Ring. Healing practices
Re: Healing practices
Post by Шалтай Балтай » Fri Nov 25, 2016 10:44
Ross&Moor Nanobeat BT10W
Key features
Sound
mono
Total power
10 W
Food
battery, USB
Design
The number of lanes AC
1
Wall mount
there
Food
Type of batteries
your own
Connection
Inputs
linear (mini jack)
Interfaces
Bluetooth
Additionally
Function
built-in microphone
Dimensions (WxHxD)
55x72x55 mm
Post by Шалтай Балтай » Fri Nov 25, 2016 10:54
I've been more occupied by the question, and if you take the stereo vibrodynamic and submit it mineralki. :roll:
here is an interesting fishko 8)
Post by Шалтай Балтай » Wed Nov 30, 2016 12:12
Шалтай Балтай wrote:
Code: Select all
adrenals | adrenals | 492.8 | B
bladder | urinary bladder | 352 | F
blood | blood | 321.9 | E
bone | bone | 418.3 | Ab
brain | brain | 315.8 | Eb
colon | large intestine | 176 | F
fat_cells | fat cells | 295.8 | C#
gall_bladder | gallbladder | 164.3 | E
intestines | bowels | 281. | C#
kidney | kidney | 319.88 | Eb
liver | liver | 317.83 | Eb
lungs | lungs | 220 | A
muscles | muscle | 324 | E
pancreas | pancreas | 117.3 | C#
stomach | stomach | 110 | A
http://www.orgone.guru/wp-content/uploa ... .1m.tar.gz
Post by Шалтай Балтай » Wed Nov 30, 2016 12:13
Code: Select all
calcium | calcium | 320
chromium | chrome | 384
copper | copper | 464
iodine | iodine | 424
iron | iron | 416
manganese | manganese | 400
molybdenum | molybdenum | 336
phosphorus | phosphorus | 480
potassium | potassium | 304
selenium | selenium | 272
zinc | zinc | 480
iron is iron, and Yandex - garbage :lol: / smile - left
PS
Her - kirilicheva letter of the Russian alphabet. The word Fuck can be found in the dictionary of VI dal
Post by Шалтай Балтай » Wed Nov 30, 2016 13:45
I quietly I put the audio session. Mainly by Reif, Barbara heero and Hilde Clark.
Guidelines for using
  • 5-10 min a day, not more.
  • 7-10 days, then rest a week, maybe two
  • after the session can greatly pull in a dream, space off. This is Norman, even good. Do not forget about it.
  • In no case do not sit behind the wheel immediately after the session. Min 20-30 min to recover.
order listening, but also do sessions individually.
good luck
Влад Н.
Post by Влад Н. » Thu Dec 01, 2016 7:55
Good day! Humpty and Aku-WAC made some of the measurements?
Post by Шалтай Балтай » Thu Dec 01, 2016 10:19
Good day, Vlad N.
If You are on that Host that video, it is a Sacred Measurement, 144; 3.5 Size/Harmonics
Влад Н.
Post by Влад Н. » Thu Dec 01, 2016 10:56
Also wanted to clarify... mp files that are posted here, these are audio files that are made with the help of Aku-VAK (sacred scoop), using different frequencies?
Post by Шалтай Балтай » Thu Dec 01, 2016 11:10
Влад Н. wrote:audio files that are made with the help of Aku-VAK (sacred scoop), using different frequencies?
:roll: no
It's just degenerancy the computer tones of different frequencies.
no magic. everything is very flat. Anyone can do the same.
Влад Н.
Post by Влад Н. » Thu Dec 01, 2016 12:33
Clear. :)
1. And these mp files, you need to only play together with Aku-HAC-Ohm or without him and will be the same effect?
2. Video is already Sacred ACU-VAC with the frequency - Right!? (I haven't watched it)
Post by Шалтай Балтай » Thu Dec 01, 2016 13:03
Влад Н. wrote:And these mp files, you need to only play together with Aku-HAC-Ohm or without him and will be the same effect?
IMHO: a Simple audio (significant) effect is not. It is better to take 432 or 528 music and listen to it
Session data created by activation products. In this case, the efficiency of the product increases significantly or orders. Depends on the stiffness of the structure.
Влад Н. wrote:Video is already Sacred ACU-VAC with the frequency - Right!? (I haven't watched it)
Yes. Videos you can just watch. This has the effect. Still that remote effects. For a tensor field is a completely normal form of work.
The combination of video with the product (located between the monitor and operator) - enhances the effect.
I have plans to make a small video on using sessions in conjunction with the products. I understand that a "gun" with a Knot "on a stick", :) will be able to collect every :)
It is only a prototype, In the market yet and is not planned. For a good tree is not working properly. Need ebony design. Have some work to do, in short.
Влад Н.
Post by Влад Н. » Thu Dec 01, 2016 15:28
Шалтай Балтай wrote:remote effects. For a tensor field is a completely normal form of work.
This is interesting!! Where you can read about this remote influence?
