About the parlor
Гост'ь (Спири)
Dear, Guest.
If You are drawn to materialistic and technical merit of efficiency of a Chamber, You will probably be more informative to look for information in scientific publications that You trust. Or you can write letters directly to organizations conducting studies of the effectiveness of this device.
Jalovec is a holistic system, in which, as You know, everything is interconnected and the placebo effect is no exception. If the dried feces of mountain monkeys on the neck will replace consecrated a cross and get rid of a headache or aspirin, then, personally, I not thinking it will wear. (with the help of neighbours and friends).
the point of the experiment for Arthur is simple - he puts it like in his pocket ... and I propose in a non-transparent neck pouch ... by the way this was offered on the forum Tolley Andrew Tolley kabankov Dimas ... and this opaque pouch to put newcustomer to wear people that the parlor the simulator the shape is similar ... te the meaning of the experience of ignorance is wearing there .... and the reason for its temperature will be revealed more adequately on the solution level of Svetlitsa or placebo ...
you write takes the pain ... and probably generalize that and have a gun to bring good luck and buy a TV set without marriage contribute to and etc ... and this error ... t to relieve pain this is a placebo is most clearly manifested on the body , that it inculcated the brain and the psyche is exposed to the homeostasis and functions of the body ...
still under the influence of gravity falls in the placebo effect for subjective assessments of feelings and insights striving to replace real experience as a real ... success , luck and etc ...
many people help charms for a toothache - the work of suggestion on the perception of pain but tooth decay is not a cure
pain during fight or Boxing in General don't feel ...
in the confusion too ... is the effect of the perception of the mind ... it does not figure ... the pain takes not Svetlitsa and your perception ...
by the way the pain is most noticeable before you sleep when all the stimuli go away and the real remains
I marvel at how you get yourself from the particular meaning under the influence of desire Svetlitsa works ...Dear Guest, how do you imagine such an experiment ? To make a circle of the same material, same size and same weight (with a groove around the circumference) ?
suggest more carefully to the words works ...Despite the fact that I still have all sorts of questions about the front Room, I can tell You - it works - improves performance, relieves pain.
Host b (Spire)
I will try to find the real mechanism of the dried feces of mountain monkeys on your neck which will replace you a blessed cross ...
I'd better cross than what you have written ...
I'm all for placebos in such cases , but agree the cross and all that it involves better dried monkey feces on the neck ?
or are you the club plaistow ? te my posts violate the faith in the placebo ? then you are right ... so what ?
nesomnevayus that you will do soJalovec is a holistic system, in which, as You know, everything is interconnected and the placebo effect is no exception. If the dried feces of mountain monkeys on the neck will replace consecrated a cross and get rid of a headache or aspirin, then, personally, I not thinking it will wear. (with the help of neighbours and friends).
t e you will not be attracted to materialistic and technical merit effectiveness ? and are unwilling to write letters directly to organizations conducting studies of the effectiveness of this device ? well, I won't stop you ... believe and use ... such people no one can stop ... faith is stronger than common sense ...If You are drawn to materialistic and technical merit of efficiency Front room, You may will be more informative to look for information in scientific publicationsthat You trust. Or you can write letters directly to organizations conducting studies of the effectiveness of this device.
Гостья
I do not generalize, please do not attribute to me the words of others. Responsible for their words - relieves pain, improves performance. The effect is felt for quite a long time (over 4 months).Гость wrote: and perhaps generalize that and have a gun to bring good luck and buy a TV set without marriage to promote and so forth
About good luck, success, luck - apparently, it needs to properly configure, we hope that the seminar can help. (I have this effect especially do not count.)
About tooth decay - it will certainly not be cured without the help of a doctor. I do not expect.
