SELF-HYPNOSIS AND PROPER GOAL SETTING
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Mon Aug 03, 2009 18:09
Hello, Andrew Can you recommend a good book on NLP? :)
Post by Андрей Патрушев » Mon Aug 03, 2009 19:55
рыжая wrote:Hello, Andrew Can you recommend a good book on NLP? :)
Frogs into princes. Reframing. The structure of magic. Change your brain and use the result. Everything else is a rehash. :) Well, perhaps even Turtles so below.
Post by Андрей Патрушев » Mon Aug 03, 2009 19:57
Алив wrote:
Андрей Патрушев wrote:Aliv wrote(a):
In Your article afformations we are talking about the fear of sales, but in the General case of all fear be like?
Explorer, Sedona, in the case of phobias - triple visual-kinesthetic dissociation (with the specialist NLP), Aspektima...
And EAE to find a specialist NLP? Many of the classic NLP psychotherapists think about the direction in psychology. What are the criteria to know a real nlpers might?
The city usually has its own napierska party. Most often have a website with a forum. There you can ask...
рыжая
Post by рыжая » Mon Aug 03, 2009 20:11
Thank you :oops:
амир
Post by амир » Tue Aug 04, 2009 18:33
DIMAS-I thank you!!!! advised!! Andrew!!!!!of course you know the technique of self-hypnosis the Betty Erickson "I am going hypnotize myself for 20 minutes "...for the purpose of allowing my unconscious mind to make the appropriate settings to help me ____________". a dash is inserted in the goal that I would like to achieve. help me reach the goal correctly. but the problem is this-when there is any trouble at work , I have the fears, the excitement unpleasant feelings in the stomach are constantly thinking about the problem all day to yourself in General. of course I know what goal I want to convey to the subconscious, Yes I'm afraid this goal is to supply correctly. want to type quietly without the fear and excitement respond to trouble vstrechajutsja in life or the type togob that could be inserted into the dash neverhow sorry wrote a lot.
ЖСЛ
Post by ЖСЛ » Thu Aug 13, 2009 1:02
амир wrote:DIMAS-I thank you!!!! advised!! Andrew!!!!!of course you know the technique of self-hypnosis the Betty Erickson "I am going hypnotize myself for 20 minutes "...for the purpose of allowing my unconscious mind to make the appropriate settings to help me ____________". a dash is inserted in the goal that I would like to achieve. help me reach the goal correctly. but the problem is this-when there is any trouble at work , I have the fears, the excitement unpleasant feelings in the stomach are constantly thinking about the problem all day to yourself in General. of course I know what goal I want to convey to the subconscious, Yes I'm afraid this goal is to supply correctly. want to type quietly without the fear and excitement respond to trouble vstrechajutsja in life or the type togob that could be inserted into the dash neverhow sorry wrote a lot.
When I have cleaned myself all these affirmations and other self hypnosis, instructed at the time - was a great relief. Because of them, the so - oblique%beat 8)
Post by Андрей Патрушев » Thu Aug 13, 2009 10:37
Sorry, missed... :oops: Thank you Gslu that savacol in the subject... :)
I think the best is: "to Find new ways of behavior (response to the challenge) and test them in the next two weeks."
ЖСЛ
Post by ЖСЛ » Fri Aug 14, 2009 2:19
Yeah, and how to find them if mental charges produce uncontrolled automatic reaction, and affirmation makes people hard certain i.e. inadequate and employees of a laughing stock for others? bi
Post by Андрей Патрушев » Sat Aug 15, 2009 15:52
ЖСЛ wrote:yeah, and how to find them if mental charges produce uncontrolled automatic reaction, and affirmation makes people hard certain i.e. inadequate and employees of a laughing stock for others? bi
Uncontrolled (and then only up to certain limits) the automatic responses provided only the spinal cord (backlog for the hot - hand flinched). Everything else is just once a learned behavior. Man is the pinnacle of evolution because they are able to effectively learn and relearn all his life. The problem is that all sorts of rubbish he is able to learn as effectively as the good things... :?
Each person has sufficient experience, which is an inexhaustible resource for change.
In altered States of consciousness (hypnosis, meditation, special wheels and mindmachine) the Subconscious is able to perform personal experience (including communication with effective in this region people) and find other (less effective)ways of conduct.
If the subconscious finds a new behavior is more efficient (at least simple and affordable), it easily takes it and starts also automatically to use as the old.
No affirmation can't make a person "rigidly defined and inadequate". It all depends on the person - "Make a fool to pray to God, he hurt his forehead"...
