Small offtopic.
Пианистка
Has thanked: 10 times
Re: Small off-topic.
Post by Пианистка » Fri Apr 19, 2013 21:14
Михаил_ wrote: and for that question about the at....
here I am a noodle... :?
Стасевич
Been thanked: 2 times
Post by Стасевич » Fri Apr 26, 2013 2:01
Finally :) I mug(T1+ASD) began juzat :D one is ASD,secondly the water(more precisely hand-assembled by my brother the birch juice) is structured :) ...The key to good structured...Luminosity on GDV images increased from 26 thousand to as much as thirty :D for 5 days...I hurt my :D
http://content.foto.mail.ru/mail/tetrag ... 9/s-71.jpg
Post by Михаил_ » Fri Apr 26, 2013 5:46
I already 1001 times explained that the luminosity is the integral parameter "nothing". Ie, it is of course in General average case means something, but not all, not always and generally.
And if something and look at GDV-grams, only the individual "fingerprints" and under magnification and gently (properly) taken.
Стасевич
Post by Стасевич » Fri Apr 26, 2013 10:46
Michael_
I didn't know...Now I know :) ...And info on the chakras in the pictures is also "nothing" :) I want the end to understand...
PS and to hell with him by and large....most importantly how I feel and not these pictures :)
Post by Михаил_ » Fri Apr 26, 2013 19:30
ifno about the chakras considered sectors in the pictures of fingers associated with these chakras Meredian (or rather sectors of their release on the fingers). I.e. a single end point. Given the fact that the sector points really a lot of about considered. Correlation with the real condition of Affairs there, but chakras options very much - it is a multidimensional object, and on the chart programme is only one option for each chakra - a highly simplified representation. Definitely simplified for quick diagnosis in the absence of the opportunity to experience something otherwise useful.
Анор
Post by Анор » Mon May 20, 2013 14:18
Michael, welcome!
Do fans Rinat for the 2nd year. Written off with him, discussing something. Good guy only classical science, it is all the eyes see.
In General, I told him my idea laid out, he ignored her, which in principle is clear.
Will explain all here:
The whole point is, do not run the engine with the drives to connect via a "conductive" material rim. That gave me an idea about the nature of the phenomenon, but about it below.
I use the bottom part of the fan (where the motor is mounted) of iron. Iron is really a detention center for "mu-DC".
In General, after playing with plenty of this miracle, found that by this device it is possible to revive batteries which caught the memory effect.
So I reanimated (not 100%) more batteries for screwdrivers. To full resuscitation is not reached, but those that are already not holding a charge even after charging to charge normally after "education" "spinner". But again, it did not restore them to 100% because some elements just went out (needs replacement), but the charge began to keep. In the same way I got rid of memory effect your Bluetooth headset with rechargeable lithium polymer battery. In this memory effect disappeared completely (half a year no problems)!
Put on the engine the effect is. Now to finish the 3rd option. You can see it here:
here:
now thinking about the nature of the phenomenon.
've been thinking about this effect and this is what came.
"It is not necessary to attract new entities without extreme necessity" ("Occam's Razor")
This I mean that no mu-particles in nature. There are different kinds of electricity (or what we call this word).
Began to look for analogies in things known to me and at one point realized that it was one in one electrostatic machine.
Only the nature of electricity in the chopper the other is more subtle.
Accordingly, if the electrostatic machine rotate two wheels with the dielectric relative to each other and we have static electricity, in this case the rotating disks of aluminum is relatively static, we get electricity but the other kind, and other properties. I think the Parallels in the properties of statics and the "mu-DC" may be the influences which they exert on the substances: air, water, metals, etc. By the way statics are also not kept on metal. And Petrushka again, the iron tends to insulate the energy of the fans.
Another conclusion to be drawn from analogy with the electrostatic machine: turntables have two poles of opposite energy. The first is the case. Second - the engine.
In line with this, I changed the design. The large area of the disk will interact (move) relative to the body, the more you receive from it energy. In my design the top cover of the housing has a clearance relative to the disks about 1 mm and from below and is essentially a continuation of the rim as Rinat, with the exception of the iron washers of the insulator which is attached directly to the engine.
There is a desire to experience the "charging" of water between these two poles.
But while waiting for ORP meter, that would at least like to see change the properties of the water.
