Designer ties
ММ
Has thanked: 185 times
Been thanked: 40 times
Re: Designer ties
Post by ММ » Sat Oct 17, 2015 23:28
Спящая Кошка wrote:What is a good leveling skill "patience".. :) Although the designer is already working hard, it seems. Again, like Your other items..
Michael, thank you for Your form submission information! Any description is so clear to mind that it generally does not resist, and that is probably why the subconscious mind perceives all read as a direct guide to action. :)
V takom sluchae privedite 5 primerov togo kak srabotal konstruktor dlya vashego blaga.
Спящая Кошка
Been thanked: 5 times
Re: Designer ties
Post by Спящая Кошка » Sun Oct 18, 2015 10:35
And why 5? :)
I quite long did not give rest to one specific link that I could not break. Approached from different angles, it is, incidentally, helped the Conductor. But on a conscious level, it was so hard to work out, as very succinctly put Michael under tension is electric. Every attempt has led to the fact that I was boiling like a kettle, and it only intensified this relationship. And now I can't feel anything in that direction... Look there - and there is nothing. Long-term results to speak still early, but 3 days - flight normal. :ay
And one interface itself prescribed - works! :D And everything else is fine with me.
Just physical products provide additional concentration, and the effect, I think, will be more powerful. So be sure to make the constructor as soon as Michael will publish.
Астероид
Has thanked: 22 times
Been thanked: 9 times
Re: Designer ties
Post by Астероид » Sun Oct 18, 2015 20:19
What if I have on the active side of Pandora will lie not one card, but two or all three?
What happens if I lie card Entry on the active side, when I communicate with other people?
What happens if I forget on the active side of the card Activation or Reset, and lie with her to sleep? (map will be next to me - not very far)
What if on a specific issue in the relationship I several times with the reset going to talk about various things, but not real output in the map entry. Will ulitsa and ulitsa? In what it will show? In the first place?
What happens if I work on map part? That is, the cards will be with me, I'm going to change them. And sleep will not. But I will deal with activities not related to maps? What usually occurs?
Илья Гор
Re: Designer ties
Post by Илья Гор » Sun Oct 18, 2015 21:52
Michael, please tell me the Entry will only work on the time that the card is on the Pandora, or rather a certain time period, and the record is to be done "forever"?
Рикуся
Has thanked: 7 times
Been thanked: 12 times
Re: Designer ties
Post by Рикуся » Mon Oct 19, 2015 0:25
Астероид wrote:What happens if I have on the active side of Pandora will lie not one card, but two or all three?
I've had that I left on the active side of the zero and went to bed and discovered the next day only in the evening. All this time I was in such a state of unresponsiveness and a pleasant inner emptiness. But it was absolutely impossible to work with. I am for a whole day only managed 2 letters to send and that it was worth the enormous effort :) All 3 cards I also managed on the active side then left, also on the day. But zeroing the first lay to the activator, so that the effect was about the same. Only more, because I this day didn't need to go anywhere and I'm completely in these sensations plunged. Strong feel like there are really only my space, and all around just an illusion . The output is then the real reset and a feeling of deep relaxation, but it takes a willful decision to get out of this state and the time for adaptation. And don't think that specifically is too long to leave.
Re: Designer ties
Post by Михаил_ » Thu Oct 22, 2015 3:10
25,37,36,29,24,27,6,15,18,23,55,15,55,0,52,9,9,34,33,49,5,10,24,50,18,45,3,20,32,32,27,45,47,9,33,14,1,50,37,1,49,8,54,33,15,26,45,5,21,25,38,4,11,30,27,32,41,38,51,56,1,57,22,32,15,18,3,1,50,31,54,13,49,2,17,4,43,38,17,2,57,10,18,3,20,18,9,0,9,27,49,32,23,15,35,48,37,3,1,34,24,13,55,4,16,55,14,33,25,11,16,41,16,30,16,20,59,25,38,39,8,44,16,59,56,0,52,
6,45,41,33,21,28,20,4,46,15,58,35,39,31,10,26,49,6,43,24,55,46,27,39,43,6,32,58,7,22,3,37,11,22,5,37,9,20,46,55,60,13,5,28,24,39,19,15,51,26,15,28,58,46,19,46,25,33,10,35,35,24,59,3,23,23,30,3,54,21,36,2,39,22,24,14,11,54,52,12,32,33,12,46,37,6,11,11,16,20,18,0,23,47,56,28,7,1,0,44,14,1,45,25,9,53,48,41,6,47,34,57,54,5,29,42,35,9,1,18,5,16,35,2,35,6,19,
here it is the Lite version of the designer.
The numbers located on the card activator.
And from the picture do work cards.
The rest is all well :)
Re: Designer ties
Post by Михаил_ » Thu Oct 22, 2015 3:19
I hope all have stated clearly, sorry for such a long edition with activator working pretty...
Has thanked: 5 times
Been thanked: 8 times
Re: Designer ties
Post by Воффка » Thu Oct 22, 2015 3:42
Михаил_ wrote:here it is the Lite version of the designer.
How it is possible to combine commercial version? :) Be used simultaneously or sequentially?
