AMB - a product which seems to be there :)
Re: AMB - product of which seems to be there :)
Post by Михаил_ » Thu Apr 17, 2014 12:54
It is not necessary to AMB animals. NOT
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Thu Apr 17, 2014 16:10
Thank You, Michael_ ! All clear.
АлексейН wrote:Yes, what You pigs do not hit? :)
Recovering slowly - only three days as the images of cucumbers(for some reason only the short) again began to send...
Post by Михаил_ » Thu Apr 17, 2014 16:44
Wants other :) more correct in the genome of cucumber :) hihi
Post by Михаил_ » Thu Apr 17, 2014 16:48
AMB in its principle contains a certain modification of the PC, and PC is applicable only to people (or very intelligent beings, essentially the same level of reasonableness).
Post by АндрейКо » Wed Apr 23, 2014 0:52
Василий wrote:3. Prepare for the impossible, which will come into your life just like that and suddenly become everyday reality. Get ready for an absolutely non-trivial situations, the analogue of which was not in your life...
Here here! and I have started! Have to work 13 hours a day while still with 1 day off per week. After more than a year experience with AMB!(missing 2 AMB) Interestingly, the largest assistance-assisting people who already in this life had experienced severe crises (the probability of a cure according to official medicine, 1/1000...) has changed and completely changed the sphere of activity.
PS - with the mumps just fine without the SBA - became too independent - very strange. Tried today for the first time avocados - live ;-)
Алсемо
Been thanked: 21 times
Post by Алсемо » Mon Apr 28, 2014 14:43
4 AMB carry 11.03.2014 constantly. I want to note that sufficiently large event and small event, with action nothing happens, a non-trivial too. There are prerequisites to a major change in the quality of life, but they were informed, as well as the desired swirling events around it, and the result is always postponed, postponed. Health all as it was great. Those abilities that have been dulled. Changed a bit the attitude, not words. The business is also not affected, as the same around and in his hands is not. BRM quartz, too, has not produced results yet. Also feel the "plug" in, but with the feeling that she started moving with the trend on the flight. Quantitative and qualitative indicators in life yet, but this is just to measure the action of AMB.
It is possible to throw that was not enough time to integrate to open up the instrument, but given my General physical and other development should manifest brighter!
Just noticed that the information from the author about AMB minimum. Just the General feeling of testing, changing, sleep time and quality of nutrition, as well as the intriguing experience of a stranger with the drive and action from the use of AMB+AMB stream.
Michael, open question about AMB wider, it is time!
Exactly how by means of the AMB, you can play with reality?
From your point of view, as in my case need time to move from a dead point to "brake unlock" (you're monitored)?
Thank you!
Post by Михаил_ » Mon Apr 28, 2014 20:08
1; I already wrote that information about AMB enough.
2. Have no idea how much time You have because of your approach I have a feeling that the first may very much time will be spent on a modification of the approach.
3. I STRONGLY recommend the use of BRM on a permanent basis (permanent wearing).
Post by Михаил_ » Mon Apr 28, 2014 20:21
4. AMB is a tool to ensure that your relationship with the world was light and casual... Many people wrote reviews and have been in a very "ready" state in the sense of private freedom, that is. If sosanie otherwise, it will gradually change, as long as it will take a year or two or ten and it is purely individual.
No, there can be there are definitions, but in this process You may like to stop and help... I have a suspicion that You are at least not helping, at least that You have some urgent expectations, which by themselves are not a plus for the process that should be let go.
Actually, I was sure that it is clear that the opinions of individuals not the marker about what You will do the same or someone as well.
AMB is made so that it can work from the beginner. however, he will first be closer to 2_2 or the panacea, but several dinamichnee harder and faster.
Алсемо
Post by Алсемо » Tue Apr 29, 2014 7:50
On account of the urgent expectations, you are right. To release desired for me is VERY difficult, especially when much need! And way to go, for me personally, but many do not pick up yet.
Why BRM do not recommend regular use and how often to use it?