And generally have a lot of ideas for the exploration of the turntables.
Criticism is welcome.
What do you think?<
Post by Михаил_ » Mon May 20, 2013 15:15
1. I think that by and large this in this thread slightly offtopic, though branch and is called off-topic :) but another suitable time where You would have access to - no, let it be here. Account on my forum You have probably not, but check there too yet.
2. You are wrong about the essence of the phenomenon. Specifically, a chopper no matter the iron and the DOJ may not necessary to call the DOJ.
Turntable works at all in the air, i.e. without rims and caps, as they should of the correct "theory".
3. Rinat unfortunately, not only stubborn, but also does not want to change, and so life catches hard problems on the way. And because I stopped him direct interaction (helping him not helping him because he gets in any more trouble, and that does not fit, he needs a consciousness to change the approach to life dramatically. I.e. in order to achieve success it is not the turntable to do it, and you!!!
On practical examples it reacts however - sharpening - checked and believed (was my idea). BioLink - check for yourself (he went hard with the habit) - once believed, but did not go further. Why????.... because the head thinks.
4. to achieve different effects is possible by replacing the material. (but I will not say more not guys who are smart - smart enough, please forgive me, it's not the reluctance, and in danger from such a thing).
5. the usual spinner from Rinat, on the "classics", the thing is ancient. in his normal incarnation (counterclockwise) increases the vortex quality, I already wrote about this. And impact in its area. Therefore, the recovery of batteries (not only battery)
All really very simple and difficult at the same time. And AKB has long been a restore so, this was written and Rinat wrote a long time ago.
Undoubtedly close the lid and creating other "electrostatic" effects, it is possible there is something else to from modification phenomena, but this is not about that all.....
Something like that.
In General, the turntable of the PRIMARY operator. This is the main thing you need to remember. Operator (tested) can remove 100% effects just directing them to another place.<
Хастред
Post by Хастред » Wed May 22, 2013 13:49
All the answers to these questions are in the lectures which I offered to look in informatori.
what is this informatory and how to get it?
if the question is misplaced here but please reply to the PM and the question Bang
Post by Михаил_ » Wed May 22, 2013 15:03
1. I described it on the forum, you can try to find.
2. no way. I because of certain personal tolerance levels prescribed interested then in that conversation. If you find it, it might fall under the same tolerance (the time is not entirely linear).
3. overall this is a real manmade infra structure and level of technogenic advanced civilizations available both physically and on the information plans and created hell knows how long, for a typical project (the same everywhere in different worlds) to communicate with other worlds in the sense of organizing information from the world and pass certain information flows, permits, tolerances, registration, external action, etc. (kind of a big help with the municipality, but not related to this world, i.e. the internal privileges not available, except that due to the high technologies).
attempt entrance without a ticket is useless (can damage), although there are plenty of people who due to past work still have some tolerance but I don't remember about it.
Post by Михаил_ » Fri May 24, 2013 4:01
yeah, caught the eye today new Wikipedia, very in tune with the beginning of the topic.
1. http://www.meddaily.ru/article/23may2013/glioplazma
it's just the topic Lohovskogo and very reminiscent of his second version of the radiator at the core of the action.
We can say that the method is scientifically recognized for the second time.
2. It's a bit on the subject of nutrition
http://www.meddaily.ru/article/23may2013/mitosta
directly related to the operation mode of the cells and the fact that the food a person eats. So too say the confirmation.
3. And finally
http://www.meddaily.ru/article/23may2013/kt_ris
I am the author, and 1 a few months ago said that it is not carried out in childhood imaging, and conducted during the course of the disease (cancer) turn the effectiveness of the treatment (various methods including his tool in centers where it is experimentally in use) to sleep, the man after imaging "burns" just before that, however, improvement was. These are the conclusions of the medical center in Kiev and the Germans, who have a network of medical centers around the world and there are dozens I1 work.
Well, the article soft confirmation.
You've got to understand the duality and the gravity of the situation - the person if Onco in a serious stage, it tomographic to find out what is what with metastases. And this is a major blow to the body and immunity.
So... for the General note to say so to the heap.
Post by ЗОМБИ » Fri May 24, 2013 7:55
Михаил_ wrote:2. It's a bit on the subject of nutrition
confirmation of what? provides information about how food affects the mitochondria?
