Stabilizer.
Шломо
Been thanked: 3 times
Re: The Stabilizer.
Post by Шломо » Sat Oct 15, 2011 3:20
Михаил_ wrote:TO have all of our commercial products if I didn't forget anything.
Pour stoppage in stabilizer is absolutely not necessary. Then how to remove? :)
do all the components of the stabilizer as a separate product kind of makes no sense. Ie, wear them separately ... I don't know for what.
And make the glass parts of the stabilizer will be expensive however. Ie you can. But expensive. There is no demand but....
we don't need another whole pack of scheduled products need to produce.
The remains of a series of aircraft, and the extensions in EK is a very interesting face and so on...
So just experiment with the Stabilizer in the glass.
Although in General it would be possible at all to make a mega-regulator into a big glass, but it will have new technology to create...
Yeah glass cast stabilizer probably even more beautiful would be it!Perhaps on the basis of your ideas can be super to build a house:a room of cubes stop magic,to another floor of the ISB-3,pool from Q....something I have pantanoso the impact of an overactive imagination. Michael,and extension at EK? tell us a little bit(if you have time) interesting fact!
Re: The Stabilizer.
Post by Михаил_ » Sat Oct 15, 2011 15:31
We are preparing for two options portable EK.
One variant of the format "sleeping bag active" with external power supply :)
The second option - the bathroom.
Describe later ACC. section. At the moment the main problem is the purchase of components and some other expensive part. Ie and decent attachments and fuss a lot organizational. And what will this on sale and while it is not clear in the first place, as always do for yourself, and see what happens.
Faced with a number of interesting moments on this account.
Stabilizer glass to do you can try, but it is better to use donnamoderna fillers (less chance that will break under the strain of its own work)
Шломо
Re: The Stabilizer.
Post by Шломо » Sat Oct 15, 2011 20:47
You just inspire from gray casual autumn days!
Yes to glass stabilizer probably need glass and very durable!
Although # 1 of the glass.
Re: The Stabilizer.
Post by Михаил_ » Sun Oct 16, 2011 18:45
do not understand, what is the number 1 made out of glass?
Has thanked: 5 times
Been thanked: 8 times
Re: The Stabilizer.
Post by Воффка » Sun Oct 16, 2011 22:16
http://www.fayloobmennik.net/1074805 password: 222 link to archive file augmented with mandalas placed on A4 format. Please note that all mandalas designed directly for the manufacture of the stabilizer (except "stabilizer base" that is glued first, it on A4 no, but in General, the present) are in the order that in which they have to stick in the manufacture of :)
Шломо
Re: The Stabilizer.
Post by Шломо » Mon Oct 17, 2011 1:00
N1
N1 - a product number one in the series N.
N-is derived from the title interior line projects "N" series, which is a joint development of our team and our colleagues in the field of information water and other interesting things.
Re: The Stabilizer.
Post by Михаил_ » Mon Oct 17, 2011 19:41
Well, it's different. I.e. it has a stabilizing factors in, but that is not a stabilizer in the sense of the instrument stabilizer. Ie is built completely different. So to steklyannoi of the topic - in any way. However, these trinkets have just mentioned drawback sometimes can form cracks and / or chips for no apparent reason. That actually says that it paid for itself :) for wearing :) but I would like to walewale. While there is no suitable fabrication technology.
Малыш
Re: The Stabilizer.
Post by Малыш » Tue Oct 18, 2011 1:49
well then stick it to some metal framing on their own or a nearby jeweler that would not have collapsed in the hands
Малыш
Re: The Stabilizer.
Post by Малыш » Tue Oct 18, 2011 2:04
Michael, please tell me, paper the regulator is cut out with round or so on a normal sheet of paper (rectangular) to draw and write? recruited a large number of those W paper stabilizers, around the house they are not going to leave as is permissible to store such stabilizers are mounted with anchors that would not be influenced by each other , the pile will be okay?
Re: The Stabilizer.
Post by Михаил_ » Tue Oct 18, 2011 15:05
1. you can not cut.
2. in the pile, if observed orientation of the axes
4. the jeweler here is not very helpful, a good solution to make so that did not burst at all, but crack (depends on load) any materials of conventional origin. Crack only artificially simulated, but we still it is not available on the level of technology.
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Re: The Stabilizer.
Post by Ланцелот » Tue Oct 18, 2011 21:19
Михаил_ wrote:However, these trinkets have just mentioned drawback sometimes can form cracks and / or chips for no apparent reason. That actually says that it paid for itself :) for wearing :)
When the protective amulet the "work", he goes from wearing it, disappears, disappears. Watched it several times.
Can chips and cracks in key chains emerge for the same reason?
Has thanked: 24 times
Been thanked: 142 times
Re: The Stabilizer.
Post by Маг.нет » Tue Oct 18, 2011 21:30
Compensation of internal stresses....
Михаил_ wrote:Pay attention to using key chains series at. They are certainly convenient to hang on keys (including AK designed for this purpose), but the possibility of their physical destruction method of breaking increases. All of the same glass.... glass program beats lighter for the same reason that exploding gum on BJ - even when there is a particular tough situation might not be noticeable strained by the vector of action of the product.
