Orgone generator with their hands (SP). The FLAME
Александр_
- Свами Доупаду
-Mine too, but now..Александр_ wrote:I wanted to say - EVERYTHING LOVELY !Свами Доупаду wrote:As promised: here's the raw rock crystal in the lower part fastened a piece of flexible tape with two RGB LEDs. By mixing the three main get any other color..(not all shown).
The LEDs operating in pulsed mode-upravlautsa scheme 555-m timer(like the Zapper )
But I will say - great work, I loved it
Shovel the archives for similar sites and found an example of the calculation of spirals, translation by Google
Has anyone tried to calculate the length of wire going to the coil.
PS Maybe not quite in the topic, but an interesting book http://narod.ru/disk/17316402000/communication.pdf.html<
The original here http://educate-yourself.org/dc/orgonege ... hembusters3 . Coil)
When you cut a piece of wire of a certain length known as the "cubit" length, that wire will resonate or act as a transformer to special cosmic energies and draw that energy into the wire. There are many different "cubit" lengths uses advanced civilations for centuries C. In a telephone conversation with Slim Spurling in February of 2005, Slim mentioned that he found that ancient Egyptian Royal cubit ( 524mm + / - 2mm) to be more useful for bio-physical energies and Hans Becker's "Lost" cubit ( 596.6714 mm or 23,491 " ) more useful for emotional and mental energy . As I add at least two coils of large orgone generators, I decided to make one coil based on the length of a cubit and the Royal second coil based on Hans Becker's Lost cubit length. I assign multi-disc source unit elbow with the use of the letter "X". For example, a 3X Lost Cubit coil equals 3 x 596.6714 1790.01 mm or mm . Any multi-plate elbow length unit will produce the desired results. You can also use 1 / 2, 1 / 3 or 1 / 4 share of a cubit, to give you a similar resonant effect, but usually not as Stong a whole unit length of the elbow. Depending on the wire gauge to use, I usually fit a double or triple multi-plate elbow at the TB or HHG. When you coil the wire, you make orgone energy in spiral movements. If the coil is contained in a plane, the energy will be distributed laterally and vertically. If you stretch the coil in the vertical plane, you have a vertical conical spiral which drives the energy to the tip of the spiral in a vortex fashion. For HHG, I add both a wide cone-shaped spiral coil that encloses the 5 crystals as well as a flat plane coil (sometimes called a "pancake" coil) placed at the bottom of HHG. For TB you add a single flat coil at the bottom. Two coils shown on the right are wrapped in a configuration known as a SBB coil, or S is not a B Uster's B coil a few times the button, came up with the name don Croft
Some parts of this "elbow" Lost Cubit (and not only him, but other cubits (sacred Cubit, Royal Scared, etc.) you can search among the product information Slim and Spurling'a).Ланцелот wrote:Shovel the archives for similar sites and found an example of the calculation of spirals, translation by Google
About the "elbows":
http://en.wikipedia.org/wiki/Cubit
Сергей Александрович
some sermyaga is - in the twenties of the last century, the throttle of the transmitter output stage "calculated" just - took a piece of wire shorter than a quarter wavelength , and wound coil.
Now there are so many formulas
But the accuracy of such
Arbilo and Wilbur the Wright daddy said that man would never fly because if God had wanted man to fly , he would have created him with wings. But they flew.What were the parameters of the aircraft - it doesn't matter now , what matters is that their plane l e t a l .
So, IMHO, the main thing is that it works , the main thing-to do it all and make sure it works.
And then ,having got the hand , you can optimize the design parameters.
low, up to one-half inch , so the answer can only be the experience to do the coil multiple lengths and simple -but that experiment will have to repeat at least twice for two amounts of turns - a total of at least 4 coils and at least three people to evaluate the properties (since there's no device that can objectively (how to hang in grams!) to measure the result).стрингер wrote:"elbow" Lost Cubit (and not only him, but other cubits (sacred Cubit, Royal Scared, etc.)
Totally agree with You.Сергей Александрович wrote:So, IMHO, the main thing is that it works , the main thing-to do it all and make sure it works.
And not always someone's advice can be effective in Your case, the cases are different:) Someone's experience offers many options to increase efficiency for most cases, and if it is Your event private?
Right Humpty Baltay in the beginning of the theme is the production of SP compared with baking cakes:) very good point. Women bake cakes, different women, different cakes, even one recipe. Can delicious can be so-so... and not the fact that if one woman "I repeat" (according to the girlfriend), her delicious "work of confectionary art", will be very tasty. But if (even not adhering to the advice of a friend, just a recipe and General recommendations), you can get "a masterpiece of confectionary art", yum...
