Architecture GAIP. System products SAMM.
Integrated control technology a reality
Гуфест
Has thanked: 125 times
Been thanked: 120 times
Re: Architecture GAIP. System products SAMM.
Post by Гуфест » Mon May 08, 2017 15:49
Гуфест
Post by Гуфест » Mon May 08, 2017 16:10
the emotional center of not only his mental controlled ,but navedenim different ..and we are advanced all at his own expense and accept yourself starts ..
In the dream there are techniques which allow us to determine the presence in my head or in someone else's.The emotional center of something similar,you can be on someone else's emotions ,thinking and taking her for his own,learning to identify the affiliation (the author of the owner's emotions),you can take a step in the development of its important to understand why it is necessary to understand one day how the wind blows,you can work selectively.
Гуфест
Post by Гуфест » Mon May 08, 2017 16:15
rel
Guest, have apparently different "waves" of thinking - I'm here from time immemorial your writings can not read - some conglomeration of anything and everything, there are opinions-statements about everything, but without any clear rod
I cosmogramma pronounced Neptune, Pluto and Uranus.
раданов
Has thanked: 76 times
Been thanked: 72 times
Post by раданов » Mon May 08, 2017 18:27
rel wrote:where I wrote/expressed to someone "I hate you"?
brother radanov, maybe it is not necessary to believe in the word so soon))
in other words - the quote in the Studio! ))
meme beguiled :?
раданов
Post by раданов » Mon May 08, 2017 18:29
Милая wrote:the Artifact is a killer, as much from the monitor discards. In the work haven't tried?
all described results were evident after the soldering structures .ignite did not try ,yet previous experience digest )
раданов
Post by раданов » Mon May 08, 2017 19:18
Гуфест wrote:About the responsibility for drawing it you have bent or it's just not your job for its issue.
you see, about the responsibility for the information or heard .you said tsiforki write ,you write and enjoy .the more tsiferok and sketchbook more interesting ,huh ?
believe in my way a lot of different experience was ,not everyone wants to remember about the responsibility I know neponaslyshke people Hakala ,prescribed term of life and bore responsibility for it .
so you are not for me to decide ,bent or not bent .there are people empty ,catching the halo and a the old that do not understand that around them it was interesting to listen to .I put kernels from the husk will separate what can't vouch for everyone reading this thread .if necessary I information plan once you can dissect to see what's inside .
I described the process and posted a photo for those who own source code .what are the issues ?
the source and the source may not share the accusations of imposture little effect on me .
all there is in the world .look and obryaschesh
Гуфест wrote:I Think all pull the same code will not work.
and I do not need all ,but someone should –can pull
Гуфест wrote:National education can be considered the Nations created by the priests,sorcerers and alchemists,with headquarters somewhere in Syria.The national education, there are different races,several races, devoid of identification as hybrids.
kasha-Malasha .you'd better sort through what is available and then have a new old ate .just a tip .Guest ,no offense .I see –that I sing ..this is my personal opinion which I will not impose .want answer want not .but then our dialogue is futile ,may the story continue ,and our discussion I close my unilaterally so as not to clutter up the thread .
I don't talk for years with different teachers ,an alternative physicists ,medics and other .no guru among them was not found .
what deserves your attention m b does not deserve my .
basically all throw a seed-mozgovogo that indiscriminate eating and consider noteworthy . jammed adherents of indigestible amounts of information ,to disable the filters and critical thinking and adept became omnivores and sauce priming ate all that they give .
you where already stunned or he is omnivorous in nature .I did not eat it filter hard is particularly so infrequently here unsubscribe .share only your experience .<
Гуфест
Post by Гуфест » Mon May 08, 2017 20:46
and our discussion I close it unilaterally
You know better.I just wanted more information,well, you understand))no offense.
Джеймс
Has thanked: 12 times
Been thanked: 18 times
Post by Джеймс » Mon May 08, 2017 21:34
раданов wrote:card alchemy for a week very active
See also activity card Alchemy in recent years, especially in the morning. Dreams began to dream strange lately: childhood, children.garden, school... got a Little pain, thought lay down, turned on the package Body, the Microcosm and the Intuition to power, and not revealed signs of ailments, only the vivacity and freshness in mind. Shifted business activity, new customers. Noticed that you to change the settings you want 4 times a month.
Гуфест
Post by Гуфест » Mon May 08, 2017 21:40
Radanov
you where it is already stunned or he is omnivorous by nature
Radanov not to run out of the blue,you good tip.We assume that it is yours.
people hack ,prescribed term of life and bore responsibility for it .