Often (especially if trinkets a 1st), it's a good idea to leave the FOB in the pouch supplied. It can be tied "tighter" in the area of his neck, releasing him from the ring. We introduce, in spite of these recommendations of the special exchange rate on keychains, but only for already purchased from (this modification). While most are breakable buttons from HELL because the bowl is further enhanced.
However, I also want to note that we now check the key fobs twice, after the production (they are visiting there, too), as obtained in one lot (but in bags), different types of trinkets. And the second time while sending. Therefore, the presence of defects of production are virtually eliminated. If You find so - and-so is the result of a keychain with You.
here
Sincerely, MAG.no
Re: The Stabilizer.
Post by Михаил_ » Wed Oct 19, 2011 20:20
1. Yes you can, but the functionality they do not lose, even if it remains only a piece of it. Power may slightly drop if the mass is decreased.
2. the disappearance and emergence of subjects not necessarily related to their intervention. This is often a problem of some kind related to the divorce of inconsistencies in the probabilities or even of internal phenomena in the head and in the world view of the operator. Such a lot of time watching different people, then these items can appear and be gone again and the flashing is constant. I.e. the effect of "loss" often associated with certain other processes.
By the way, in some cases, anomalies can not be over.
However, on our key chains like this flashing is minimized (well, since it is not convenient however) due to the stabilizing effect of CO, which supports communication with the operator and other components in the system.
ВитЗлат
Has thanked: 4 times
Re: The Stabilizer.
Post by ВитЗлат » Thu Oct 27, 2011 19:16
Hello, dear friends!
Printed paper version of the stabilizer, put the anchor itself in the center, a feeling of pleasant tranquility, and as it became more comfortable. Swung it on a metal tray 50 cm, but the scope is confused, for a long time with epoxy didn't work. Decided to make the stabilizer less than 24 cm, for one and rack up experience and work with it more convenient in the drawer to put. Reading the previous posts about KO, came up with the idea, recently broke a wooden (Crimean) bracelet 2.0 that if the base is Druze amethyst stick three links from the bracelet? Digest the stabilizer is TO or erase? If you digest, whether remaining parts of a stabilizer? Tell me who in the subject.
Thanks in advance for any advice. :)
Re: The Stabilizer.
Post by Михаил_ » Thu Oct 27, 2011 19:39
You can digest it in the following.
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Thu Oct 27, 2011 19:54
Wetzlar how to describe the results but do not forget, I have a link from the bracelet for one more is not know where to accommodate.
Шломо
Re: The Stabilizer.
Post by Шломо » Mon Oct 31, 2011 1:01
ВитЗлат wrote:Hello, dear friends!
throw please a reference where you can print the paper stabilizer
Шломо
Re: The Stabilizer.
Post by Шломо » Mon Oct 31, 2011 1:04
Michael,as you say to try to make paper stabilizer with a printed photo?
Re: The Stabilizer.
Post by Михаил_ » Mon Oct 31, 2011 4:18
not worth it.
Шломо
Re: The Stabilizer.
Post by Шломо » Mon Oct 31, 2011 16:29
Dear Michael! why not make a release of the stabilizer instead of paper of plastic for example? after all, when the specialist produces,you get much more effective than when he kolobot what to do,hurt yourself and loved ones.
Re: The Stabilizer.
Post by Маг.нет » Mon Oct 31, 2011 16:40
Think about what "should not", Michael_ answered about print Stabilizer light on your pictures or pictures of the Stabilizer, it is of course superfluous.
If You mean the manufacturer fotoprint, the necessary elements here.
Rules of placing "borders and zones" here.
Procurement (and references to sources) above on the same and previous page, where Your question, in posts User Voffka.
Sincerely, MAG.no
Шломо
Re: The Stabilizer.
Post by Шломо » Mon Oct 31, 2011 16:47
Маг.нет wrote:Think about what "should not", Michael_ answered about print Stabilizer light on your pictures or pictures of the Stabilizer, it is of course superfluous.
thank you for understanding,just rebooted again,so, uh, confused here
Шломо
Re: The Stabilizer.
Post by Шломо » Mon Oct 31, 2011 20:01
Dear MAG.no! I think that certainly you have the experience of using handmade and commercial STB,can you describe the difference:pros,cons?Thanks in advance.
Re: The Stabilizer.
Post by Маг.нет » Mon Oct 31, 2011 20:45
But in this matter in any way. The fact that I have the commercial version came long before the Regulator-and therefore light Stabilizers-light are not perceived as individual products and as one of the extension Stabilizer H. Ie immediately fits into the overall structure, so it is difficult to correctly judge the effectiveness of homemade products, but I they also are beneficial when used as a "remote control unit" of the Stabilizer N, and the structuring of space in the workplace.
Sincerely, MAG.no
Борис_
Re: The Stabilizer.
Post by Борис_ » Thu Nov 03, 2011 13:12
Actually, the situation is often such that the person is not synchronized in any way the task of self-realization and financial success. Ie it turns out that the success of this kind of duty (a close word - a burden), and self-actualization generally retracted where a=the 10th plan. Or something like that.
But it would be nice to match at least partially.
Here I think -What and where to put the anchor what would I think of an interesting case.
Maybe to start something like "creative ideas" in the zone "Development" ?