Sincerely, MAG.no
Masterpiece - a unique work.Маг.нет wrote:Right Humpty Baltay in the beginning of the theme is the production of SP compared with baking cakes:)very good point. Women bake cakes, different women, different cakes, even one recipe. Can delicious can be so-so... and not the fact that if one woman "I repeat" (according to the girlfriend), her delicious "work of confectionary art", will be very tasty. But if (even not adhering to the advice of a friend, just a recipe and General recommendations), you can get "a masterpiece of confectionary art", yum...
The square of Malevich, too, I consider a masterpiece. Every time new times. In black you can find the whole range of... Shades of black even moods, not only from the perspective and viewpoint change.
Masterpiece SP - something amazing, maybe unusual but definitely effective at work, with a share of the individual device. Some examples in this thread on the "first glance" would have attributed to the masterpieces of the "Orgone-crystal of creativity":)no worrying. I would like to see a time on the same shelf (in one place).
Sincerely, MAG.no
Well, after the "Black square" all other pictures look like some kind of "being redecorated"))) But seriously, it is very easy to talk about what you've never seen. The idea in this picture is really great..."the Black square" of Malevich, too, a masterpiece I think.......Shocked
book Sanjivini in pdf and in Russian you can download here
http://www.megaupload.com/?d=IT9DPQCO 57мегов
there is another option, but there how to write a few cards
http://rs38cg2.rapidshare.com/#!downloa ... .pdf|19004
on the topic, while the quartz did not come - I want to work out and fill in orgonite the bar is granite - what do you think about this? at the same time and the optimum amount of curing agent for EAF will find out.
about the power of granite almost nothing, and Logan too.
found out that it has a microscopic fraction of plutonium, how it will work when the influx of orgone is unclear.
probably at the slightest danger, this cake will turn into a Holy grenade
granite will take deep in the mine, with a depth of approximately 800 meters, maybe work there
so to speak, and the ancient energies soaked. I think the stimulation frequency of Schumann, to strengthen the relationship with the land, Logan describes such minerals. Or nothing will happen. in General, I will keep you updated.
please share your opinions
Fun here you are!
About pseudo-science was just silent. One already the term orgone, which only costs. And A. Patrushev modestly silent... What really attract torsina and the information field I don't know - they still exist as a hypothesis, and not podverzheny. BUT brainstorming the thing cool - criticism is not applicable.
About coil. We immediately see that the normal inductional field it can not create a four of opposite coils have to put out each drguga. In the end, except induction noise, get nothing. Again, why use a specific frequency... in one of the posts was used about low-quality diamond, as a generator poly-frequencies, you may want to experiment with white noise?
The coil itself, with a maniacal twist reminiscent of one thing, sorry can't remember the name. In koldovstve used twisted candles, of course as with any magical attribute - preferably a Church. They had to influence the flow of energy(kind of terms, buy - in and sell those). There is mention of such things in Buddhism(most likely Tibetan, neither on the original nor on Zen\Chan Buddhism is not it seems), to enhance the flow of energy through the top chakra. Just candles were lit and held over head. One legend says that a monk with such a buildup cracked skull, and fell from the sky the flower petals. Interpreted - maliciously that have reached Nirvana. Evil tongues however interpreted that he just took care of the last forces about a proper burial
So the coil in its design really looks like it. From the same source recommended not to keep these candles in the residence and used only for ritual.
But in the DIY it looks beautiful, the idea is to add LEDs - chic itself of such a thought - a beautiful night light can get. I'll try to do.
Doubts about the efficiency of the device is, screwing over those who work, will not.
By the way of spiral. Judging from the pictures from the sites should be similar to the universe, what is written didn't read - there is no desire.
For anyone can experiment with a large number of tails. Of the monuments of Tripoli culture were symbols with 3, 4, 6 tails. If you are followers of neo-Christianity - 3, if yoga or just Shiva 4, of Pythagoras - 5(though I like this character have never met), or on request from 6. Just dopivaya additional rods of copper in the core and twist.
Adding power or any characteristics not guaranteed, but at the level of arhetipov may not strengthen frail.
Experiment, is a similar structure (spiral including 3, 5, 6, 8 tails) is represented on some cards "the Arcturian keys." The explanation is the work (interaction) with different "Platonic bodies" the number of tails is affected on it.Соловей wrote:who wants To can experiment with a large number of tails. Of the monuments of Tripoli culture were symbols with 3, 4, 6 tails. If you are followers of neo-Christianity - 3, if yoga or just Shiva 4, of Pythagoras - 5(though I like this character have never met), or on request from 6. Just dopivaya additional rods of copper in the core and twist.