(I know, the lectures Demenkova, unsaturated fatty acid affect the mitochondria through inhibition of something there is (almost cellular respiration)... I do not remember and did not understand... while Frolov recommended to drink at night, a wonderful blend of vodka with vegetable oil...)
They started with the study of mitochondria of mice, and found three genes that affect the lifespan of the animal through speed. Mouse, which the expression of genes was 50% slower, lived approximately 250 days longer (about 30% of the total lifetime).
ie in fact no repairs there is simply an increase in services due to more economical use
Acting on the same proteins, but in the body of the worms, the scientists were able to extend their life by 60% (from 19 to 30 days). Experts have taken the view that mitochondria - bacterialiving inside the cell. So they turned to antibiotics.
i.e. poisoned mitochondria antibiotics? For what? for further enhanced biogenesis of mitochondria after Petrovci or to directly ruin these mitochondria and not allow them to breed??
Mitochondria convert nutrients into different types of proteins. And earlier studies have said that the mitochondria lead to aging. Swiss experts were able to identify the particular gene involved in this process.
by the way, right now the hysteria on the basis of mitochondrial... even movies about blue and green pills to mitochondria... about shpienov :)<
Хастред
Post by Хастред » Fri May 24, 2013 15:42
Sedna was charging the bracelet itself with modules for charge, Braley lay side by side on each other, made 3 passes of the modules somewhere for 3 hours on average. I wanted to know how did I do? because 1 is doing. I would acharnae would himself feel if he works or not but it is on my hand nenalazit little. Please look at the picture who have svobodnoe time.
http://dxloo.com/syar/peredacha/br_2.jpg
And escho. yesterday was naldeul to a photo of his garden through the generator iMedia programa panacea (2) and health program, with the purpose to protect plants from pests (aphids I have many divorced). here in the process of blending when I stared at the photo with matrix thinking what she has to do something to feel discomfort in the area of the bracelet. I'm feeling that it works, the more he presses into the hands of those stronger than he is involved poidee, so that each following matrix this discomfort increased (bracelet 2.1)., ussal in hand исн1 stale just not so much shake hands and then it's somewhere prodlitsya half an hour, gradually dropping to no. The question why exactly he began work if he sort of fiction involved, I'm matrix, the panacea of thought and not the bracelet's own when the program was put? I was not able to screw it up somehow?
Post by Михаил_ » Fri May 24, 2013 17:09
The zombies here (briefly) yesterday, and long - write is not very desirable and there's no time.
There is a threshold up to which the potential of the body holds all the norm, and beyond which, the destructive factors of the body gradually begin to break (age).
Secondary signs seen on the same body temperature (lowest is less).
"psychosis" with the mitochondria - specific. Declared a new era - epoca wide introduction of different innovations that had recently been shelved. Control mechanisms in a digital society now, you can use other.
And there are people (and not people) who know that this topic (mitochondria) can give them years and centuries of life. But they absolutely do not want to live humanly, want to the years a tablet or more than.
In the article they write that shocking (suppressing) mitichondria received a significant change in the degradation processes. I can assure that other processes were affected little or not at all.
It's very difficult in this topic if you dig into the history and if I start to tell, will take it as a tale.
In General, the number of mitochondria - changeable, as in cells there are many modes of operation.
For example, the cleaning of cells in the dry starvation mode and eating heavy meals - it is something very, very different.
With a minimum of light power of f-tion of mitochondria and their number keep on changing in a natural way. Without shock with antibiotics.
I thought it was obvious, especially to those who tried to change your diet and studied the inner eye processes in cells.
Do yourself a "threshold" effect can be compared with the preservation of the structure of water (by the way the process is very close). There are some types of structured water, which "erased" themselves. How many don't. But if you create a strong external background can be erased.
And there are those that are stored only a short time (the signal there is not natural and not clear) with the cells and health - about the same garbage.
Don't know how else to explain the way to make it clear. I thought that for those who in the subject, in my post immediately clear.<
Друид
Been thanked: 3 times
Post by Друид » Fri May 24, 2013 17:18
Хастред wrote:how did I do?
unity turned out
Хастред wrote:I was not able to screw it up somehow?
no
Хастред wrote:Question why exactly it started to work
ktozh except you knows that. or do you think that there is someone to do nothing and he will perform a full scan of you, your relationships and goals? unlikely. usually the man himself knows what happened. you just need to believe yourself more.
