CD "brain Massage"
Свиатослав
Andrew, I want to listen to the disc in the car on the way to work (of course I'm a passenger
). Do you think maybe in such a situation, to relax and to get a result from listening or it is better to listen to at home in peace and quiet?By the way,what's your radio (in the car) can be left on or off?
"Who have multiplied those who have not - taken the last..."лиза wrote:And have we not set ourselves almost every day some purpose? And not trying to achieve them? Wash it happens very often. Or are due to some dolgoletiya? For example to build a house,or learn three languages at once, or to find new or to unravel what is written on the Phaistos disk? What goals need to train? The same applies to kazhdodnevno and long lasting? Prvilno I understand?
The ability to set goals and consistently achieve them is developed not all. Some even momentary purpose, learn with difficulty... the Key element here is voluntary attention, which, incidentally, also meet the frontal lobes.
After any massage you should calmly take a NAP, completely relaxed, 15-20 minutes...Арамис wrote:Andrew, I want to listen to the disc in the car on the way to work (of course I'm a passenger). Do you think maybe in such a situation, to relax and to get a result from listening or it is better to listen to at home in peace and quiet?By the way,what's your radio (in the car) can be left on or off?
1. I like the sound of MM.
2. What is this ringing in my ears: People! So it's headphones!!! Try it without the headphones through the speakers to listen to!!! Pressure on the brain and ringing will not.
3. I want to do, to create , to help... something that previously was too lazy. In this I agree with Lisa.
4. Mood - super! I do not go, I fly! I feel good, I don't know negative, I'm open!
5. Need to listen to in the morning after sleeping on an empty stomach (!) the body should satisfy the need for sleep. The main thing is relaxation and not fall asleep.
6. There are no side effects. Maybe I'm doing it right?
7. For me, a lot has changed, but I don't know whether this is due to MM. No one knows... But this is my period accidentally coincided with the moment when I started to listen to MM. Make your own conclusions!
PS. Lisa! The girls all know how to talk behind the wheel, and eyes on the road, only when it is necessary to turn. I personally, when passing near the bridge - look over the landscape. But you carry the baby. It is worth considering. Our attention piggy Bank. If we spend it in parallel to other objects - it decreases on the road. It is a fact.
I wish you all success!
Вася Пупкин
Please read the recommendations written on the box of the CD "to Listen ONLY in the headphones"!!!!Children under 14 years listen to this disc is not recommended.Anonymous wrote:Hello! I have a question: how does this music on the brain 3 x lengoiboni? how? just I can only listen to MM when my child sleeps in this Recanati. in this regard, I am interested in having him do some action (I'm listening through the speakers) for the answer thanks in advance!
Аноним
I have a question to Andrey Patrushev. Listened to two days of MM through the machine with glasses of colortrak. The volume had to be put slightly above average, but they plowed the only way. And then read on the forum that the disc is MM without audiostrobe. I understand that the points worked from an excess of high frequencies. So the question is - not whether the negative effect of this combination? The sensations I liked, but that's how it will manifest in the long term, given that the disk is specially made without audiostrobe?
It turned out just LumiereНиккей wrote:I Have a question to Andrey Patrushev. Listened to two days of MM through the machine with glasses of colortrak. The volume had to be put slightly above average, but they plowed the only way. And then read on the forum that the disc is MM without audiostrobe. I understand that the points worked from an excess of high frequencies. So the question is - not whether the negative effect of this combination? The sensations I liked, but that's how it will manifest in the long term, given that the disk is specially made without audiostrobe?
Two days later, on the third - to those who every day is too much.Никкей wrote:Oh, and one more question. On the forum wrote that to do with the MM ROM should be 2 days on the third. In the instructions to the disk is not written. Worked two days in a row and all very healthy, all sensations only in black.
Хабаргин Алексей
I have while listening to MM appears nervousness, muscle I'm driving, I want to stretch, start to turn over. In General feel uncomfortable. Proyavitsa it immediately, but somewhere in the middle of the session. Listen to the disc immediately after waking up. This is a temporary phenomenon? Once this is explained?
It is not necessary to lie still, it is possible to change the posture as You like. Louder does not mean better...Хабаргин Алексей wrote:I Have while listening to MM appears nervousness, muscle I'm driving, I want to stretch, start to turn over. In General feel uncomfortable. Proyavitsa it immediately, but somewhere in the middle of the session. Listen to the disc immediately after waking up. This is a temporary phenomenon? Once this is explained?
Алексей Ильич
Hello! please tell me purchased two of the disc massage the brain and theta-meditation-as fond of lucid dreams
last night would put an excerpt for dreams right when listening I suddenly felt as if my eyes started running the fly-even wanted to raise a hand to drive away
then abandoned this idea as they were sure that I have flies now no)
and this morning I discovered that my nervous TIC which had tortured and mutilated my face(constantly twitching left eyelid) passed!!!!!!
in principle the effect I'm satisfied-but as I understand this CD was not designed for such miracles))) is this normal or shouldn't be??
Yes, this happens often in trance States as You get access to resources, which in the normal state You were unavailable.Алексей Ильич wrote:Hello! please tell me purchased two of the disc massage the brain and theta-meditation-as fond of lucid dreams
Дарк
Question to Andrey Patrushev:
track with MM gave a listen to each, though not warned neither about water nor about the time or about everything else. Whether I forgot, or I don't know it all.. read on this forum. Listen through the speakers for the first time (good speakers - Microlab Solo 2, and source material in the format of the AAR, i.e. lossless), parallel to reading this thread. Effects: while listening amuletos some "movement" in different parts of the brain. Interesting. After about the mid-entered the ISS. Self-absorbed, quiet head, etc. And a very sour dry trees ) And just immediately read about the glass before, a glass after. Respectively turned out to have a drink just after. Was listening yesterday late afternoon (about 16 hours).
Noted the great drowsiness. Literally turned off immediately after listening because it was opportunity, dozed off for 15-20 minutes, but drowsiness is not passed. In the end, always want to sleep (with varying intensity) until the current moment. There is a suspicion that this is normal - going restructuring of the brain, as I understand it. And must pass. Tomorrow morning I will try to listen to it with headphones, in the morning after drinking water
The difference will try to post here. In General, the reviews delight - a must listen course. Thank you for your work!
PS the Question is a little not in the thread - you said that MM for astral is not intended, though some manage. OK. And are any of your disks just "adapted" to such things? If Yes, which ones?
Sometimes increased drowsiness and appetite after listening to the MM associated with the removal of the focus of pathological activity in the brain.Дарк wrote:a Question for Andrei Patrushev:
Noted the great drowsiness. Literally turned off immediately after listening because it was opportunity, dozed off for 15-20 minutes, but drowsiness is not passed. In the end, always want to sleep (with varying intensity) until the current moment. There is a suspicion that this is normal - going restructuring of the brain, as I understand it. And must pass. Tomorrow morning I will try to listen to it with headphones, in the morning after drinking waterThe difference will try to post here. In General, the reviews delight - a must listen course. Thank you for your work!
No special disks that I have.
Наталья2
Question to Andrei Patrushev: 6 years ago I had surgery to remove ependymoma the right lateral ventricle of the brain. Reading the forum, I would like You to know, what disc would You recommend to start treatment? Occasional epileptic seizures (2-3 times per year) in patients receiving anticonvulsant drugs, the left side of the body runs a bit worse (after the operation was paralysis). Sincerely, Natalia.
