Stabilizer.
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Sun Sep 11, 2011 16:00
Sources (products) TO 2.0 are available, if I understand You correctly then all should Druse charged by technology 1.0 hold it for some time with the source TO 2.0, it is possible that some will go to Druze, so probably going to make it worse I think not. The work of stabilizers, full with TO and without it at the beginning of the production, will differ from each other?
Has thanked: 24 times
Been thanked: 142 times
Re: The Stabilizer.
Post by Маг.нет » Sun Sep 11, 2011 18:00
Michael_, You had previously written here:
Михаил_ wrote:this is generally the correct answer.
Other light matrix prescribe a system of manifestations of properties.
and panaceia matrix and creates a copy of the cell body, responsible for preprogrammable panacea. This is the only publicly available matrix, creating a cellular structure (well, not counting stabilizatory systems and programs).
Is that a typo? True or not understand.
Oh, and there's also about "reprogramming software an matrix" for Panacea:
Михаил_ wrote:the Objective of this matrix is more likely to switch the panacea 2.9, or 2.0+
The owners are not full, and the matrix a panacea, too, can try (especially the paper version, it's quite simple).
If druso charge matrix a Panacea and reprogram 2.0+ (for stability), it is possible TO apply for further reprogramming Stabilizer? Or you can just charge the P-matrix and the Stabilizer TO preprogrammed for themselves? It is unlimited, will not work, right?
Sincerely, MAG.no
Re: The Stabilizer.
Post by Михаил_ » Sun Sep 11, 2011 21:06
1. program to the stabilizer independent and porazhdaet copy TO using matrix, but this is as far as I remember, it's not about the device itself (the working field). At work the source field of the primary CO - Druse. Although, frankly, I could be wrong.
2. Yes, you can handle paracanoe matrix. You can just operatorsky to put on the field piece TO 2.0, i.e., in General there is a big problem. It's just a question (why is the stabilizer on the desktop not porazhdaet independent) IS that the stabilizer can be a dangerous tool and I gave some facilities to non-standard situations to facilitate the elimination of the consequences if this once will have to do. Well, you never know....
I.e. if the UK for example there is a harmonization of roughness around the operator (albeit with a kind of trend, but still), BJ is guaranteed from unnecessary jokes that the subconscious mind in 99.99999% of cases is not harmful to yourself and the world (in a global perspective at least), Stabilator, in a zone of attention of the operator, is able to produce different anomalies. I hope I never have to be concerned with compensation Duri this device sgenerirovanny, but the danger from it is higher than from other devices.
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Re: The Stabilizer.
Post by Ланцелот » Sat Sep 17, 2011 22:51
Michael_
Long heard about one source nakonec today and found it. Very unusual energy place with a thick layer of greasy grey clay near the water. On the banks of the Creek grow mushrooms with a leg diameter of more than 10cm. Tree found mushrooms with thick legs one and a half cm, the diameter of the cap см10. Sturdy crisp. Two weeks ago, in the same area, when we started to look for the source, found a raincoat with a diameter of 70cm, weighing 6.5 kg.
If you use the clay stabilizer from this source, much will be shifted to the capability and strength of the stabilizer, if I may say so? Clay is not charged on the system of BJ, and to apply "as is".
АКВО
Re: The Stabilizer.
Post by АКВО » Sun Sep 18, 2011 23:49
And that the source of such intriguing? :)
Where?
Ланцелот
Re: The Stabilizer.
Post by Ланцелот » Mon Sep 19, 2011 0:34
Kaluga oblast, Przemysl district. :)
Re: The Stabilizer.
Post by Михаил_ » Mon Sep 19, 2011 4:15
1. You can only use for Neutro sector.
2. clay is never recommended to charge BJ.
3. Well, in this situation (for the quality of the clay) just be good neitro the sector regulator. We kind of clay in serine production and use. Well, really more interesting places.
Has thanked: 5 times
Been thanked: 8 times
Re: The Stabilizer.
Post by Воффка » Tue Sep 27, 2011 11:05
Hello, dear friends! I've worked a bit on photoshop and edited all of the files for the manufacture of the stabilizer in the desired format and signed each mandala to make it clear. I want to lay out the resulting creations for your evaluation. While the link to the archive here ( http://www.fayloobmennik.net/1012022 password:111 ) do not know how else to add here the files. Files in the archive 28 pieces that meets all of the files on the link http://openmagic.org/stabilizator/ in addition stabilizator001.pdf stabilizator004.pdf, but they are for the manufacture of the stabilizer is not needed. The sizes of all programs and Mandal (besides the "stabilizer base" the size of this mandala Michael recommended that it be retained in the original) in the archives ' collection is one inch.
