Activator.
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: Activator.
Post by Бисо » Sat Dec 26, 2015 20:50
Галатея wrote:I understand that for the independent production of the Activator it is necessary to print the file 1.2, to apply the figures from the 1.3 file, then print this sheet 1.5 file and put the numbers from a file 1.4 and then laminated? Would it be possible to use a commercial anchor to a self-made Activator, whether it's more effective than using free anchor?
Yes, that's right.
You can use commercial anchors to a self-made Activator, I think, will be more effective.
Расторгуев
Has thanked: 6 times
Re: Activator.
Post by Расторгуев » Sun Dec 27, 2015 16:54
Michael and redraw all in sequence,without the use of a copier so it is possible,would such a product work?
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: Activator.
Post by Petr99 » Sun Dec 27, 2015 17:42
Will. Does the printer need only for markup.
Арго
Re: Activator.
Post by Арго » Mon Dec 28, 2015 21:52
it is possible on the printed Activator (from file 1.2 ) to manually draw a table from a file 1.5 and apply the figures from the 1.4 file ?
димыч
Has thanked: 7 times
Been thanked: 16 times
Re: Activator.
Post by димыч » Tue Dec 29, 2015 11:39
Yes
Дмитрий Т
Been thanked: 2 times
Re: Activator.
Post by Дмитрий Т » Tue Dec 29, 2015 13:55
Made a listing, put yourself in the center.
Two teeth began to ache, bearable, went to work it went. On the second day has no such.
That's power. I cannot even imagine what the "real" Activator...
And thank you
Question: I understand that if you do not know where to move and intuitive oduetse, it is better to leave people in the center to make the total harmonization?
Including programs health, protection, stop magic?
Re: Activator.
Post by Михаил_ » Wed Dec 30, 2015 18:47
No, it is possible to work to place it.... itself in the center.
Re: Activator.
Post by Михаил_ » Wed Dec 30, 2015 18:49
Yes, from the manufacturing process commercial (in the sense of power) me a little ... pripuskaet :) :) :) :) :) and since people have seized ( I mean demand ) that I go that day in vieilley this alternative :)
Too bad you can't upload pictures client activators - how they are different.... smooth and bubbly, convex/concave, with a rough center and so on..... including different colors when an identical mixture to fill.
Княжна Инстасса
Been thanked: 9 times
Re: Activator.
Post by Княжна Инстасса » Wed Dec 30, 2015 19:25
If I anchors the other person and puts it in the center, that is for him to be?
Been thanked: 10 times
Re: Activator.
Post by Мастер 108 » Wed Dec 30, 2015 23:14
Княжна Инстасса wrote:that is for him to be?
It will be for you
Лоцман
Re: Activator.
Post by Лоцман » Wed Dec 30, 2015 23:47
Duplicated some of the anchors on the Stabilizer.Why in one area n stabe perceive me something like the earth... and the Activator :)
Re: Activator.
Post by Михаил_ » Thu Dec 31, 2015 10:33
Лолита wrote:Got my activator, the size of a basin)))))
Well, that sat - knocked down completely. I see him in my head any thoughts
at the heart and throat chakras, this wave, like boiling water.
When the hand above him holding the hand of stabs and twists and rings heat up instantly.
We're each other immediately liked)))
Big thanks to Michael, an artifact of such power appeared in that time.
Already set goals for the new year and the goal of solitaire. And client goals. And purpose just good
people.
There is an understanding that you need special anchors for activator. But that is another topic.
More important - with such power, he is very responsive and thoughtful.
Dorval to the Internet))) and I can't stop.
Today showed a friend photos of the stars of the activator, according to her ISS covered instantly.
And long time passed this condition.
Re: Activator.
Post by Михаил_ » Thu Dec 31, 2015 10:35
They are special, and staba will fit,,,
PS (with a basin this is due to the standard trigger.... 40cm in it... later I will post photos neutral, ie not client activator.)
МерКаБа
Been thanked: 25 times
Re: Activator.
Post by МерКаБа » Thu Dec 31, 2015 16:12
Ready-to-fill Activator to JPEG. In the centre is a table made 75% transparent, but you can see where to enter with no problems.
Michael_ thank you :ay
Option 1 (without the circle):
Option 2 (with a circumference of ~40 and close to the original proportions)
Аиша
Has thanked: 56 times
Been thanked: 14 times
Re: Activator.
Post by Аиша » Thu Dec 31, 2015 16:22
Merkaba! Thank you !!! :o
Re: Activator.
Post by Михаил_ » Thu Dec 31, 2015 16:25
A small comment - the circle can be extended significantly to the field work areas were formed.... In other words, place a star in the field is approximately double the radius ( in commercial device the star in the middle of the field is 40cm).
МерКаБа
Re: Activator.