Sincerely, MAG.no
Reference:
the five Platonic solids: tetrahedron (Fire), hexahedron or cube (Earth),
octahedron (Air), icosahedron (Water), dodecahedron ("universal mind").
Buoyancy of the body: truncated tetrahedron, truncated cube, truncated octahedron, truncated dodecahedron, truncated icosahedron, etc.
Perhaps it is the organizing form for the different energy structures?
Sincerely, MAG.no
Sincerely, MAG.no
An interesting property that if the first four (on the list) Platonic solids faces can be decomposed into the plane so that they can fill a flat surface tightly (fully), the dodecahedron in such a "situation" with the face of Pentacles tight flat surface does not populate, although the volume has a symmetrical form and full fill.
The world of crystals (natural) "pentagonal" symmetry is not peculiar at all. In the world of nature such symmetry is one of the most common.
Sincerely, MAG.no
Sincerely, MAG.no
Platonova body <=> World of ideas <=> Collective unconscious <=> Architype.Маг.нет wrote:"the Platonic solids"
I knew that each digit(or letter, the Greeks have no numbers)(and associated value) is in ancient philosophy geometric analogue, but never nedumal to link shapes to archeotype. Interesting. Not sure how well the comments of archita geometry. I'd rather have some sort of symbol. But for people who used to think such figures - definitely rulezz!
After a wide acquaintance with the current technology development stepped into the next stage - commercial use. Probably just for this, and there was the previous stage of consultation. Well, for the quality settings - feedback. Logan patron? Normal.
That would be in Your area began to grow exotic fruit, perhaps you need to start to "establish a need" for something to give a try to consumers, among them are defined by "potential customers" who enjoy "the taste." Until you try you'll never know how much it is acceptable and necessary. So gave a try... taste... And then or "grow home-grown" or "buy cigarettes"... or quit! Sorry for the analogy...
Sincerely, MAG.no
Sincerely, MAG.no
Very interesting results of quantum physics experiments with orangenation. Maybe the scientific approach to this phenomenon will be selected:)
Graythe participants of this thread, the experimenters, do not limit your perception of someone's dogma, that "master recipe" yet. Maybe even better. "One knife is easier to cut bread, others to clean the fish, the third - to clean the vegetables...", but in the campaign take a one-stop - travel... and bread to cut, and vegetables with fish to clean:) ArgumentError is a tool for different needs. Study, mark the effectiveness of different formulations and configurations - please share your experience and will be a variety of "effective recipes."
About graphite - filler material depends on how the density of orgonite and other properties. You need to study (only empirically).
About the coil - you can try different, but... soon it will not be SP and the other ArgumentError with unique properties.
Success to Your endeavors!
Sincerely, MAG.no
We look forward to Your results.Седой wrote:Well here is the questions more and more.
Okay looks like I will have a few different ways to collect but with a scientific approach and methodology.
Sincerely, MAG.no
If measured, it is probably more useful "changes" interactive object (such as Operator or location). Such measurements can provide a more objective assessment of the effectiveness of the result. Because SP is not just the field generator, and the GENERATOR MANAGED FIELDS, that is more important, not the power of the flow and its direction, the interaction with the environment and the range of interaction. Justify... were not included in the range - there is no noticeable result (interaction), and the flow may not be small. Efficiency =0. There is no interaction with the Operator or a location. Efficiency =0. The direction is inconsistent. The effectiveness is not 0, but is removed from max. More than not matching, the lower the efficiency. Well, again the analogy... It's like a Mazerati or without wheels:)or without a steering wheel:)or without driver
... Well, that is the engine powerful? Will not get far...
So Marim and compare the results of "the distance traveled" - the principle of "feedback".
Success!
Sincerely, MAG.no
... Well, that is the engine powerful? Will not get far... So Marim and compare the results of "the distance traveled" - the principle of "feedback".
Success!
Sincerely, MAG.no
Your lips Yes Honey to drink. Did you know that this is a serious problem of modern physics. Detectors of different kinds of essential processes.димыч wrote:it would be nice to do something for registration power emission.if the radiation itself is not fixed, you can find what it affects and to measure this, such as a change in resistance, a change in the spectrum of the beam passing through the field of wondering if you smoke scented stick -will the smoke how to react?
frame operator-dependent, therefore, to consider them seriously not worth it
Already 30 years puzzled over that thousands of scientists and RAS are much harder(in terms lomagna head) and tens of thousands of home Gumerov on hundreds of forums. But while it is absolutely not a lot, alas.