Хастред wrote:(I have a lot of aphids divorced
I suspect that you incorrectly run a household, hence the pests and low yield. please note, Sepp Holzer, as he suggests that you keep a vegetable garden. (key word "Permaculture", Sepp Holzer) on the tracker there are books and videos
what does this forum topic have to do with your question. for this there are technical issues.
Анор
Post by Анор » Fri May 24, 2013 17:50
Michael, thank you for the quick response.
1. ...
2. About the essence of the phenomenon I think that all the same I'm right, since the chopper in the air has such force as in interaction with their own kind at a close distance. Moreover, if you turn the ebony disc for example in a dry room, it will also be electrified (static).
3. Well to change the other person does not make sense to even try.
4. Yes you are right. Other material will be more effective and it is really dangerous. Because even on this chopper I felt a strong impact to your body - heart began to fail shes after a long use of this unit in the immediate vicinity.
5. That in any phenomenon is primarily a man it is natural. A good "operator" and the turntable is not needed :)
By the way recently finished the latest version:
If anyone should make contact.
Wanted to ask a question about sodium thiosulfate.
Began to take. Toilet treatments - all according to plan. But consciousness is happening, something is not right. So covers me for lunch (after a morning reception) that I can't think. Cannot concentrate on anything, all a blur.
Is this normal?
Post by ЗОМБИ » Fri May 24, 2013 20:30
Michael_
To not much to write you can answer Yes/no according to the numbers of questions and points.
1.
secondary signs seen on the same body temperature (lowest is less).
I understand that it is the decrease in basal metabolism?
(Athletes main exchange alone reduced, especially, in my opinion, sports endurance and strength endurance... i.e. security forces and players are not affected)
2. To increase resource of the organism is necessary
and. To increase the number of mitochondria and optimize their work
b. To reduce the number of mitochondria and optimize their work
V. to Reduce the number of mitochondria
3.
In article writing that shocking (suppressing) the mitochondria - received a significant change in the degradation processes. I can assure that other processes were affected little or not at all.
After the shock of the mitochondria became more or less?
Their number has changed dramatically and remained at this level or drastically changed and then gradually/abruptly returned to normal or became higher than normal?
(although, how do you know you're not doing an experiment... but, at least in theory, what should happen? )
http://video.yandex.ru/users/johnlord/view/5/#
please view a lecture there about mitochondria, about the inhibition of nefas release of hydrogen peroxide by mitochondria, which in turn causes the inhibition of breathing (work) mitochondria... what is nefas, I still entered...
interestingly, Dmitry Shamenkov, Yuri Bulanov promote periodic limit hypoxic respiratory training... ie. roughly speaking, the limit of breath-holding, and as far as I understand it, Demenkov says that it is necessary after the limit delay to do from hyperventilation (e.g. kapalabhati), and Bulanov says that it is necessary, after a delay of not in a hurry to catch my breath, and as long as you can keep hypoxia...
in the event of extreme delays there is something going on with C-AMP and run the biogenesis of mitochondria...
also Bulanov claims that muscle hypertrophy is much faster maratonci in runners, swimmers and other tough dudes because they have mitochondria in cells are many and they can be quick to provide energy to build muscle fibers...
if you start from this statement, the system Wuxi directed to the initial increase in the number of mitochondria in cells with conditionally periodic full exhaustion of the muscles, which leads to an increase in the number of mitochondria... and then to increase the mass of muscle fiber... nutrients to think is also stored in the muscles... anyway
(I wonder what would happen if at the end of each of the limit approach as soon as the maximum breath... I tried several times... the extreme of this)
on the other hand Frolov (which went fabulously at the end of life died, like from cancer) recommends doing a long training with prolonged hypoxia with hypercapnia, as well Frolov taken every day at night vegetable oil with vodka, and this, as I understand it, esterified fats get... why is he drinking the oil+vodka, breathed through the apparatus for a long time and did it all before the night decrease in basal metabolism I don't understand...
4.
and. In the mode of dry fasting the number of mitochondria decreases?
b. In the mode of devouring heavy meals the number of mitochondria increases?
5.
At minimum light power of f-tion of mitochondria and their number keep on changing in a natural way. Without shock with antibiotics.