Спящая Кошка
Re: Designer ties
Post by Спящая Кошка » Thu Oct 22, 2015 12:52
Michael, thank you! :o All clear.
Re: Designer ties
Post by Михаил_ » Thu Oct 22, 2015 14:52
A question of philosophy - WHY ? :)
Explain, then I will answer as :)
but the question itself is literally reminiscent of an old bearded anecdote about the mermaid and the fisherman :)
It is identical to the product.
Card the Lite version and the activator is weaker than for commercial reasons, different technical implementation.
In the presence of nuclei of Pandora (in the sense of European commercial cards including VIP) can be enhanced activator. The cards are still somewhat weaker. Will it affect efficiency ? not a fact/don't know. Because here depends on the person/extent of neglect of the problems of sociogenic he...
Алега
Been thanked: 3 times
Re: Designer ties
Post by Алега » Thu Oct 22, 2015 16:02
Guess what card to print on a laser printer and then laminate it,and what will be the optimal size, and what print resolution?
Андрей ВН
Has thanked: 9 times
Re: Designer ties
Post by Андрей ВН » Thu Oct 22, 2015 16:06
To print better on film or on paper?
Re: Designer ties
Post by Михаил_ » Thu Oct 22, 2015 16:23
1. better laser on the film if any.
2. you can laminate
3. recommend convenient size (the size of a passport or credit card).
Арнольд
Has thanked: 44 times
Re: Designer ties
Post by Арнольд » Thu Oct 22, 2015 17:34
On map "Pandora" is placed, the printed activator and on top of one of the working cards.?
On what side of the map "Pandora" to put the activator and work cards.?
Аиша
Has thanked: 56 times
Been thanked: 14 times
Re: Designer ties
Post by Аиша » Thu Oct 22, 2015 19:34
Michael! Thanks for the info!
Кимили
Has thanked: 6 times
Re: Designer ties
Post by Кимили » Thu Oct 22, 2015 21:48
found the answer. you can delete this message.
Кимили
Re: Designer ties
Post by Кимили » Thu Oct 22, 2015 21:51
Sori.
activator separate map.
Русалка
Been thanked: 18 times
Re: Designer ties
Post by Русалка » Thu Oct 22, 2015 23:26
Михаил_ wrote:Attention — at the stage of zeroing the man falls out of egregorial machine and she loses sight of him ceasing to flow from it (both ways), and his inclusion in the under egregorial structure is also temporarily terminated.
I liked it a lot, and then next:
Михаил_ wrote:Reset — as a mechanism to dull yourself just psychological pressure.
And all? For some reason I thought that this card can be used more widely and actively ample, because the fallout from "egregorial machine" the idea is to remove certain restrictions imposed. To use the status of "zeroing" in addition to the psychological effect, I would like a little more detail.
Владмосква
Been thanked: 7 times
Re: Designer ties
Post by Владмосква » Sat Oct 24, 2015 9:23
Арнольд wrote:In map "Pandora" is placed, the printed activator and on top of one of the working cards.?
Yes
No difference, the kernel, both sides are working.
Хаст
Has thanked: 13 times
Hast
Post by Хаст » Sat Oct 24, 2015 16:06
And this:
Image maps open on your tablet or smart, it put the activator with numbers.
Will work? In my opinion no worse than should be and even better.
Re: Designer ties
Post by Михаил_ » Wed Oct 28, 2015 11:54
1. it is not necessary to do on the tablet if it is written on the printout.
2. cards are placed on the activator side of the figures.
3. reset brings the person in inactive status. To use this as a tool of liberation from limitations, for this is the whole constructor. But it does not need to be in reset condition, it is necessary to purge the designer, the end (possibly after a few times) and would be a suitable condition.
4. and Yes, each card is used separately as a standalone tool (with the activator, of course).
5. Pandora it is possible not to put, she's had enough of the team.
Re: Designer ties
Post by Воффка » Thu Oct 29, 2015 1:09
Michael_
Michael, tell me, what's the range of a constructor? If people are nearby, they too fall under? As a designer acts on animals? :)
Владмосква
Re: Designer ties
Post by Владмосква » Sat Oct 31, 2015 2:28
Воффка wrote:what's the range of a constructor? If people are nearby, they too fall under?
Normal constructor is only valid for the operator.
Another person can only act VIP-constructor, which is not yet released, will be released in early November.
Re: Designer ties
Post by Михаил_ » Sun Nov 01, 2015 0:00
Usually, my products are not designed to work with the space (designed to work with the space ISS-1/ISS-2 , EP and similar) no problems fonit on others ( not kicking).
The designer works with the operator only. And the operator himself can fonit - Yes... because its processes are under the designer - they are kicking. Another thing is that it's regulated intelligently...
Has thanked: 112 times
Been thanked: 71 times
Re: Designer ties
Post by АндрейКо » Thu Nov 05, 2015 2:03
Free designer links:
1. compared to the call mode fire - stronger
(all by itself was to be remembered...)
2. but the upgrade as weaker than than at the webinar
(not to the extent of the "Stripping")
to compare the results can not yet...
(while writing the message, the light was turned off for a few minutes in...)
