CD "healing: the magic river"
Hello, I want to share my impressions from listening to the disc. Listen to the week after the 3rd session beginning to tingle in the temples, then in forehead and so on, as if I massage the brain. Dreams become vivid and interesting. In life began to happen a lot of pleasant things. Here such here Affairs...
Just listen to the Healing.Агент Смит wrote:I was not referring to the simultaneous use of the Healing session and MM, and using the session (what?) with affirmations designed to improve the health, alternating between the session and the disc to focus the action on the right place. For example, a headache - session+affirmation "from the head" (although they are all in some measure "from the head"Андрей Патрушев wrote:There is audiostrobe.), it hurts ... and so on. Or just listen the Healing, and in General not to focus, the body itself will understand?
Ринатер
When I listen to the disc, my first by themselves begin to strain the muscles of the legs and hands. I can step in and relax, but if I am not interfering just observing as if from the outside, the tension is becoming stronger. Hands clench into fists, feet as if trying to grab something. The body begins to twist, to writhe, to shake, to shiver and tense knock teeth. I remain calm, no discomfort and discomfort experienced, as if looking from the side. Only constantly think to relax me consciously or continue to watch. The voltage held by itself, and then starts again. What do you recommend?
Валерий Юрьевич
Hello Andrei Patrushev.
I'm new on the site, accidentally, became interested in and bought all of Your CDs(mind no car). For seven days listen to the Brain Massage morning Healing before going to sleep, the result is zero. Only a small relaxation of the muscles and all. It would be expected to be a calm, improve mood, uplifting performance. When listening to the disc, carry out strictly all instructions. Listen to Muz.the center of stereo headphones. I'm a lawyer, I need a calm, sober and logical mind, and a nervous wreck.In court, at meetings, sometimes through force holding it together, so as not to explode looking at all this chaos. Maybe a specialist will advise what? Maybe there is another method of listening or something else to do before the audition?
Me to relax, to find a morning tone and relieve the nervous system helped the Conductor, but to cure some mixed impressions...Валерий Юрьевич wrote:Hello Andrey Patrushev.
I recommend to read the Sedona Method http://www.mindmachine.ru/viewtopic.php?t=1652&start=0
I'm slowly practicing machnau, learned a bit already to get results. View, try, maybe I will take on Board!
- Агент Смит
- Been thanked: 1 time
As promised, unsubscribe: after the third session I had stopped all treatment of his sore throat, after the fourth passed almost all of her symptoms, and after the fifth it went. Yay, Healing works!Агент Смит wrote:will unsubscribe by results
As I understand it, you need to trust your body to do its setup well and believe that he can. On the other hand, why not believe when the majority of authors clever books argues that our body is smarter than us, and we're trying deliberately to guide and confuse him.
And of course, huge thanks to Andrei Patrushev for the creation of these disks.
Disc Healing and Conductor have been working for over a year and I can say that from Explorer, I have a mixed impression and nightmares serial horror, and Healing works.
In the beginning I listened to them a series of turns somewhere for three months. Strong changes were observed, but there was some apathy and my job (which I "fed") began to irritate me really. Yeah, plus, I have some time after this "series" were not able "to meditate", as practiced previously.
Of the positive changes have increased stress, but kind of weird. I became some stressful situation as would be seen from the side, no emotional involve in the process. In dealing with people of different ranks has become easier, but also something is not clear to me yet, but the General impression is that, if you deliberately "work" towards the development of communication skills, the Healing helps, but if you listen to him without goals, the results are mixed.
Drive Healing to cure colds I not much help. Sometimes after him a wicked headache (even if you drink water before and after). But to relieve tension after sports activities fits perfect (enough for me even 15 minutes of listening to immediately after workouts).
Add that water to drink is necessary and should be very careful to listen to the disc after meals and when taking medications or vitamins. I once as usual took vitamins and immediately after that went to listen to the disc Healing, but I fell asleep for an hour. And when I woke up, the condition was shocking, as after intoxication. In short, 20-30 minutes I "called" the frogman, which I have not had for many, many years.
I would also add that after prolonged listening, of Healing, I became easier to take any music. Now I can easily listen to classical and pop music, and all variations of metal. Moreover, I can easily switch between these directions and listen without straining for several hours in a row mixed classics, "gangsta rap", heavy metal and even a che-thread Russian contemporary.<
Hello.Валерий Юрьевич wrote:Hello Andrey Patrushev.
Drives is training, not tablets.