Post by МерКаБа » Thu Dec 31, 2015 17:24
Michael_ please tell me, so what's the key difference Staba from the Activator?
Because both work with the consciousness of the operator, both have the same axis and zones (boundaries?).
Appearance, differ only in the way of creation and power :roll: :)
PS the power of the handmade is really amazing. I am 6 years in the theme of BJ and still surprised))) like a piece of paper with a star (even without numbers) may make such tough ISS :shock: :)
Petr99
Re: Activator.
Post by Petr99 » Thu Dec 31, 2015 18:26
As I understand it, stabe impact on the world comes from the area of NATO, i.e., the operator carries out the impact from the world of NATO. It happens without the stabilizer, but the stub structures, and enhances the operator.
In the activator zone neito no, instead there is a zone of formation of the buffer from the personal world of the operator, i.e. the operator carries out his creative energy and the impact is also structured, as in stave, but has very many advantages, which you can learn about in Seminary sanitech personal worlds.
Владимирович
Re: Activator.
Post by Владимирович » Thu Dec 31, 2015 20:00
Михаил_ wrote:Little comment is a circle can be separated significantly to the field work areas were formed.... In other words, place a star in the field is approximately double the radius ( in commercial device the star in the middle of the field is 40cm).
Michael, and such a question: if the Activator is printed on a sheet without the circle, where the end zone? At the edge of the sheet? And then if I want to pour the Activator into a round dish, that will not hurt whether circumcision is already generated areas ?
Галатея
Re: Activator.
Post by Галатея » Sun Jan 03, 2016 5:10
Hello Michael. Can I use a homemade Activator to enhance the objectives formulated in the deck Smile Ishirkovo cat? Will it be effective? How in this case to use the Activator, which zone is suitable for placement of an anchor? Whether the anchor also prescribe this goal? First you have to put the purpose of the Activator, and then solitaire? Please explain.
Re: Activator.
Post by Михаил_ » Mon Jan 04, 2016 18:16
1) they don't really end. the density operator of the influence of falls. Actually can do mentally to determine where.
2) don't hurt.
Re: Activator.
Post by Михаил_ » Mon Jan 04, 2016 18:19
Галатея wrote:Hello Michael. Can I use a homemade Activator to enhance the objectives formulated in the deck Smile Ishirkovo cat? Will it be effective? How in this case to use the Activator, which zone is suitable for placement of an anchor? Whether the anchor also prescribe this goal? First you have to put the purpose of the Activator, and then solitaire? Please explain.
1)
2) will effectively
3) the zone may either be similar to the type of solitaire (it depends on the target card, for example in clubs it is better to take the development/chaos), or to be generally independent of the type of solitaire.
4) the anchor can be prescribed as the goal, or something close to it. It is necessary to look what is tied to the anchor. Possible options (for example, you anchored yourself a goal to write about yourself in the world).
5) the order does not matter. In the process to change the anchor a few times, particularly is to do it after solitaire (which will change the world and old anchor may be not so much relevant). In General, anchors are useful to update.
Re: Activator.
Post by Михаил_ » Mon Jan 04, 2016 18:22
МерКаБа wrote:Michael_ please tell me, so what's the key difference Staba from the Activator?
I have sufficiently described it during the opening theme on the webinar/meeting.
This is a different projection from the interaction of Mir-operator. In the current situation, the world has changed so that this "lever" is more effective.
And they are absolutely NOT the SAME!!!
in Activator no NATO and borders, this is a significant difference!
Re: Activator.
Post by Михаил_ » Mon Jan 04, 2016 18:27
Petr99 wrote:As I understand it, stabe impact on the world comes from the area of NATO, i.e., the operator carries out the impact from the world of NATO. It happens without the stabilizer, but the stub structures, and enhances the operator.
No.
Not so.
The operator of the stabilizer holds the projection of his view of the world in the world (and here from the world of NATO? just where this area is).
Tell me, I'm talking about personal peace and buffer in the aspect of the webinar activator?
There is a model of the world (it automatically is in soznane operator as the archetype) and in the case of the activator it is not a model of the world and the typical for the operator the process of the projection operator in his area (which is a thing specified mental) and it NATO and boundaries are not inherent to what "I think" statement. He works in the area of active influence. Nothing is said about the buffer. This is a different description of the same process. To date, this approach effectively to influence, and the boundaries and NATO not as relevant at the same time, no one bothers to use the activator and stabilizer together. I'm not going to shoot production stabilizers, and free to do. Just the approach is different.
Галатея
Re: Activator.
Post by Галатея » Tue Jan 05, 2016 2:42
Michael, I have a goal associated with the job search, it turns out mumble. In which area of the Activator in this case is to place an anchor? If not difficult explain which areas on the Activator suitable for each suit? I would like to learn how to use anchors, where you can read about it? If there is a link to the details I would be very grateful.
