I do not know. Just downloaded, just like you. Have not had time to try.And MindLabPro estchto different from Photosonix in terms of the impact?
The program MindExplorer SW 3.6
session for mindlab pro , thank Logikhave
http://narod.ru/disk/3683458001/MindLabPro.rar.html
or here
http://depositfiles.com/files/zzwk2svok
or here
Re: Program MindExplorer SW 3.6
Does anyone still have working versions of MindExplorer and MindLabPro?
I have a crack mindexplorer to him a bundle of sessions from different mindmachine
http://depositfiles.com/files/j1tmpxzdm
crack working, throw in a folder with the program launched, the window of the crack disappears
then run the program, see the registration window - in the name of writing a few words with a space, or a couple of numbers
password any.
password any.
dimych
Thank you!
For session respect!
Thank you!
In MindExplorer carrier frequencies are specified by digital values in Hz and notes. Carefully dig deeper, drew attention to the fact that all the values of the notes A and B are shifted by one octave.
Compared with these tables:
http://blog.cuesonic.com/2011/05/25/1/
http://gtwiki.2102.su/index.php?title=% ... 1%82%D0%B0
Maybe someone knows how to translate the notes into frequencies?
Дмитрий__
- Has thanked: 2 times
- Been thanked: 27 times
Note La 1 octave (I don't remember what the marking on the scale of the midi standard, something like A+digit) is 440 Hz. Octaves are always different from each other 2 times frequency. That is, 880 Hz, 1320, etc.
Within the octave usually 12 semitones, as they are from each other - depends on scale type. The most natural - string - whole fractions. BUT usually for convenience, transpose melodies (i.e., transfer it to a different key), the frequency of the halftones differ in root of 12 degrees 2 times. THAT is, the C minor 1 octave is 440гц*2^(1/12) = 440*1,0595 = 466
C 1 octave == 440*1,0595^2= 494 Hz
well, and so it's very simple
does anyone still have working versions of MindExplorer 3.7 or higher, and then all the links that you have in this thread are outdated.
Dimych thank you for it. on Win 8.1 got up fine., it works, and the session is still separate thanks.
