I'M BUILDING A PYRAMID
Вадим Перелыгин
Been thanked: 7 times
Re: I'm building a PYRAMID
Post by Вадим Перелыгин » Mon Oct 22, 2012 21:41
Thanks for the interesting link. In the blog "current energy" andrewfil777 describes the experience and practical usage of the great pyramid of scarlet.corner of 25 and polycarbonate with 3M base within which is located a homemade generator, a capacitor for providing charging of the gel battery and Converter to power a light bulb for a suburban area.
Today at 14h took two autoambulator. Measured in one charge (18V), the other is completely discharged(7b) - stood all summer doing nothing.
Put them on the second tier (1.95 m) to the pyramid of harmony. I measure every day. We ought to try to make a generator like andrewfil777.
амилиус wrote:Here I think it has to do copper.Of the tubes,clean the frame
29.06.11 I quoted a bit from Gabriel Silva textbook "FUNDAMENTALS of PYRAMIDOLOGY" :
“Should NEVER be used for the manufacture of the pyramids ferromagnetic or diamagnetic materials. Should NEVER be used for the treatment of a pyramid made of copper, for living organisms they are very dangerous. Paramagnetic materials eliminate any risk with judicious use. Aluminium is the only metal acceptable for the pyramids, and only in the alloy with silicon, but in any case not with iron. You can use glass (it would be best if not for its fragility), wood and derivatives (secondary derivative), natural resins, fiber-reinforced plastics”.
Вадим Перелыгин
Post by Вадим Перелыгин » Tue Oct 23, 2012 20:55
The obvious obscure :roll:
амилиус
Post by амилиус » Tue Nov 06, 2012 13:19
The total charge is greater than discharge.Very interesting.Maybe it was not necessary them together to each other to put.By the way I forgot to say they should be put not at the level 1/3 and 2/3 of the city.
Вадим Перелыгин
Post by Вадим Перелыгин » Tue Nov 06, 2012 13:50
Alas, after two weeks of stay of the battery in the pyramid they charge more does not increase. And increase 2.5 in is not objective because the measurement was not under load. :) At leisure I will try to experiment with the capacitor.
Igor
Been thanked: 2 times
Post by Igor » Thu Nov 08, 2012 1:21
Vadym Perelyginand you here about such a device is not heard?
http://www.001-lab.com/001lab/index.php?topic=2120.0
Read there entire thread, you will be interested.
z.s. in General, the idea to use this sensor for measurements in the pyramid, well and the sensor itself is also interesting.
+ангел
Post by +ангел » Mon Jan 14, 2013 22:35
THE PYRAMID OF CHEOPS IN THE CAR http://www.zr.ru/a/4815
+ангел
Post by +ангел » Tue Jan 15, 2013 17:05
you can sometimes look at the Egyptian pyramids via webcam http://www.geocam.ru/view/cam11x1102_pyramid_cam.html
Moon
Post by Moon » Tue Jan 15, 2013 17:21
Last check of the webcam showed that it was no longer functioning.
is this link written
+ангел
Post by +ангел » Sun Jan 27, 2013 19:43
Moon wrote:Last check of the webcam showed that it was no longer functioning.
yeah not working was only a photo of the pyramids taken with this camera at different times http://www.listcam.com/go.php?a=stats&u=pyramidcam_com
Светланка
Post by Светланка » Tue Jan 29, 2013 19:33
bc Please tell me, I have prepared a transparent plastic pyramid - all of side 18 cm, and высота13см, as I understand it is out of range in the Golden ratio, it is possible to use? :wiz
Искатель-2
Post by Искатель-2 » Thu Jan 31, 2013 4:51
Lord. Help blunt the sense in the calculations.
