СК1М
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Wed Oct 27, 2010 17:17
Михаил_ wrote:power consumption by the meter - 1.5 kWh
This is the amp? Or electric heater? :) I have a heater less energy eating...
The goal probably should srivatsa immediately when this flow of energy... :)
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Wed Oct 27, 2010 17:25
Michael_
:shock:
Михаил_ wrote: but in light order can be a little less.... most importantly cooling.
1.If you put on the balcony, -30(C), how much will decrease flow?
2. What if it is used at room temperature and not cooling at all?
3. Up to how many degrees it heats itself?
4. If not a secret, what exactly is there so much eating?
5. You said next to him for a long time is problematic, what is the radius need to move?
Петр Петрович
Post by Петр Петрович » Wed Oct 27, 2010 17:55
And one more question. But if before the amp put too complicated target, it will not burn as the predecessor of SK, who drove drunks?
And about consumption 1.5 KW/hour and the need for cooling - it's a joke was to stop overly active buyers? :wink:
Post by Логик » Wed Oct 27, 2010 19:06
Петр Петрович wrote:And about consumption 1.5 KW/hour and the need for cooling - it's a joke was to stop overly active buyers?
I bet Michael wasn't kidding about the kW...
Post by Воффка » Wed Oct 27, 2010 19:23
No, one and a half kilowatt is certainly cool, trust the wiring to be connected, and then plug all povyshaet :? :(
Post by Михаил_ » Thu Oct 28, 2010 3:15
outlet Yes, you need a reliable.... well at least managed to do without three phase power, not all of it is.
Post by Михаил_ » Thu Oct 28, 2010 20:38
Yes people... I joked about 1.5 kW, do you believe ? where in such a small box to put that kind of power? the radiator is then needed.... with a fireplace. :)
there is an external power supply, low voltage device, powered from 12-24вольта. (included power supply unit 24), consumes about 10-12ватт.
The device has audio input to connect the modulation output, to connect to the UK or other equipment and the operation indicator that lights up when the disconnected consumers (with connected SK may go blank).
The object table does not replace SK completely, his goal - strengthen communication with the device more strong, in this case with the UK.
Independently device can use - for energoseti premises and / or operator, particularly at high frequencies, but not only.
To burn, as in the aforementioned stories must not - high reliability and protection plus I checked in terrible modes - always survives :)
Post by Логик » Thu Oct 28, 2010 21:02
Михаил_ wrote:Yes people... I joked about 1.5 kW, do you believe ? where in such a small box to put that kind of power? the radiator is then needed.... with a fireplace.
And who knows you? He joked... And Kilowatt power supplies for computers, roughly comparable, where are their energiyu get? :)
Михаил_ wrote:is there an external power supply,
In the pictures it is not visible. Grey Quadrat and another on top of it. All. How do we know about his power?
Михаил_ wrote:consumes about 10-12ватт.
Well thanks, calmed.
Post by Воффка » Thu Oct 28, 2010 21:13
Post by Воффка » Thu Oct 28, 2010 21:15
Michael_
Тоха
Post by Тоха » Thu Oct 28, 2010 21:18
Oh how fun). And the gain from this device what is it? Well, at least as to compare efficiency?.
Post by Михаил_ » Thu Oct 28, 2010 21:36
well, computers, and ventilation is good... and a little more body and metal where it is blown and is used by so many is usually only at full load... it's just the heater :)
hmm... but the pass is not a joke, it was not possible :)
all processes directly related to the person rested in his personal "ceilings" -there is nowhere to put kilowatts. Ie that we can really do is lightly to help the person in some external conditions that determine the degree of manifestation of his abilities and opportunities, but no one does anything. And I am deeply convinced that the situation with radionically or parlor broadly similar.
Ie on the one hand there is the striking phenomenon and this is changing conditions or internal settings. On the other hand there is a limit.
I.e. there is in principle supermodeli do not need and nowhere to put them would be. If they apply, it will be a La "mad fishmonger" at best, at worst - a dead body and problems with it in the next incarnation.
And all that I know is designed to work below personal limit with a significant margin, so even at the risk approach did not appear, and rightly so. What I do is no exception. And work in this "gap" is more than enough. On the one hand it is safe for all (and of man and the world), even given the crucial role of certain individuals in history (as such, the role is often a degree of freedom or factors of a different order than discussed here). Miscellaneous, such techniques will not harm society, can only help to receive personal bonuses to individual participants, and to ensure that they these bonuses are received, they must be motivated..... well, how shall I say -quite harmonious to the world. Ie is useful not only to them but also to others.
Ie, these bonuses are personal, but I'll be a lot more people. Ie externally it is a "lucky", which leave behind a trail of solved problems and interactions even where like personally was not involved, but was just there (was Ottonel).
On the other side of all this for personal tasks, and so more than enough and the same 3.0 that is a good example of where much stronger shake to arrange.... and so people get too much change in a short time.
Working in this area, you can certainly increase the effectiveness of techniques or technologies or their narrow specialization, but it is impossible to approach the border, especially because of the large capacities here and need not and can not and will not be possible.
polutoraterabaytny if it is only for Mars to teleport :)<
Post by Михаил_ » Thu Oct 28, 2010 21:37
Воффка wrote:Michael_
it is advisable to keep the area 2-3 meters in front of me, although if he's to play a bizarre record, then it will impact on your whole room approx.
