Damn, I forgot the newsletter on the forum to spread
ЗОМБИ wrote:I HAVE all the anchors mixed up...
It happens
. If being anchored in very deep States, it turns out the imprint is a steady anchor, it is virtually indelible (that's why I batter that you need to master the form of sessions of each phase before proceeding to the anchoring, and use strong natural state and emotions). Conventional anchors work only 10 times, if not always fill. There is another way to make a positive anchoring more persistent is to demonstrate in brain that preserving some concrete anchors for him carries a very big favor (examples and with the help of visualization, for example - it often works much better than the constant filling setiausaha keys, although it is not completely eliminated - nothing is eternal under the Moon, and even more that relies on the stability of the mind
ЗОМБИ wrote:I was trying to fill the same alpha anchor before falling asleep without MM... type according to the method of Silva... damn, he mingled with the non-Delta... now this sucks... now I listen to the alpha session, turn on the anchor to fill, and he half asleep...
Superimposed... In NLP in General there are different techniques when multiple States consciously put to one anchor. If needed, collapsing it and refill.
ЗОМБИ wrote:Understand another point – the anchor should not be requiring continuous, ie... for example, I put the laughter tickling the language of heaven – it is not very convenient... if you do such an anchor it is only specifically, for example, to transfer the SMR as walking or running, activating during the action of these anchors put on the state of the SMR from mindmachine... I think so, not saying anything...
Let me tell you a little secret - how did you know it is, but if anyone understands differently, it differently, but also correctly. Anchor - is the patrimony of the brain, he decides, so be it (not like you're trying to sing and want to think, and exactly as in really think).
ЗОМБИ wrote:the problem is that new is not noticeable kinesthetic anchors can not think of so many... and they are my best work... for example, to keep the image of the alpha anchor in the time of anger is much more difficult than to fold figurku...
Yes, some of the fingers 4 dozen of them (and this is on every hand, and many easily can be simultaneously activated). Touching parts of the body (does all the space is practically unlimited), breathing (sharp intake of breath, for example, or a very slow exhale is also quite a good anchor), tension of individual muscles or groups... Is that you just head to think, not want)))
ЗОМБИ wrote:Synchroa-anchor of the alphabet has become a sort of cast – ie I tried to play several times in the alphabet for the first time at the Endorphins in the head, heaviness and pressure synchronization is almost gone, and if it appears that heavy for some... but now these feelings are appear spontaneously or when attention to frontal lobe gray pieces of fat... while if you put alpha and synchro anchor-anchor, that turns normal alphabetical sense... from a pure synchro-anchors it is smeared, but there is no gravity as in the game of alphabet... some garbage...
So, too, overlapped with something... You're in a hurry, can see himself overtake)))
ЗОМБИ wrote:Another bonus... began to happen flash visualization... especially strange to catch them from waking... switching is a dull movie in my head... the so-called cinematography breaks out
and during the slumber short is good short film pieces of fat... ie look in the case and not just pictures... that is very helpful
I'm often so short answer where I don't have enough data - sketches to draw customers, for example, or the sequence of steps in the manufacture specify. As I understand it, sooner or later, this contact with the subconscious we all should open.
ЗОМБИ wrote:What else?.... I want to cram into the month of vacation the maximum that you can squeeze out of yourself... maybe what the specifics will be for free graphics??? want OS and euphoria...
To tell you the carousel for first and grimstalker with glycine for the second?)))
ЗОМБИ wrote:by the way, I have a kinesthetic flashbacks from tabletku... ie. when the music is catchy I start to run down my spine at the back of my head and the whole body in the end... I have them too from the very beginning of the training trying to anchor to catch – figvam – as soon as the anchor is trying to fill, they cease, and if nothing is done, then run until you let go of the music... such garbage
Goosebumps, and I often have, especially when trying to quickly with the chakras to work (alternately colored vortices on the second two represent in the right places) or with the flow of work. I have always believed that it is the opinion of the body. Why should it be anchored.
ЗОМБИ wrote:assuming the first week, do alpha
Alpha you can do first thing in the morning, regardless of what the day was going to do.
ЗОМБИ wrote: next week sync, next week beta and maybe sync the last week to try the Delta...
From personal experience I know that the beta and the sync is quite normal train together (break three hours and order, and better in the second half of the day).
ЗОМБИ wrote:During synchronization, you can probably session Left brain and right brain from the Navigator to alternate...
Yes, just put each on a separate anchor (and focus on the fact that it is an anchor on the activity of the hemisphere), then you can try to simultaneously clamp and to the balancing (assuming both are installed properly).
ЗОМБИ wrote:a novel, maybe I will throw down the Express version of the training... maybe we'll figure out how to push not pihuamo in one month...
I imagine something such experiments do not risk to put, and then you're Guinea pig is called. Theoretically at a certain level of experience and the week to meet, but the risk somewhere nakosyachit and generally screw up the entire course - the same diffuse inhibition to catch after attempts to fill the anchor, then it will be very difficult to quickly return to the previous rate of training. I know it myself.
Easier normal pass all the stages, and then only work on the support and donporneone anchors... I 20тиминутный a file with all the frequencies at once at a time, with a normal basis it is sufficient once or twice a week to listen to (just the player) and pass by the main state - changes the type of modulation and type of signal you want the anchor (even if it is weakened), get the necessary condition, deepen and fill - and so for the most part anchors. Remain specific, but they can be in life if you wish to fill (and Wasps to use). All! Anchors is much easier - all the delights of the mind-machine is always and everywhere with us.<