Now the manufacturer of the stabilizer will be faster and easier :). In the near future I plan to modify the files by placing all files on one sheet of A4. If something is wrong or have any suggestions.
Adding from 17.10.2011
http://www.fayloobmennik.net/1074805 password: 222 link to archive file augmented with mandalas placed on A4 format. Please note that all mandalas designed directly for the manufacture of the stabilizer (except "stabilizer base" that is glued first, it on A4 no, but in General, the present) are in the order that in which they have to stick in the manufacture of :)
Adding from 07.11.2011
http://exfile.ru/219960
Here's the latest (and I think final) version of my build all the files, Mandal and brief instructions for the manufacture of the stabilizer. Please use :) In this embodiment, the mandala for the manufacture of the joint on a sheet of A4 paper, making printing easier and faster.
PS If you have any suggestions or additions please write.<
Been thanked: 10 times
Re: The Stabilizer.
Post by Мастер 108 » Wed Sep 28, 2011 20:47
Воффка wrote:Hello, dear friends! I've worked a bit on photoshop and edited all of the files for the manufacture of the stabilizer in the desired format and signed each mandala to make it clear.
And thank you :ay
He obioulsy to do such an operation, but time is sorely lacking. Now it really will be easier to do the Stabilizer. Next week I bought all polièfirkoj and ...
Доктор
Re: The Stabilizer.
Post by Доктор » Mon Oct 03, 2011 22:24
Good day!
Please tell me! If he'll do the stabilizer, does it make sense to buy the programs!? Or is there an opportunity to do such a thing?
Re: The Stabilizer.
Post by Маг.нет » Mon Oct 03, 2011 22:40
Good!
A set of mandalas for the manufacture of home-made Stabilizer, also includes a set of mandalas for the production of software similar to commercial, you can simply have a printout of, or of the mandala to fill in with something "drying" (like checkers or tube with epoxy or other crystallizing when drying materials). Commercial "clearer" inscribed mandala (or rather quality) in the object - effectively exhibit their properties because of the manufacturing method (transfer mandalas laser unit with special properties).
Voffka made comfortable billets Mandal under the listing "in size" (one inch - the download link in the message above), in the same message there is a link to the source.
Sincerely, MAG.no
Re: The Stabilizer.
Post by Михаил_ » Tue Oct 04, 2011 1:45
In other words, depends entirely on the willingness and financial capabilities. You can make a homemade. They will work well. The factory will work more effective. Unlike the stabilizer, their value added is not high. Therefore, it is possible in particular to combine. Ie some important - buy, any pile up to do it myself. The whole stabilizer may be homemade. Due to the possibility to increase the size and other parameters can make a very efficient homemade.
Post by Воффка » Wed Oct 05, 2011 10:11
By the way, those mandalas which I edited for the manufacture of stabilizer you can use directly to do with labels :) it does not interfere with the operation of the finished stabilizer. From the correspondence with Michael:
Михаил wrote:
Воффка wrote:Michael, Hello! I have a question. If you use the mandala like in this archive http://www.fayloobmennik.net/1012022 password:111 i.e. to glue on field stabilizer directly with the label is not cutting (the sizes of mandalas already adapted 1dyuym), it does not degrade the operation of the stabilizer?
Yes you can
So to persist with a pair of scissors, razors, rulers, etc. do not need :)
Re: The Stabilizer.
Post by bofara » Wed Oct 05, 2011 13:30
Thank You, Dear Voffka!
I think that may be even easier - if the Stabilizer of a graphic editor, insert /Corel Draw for example/, then convert to jpeg, png ...
Will be weaker IMHO, but a simple starting production - printer, who wants epoxide, Druze all.
Actually - thank you! 8)
Re: The Stabilizer.
Post by Михаил_ » Thu Oct 06, 2011 1:41
Appeared in the office cube "Stoppage".
The set of programs inside the same as for the keychain and disk Stoppage, i.e. actually "stoppage" and "protection", "health", "additional stabilizer". Contrast to already known products, key chain and disk stoppage, in which the same set of programs, primarily in the fact that the cube is significantly larger in scope and the program repeated in this laser significantly greater number of times. This "weight" in the literal sense (product weight) affects its specific power. That is, the base function is more powerful. More suitable for business applications. Unlike disk-stop magic, which if desired can be carried in a briefcase, the bag cube stop-magic is more suited purely for desktop use.
the cost of the product 9T R.
In other words, the meaning of this, more powerful version, more power. It may be useful to those who participate in any large-scale processes (business for example) and will have a greater stabilization effect.
Let me remind you - articles series "stoppage" work successfully for those who uses a device "Stabilizer" for those who do not.
The effectiveness of Stop-the magic begins (and this is verified by many) with free available printer prints programs stop-magic-1 and stoppage-2.