Агент Смит wrote:As promised, unsubscribe: after the third session I had stopped all treatment of his sore throat, after the fourth passed almost all of her symptoms, and after the fifth it went. Yay, Healing works!Агент Смит wrote:will unsubscribe by resultsAlthough I never doubted
Идущая вперед
- Been thanked: 6 times
have Renater
so you want... your mind is beyond the sounds on the CD... for the drive... and the sounds that it sounds anxiety - increasing .... the more it took from the beginning the more anxiety and stress - and the forest sounds of water and birdsong, like, smooth.... you just need to carefully listen to the disc and you'll understand... ie. sounds the alarm of danger reaches a certain point and the piling climax and abruptly cut off -- it leaves your tension and you be healed...
just be aware of what is inside and not outside... outside in the drive, the woods the water the birds are singing - like lepota - and if you carefully listen to the rest.....
I have to drive very acute sense of smell and hearing at first, and fear plagued that someone is there... then it was gone
Валерий Юрьевич
ANDREY PATRUSHEV-the Disks are training, not tablets. Requires regular use within two to three weeks...
Understood. I will continue to listen, about results I will unsubscribe. I read on the forum that much focus on past injuries, but how can I be, can I continue to engage with the disks? In the recent past, I am an officer of the airborne troops, world Cup injuries were two, one of them with an axe (1988). The last time the parachute did not deploy in landing for over low , the result of open fractures, seven surgeries, leg bones gathered up the pieces (2001-2002). The body seems to have coped really can not run, only walk fast, and everything is within normal limits. For minor injuries don't even pay attention, all heals as on a dog.
After a break again began to listen to the CD "Healing." Only doing this at night before bedtime, combined with workSvetlitsy.There are new details. The audition itself takes place without problems, but began to notice that began to appear around me people with strange behavior. Fit, say something and go. I don't know. Suddenly, events begin to unfold that I not only planned, but did not even assumed it in my life happens.
If "catchy" at once - at the first listening. Sometimes, the presence of psychological trauma, it triggers a traumatic memory, but it is at a deep enough dive...Валерий Юрьевич wrote:ANDREI PATRUSHEV-ROMs is training, not tablets. Requires regular use within two to three weeks...
I want to share my listening experience of Healing.
From the first day of listening to this CD, I have everything I could. From top to bottom. And this without external cause, I didn't have the flu, it was not insufflated and not.. not.. Once the temperature rose, a few days was 40. Inflamed gums, teeth, runny nose, transformed into a severe sinus infection with headaches and pain in the facial bones and with a huge amount of discharge, plus cough and bronchitis. In addition there is something in the stomach shkvorchit, kidney stabs, to top it off I just laid in bed with inflammation of the foot, the pain is terrible, not to walk, lie down in pain. In General my life so have never flaked. Today, the 21st day (I can't stop listening to, although in the middle of a few days was listening to without glasses, because my eyes were very sore from all of it), like the aggravation subsides, but I can't say that completely. Here are natural ways of healing, but still survived, maybe I will get healthier and I now transcend all!
Идущая вперед
Валерий Юрьевич
Honestly, I neponyal can I listen to Your CDs or not recommended?Андрей Патрушев wrote:Valeriy Yurevich wrote(a):ANDREI PATRUSHEV-ROMs is training, not tablets. Requires regular use within two to three weeks...
If "catchy" at once - at the first listening. Sometimes, the presence of psychological trauma, it triggers a traumatic memory, but it is at a deep enough dip..._________________
And another question how to overcome the problem? (Sorry for the intimate details) pulls All the time for sex. Time and so not enough, and then 2-3 hours daily departure. Problems appear at work, but nothing with him can not do.
Yes, you can, of course.Валерий Юрьевич wrote:Honestly, I neponyal can I listen to Your CDs or not recommended?
http://www.mindmachine.ru/viewtopic.php?t=2181
Валерий Юрьевич
And for example what can it compensate? Problems like this never happened.Dimas wrote:Valery Yuryevich
Quote:pulls All the time for sex. Time and so not enough, and then 2-3 hours daily departure. Problems appear at work, but nothing with him can not do.
And the reason for this You know? Can thereby compensate what? First try to work with the disk Explorer. Listen to CDs recommended _________________How many of us brains,and kind of sense,but why so MANY???...Will understand!
Thanks for the recommendation on the "EXPLORER", but first listen to 21 day "Cure" and "Massage of the Brain" and during the time interval going to listen to him.
Валерий Юрьевич
Days 5-6 after listening. But I've already figured out what it is. Before going to sleep listening to Healing,and listening to the Massage of the Brain that's on him and bears. It so happens that in a hurry, not listened to MM in the morning and everything was fine.Андрей Патрушев wrote:Valeriy Yurevich wrote(a):pulls All the time for sex. Time and so not enough, and then 2-3 hours daily departure. Problems appear at work, but nothing with him can not do.
It began when?_________________
Conducted "investigative experiment": in the morning, MM = mad craving for sex. In the morning no MM = no craving for sex.
Conclusion: Massage of the Brain = the health, smooth mood is above average, an increased craving for sex.