When connected to SK a couple of meters.
Post by Михаил_ » Thu Oct 28, 2010 21:40
Тоха wrote:Oh how fun). And the gain from this device what is it? Well, at least as to compare efficiency?.
it enhances the energy component (in the natural model it would fire, trenchlines - neitro and neito).
ACC. mass it does not increase, i.e., the parameter of inertia does not change.(water or Homo, as a factor of stabilization of the system-changing external world), this is achieved due to the increase in mass in the UK. I.e., the size of the device and the amplifier are two different things.
However, because the impact of this and that and if to compare for example the sensitivity of the audio playback via a link to the object table SK per person, I think 5-10 times. It's hard to say for sure.
Тоха
Post by Тоха » Thu Oct 28, 2010 21:49
Stunned. I'm with 2 of my SCM can not understand plainly, and if amplifier. Perhaps the weather is))
Michael is a huge request all the same software application for SCM is really Nada)
Олег27
Post by Олег27 » Fri Oct 29, 2010 1:36
Михаил_ wrote:Yes people... I joked about 1.5 kW, do you believe ? where in such a small box to put that kind of power? the radiator is then needed.... with a fireplace. :)
Well, Michael, well, the joke you. I have stuck with regard to where such an outlet to take, and when and three phase mentioned here I PU..l, I think we are against who we shall fight. Directly the peculiarities of national hunting.
And in respect believe do not believe, and who knows you may the laws of physics already canceled and had to enter his, that's on them and needs a power outlet (well at least not three phase!!!). :wiz
Post by Михаил_ » Fri Oct 29, 2010 2:01
nothing :) good training of intuition :)
Новик
Post by Новик » Fri Oct 29, 2010 2:08
Michael,
So what in General can make such a unit:
Ск1М+RF+Amplifier?
The experience is such a combination from someone in your circle?
And what would you power can compare its line of Radionics?
Post by Михаил_ » Fri Oct 29, 2010 2:25
1. do not want to compare SK and Radionics, all the same well at different work.
2. what can do it I don't know :) still very subjective.... I feel the impact of SK+HF, and sometimes it's overkill. Generally one person has an opinion that for example the early emergence of бж3.0 is the result of one formulation in the UK and not on my...
3. the amplifier has only me personally on the operator of the on signal is fed through the IC enhances in my opinion ... dramatically... along with the signal is the flow of energy.
4. as a 3.0 I (not necessary to say that this is hidden advertising) would not advise grabbing a booster all in a row. Ie believe that it is necessary to reasonably set against the capabilities of the device without the amplifier. With the understanding that the effectiveness of the use of SK depends not only on device but also from the operator (see for example recent reports on my forum about the 3.0 as an example), ie your opportunities and personal growth increase the accuracy of the adjustment of SK and more fully realize its potential.
actually, I believe that this is machine specific, but some people actually dragged himself personally car tasks (such as big business tied to the Creator) and it's really hard and time-consuming and energy.
And another and insurance can be much.
Дмитрий_999
Post by Дмитрий_999 » Fri Oct 29, 2010 11:45
Михаил_ wrote:output, to connect to the UK or other equipment
Michael Hello. If possible, please explain which equipment can communicate with the amplifier, and do I have through the exit , or will work through the object table.
Post by Михаил_ » Fri Oct 29, 2010 12:36
1. with power at the moment can run any BJ shot from the hands (it remains bound to the operator), the UK, and in the coming days of sales (as a variant of independent production) stabilizer.
2. not necessarily through the exit, just the presence of such possibility would be a stronger result.
м-р Фримэн
Post by м-р Фримэн » Fri Oct 29, 2010 14:18
Michael, what efficiency is better СК1М HF or СК1С? The price is the same, I understand that the question is somewhat flawed, but still with a limited budget what is the best option? Or enough to start and СК1М + BJ 2.0; 2.5 (2.0 and 2.5 already have)? Just want to invest with the prospect of...
Post by Михаил_ » Fri Oct 29, 2010 15:41
I think that with a limited budget do not think about the increased IC.
For starters don't just do SC and HF and the increase is different characteristics.
Well the car is engine power and maximum speed, stability on the road, turning radius, stopping distance, clearance.... and so on.
For example, we choose the power, what we need is actually a Rover.... floating :) because where we're going - all tracks and no Lamborghini will have to leave the village short of goal. I.e. one parameter can not be judged.
Well, then СК1С yet available, only experimental samples. However, the production of trained them to do and are just waiting for the corrected form.
м-р Фримэн
Post by м-р Фримэн » Sat Oct 30, 2010 16:11
Okay, thank you.
Michael, what kind of stabilizer like this on which You are working? How is it different from the picture on Your website and what is it for?
Владмосква
Been thanked: 7 times
Post by Владмосква » Mon Nov 01, 2010 12:16
Mr. Freemanfrom the pictures differs greatly. It is rather "upravlator". The closest analogue is a Board game. A more detailed description will be on display in the website when it goes on sale and the forum where the instructions for making the free version personally (there has already been discussed what tools and materials you will need). There was already a lot of posts about the new stabilizer on the forum from which you can lay down some tile (I hope I'm not caught in the darkness of the elephant's trunk said it was a snake :)