The program for the device "Stabilizer" has a higher efficiency due to the method of application information. But a separate product "Stoppage" contain additional useful programs and have increased deistvuya force, growing volume and weight of the product.
At the moment we have three members of this line - the keychain, the drive and now the cube.
Re: The Stabilizer.
Post by Воффка » Thu Oct 06, 2011 10:04
bofara wrote:Thank you, Dear Voffka!
I'm on it :) But the stabilizer will be the Express of manufacture when does no time, because it will be a bit weaker than the same paper stabilizer, but with hand-glued labels.
Михаил wrote:
Воффка wrote:I came up with the following idea :) What if I'm on photoshop will impose inch of the mandala on the image stabilizer which is on the very first page of manufacturer and then don't need glue at all, just printed and use. So it is possible or not ride? If you can, it will be not weaker than that in the melee on a cardboard disc, glue?
can. will be a little weaker
Re: The Stabilizer.
Post by Михаил_ » Thu Oct 06, 2011 13:22
1. when manually building the field of stabilizer and bonding of its components, runs a specific initiating process. When you print a paper, not so much. But will work anyway. Just more efficient to glue (not that there are a lot of elements). You and another. Can be printed box to put on top of stickers for their letter matrix at a time, this will also trigger the initialization of the fields - something like ripples on water, to acquire the system operating equilibrium state.
2. yesterday I forgot to write about Stoppage. Her work (all versions) occurs naturally and remotely for the factor settings on the operator, but being in close proximity - effective.
Re: The Stabilizer.
Post by Михаил_ » Thu Oct 06, 2011 16:02
something I have distracted lately...
Another important addition about stop magic version CC
In this version, in addition to the BASIC programs is identical for all 3D products in this series, the product system is a Panacea in the form of 3D prints. This creates an increased supply of products and some flexibility in its programming. Thus, it is not just a passive artifact of stop magic, but more flexible and programmable object. "Panaceya" insert allows you to focus attention on certain troubling lines of events, antisera the work of stopmovie stronger in him.
It also reinforces the basic f-tion of the product at the expense of own properties of a panacea, but with minimal impact on operator (panacea).
АКВО
Re: The Stabilizer.
Post by АКВО » Thu Oct 06, 2011 23:03
And homemade keychains whether it is possible somehow to include it? The Matrix P?
Re: The Stabilizer.
Post by Михаил_ » Fri Oct 07, 2011 0:03
well, you can, but it will be a little something. However, try it. Then command her to work for the benefit of the product and not as a BJ-panacea, i.e. a program reboot.
Шломо
Been thanked: 3 times
Re: The Stabilizer.
Post by Шломо » Wed Oct 12, 2011 20:32
Михаил_ wrote:2. yesterday I forgot to write about Stoppage. Her work (all versions) occurs naturally and remotely for the factor settings on the operator, but being in close proximity - effective.
so it is enough to attune to the cube of its distance work?
Michael please tell me,is it possible to set the cube on a remote impact on the family?
Re: The Stabilizer.
Post by Михаил_ » Wed Oct 12, 2011 20:36
1.I wrote above - being around will be more effective than remotely.
2.Will construida useless. You need to be his operator, i.e., to purchase or otherwise acquire full right to use it. While your alignment is not much important.
3. In fact programs to their stabilizer is of course possible to prescribe for the family, but in ACC. anchor and pitch stabilizer.
But not very will. I.e. someone will still be the operator. But the family is still protecting.
Шломо
Re: The Stabilizer.
Post by Шломо » Wed Oct 12, 2011 20:39
And whether it is in the manufacture of the stabilizer to fill in the corresponding box disc Stoppage?
and if so,do you plan to do type stoppage the remaining components of the stabilizer?
Шломо
Re: The Stabilizer.
Post by Шломо » Wed Oct 12, 2011 20:42
Михаил_ wrote:2.Will construida useless. You need to be his operator, i.e., to purchase or otherwise acquire full right to use it. While your alignment is not much important.
of course I meant that after buying a cube stoppage,i.e. it also includes the principle TO?
Re: The Stabilizer.
Post by Михаил_ » Wed Oct 12, 2011 21:25
TO have in all of our commercial products if I didn't forget anything.
Pour stoppage in stabilizer is absolutely not necessary. Then how to remove? :)
do all the components of the stabilizer as a separate product kind of makes no sense. Ie, wear them separately ... I don't know for what.
And make the glass parts of the stabilizer will be expensive however. Ie you can. But expensive. There is no demand but....
we don't need another whole pack of scheduled products need to produce.
The remains of a series of aircraft, and the extensions in EK is a very interesting face and so on...
So just experiment with the Stabilizer in the glass.
Although in General it would be possible at all to make a mega-regulator into a big glass, but it will have new technology to create...