Post by Михаил_ » Tue Apr 29, 2014 8:48
about BRM - any crystalline structure in the zone of the cocoon is inordinate and harmful education in most cases. with any not recommend, but if you are using, then at least not constantly.... if AMB restores the cocoon, such things deform. The effects from them can be bright, but is it necessary for them to pay the price ( in terms of potential consequences ) ? I was not clear... I think there are no cases when you need to.
Well, if you are using, then dispense it as "practice" not more than a few hours per day and intermittently.
I wrote about crystals many times, including for a long time even in topics about all sorts of cakes orgone and others like them. The correct mono-crystals are the most dangerous in this respect. here the crystal is microscopic, but it made the device significantly increases its efficiency.
Efficiency first and foremost as a kind of self-consciousness, which is not exactly the same as yours. You need symbiosis?
ПрактикОМ
Post by ПрактикОМ » Tue Apr 29, 2014 10:41
Michael, what You say about tourmaline? It generates a huge amount of negatively charged ions. An endless source of energy. And when worn close to the body, they reveal the effects of recovery and so forth. Now it has become very popular, based on it produces a wide range of products for health, including the American powerbalance bracelet.
And if not difficult, throw off someone please link to the topic where Michael wrote about the crystals.
Алсемо
Post by Алсемо » Tue Apr 29, 2014 12:12
Symbiosis in favor of a crystal is not needed. That is, BRM can get some of the energy and therefore the interaction man - AMB is not correct?
The night kitty is one year old, tricolor sitting on the window sill and trying to climb through the window. It happened once to break. What he wants is unclear, fed. It's the evening and he did not give up. Something wants to say, but I do not understand it. Red-haired little girl pulled him to play, and he moved to nearby my window sill, from where not to get. Those who have experienced and understand? Also in the mountains the bird podrygala to the arm 7, see Here wrote about a similar case.
ЕленаР
Has thanked: 30 times
Post by ЕленаР » Tue Apr 29, 2014 13:46
Алсемо wrote: night kitten one year old, tricolor sitting on the window sill and trying to climb through the window. It happened once to break. What he wants is unclear, fed. It's the evening and he did not give up. Something wants to say, but I do not understand it.... .
...And put yourself in his place, maybe, to understand will be easier? :)...
львёнок
Been thanked: 5 times
Post by львёнок » Tue Apr 29, 2014 17:02
Well, quite a fucking mess, damn :shock:
And crown :? and the clothes of the nobles of different times just full has all sorts of different precious stones, and all in the field of the cocoon :? to call them idiots for what they wore, and still are, complicated 8)
One fucking hat you know who weighs - easy to pick up if you drop on the floor.
And you - bad :wink: Yes, these stones absorb the insatiable envy of everyone who looks at them, and the bigger they are, the more envy hawala, and so they feed more of their owners :ay not only his, but also someone else's energy, but envy or joy to someone else - without a difference: energy it is just energy
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Tue Apr 29, 2014 19:37
and charging the crystals as BJ will change their minds? :)
Post by bofara » Tue Apr 29, 2014 23:59
львёнок wrote:well, envy or joy to someone else - without a difference: energy it is just energy
Believe me, that's not entirely true, depends of course on 'the level' /'depth'/ perception, but at least I have long passed this moment when did not feel the difference in quality /not only/ energy because of envy and happiness if you adhere to Your example. In some cases /and most/ of those 'sensations' are fed most likely some of the essence than the essence of man.
PS of course, you can specify a Panacea to eat power of envy and send her /energy/ to something needed.
p. p. S. in addition to homemade /digital/ AMB I used another version.. But if someone wants to feel a very powerful drive /at least I have a so/ just put the needle at the point of the month /advisable two weeks in advance, it is actually a month, but more on the principle trenchlines chronopuncture /the book is there for TH, Michael give/ and provide /impose their wishes/ that's the channel to the needle using your index finger as You want. The simplest technique to 'drive' for the whole month, in my opinion - not more than 40 minutes to impact /tested by me many times with BJ and there is no difference with the broadcast and without there is a difference in the use of broadcast and BJ, but still even on their own gives the effect of/.