There is thrown adrenaline or endorphins (like in sports), but I don't do extreme sports.Гость wrote:pain during fight or Boxing in General don't feel ...
so relieved ... but where does all naplitano in the parlor ?
it's not the words ... I want to docreate Sya to you that the pain a person can take the suggestion itself ... Svetlitsa only helps those who can't adjust ... but it does not work the miracle of the mechanism a chamber ... I could fall in the grass in the fields of their homeland, and to imagine that get power from the ashes of the ancestors and preparedto and claim with this faith I will move mountains and pain asemeco ... you sons learn such is the power and not the amulet ...I do not generalize, please do not attribute to me the words of others. Responsible for their words - relieves pain, improves performance.
you have what was once relentlessly for more than 4 months ? think ... analyze ... everything you write is achieved simply by the mood of the psyche and the adequate ... plus sure that you the miracle you and sleep returned to normal and the adrenaline droppedthe Effect is felt for quite a long time (over 4 months).
true ... fortune favours the adequate and persistent ... that these qualities develop and the front room is like a porridge of axe ... until I have to axe cereals oil meat fat and salt - Kashi will notAbout the good luck, success, luck - apparently, it needs to configure itself correctlyI hope that the seminar can help. (I have this effect especially do not count.)
then what are you ? the pain relieves and suggestion but the suggestion will not cure the caries - surgical violation , unrelated to the selfrecovery ...About the decay of course he will not be cured without the help of a doctor. I do not expect.
so what ? you have other mechanisms of self-regulation ... I know that the anticipation of pain makes the pain stronger ? and Vice versa ? read on pain and self-regulation that is ITSELF ... or read the system key single Armenian with the Soviet Union its special forces uses ... in Cuba, there areThere is thrown adrenaline or endorphins (like in sports), but I don't do extreme sports.
Гостья
Guest,
I will not go into details - Yes, was sick for a long time, chronically, for several years, with the years became worse - now it does not hurt (although the reason, I think, not resolved).
System Key in the time, read.
If I fell to the grass in the fields of their homeland - I certainly would feel better (without any thought of the ancestors) - sorry, meant purely urban way of life.
Svetlitsa restores the system to human connections, removing the distortion. Self-destructive motives and autoimmune diseases is the result of distortion. View the report on the studies of the effect of a Chamber on the immune system. There is evident a normalizing effect and refers to possible application in the treatment of autoimmune diseases.Гостья wrote:If Svetlitsa increases the energy of desire that occurs in people with unconscious self-destructive motives and autoimmune disorders (which also have self-destruction)? The desire to self-destruct is lost or enhanced?
МерКаБа
Dear Guest!
Your left, logical hemisphere, is simply amazing. And how do You explain the phenomenon of "siddhi" (psychic powers) or is it a PLACEBO?
Here's the problem:
The morning (!), standing with a friend on the street. At some point, I just wanted your heart to see the movie "Perfume". And wanted, very much (it happens). After a few minutes, in the darkness, see the silhouette of a familiar person to me. This is my friend. He actually lives in another district. Come closer, I notice the hand in the box and what do You think? Movie: Placebo
a joke , of course it was the movie "Perfume".
Attention a question: the Result obviously, but for what reason?
To me the answer is known, and how to resolve this issue of Your left-brain?
Dear Guest, it is not an isolated case, believe me. I have enough examples that would lower Your logic to its knees, but... I don't have that right!
PS sorry for flooding.
Here's the problem:
Dear ASD, theoretically ....
That is the question : If you take pre unlucky pensioner's financial wealth which is limited to one-room apartment and a pension of 5,000 rubles, and to arm his front Room Good-Brilliant for a month or two (so he didn't know about it), what is the gain of financial wealth through the quarter ? Feel whether the pensioner cash flow ?
Suppose that the mental state of test subjects is very positive, but actually in condition to go to work, he can not, no relatives.
Spiri
I think this you said about yourself ... as always no justification and as always, unsupported by anything charges ... live in a fantasy and always give out the desired for the real . give at least one justification your charges are written always as though a priori and I agree ... as long as you write in this post only about yourself
Guest, You are right a Gift from the Creator(Creators) to turn everything on its head ... and (perhaps) as a side effect of unwillingness to listen to what You are trying to convey in plain text =))
Good luck in your search.
