without, packaging,containers, etc left after a fair dose of alcohol immediately...
Took the tape paper and pen abanazer trees in a circle "seats". Through 2-3 weeks, the local administration has driven a few workers , brought the car debris. Maybe a coincidence? The first and last time such large-scale clearing of forests was in the fall, on orders "from above". After 2 weeks in the woods there was an announcement with the invitation of enthusiasts and concerned to get out in the woods. In my memory, Saturday in the woods was conducted, even during the Soviet era. Took active part, 10-15 participants of different ages (thought to be more conscious)...the result-the container garbage. The organizer was a woman, a mother of 2 children. Asked the question that had pulalo the desire to organize a community work day? "Gave birth, walked through the woods with the child for over half a year, not a forest , a junkyard, decided to organize the cleaning. Found in contact these enthusiasts, contacted, gained experience in organization ,appealed to the administration with a request to take out collected and wrote the ads". From me received a gift of a matrix and how to find information on them.
Abanazer photo of the village dumpster and the territory are rare, constantly overflowing, the debris falls out, flies around, which set fire to well-wishers, 2-3 days arrived the loader was taken that falls around the container.
Abanazer brick fence, the owner undertook repairs, he's got a tile in the spring pootvalivalis from below into the fence appeared graffiti "learn to love,..Ki".
On the other side of the forest, the situation is even worse garbage in the forest brought to the village by cars, residents save on the order of kontenera. Then, in the evenings going to a crowd of prostitutes. Took a paper tape, pen, marker, abanazer fence, trees, stones, lots of photo imposed matrix. Also, almost at the entrance to the forest, double-dug holes, buried the balloon to the automobile had passed and while I was digging, recalled our soldiers ,trenches, Germans, and tanks that won't pass the bastards... a few days later came the tractor was postviral musornye the dumps on into the woods,periodically , every 2 years this happens, and 25 metres from my pit,at the entrance to the forest and began to dig a pit 1.5 meters deep and found the high voltage cable, which of course broke, day, the village and the nearby villages were without electricity, had postaralsya a little tractor the hole was already there, but for a couple of years it was leveled... That prostitutes like ants, do not want to leave the territory. Conduct observations. Take advice on what and how they still handle...<
Range you can try.ВикторРусс wrote:Take advice on how to handle...
the number of the digital panacea is possible (stronger than 9 letters).ВикторРусс wrote:how to treat...
I would have got a specialized - not to litter.
(update: that it was clean
(but I think it is necessary on the physical level as something to take to tractors in the forest debris was falling - to talk, to photograph...)
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
make it rain - not the cause but the consequence. Garbage - it's in their heads. We need society to change around here. And patience is not for the day is done.not to litter
Here is the program "stop Smoking" - a good thing. Offer its common to do as "Food". Only need to add "... and to find a harmonious substitution / alternative" to Smoking. Someone who does not smoke, and litter will be less.
In my town people have already started to make a dump right on the streets (in the opposite area of the city) so much so that the authorities have installed cameras with night surveillance on two streets - now on local TV transmission that was directly fines to prescribe willВладмосква wrote:to litter less
trash and truth in their heads - and it's not one generation vaccinated..... gradually... slowly...
and there is a direct relationship to the environment - "not mine"..... we need a different education system and different paradigm of life however
Yes - it is not for one day.
Владмосква
Yes: the apartment - "my", and the Elevator, stairs and the yard is already "not mine".
some apartment not mine and even had his own room - only partially