Do not be afraid of laughter (including on himself) - "All the most terrible crimes on earth are committed with serious faces". Laughter, on the contrary, treats and helps to relax. Laughing at myself I'm afraid only a very limited and narrow-minded people...
Камуи
Post by Камуи » Mon Aug 24, 2009 18:37
Good day!
Question: is it possible to begin your affirmations with the words: "I allow myself" , for example "to write beautifully and legibly", and then have myself speculated about napisanno :) .
Post by Андрей Патрушев » Mon Aug 24, 2009 23:42
Камуи wrote:good Day!
You can, but better, IMHO - "I choose". :?
Алив
Post by Алив » Thu Aug 27, 2009 2:30
Here I read a lot of things, and everything is messed up. Tell me how to relate to each other Aspectics, the peat, the method Sidony and classes with discs and a mind-machine? Listened to different alpha drives - helps, but how to combine with the above techniques? And another question - what book describes in detail the peat and translated on Russian. What I know now, these techniques are so unlike each other that I can't believe they have one author. The main problem - the fear (agoraphobia) and poor social adaptation.
Post by Андрей Патрушев » Thu Aug 27, 2009 15:15
Алив wrote:here I read a lot of things, and everything is messed up. Tell me how to relate to each other Aspectics, the peat, the method Sidony and classes with discs and a mind-machine? Listened to different alpha drives - helps, but how to combine with the above techniques? And another question - what book describes in detail the peat and translated on Russian. What I know now, these techniques are so unlike each other that I can't believe they have one author. The main problem - the fear (agoraphobia) and poor social adaptation.
The mind becomes more receptive to these techniques during and after (minute on the 10th) listen to the alpha CD's...
Ванчез
Post by Ванчез » Sun Aug 30, 2009 16:19
And is it correct installation
"I realize myself in a dream"
or
"I realize myself in a dream when you sleep"?
Post by Андрей Патрушев » Sun Aug 30, 2009 19:31
Ванчез wrote:And is it correct installation
or
I wonder who You are usually aware in the dream? :roll:
Ванчез
Post by Ванчез » Sun Aug 30, 2009 21:15
if I meet someone and realize in the dream, it is for a short time. And then forget.
Well, how will?
"I understand your sleep" +))
Post by Андрей Патрушев » Mon Aug 31, 2009 12:46
Ванчез wrote:if I meet someone and realize in the dream, it is for a short time. And then forget.
Well, how will?
Well, something like: "Every time in the dream, I realize I'm dreaming" :)
Алив
Post by Алив » Wed Sep 02, 2009 1:13
And Sidon, a method and peat in respect of working with Polarities as relative efficiency? Is it possible with the help of Sidon-a method to neutralize primary polarity?
Post by Андрей Патрушев » Wed Sep 02, 2009 12:04
Алив wrote:And Sidon-method and peat in respect of working with Polarities as relative efficiency? Is it possible with the help of Sidon-a method to neutralize primary polarity?
Of course you can, You book-read it... There are many wise thoughts - you can and just read, without even practicing.
Алив
Post by Алив » Wed Sep 02, 2009 14:56
_________________
The fact of the matter is. Book Dvoskin read, but something did not understand. Described the technology to me seems suspiciously simple or blurred. What's the catch?
Post by Dimas » Thu Sep 03, 2009 12:11
Aliv
The trick is precisely in the simplicity :) We somehow always think that only complex can help us,but it's not....Would advise to learn the method Phillip M. (son of Slavonski) TMO (technology modification experience). I think this is a very powerful thing,works for me on HURRAH! If anything, you can throw the manual... :wink: :)
доктор Бармалей
Post by доктор Бармалей » Thu Sep 10, 2009 23:40
Somewhere I have heard it all. The film is called"the Secret." And you openly dictate it. Not good...(((
Post by Guest » Thu Sep 10, 2009 23:44
I Patrushev appeal, but Dimas says. And what about sleep, the author of something can't remember...
Алив
Post by Алив » Sun Sep 13, 2009 16:24
доктор Бармалей wrote:somewhere I have heard it all. The film is called"the Secret." And you openly dictate it. Not good...(((
I don't think. In the movie "the Secret" the basic principles, there is a naked theory, and we do practice.
МАКСИМ Р.
Post by МАКСИМ Р. » Tue Sep 15, 2009 15:04
Welcome Andrew!!!!!Only now there is an opportunity to thank You for the advice!!!!So to me after the last post Ewen banned for a long time,well and good!!!The peat-that's what all of You listed kankretno "tearing" all g..BEEP...but from the past!!!I'm on a completely different level of personal development...Already collect their pieces scattered in "the past"....Samh You blessings and all the best!!!