Build an analogue of the pyramid of Cheops
If the height is 40 cm
the angle of the face 51°49'38,25"
how to calculate the length of the base and the lateral faces ? for some formulas
ie
This:
the height of the regular quadrangular pyramid 40 cm
to find the length of the base, the length of the side faces
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Jan 31, 2013 8:00
In the context of the pyramid height is obtained a rectangular triangle with one of the other two sides (b) equal to half the length of the fin base of the pyramid, others (a=h), is equal to the height of the pyramid, the hypotenuse (C) equal to the length of the height (cut from the top to the edge of the base of the pyramid, dividing the triangle in half side face, i.e., the height at a 90º angle to the edge of the base of the pyramid) lateral sides of the pyramid and the angle (α) between the leg (b) and the hypotenuse of the triangle (c), corresponding to the angle between the base of the pyramid and a height at its side faces and then correct the following relation: sinα=a/C; cosα=b/c, from which it follows that the length of the height of the lateral faces of a pyramid: s=a/sinα; and half of the length of its base: b=c•cosα. In Your example, a=40 cm, α=51º49'38.25" remains to count.......
To calculate the length of the rib side faces of formula d2=c2+b2, where c is the height of the side face b is half the length of the base of the pyramid.
Sincerely, MAG.no 〠
Искатель-2
Post by Искатель-2 » Thu Jan 31, 2013 12:40
MAG.no
night realized that I have something cool on my mind and fairly well-known proportions of Cheops divided by the same number
ie if it
A Length Of Base 232,7978
H Is The Height Of 148,0617
h Apofema 188,3374
and the height need let's say 40
then
148,0617/40 = 3,701542075
the result:
A Length Of Base 62,89211018 (232,7978/3,701542075)
H Height 40
h Apofema 50,88078595 (188,3374/3,701542075)
Искатель-2
Post by Искатель-2 » Thu Jan 31, 2013 13:13
Светланка
Post by Светланка » Thu Jan 31, 2013 19:08
Guys, answer me somebody. I'm afraid my pyramid refers to "mertvoi matter" bc
Искатель-2
Post by Искатель-2 » Sat Feb 02, 2013 13:40
Lord. building a pyramid as the structurer of space to hang going to the ceiling
question for CONTENT:
polycarbonate, galvanized iron, plywood, plastic - what is better to build ?
is there somewhere the communication data of material and energy pyramids ? if you have a place it can be read
+ангел
Post by +ангел » Mon Feb 04, 2013 16:56
Светланка wrote:please Tell me, I have prepared a transparent plastic pyramid - all of side 18 cm, and высота13см, as I understand it is out of range in the Golden ratio, it is possible to use?
:) read here http://www.apxu.ru/article/geoforma/how ... ramidu.htm
Искатель-2 wrote:polycarbonate, galvanized iron, plywood, plastic - what is better to build ?
my opinion, of all these materials fit better to the plywood although do not want to learn with some of the adhesive was compressed veneer :)
the best grade of plywood for this purpose, FBA http://ru.wikipedia.org/wiki/%D4%E0%ED%E5%F0%E0
Светланка
Post by Светланка » Tue Feb 05, 2013 13:06
+angel Thank you!
Троечник
Post by Троечник » Fri Feb 08, 2013 13:44
Good day, dear!
Many (more than 10) years ago drew attention to slip into media reports about the properties of pyramids. Interested, but almost no information on self-production did not find, except the pattern for A4 paper in the proportions of the pyramid of Hunger. Glued the same plastic, by increasing all dimensions by 2 times. Made a quick frame to Dowse, found the room to one strong geopathic zone. Put pyramid was "clean". Said, "Oh, cool!", and threw this thing for a couple of years. Then shoveled the trash on the balcony, found a huge sheet of cardboard. Throw a pity, and store - is meaningless. Made it another pyramid in the same proportions, with a height of about half a meter. Have poeksperimentirovat with seed germination, found a distinct positive shift - given a pyramid parents to the country. But there she was safely broken after some time. Took another couple of years...