The number of mit-iy reduced function stabiliziruemost?
The number of mit-iy increases, the function stabiliziruemost?
(.... By the way, someone Zholondz writes in one of his books that the low-calorie diets and vegans are constantly being driven through the body lactic acid as an energy source... this brain energy usually does not reach :) )
6.
it's very difficult in this topic if you dig into the history and if I start to tell, will take it as a tale.
I'm all ears, want to hear a story!
(About that early mitochondria were parasite I've heard from maverik... says spare me 2-3 kilos of this muck :) )
7.
I have no clue. But there is no desire to tear off the bat. For example, raw food experiments no desire to waste resources because you never know... it could be worse... and then there are people on hunger also deceiving yourself that cleaning is a crisis, everything is back to normal... and then, I apologize (really) die of stupidity...
If off, let's move on to the chemistry of the body
Will soon be thrown to the forum a few books Garbuzova... in the last he writes about mitochondria and about membrane potentials in the nucleus and on the outside of the cell membrane, and the protons of hydrogen and about... cations the most important practical methods offers
(uscany only places the topic of water)
I beg you to read his book and write your opinion... because you're a chemist... here's Andrei Patrushev will be asked to Express an opinion... he is also a chemist.<
Post by Михаил_ » Fri May 24, 2013 23:05
1.there is one problem, there are a number of processes, especially in the body (but not only) which through logic and "physics of the process" does not understand. Thanks for the list of questions I leave unanswered, no time to answer, especially, to go to another branch, the more my answers spawn more questions....
2. You see those roots in different processes, and many people naturally (based on the same approach) - well mistaken.
So the conversation until and at the current level of interaction and experience - just meaningless.
The same change of power, many (at least of my friends) do not come from the head, and from the hard body needs energy. From the inability to eat differently.
Post by Михаил_ » Fri May 24, 2013 23:06
And a dream, You would not believe.
Анор
Post by Анор » Tue May 28, 2013 11:34
Michael, wanted to ask a question about sodium thiosulfate.
Is this normal?
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue May 28, 2013 12:00
Moon
Post by Moon » Tue May 28, 2013 15:12
Zombies
This many times:)
And looks like "persuade me to become a raw-foodists"
Not afraid:)
Become raw-foodists:)
Post by ЗОМБИ » Thu May 30, 2013 16:04
Moon
me to persuade is not necessary... I need the essence of things... for those who like to blindly believe there is a Church, for example...
Allah-Akbar in truth Akbar :o
Post by Михаил_ » Thu May 30, 2013 16:27
and there is just no blind believers, so you are not yet here.
Don't confuse one with the other. Have the feelies this and it is something, as yourself - do not be fooled :) most now came to the change of diet, not from someone else's assurances and texts.
As for explanations, they are all there, and in the huge mass, certainly not in the form of a perfect alternative of pattern only, but a sufficient number of pieces of the "puzzle" to figure it out. And personally for You these parts are one again describe will not. All information so collected. Actually what I wrote Moon You personally to persuade, to convince and to provide examples and theories is, too.
Udosuzhtes to study the subject or discuss it. I do not care (in contrast to the same Church) what You can eat and what You will continue. There are many billion people in the world, I have been far from hysterical attempts to try to help everyone.
Moon
Post by Moon » Thu May 30, 2013 16:29
ЗОМБИ wrote:Moon
Inshallah :o
While You are a Zombie in the process hearken sex life will be:)
And Your body will: not be restored:)
And it is possible to simultaneously grasp and trying.:) on their carcass
Post by Михаил_ » Thu May 30, 2013 16:49
yeah, to hell with him, reincarnare ever if there is one.
I remember there was a surgeon, a specialist in techniques of longevity, in INM from norbekova for a VIP-Ah equipment given name was David Vazgenovich,
he loved to say "... Saravillo...., well, not scared, you die, we will miss :)" :)
it makes sense to him personally to make a fuss? it will be interesting - will study the subject scientifically and practically. And the kiss - so I feel that his body actually need (maybe) and maybe to him this trend is already on the drum. I love people, and because of time tinkering with personalities-sorry. Otherwise, for others who really need will remain. So, advice from years of experience. Wasting time makes sense only in the closest and not at all in a reasonable range, without turning their life into ensuring their influence "simulacija".
