The CHEMISTRY of the body and not only
red,
according to Sechenov, excessive stimulation leads to inhibition and Vice versa. Fatigue is only one of the possible factors. Caffeine acts on vegetation, and then there are the Central nervous system. So another reason could be desynchronization of the autonomic and Central nervous systems....
In Your last reply, thanks. I'll work more on information
And questions such:
You took Nootropics? If Yes, what:
a) described in the article, the link which You gave
b) other
c) and described in the article and other
And questions such:
b) other
Wait. In this case, I stage of agitation do not feel at all. The adoption of caffeine immediately leads to inhibition.
Could it be that the desire to squeeze out of gas is not possible as the pedals are burned?
Like drugs, porn, alcohol, and also write that and coffee, if you drink a lot?
I mainly Ginkgo Biloba 120 (Evalar) burst,
Once the flu and I had to put Semax. Sonny Semax very helpful session to take (there in addition to cognitive functions, in the form of side effects - improved mood and decreased anxiety).
Piracetam and others like it have bad effects (liver, kidneys). Phenotropil besides the side effects, still requires a cautious approach to dosage, and then comes some opposite effect. Q10 do not understand how it works - nothing particularly noticed.
I would not recommend anything there, if not, that is to say, testimony. Much more effective to develop the brain through training.
I am writing that vegetatie and Central nervous system may be in disarray. For example, the CNS - inhibition (chronic fatigue, the effects of head injury, prolonged high temperatures, etc.), vegetatio - excitation. Taking caffeine, You give additional excitement vegetatie, with the result that it is braking. Something like that.рыжая wrote: ↑Fri Aug 23, 2019 16:25Wait. In this case, I stage of agitation do not feel at all. The adoption of caffeine immediately leads to inhibition.
Well, I don't understandАндрей Патрушев wrote: ↑Fri Aug 23, 2019 16:32I mainly Ginkgo Biloba 120 (Evalar) burst,alternating with Kapilam - 15/15. What to do - age....
And there, and there change the chemical composition. And what's the difference? The release into the blood much more efficiently.
I see You the memory, the memorizing beat. About age you know. Heart, liver, kidneys. By the way, I milk Thistle, premalatha into a powder very quickly cleanse the liver from intoxication. Almost immediately the action.
Well, that and I don't understand what You want to say.
No, more on the blood vessels (bad heredity).
No, I do not understand
Andrew, I understand:))
In the article on the link You gave, about q10 is it written that directly affects the processes of energy in the body, ATP. And You wrote that as the effects are not noticed. And You long for his drinking? In which dosage?
redI do not remember...
Maybe affected. Better get used to it.
