spectrogram:
Made, put. Feels there is a difference of course. The modulated signal is much more interesting. The dreams have changed. But it should be long to roll, even used the 3 weeks that it would be possible to draw any conclusions.... View.Шалтай Балтай wrote:To SP will not putand LM - dare
Probably here is the correct 1 Hz Meander session:Шалтай Балтай wrote:the Art of Mak
try: http://www.orgone.guru/wp-content/uploa ... .15Min.zip
an empty image does not carry not energy not component infoШалтай Балтай wrote:Who can guess, what?![]()
spectrogram:
thank you for your constructive criticismаВАЛОН wrote:an empty picture carries no energy no component info
hmm, well, if anyone has any songwriting ability. The idea is interestingаВАЛОН wrote:once You personally created melody
There is such a program called FL studio. Among other things, there is a module which converts the picture into sound, pretty funny. Graphical representation of the spectrum is in some modern audio editors. These editors allow you to make various manipulations with images (erase something, move, weaken, strengthen, etc.) reflected in the source material. How these things apply in our theme - I'll never know, though, and tempting looks. The problem is that there is no clear conversion, graphic representation of sound has only one parameter, interpreted by far - the countdown time. Height of tone, intensity, harmonics can be displayed in an arbitrary scale. I prefer simple and reliable methods: they generate what is necessary, and the player on the device to get lost and lack of it)))мимоходом wrote:and perhaps such codecs exist and are common
чернокнижник wrote:these things apply to our topic - I'll never know
So he delay.чернокнижник wrote:With the same success it is possible to point a finger at any point in space... the sound of her... And we can be just a drawing to put on the device and not bother with transformations? The people did so, and all arranged!
Code: Select all
2675 | The Crystal Resonatorcontinuing the conversationШалтай Балтай wrote:well, or harmonics, 5350, 10700
on the bearing you can apply the frequency, in turn, modulated by thought. In!
It is already a business conversation.88,200 Hz Sampling rate used by some professional recording equipment when the destination is CD (multiples of 44,100 Hz). Some pro audio gear uses (or is able to select) 88.2 kHz sampling, including mixers, EQs, compressors, reverb, crossovers and recording devices.
96,000 Hz DVD-Audio, some LPCM DVD tracks, BD-ROM (Blu-ray Disc) audio tracks, HD DVD (High Definition DVD) audio tracks. Some professional recording and production equipment is able to select 96 kHz sampling. This sampling frequency is twice the 48 kHz standard commonly used with audio on professional equipment.
I beg pardon, but I want to find out what's now: the resonance of quartz itself as a substance? That is not a plate or a crystal and at the level of molecules? If there is a link not on the table, and what kind of research question - I would be very grateful! After all, if the known resonance frequency of quartz, it should be frequency and other minerals/substances.Шалтай Балтай wrote:resonance quartz