It should be noted that since childhood I suffered from various pains and ailments in the digestive tract. Doctors nothing could be done. What can I do with a diagnosis could not decide. In the Soviet army stomach was finally finished off and it burst into flames. Every year all worse and worse. Capitalism, paid, but still stupid medicine... 4 Years probably ago it came to the point that I couldn't eat almost anything. If morning eat, for example, a sandwich - then vomit it, not going to work. (Sorry for the unappetizing details) In General - normally, he could only eat milk products - cheese, cereal with milk, etc. If you ate something out of the ordinary human diet - had to endure severe heartburn, occasionally turning into vomiting. Well, at hand was always a pack of pills (Ranisan, Sanibel, Rennie) - they bring relief when things got really bad. Sounds scary, but actually once I especially was not soared. I told you that the stomach suffered since childhood. So the amplification of the disease in the 35+ years I perceived with neistrebima apathy.
It was necessary lyrically health retreat.
The third pyramid I assembled 4 years ago. Almost the same reasons as the second. Dig through the trash, found plastic leaves. Without further ADO, not knowing about nanometers and kilohertz, about the subtleties in the difference of the pyramids Perepelkinoy, Silva, etc., molded on the knee his biggest pyramid today. With a height of one metre. Based on the data that were available on the Internet 10 years ago, I was sure that only important proportions and orientation to the cardinal points. Understand that you've done everything wrong, but nevertheless...
That the pyramid was not just - he started the night to put under it (on the floor) a jar of water, and in the morning to drink a glass of water from there. Not expecting anything, not making measurements of health - just.
After a month or two, I suddenly noticed that I have not opened the pack of pills.
Well, actually - that's the whole story.
A pack of Manisana and lies before me on the table - now it watch. The shelf life of the tablets is over, but let it lie. First- remind, second - who knows what :o)
In the process spent a couple of measurements on the seed - germination by far the better seeds, which were exposed in the pyramid 2 weeks.
2 years ago, got divorced, moved out of the house, experiments with pyramid stopped for the reason that lived (and still live) it is not clear where.
Now came, apparently, another wave of interest. Appeared housing, for the pyramids, there was interest in structuring and energizing water.
Read the rest of this thread, I read the whole thread for water activation.
There is a reverse osmosis filter, there are PH meter, EC meter and ORP meter. There's an old pyramid made of plastic (the proportions of the Famine, the size of the bulldozer), there is a thick aluminum foil in roll, somewhere 1.20 m wide - I want the next pyramid to make the proportions of Cheops from it.
I would be glad if you help me with accurate dimensions, because math and geometry are my provocateurs headache and yawn.
Thanks in advance<
XUPOH
Been thanked: 10 times
Post by XUPOH » Fri Feb 08, 2013 21:16
Tried different proportions based on Phi http://rghost.ru/43646731
IMHO the geometry of the pyramid must be associated with the geographical latitude of the place. Perhaps this explains the greater efficiency of Golod's pyramids towards the North, and Cheops in the South.
Вадим Перелыгин
Post by Вадим Перелыгин » Sun Feb 10, 2013 14:49
Троечник wrote:in a month or two, I suddenly noticed that I have not opened the pack of pills.
While on http://newsland.com/onair/comments/user/1135761
I played the game "My opinion can improve the World", had not noticed the activity here. :?
Pleased with the confirmation of the "Trinity" therapeutic effects of pyramidal water even in chronic diseases of the gastrointestinal tract. :D
Remember about 40 chicken eggs were not fertilized, but NOT foul in the incubator with the pyramid Perepelkinoy it had lain in 38град 23 days.
I also have since my youth had problems with the gastrointestinal tract until generalissmo gastroduodenitis. :shock:
I suspect that it was not only in poor quality food and any alcohol-containing products, but in the absence of picture of the world most suitable for me.
Really helped me book N.D. Walsh "Conversations with God" http://fb2lib.net.ru/author/15698
About "cockroaches" in the head and in other places of the cocoon and creative work with them has received information from the book by Andreas "Essential transformation".
Here outlined http://www.mindmachine.ru/viewtopic.php?p=59705#59705
In pursuit of all sorts of "magic tricks", a wonderful instrument and effective techniques of influence on myself and other people, we sometimes forget about the "natural laws" - principles and regulations in force everywhere and always as the law of gravity. This writes Stephen R. Covey in "Seven habits of highly effective people".