What is not much for you that is held responsible,the responsibility usually starts when you least expect it.
Джеймс
Post by Джеймс » Mon May 08, 2017 21:43
Гуфест wrote:with headquarters somewhere in Syria
It turns out that the war in Syria - the struggle for "control panel"? :)
Гуфест
Post by Гуфест » Mon May 08, 2017 21:55
There's been all raskurochili.Those priests are no longer alive by age and how the system works and how to adjust ,there is no knowledge,and they are no longer relevant due to the new time technologies.
раданов
Post by раданов » Mon May 08, 2017 22:19
rel not you personally, just the topic ))the priest says the case and with humor ))
Гуфест
Post by Гуфест » Mon May 08, 2017 22:44
rela in Paradise would be?here so soon? would not let him go.The angels he will be for santista)).
Even the victim is not amiss,very clever.))
rel
Has thanked: 222 times
Been thanked: 84 times
Post by rel » Mon May 08, 2017 23:05
radanov, mercy, listen to the other day..
Batyushkov not sluhay a long time, but the brotherly tip check it out..
Guest, but why "there" to do while there, not the whole party? ;)
(A big Hello, a low bow and Grand Respect
all the Mahayana Bodhisattvas of Buddhism! )))
and why must "there"?
IMHO, Paradise where people are among themselves agreed
PS. by the way do not know the results of your tests (on the "riskest" this Loki)
but check out how the word 'idiot' I guess)
1. Idiot — in Ancient Greece, the citizen of the Polis, living in isolation from the public lifenot participate in the General meeting of the citizens of the Polis and other forms of state and public democratic control.
2. Idiot — a person suffering from a deep form of mental retardation (mental retardation) — idiocy.
Гуфест
Post by Гуфест » Mon May 08, 2017 23:09
Idiot-SEL))
Гуфест
Post by Гуфест » Tue May 09, 2017 12:51
Previously with the map of alchemy was like that,the fight around,and you here meanwhile, in bliss abide,it's a possible side effect from binding to something relevant as it seemed at the time.A private matter than attention to hold,as his personal study, or play in a virtual game after beating it and get paid idekit .There are 3,4,5 and so on to infinity variant lines.
раданов
Post by раданов » Tue May 09, 2017 14:50
rel wrote:Batyushkov not sluhay a long time, but the brotherly tip check it out..
similarly ..I looked at the tip
Сильван
Been thanked: 2 times
Post by Сильван » Tue May 09, 2017 17:53
Tell me where to read about the history of SAM and who is the author? :wiz
Милая
Has thanked: 257 times
Been thanked: 259 times
Post by Милая » Wed May 10, 2017 10:19
Sylvan
View here viewtopic.php?f=35&t=5686this topic will read first, and this viewtopic.php?f=35&t=5782
Check out Psychic-workshop viewtopic.php?f=35&t=5782 the club of self-development, there is a discussion viewtopic.php?f=55&t=5852
All threads in this section with questions and answers Auras will be useful, and other topics from the section on BRM. A lot :wiz but the point is, to understand, to apply, to observe, to relate and shape his vision is, of course, in General.
Specifically on history look at the first link, as I recall. That's all.
Even something that can "extract" from the descriptions of neocalanus 1 and 2, the outliner space, glucopon.
Aura
Has thanked: 22 times
Been thanked: 1124 times
Post by Aura » Thu May 11, 2017 15:27
раданов wrote:when was ready the file for printing suddenly wanted to turn the map around and it all came together .combined and ... matrix of alchemy fall right on the nodes of the structures !particularly evident in the 3rd .coincidence ..? ))
All coincidences are not accidental :) You can call the experiment “game closure”. In fact, you have created managed “Genie” that will clean up all pending processes at the first level. In such an artifact is quite hard, as numeric matrix of Alchemy work at all levels, and, for example, on the mental level, our “thoughts-racers” such ponadelat can... in General, created a simulator for perfection. The main thing – to maintain mobility and not get in “Groundhog day”...
раданов wrote:Aura, 3-4-8 this closure process ?
The active phase, the active, volitional efforts to go against the flow and through the removal of obstacles. Not the “easy” phase. The ending was apparently your intention, which is to pass the active phase.
Aura
Post by Aura » Thu May 11, 2017 15:52
rel wrote:I'm on that "Paradise" is impossible to name a world in which most of the people close to you is suffering..
world full of lies and betrayal..