Arthur , and that the effects of water and who measured it and what ... you believe the claims over which serious scientists laugh ... only because you want to ? and if you think about it ? but I admit that they are wrong , but really right-not serious scientists ?Артур К. wrote:Guest
How do you explain the experiments with water through a chamber ? Also placebo ?![]()
you water know ? the parameters of one and the same water is always different ... and Kirlian generally always different the gives ... he is unstable ...
and where does the water ? even if there is such an effect ... we have something about your temperature !!! well, take it and check as I wrote to you ... really very interesting ? it is better to go and think what depocam ?
PS the water is still ... maybe not a placebo ... but this reluctance to believe and the reluctance to criticise the methods of obtaining data about the water and the unwillingness to accept the fact that your water parameters unstable, and without your influence, and so forth, there's the placebo effect understanding ...
the word exposure has a negative connotation for you ?do not understand your purpose of all these revelations ... You want to buy the room or want to protect your wallet other from the placebo effect ? Laughing
the goal is not disclosure but aim to understand ... you always perceive everything of course or Yes or no ? why are unwilling either to see or to hear criticism ? wash you in advance due to the belief that you like ... notice you do not argue and blame ...
what's wrong with healthy skepticism ? only one ... in such negastat placebo
what do you mean my purpose ? and what is your goal ? understand ? make sure ? then why are you against criticism , the more I don't like spire only blame me and justify !!!
but if your goal is a placebo you are right ... criticism there is a dangerous and undesirable ... as in any faith ... if I said that I would have stopped you to advise ... for placebo nanodomains method of treatment of psychosomatic disorders ...
Merkaba
but your imagination is the activity of the hemisphere
and is it your example has to do with what we're talking about ?
and what do you know ? where ?
maybe you and your friend on the topic of movies trendeli week and maybe something else ... that's your brain and discreetly match all and gave the waiting ... it's your friend ... you probably have a General topic of conversation ... or he probably knows or has heard your sighs in film , and etc ...
to investigate your subjective enthusiasm little input ... you analyze and explain ...
I know only one thing NEITHER a MAGICIAN neither in antiquity nor Hitler, nor that d was not able to guess their fate, and arrest them right ... though this was asked a tricky tyrants .<
it is not the activity of the hemisphere is the definition of reality causes adequately reflect the reality...Your left, logical hemisphere, is simply amazing. And how do You explain the phenomenon of "siddhi" (psychic powers) or is it a PLACEBO?
it's amazing how you my simple experiments suggest a subjective assessment of the situation which they themselves will not be able to trace the points ...the hour of the night (!), standing with a friend on the street. At some point, I just wanted your heart to see the movie "Perfume". And wanted, very much (it happens). After a few minutes, in the darkness, see the silhouette of a familiar person to me. This is my friend. He actually lives in another district. Come closer, I notice the hand in the box and what do You think? Movie: "Placebo" Laughing , the joke, of course it was the movie "Perfume".
what does the left hemisphere ? logic is not a hemisphere that displays the real causes of the sober brain, even if there is mystery or magic that sober consciousness determines and notice and prove ... light bulbs , laser , x-rays , nuclear energy , flight to Mars, etc ...attention to the question: the Result obviously, but for what reason?
Guest, "for placebo nanodomains method of treatment of psychosomatic disorders"
Then it would be mental and psychosomatic disorders were treated with a Placebo, and very effective. However, psychiatrists each year the queue longer.
"logic is not a hemisphere that displays the real causes of the sober brain" - also consider this statement incorrect. Justify the statement about the reality of the causes and what's this "Sober brain."
The reasoning for his statement. Citing a source, if not more difficult ... another thing, if you get pleasure from mind games, breaking the logical chain of statements other authors.
Just by reading Your posts, consisting of scientific terms and .... dots, inclined to think that You simply challenge the proposed statements. Let's talk in this case convincingly. At the same time, flooding will be less (forgive me moderators).