Here outlined viewtopic.php?p=60561#p60561
Personal mission in four dimensions – Spiritual, Intellectual, Physical and Social-emotional formulated here http://www.mindmachine.ru/viewtopic.php?p=61992#61992
On rusfolder.com are still available file Raschet piramid.xls No. 20438657
Of all the types of pyramids for myself prefer the proportions of Cheops is calculated mathematically from the Cold, V. Y. "Pyramid Golden section" using
the sequence of spheres is inscribed in the pyramid schemes, determined by the number of the Golden section f=1,618... to the extent appropriate,
that is, f, F2, F3, F4,... even When the degree f of the secondary vortex field of the pyramid has an activating effect(Pyramid life).
With an odd degree - secondary eddy field of the pyramid has a stabilizing properties(the Pyramid of harmony).
The pyramid of Cheops(f cubed) includes the principal properties of the pyramid of harmony (the f in the first degree) and the pyramid of life (f squared).
Inside the pyramid is a Golden triangle (hundreds of.sides 1: square Root of f: f). Creates conditions for the harmonious flow of vital processes in a "live" matter.
The octahedron and the cube is the basis of the structure of "dead" matter, and secondary vortex field of their pyramids, harmful to "living" matter (the pyramid with facets in the form of equilateral triangles).
Giving another pyramid Perepelkinoy friends are going to glue the water to the pyramid of Cheops, but with the wave chart.
As he wrote, "Viktorovich": "From the whole incident, and many other experiments, it is assumed that the most appropriate size should gravitate towards 508-510 (66.6 mm, a frequency of 66.6 Hz) especially because there are rumors that gariaev somewhere mentioned that the resonant wavelength of DNA - 33.3 mm (previously mentioned 632.8 nm). A pump control system to solve all the problems".
Calculations and patterns published in the subject for his pyramid out of plywood covered with foil, hanging over the bed on a cord and moving up and down and along the bed.
Her dimensions are: B=62,81 cm; A=50,82 cm; C=59,74 cm i.e. exactly 2 times more than I'm going to do for water (but the frequency is the same).
So: take a sheet of polycarbonate, draw the pattern and cut with a knife face of the pyramid. Length of base H=31,4 cm Find the middle/2 = 15,7 cm
Building a perpendicular is apofema the face of A=25.4 mm, see Connect the top ends of the base, getting the edge length C=29,9 see Cut the bottom of the pyramid in a square 31,4 x 31,4 with a hole in the center.
With a helper on the table, unfold a thick ribbon Tape width 5cm. and put 2 faces, getting the inseam. Similarly glue the rest of the face. Put faces on the base and outside glue and tape.
I wish you all success! az<
Вадим Перелыгин
Post by Вадим Перелыгин » Mon Feb 11, 2013 23:43
Here yesterday for a couple of hours.
But as prochieve water to do.
Take 2 of the plastic container for 1 to 2 L. one to pour water from the tap and put it in the freezer. After an hour, formed the first crust of ice. This ultra-light water is harmful. Pour water into the second container and put it in the fridge. After 5 hours, the water will freeze. Pour one that didn't freeze in the sink. Is hard water harmful salts. The resulting ice spread in a jar – healing water (proteva). Drink within 8 -12 hours of prayer on health. If too cold, do not drink, and chew it slowly.
СлаваЛянтор
Post by СлаваЛянтор » Wed Feb 13, 2013 23:17
Hi all. I stumbled upon it and decided to tell about the construction of the pyramid. is not so difficult. everything revolves around the number PI and the Golden number. the main thing to understand the whole thing. but for an accurate representation please see the movie http://www.hdkinoteatr.ru/documentary/9 ... mides.html I looked and I was interested in all this and which way to send it and where to put it... very interesting.
Искатель-2
Post by Искатель-2 » Thu Feb 21, 2013 14:06
disagree
after this post posesorul. it turned out that
polycarbonate 85%
plywood 25%
galvanized iron 15%
I think the thing is that the plywood - ACCUMULATES, and more chaotic structure. And in the polycarbonate - cavernous structure, they does not absorb anything, unlike wood
don't need the sink, you need a modulator-structurer
in General, almost finished pyramid with a height of 45 cm. later the photos give.