Гуфест wrote: Previously with the map of alchemy was like that,the fight around,and you here meanwhile, in bliss abide,it's a possible side effect from binding to something relevant as it seemed at the time.
All that certain frequency settings, which give different States, and it is impossible to say what kind of "better" or "worse". "Better" when the knob is in the hands of the operator. At the same time proanonsirovat our new design, which you can use to deal with their conditions and to keep the right. Let's say, a new product is a scale of some need for different situations of States of tuning in which consciousness more successfully solves the current problems and on time allows you to come up out of the pool UN-understandable or securelythey States, or just nesootvetstviya current tasks. Some wise people say a problem cannot be resolved at that level of consciousness where it was created, or just sometimes we dig deeper and deeper, but not in the area where the solution is, but for migration we need a "beacon." The new product is a collection of such useful indicators, each of which is a separate instrument, plus one custom cartridge, recording conditions, and together they develop a custom map to "navigate" and change scope. Plus one important cartridge in a new product - protective.
Gorius08
Has thanked: 4 times
Been thanked: 17 times
Post by Gorius08 » Sat May 13, 2017 15:53
On the topic States want to stop the theme of the day for me, and everyday. And announced the device above will probably be useful to me. They are so diverse that it never ceases to amaze. The two extreme points attract more attention, so it turns out. And perhaps even they seem to be the opposite. The view from the outside. One of them is such a naive, kind, open, ready to pay the last, to draw love, i.e. I love, suddenly became), bakes cookies, and how to communicates with people, sometimes without words, people look and forget to say Hello, their eyes glowing. Not all and not always true, but there is such a phenomenon. Explain who knows, and why so. But who knows, noticed, not too much of a hurry to explain. Again two ways you can understand. In words, telling the truth is difficult to convey. There's this opinion that it is necessary to read between the lines and listen between the words that seems like it's the truth. Want trust, want check. To cry maybe even in the wrong place sometimes, it's a different story altogether. A sense of empathy, unity, a lot of interesting stories on this soil occurs. This musician, Yanni, discovered, dragged under it, especially in a time like this is, where the girl plays the violin, and the boy on the saxophone, play together, take turns, one starts the other continues, so beautiful, harmonious, rhythm. And the world says: to To all this ... And there is another point, called darkness, is not all positive, the clouds frowned, body aches, his head a mess. I always thought that it is the prerogative of women mainly cheat themselves a lot, even laughing sometimes over them for good, calmed, turns out I can do it too, so much so that out then does not work quickly, and understand this, you see, not what to sing and draw at such times, do not want anything. Suspicion, misunderstanding. Your posts seem to be nonsense, considering their very different angle. Criticism, analysis. Dark. And the world says, To To and have.. Like cycles there are any up, down, up, down. And thoughts to amplify it can and pendulum in one position longer hold. A breath of fresh air and again went up. Re-read your message, find a lot of new. Somewhere please a question then find the answer and realize that he, and the body feels a thread where some comments where you know that someone wants to reach out to you, knocking, trying to draw attention to themselves, and so happy, if it fails, the arguments are divided. Take this opportunity to encourage everyone to take notes, keep a diary of personal observations yourself, discover new things, this is a very useful vesch has been said many times, but we all so lazy. Find the answers, and sometimes questions which are then in the process find the answers, in life, in communication, some random bum sometimes throw out the phrase, itself not knowing why, and she the topic have developed mosaic, the puzzle is completed, America is open, thanks to him. Don't know, LON, on account of the bad and outline. I wonder how you're doing with the tattoo situation is contrived or not. There is a desire - tell. Radanov thanks for the video, with humor, really. Little writing, a little blogging! Read, it is a pity that-whether :)<
Gorius08
Post by Gorius08 » Mon May 15, 2017 6:06
Very interesting as periods occurs like another world, it's really an altered state of consciousness. Sounds to hear a different, three-dimensional, living, the picture changes a little. The feeling is completely different, a pleasant state of languor. Breathe nice. The whole world is alive. Caught :)
раданов
Post by раданов » Tue May 16, 2017 1:40
Аура wrote:Ordinary people can act as implementers of the interests of one group or another, like puppets, without understanding the motives of action.
how much in this case, can damage the ordinary people -puppets ?and how to distinguish interests of a group are normal people ?
раданов
Post by раданов » Tue May 16, 2017 1:48
Gorius08