Post by Шалтай Балтай » Thu Dec 01, 2016 15:43
that's all there is
viewtopic.php?f=57&t=6141
viewtopic.php?f=57&t=6147
the Versatility:
Application AcuVac Coil is not limited only to curative effect. You can use the device for pulling the negative energy out of any situation. Point the South pole of the coil in the direction of a crying baby, an obnoxious person or group of people, equipment not working properly, or any other circumstances out of harmony, the Node will do the trick. You can even position a coil in front of the picture of a sick or troubled person and the expected useful developments will occur in a short period of time.
Post by Шалтай Балтай » Thu Dec 01, 2016 16:01
PS
The Internet, unfortunately a very poor ACC. infoy.
I'd porekomendoval view website'brien: http://twistedsage.com/
I would venture to advise You to pay attention to it 5мерный Animator: http://twistedsage.com/products/5d_animator/
This is directly related to remote work.
ZZY
But be careful! On the website'brien a huge number of photo products. And how ... can't :)
kidding
Влад Н.
Post by Влад Н. » Thu Dec 01, 2016 16:41
By the way, I created a virtual harmonizer for the room, created for themselves, but in the room were other people. It turns out that they also felt the impact. This was evident in their reactions. One person actually asleep on the job went, also complained of weakness in the body. Also set 2 times, but purposefully,I set the harmonizer at home to influence the father, but the che every time (maybe a coincidence) he was getting worse. The first time the temperature rose to 40 C, which normalized within 3 days. And the second time I called an ambulance. Now th-that don't want next to him to put a virtual product. I myself even can't understand what the product is, just intention, figuratively create and it affects everyone around you!!
It is a pity that the mind at the same time, very tired and overloading me, 2-3 hours and "sosnyaki" torture :)
Post by Шалтай Балтай » Thu Dec 01, 2016 18:40
Vlad N.
Thank you for your review.
Влад Н. wrote:One person actually asleep on the job went, also complained of weakness in the body
Влад Н. wrote:but che every time (maybe a coincidence) he was getting worse. The first time the temperature rose to 40 C, which normalized within 3 days.
it's a good response. On places of power, almost immediately falling asleep. Like pulled something unnecessary.
Hyperactivity - a sign either of patogeni or parasites.
I personally drink water from the rings has led to 3 days of strong eliminations. tepmerature did not exist. I wrote about this earlier.
From slim the same thing happened. He describes this experience. It is very good.
анатали
Post by анатали » Thu Dec 01, 2016 21:00
Good evening!tell me what program to open the files on the phone and it downloaded but doesn't open?
Post by Шалтай Балтай » Thu Dec 01, 2016 21:04
Влад Н.
Post by Влад Н. » Fri Dec 02, 2016 15:24
Шалтай Балтай wrote:Hyperactivity - a sign either of patogeni or parasites.
How to get rid of this parasite? And can it is not necessary to remove? I see that many people zasrany!!
Post by Шалтай Балтай » Fri Dec 02, 2016 17:32
Влад Н. wrote:I see that many people zasrany!!
in the city - all the Besh each. And the one who chepachet and the one who reads.
BUT as to the rings it has (extremely) oposredovanie relationship,
then I stop. because: preamble:
I don't give private consultations (or try to avoid).
Post by Шалтай Балтай » Sat Dec 03, 2016 11:42
Александр С
Post by Александр С » Thu Dec 29, 2016 0:09
Humpty, it is possible to activate to connect the wire from the speaker + to the product. Minus in free flight.
Re: The Ring. Healing practices
Post by Шалтай Балтай » Fri Mar 10, 2017 3:08
Anti-parasite
[youtube]http://www.youtube.com/watch?v=Tn-SgDOqMBQ[/youtube]
Code: Select all
Name Hz
anti-parasite 125
anti-parasite 95
anti-parasite 72
anti-parasite 20
anti-parasite 444
anti-parasite 1865
Session for download
Григорич
Post by Григорич » Tue Jul 11, 2017 22:31
Шалтай Балтай wrote:Yes, Yes, Yes, exactly - the AURA!
Cling inside the aura and pull for the judges, as far as possible. It would certainly be interesting to see this "field" the picture of the part :)
Apparently the node creates an additional vortex, which when deleted, only stronger spins up, because harnessed to the pain. Therefore, the pull is so strong when you remove it... IMHO, of course.
Hello!
some days I read your conversations on the forum. So decided to join. Jewelry (rings and okuwaki) are just going to buy the Kola (already called) to something to start with
and about working with akovali to remove it...and one....if "hooked" then quietly crawl away...in protivopolojnuu side thereby increasing the effect of...... :oops:
sorry to interfere ...just very interested in the process
the second option...spinning.....as "hooked"...then quietly, slowly twist the coil.....and ukuvuka slowly but surely crawls.....doing my own thing
Post by Шалтай Балтай » Wed Jul 12, 2017 12:25
Gregorich
Good zdraveska!
Григорич wrote:the second option...spinning.....as "hooked"...then quietly, slowly twist the coil.....and ukuvuka slowly but surely crawls.....doing my own thing
Yes, I understand. The rotation of the ring node has very good reception. respect! az
Voobsheto sometimes it's like fishing. I, for example, from time to time, pass a knot through the body, such as it is there, sometimes in the middle of something and got take out... :)