Spiri
schizophrenia and severe disorders of homeostasis in patients with recalcitrant unwillingness to accept reality and want to live in the world pridumannom treat ... I'll normalize sedative , relaxing and inhibiting arousal pills ... BUT EVERY DEPERESSING treat after NECESSARILY psychologists and psychotherapists suggestion and strong images of placebo ...
may sister suffered from depressed from unrequited love and I are well acquainted as causes and treatment
I'd write in scientific terms and even write your BUT I will GIVE the DEFINITION of ...
here is the definition is the sense and logic to understand and justify ...
if someone will write the correct terms but his logic suffer from inconsistency and absurdity of the conclusions the terms nepomozhet and will not a priori make nonsense true ...
sober brain
this is when a person in their chain of reasoning is based on real facts and displays one from the other not coming up TO the COURSE desired at the expense of real ... addict never seems to understand (emotion knowledge) write pseudo artists "masterpieces" that sobered tear like a piece of crap ... why ? because the creative hemisphere without a logical and sensible not even able to score !!! according to one line of reality and purpose ... drunk a whole host of FEELINGS THAT HE KNOWS ... AT the expense of REAL ...
AND IF YOU NEED SCIENTIFIC HERE :
The adequacy of the model — match properties (functions/parameters/characteristics etc.) model and relevant properties of the simulated object.
The adequacy of the experience and perception (from the Latin. adaequatus — equal, equal) — invariance of the basic properties of the subjective image, its compliance with the conventional description of the object. Inadequate way of reflection, as, for example, in the illusions of perception, are misaligned with other forms of perceptual and cognitive experience of the individual.
in simple language we can say :
the ambition of creating in his mind a picture of the world which corresponds to the picture of the world in reality ...
so when a person attributes the lights to the sun God or the spirit of Napoleon it is inadequate or drunk
what is the connection with my post about placebo ? you do not specify which illnesses write !!!Then it would be mental and psychosomatic disorders were treated with a Placebo, and very effective. However, psychiatrists each year the queue longer.
you and I unlearned ? you verbiage on the subject of the work of svetlice ? and how !!! but even simple logic neobosnovano ...what is this "Sober mind".
sober brain
Молодой человек
Good day to all!
Now I read your correspondence on the room and decided to describe their experience of everyday life:
1) Before didn't know more about the parlor, had been agitatie another example of the modulator and bought a breeze with
Yuzal long it dragged on themselves and never how it felt.
And in the end, due to the fact that its type is not particularly suitable(flat card) that would wear it on the neck I have moved into a purse. Where I gave him to bring a larger financial income.
In the end, since by Kupka took 2 months and at work I got promoted to the RFP that the crisis is very, very nice
BUT!!!! is there merit in the breeze-I can not say, because at this background I really worked hard at work and more skenazy to the fact that because of this I SN increased.
2) read literature on this subject, after sitting on the forums.
Decided to make a device like this samostoyatelno namely:
1)bought shungite oval mascot. Shungite itself is not bad natural harmonizer
2) found the modules sakaeva.
3) I pasted them on both sides of shungite.
4) That turned out such a harmonizer
The issue price does not exceed 300 rubles
And what is most interesting, I feel it when you run Exercises at. well, or so I think that I feel confident because be can't.
Looks very nice and stylish on the neck.
3) would love to try the Parlor but the price strikes me
Actually what?
And most importantly what does it give me?
As above described in arsinale have a breeze-with the purse and "self-made talisman" on the neck.
Spiri
and that means You just dispute the proposed statements. ? how
to do it DIFFICULT ? NEPOYMU WHAT ARE YOU ? I challenge it assertion and argue ... and you what their claims are baseless ?
and that means your : Let us talk in this case convincingly.
I argue just that
it remains to you to substantiate their claims and we will come to what you call
try to understand the meaning of my answer and go back and read their posts - only allegations and accusations, but always there is no justification and evidence
if you do not see the point in my posts is nezatrudnit whether you refer to ... well, in the sense to show where I wrote wrongly and where they neuromental ?Just reading Your posts, consisting of scientific terms and .... dots, inclined to think that You simply challenge the proposed statements. Let's talk in this case convincingly. At the same time, flooding will be less (forgive me moderators).
Спири Гость
