More about Panacea, on transpacks.quantummagic.org - you can try the Panacea in the broadcast almost immediately after registration, if not mistaken.
And so, the card transfer is a very useful thing, many people underestimate. About in a short time you can make processing a bunch of things in БЖ1.0 with almost zero costs.
Card transfer (BZ 2.2/2.5/2.6/2.7/2.8/the Panacea)
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
According to the materials of the forum have built such a strategy. Using map migration create BJ 1.0. Based on BJ 1.0. create a Panacea. Then you can optionally create 2.5, 2.6, 2.7 and 2.8
- Иван Славов
Better re-read the forum materials.
BJ 1 is more effective than a literal panacea. It can be applied to any object (socks, belt, wooden bracelet on each link, etc.).Then, if desired, the matrix can wipe.
Map of migration of course leaves a "trace" use 1.0, but it is still in the map transfer
and to charge items for free easier to use, as rightly wrote above, matrix charging a panacea or something, the range of projects is huge. Than a good map - but it gives a powerful the product (commercial usually are stronger handmade
)on an arbitrary object. It is convenient.