Post by Михаил_ » Wed Apr 30, 2014 1:50
people, what do you like little kids swear obscenities, and then with these hands in my mouth :)
well, no need to confuse all in one heap - crystals-jewelry-crowns and so on
crowns and other things is a powerful magical tool made by professional (or at least started it), and the cost is not something that the state of the cocoon the wearer, but also his life, usually not very much was put into consideration (and you thought different?)
in this course, it is possible to manufacture a variety of (impact) artifacts containing crystals inside
fashion jewelry went from mindless copying of artifacts (wearing pacifiers) is quite different and it is in its more dangerous (by the way the question of the seizure of consciousness of wearing crystals including large ornaments touched upon in the lectures of BM and then we agree in General, although it is slightly deceitful not everyone tells what he knows about these things), here the problem of the "owners" of crystals may be stronger and brighter, as evidenced by historical examples (and wore them not always! not constantly).
natural not processed crystals are slightly different.
Druze - the third
artificial stones -the fourth.
as mentioned above BRM or whatever - it is generally the fifth.
This is a side branch from the old Soviet studies, which were conducted large-scale from many places, just very... side, she did not go. Other parts of this thread has gone in several different designs and it is still popular, but also a "conversion", but we can assume that the conversion is possible the initial idea (to introduce people), I'm not saying that this crystal antennas are harmful or useful - it has the part of certain properties.
Definitely the hang of the software (the same panacea) will be correct, although it does not remove all the features.
But I don't see a reasonable meaning to wear cocoon deform other objects in the field.
I'm not talking about the flow of energy I was talking about the alien intervention of consciousness (and those who can pass through it including).<
ПрактикОМ
Post by ПрактикОМ » Wed Apr 30, 2014 10:27
Michael, do I understand that tourmaline is in the same piggy Bank and it is better not to use it?
Алсемо
Post by Алсемо » Wed Apr 30, 2014 14:51
And what about the parlor!?
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Wed Apr 30, 2014 18:33
Alcamo, about the Parlor Michael has already spoken to that actually this is not its products and questions should be submitted to the manufacturer, but the harm from them in any case will not be (somewhere long ago already asked, can't remember where) and contradictions with its products no.
Post by Михаил_ » Thu May 01, 2014 2:47
ПрактикОМ wrote:Michael, do I understand that tourmaline is in the same piggy Bank and it is better not to use it?
yeah I don't see much of a problem with it
I just noticed that the net is very correct mono crystals by themselves don't have LONG is with the field of the cocoon
huh? different drusen much more harmonious, crystals, composed with powerful and complex software application products is also a separate song, there may be many variants
by the way, tourmaline is grown hydrothermal (synthetic)
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Thu May 01, 2014 21:34
Michael, I 4 PCs AMB. Want to buy 2 PCs of bio-resonance modulators with beryl and amethyst. After sticking on the phone I will need to wear modulators for yourself. They must be cocoon. How it can affect the operation of AMB? And whether at the moment of taking the modulators?
Post by Михаил_ » Thu May 01, 2014 23:08
Above I expressed my opinion. And so it is slightly beyond the bounds of propriety, because one marketplace.
I'm not impose their opinions. The authors of the article is clearly of a different opinion. Someone that enjoys and is happy.
I think SBA do not care, but the cocoon of your body - don't know. Indirectly already in AMB.
Алсемо
Post by Алсемо » Tue May 06, 2014 17:17
And how 4 acts of AMB operator who is under the influence of powerful damage supplied by a professional who had access to personal belongings and pictures? Does wearing the AMB weakening or withdrawal effects? I can recommend the operator 4 AMB to get rid of the effect of damage (how)?
Thank you!
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Tue May 06, 2014 18:07
already discussed this on the forum - PC+ quickly helps
