Psychic workshop. Discussion.
cool technique!
my switch went right... some drove here and there in the center of the head was an interesting experience...I recommend to drive switching in the figure and rapidly changing at least the fingers of the hands located about the wire...
and continue switching on the fingers of inertia...
in the alternative mode are clearly visible auric field that surrounds your fingers...
thank you!
thank you!
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Re: Psychic-workshop
Actually it's not so much brains happy, rather the "energy body", which begins to Wake up when faced with the brainstorming effort, and was glad that he paid attention.
Um, more and more convinced that I signed up for this workshop by chance.. Thanks..
Drew on paper the same, only bigger. Switches easily. Made from wire this thing first went tight, then bent it so that the sides are close to each other, about one inch, and turned out, but not immediately, as dimych noticed in the center of the head do have specific feelings, but only when working with the real object, when a work print, it seems nothing special. Interestingly, it turned out a few times with the wire, I thought... well learned, no, there it was. Morning tried, in any way, and with fingers turned out.
Yes, a visible 'aura' of the fingers.. Because, however, I have not
As endorfina tablet /well, I pointed out my BRM-and that is sometimes broadcast at me energoinformational component of endorfinov, like now, it turns out, the exercise 'fork' workshop has disabled these possibilities are../.
inнева wrote:there are specific sensations
and begin to laugh at how absolutely small the child, and the smile sort of keeps itself..нева wrote:in the center of the head..
No, well, just sort of "threw" 200 gram of vodka..
A strong impact on
Аура wrote:"energy body"
Good day!
Very interesting!
There is still no information for understanding the processes?
Very interesting!
Can't follow the link! 504To understand the processes proishodyaschih during the execution of the technician of the workshop, it is recommended to study the research of Pavlov about the "bright spot" http://bookap.info/psyhofizio/aleksandr ... /gl61.shtm
Probably wise..some kind of way.Аура wrote:Equipment control node out-of-body palm, or a node Assembly hand. The energy center of the internal structure of the palm is in the center physical palm
Усова Людмила
- Has thanked: 1 time
Aura
Good Day!
to sign up for the workshop.
with respect.
Good Day!
with respect.
Усова Людмила
do the first exercise is the volume.
I've done other exercises for the volume - they were - but as always - more earthy and need a much harder coming out.
for example, the volume can feel each joint in isolation - no.
but train - remembered - the attention to 12 points immediately translate.
12x12=144 - that's a lot to be found.. And not only for the physical body - met in the one article of Andrey Patrushev on the number of strategies of geniuses like there was a number of 144..
Have given by Alexander of Macedon strategies..probably 28 was not more..and then 144..wow.bofara wrote:12 × 12=144 - that's a lot to be found.. And not only for the physical body - met in the one article of Andrey Patrushev on the number of strategies of geniuses like there was a number of 144..
While Yes, the World is accelerating and may soon 144 strategie.. for man is not the limit.
here
It seems to me a little wrong.. Although, I think, met at Hughson the information is about 144, but now can't find..it Was established that the average person uses on all occasions three strategies, talented – six, a genius twelve. All strategies a hundred and fifty.
There is a big difference between life strategy and strategies of social self-realization, and if so, how many people in the world with a different worldview, and the same forms of these strategies.
Усова Людмила
I am working early)))нева wrote: Aura wrote somewhere that 12 points is the beginning..
I was good at it in the bath - keep the awareness on all of the chakras, but apparently it does not give the feeling of interior volume.
and I also practiced giving volume to the external world - and about myself as it is not thought that themselves perceived two-dimensional.))))
There is a good exercise - "magnet" in hasaya Aliyev. In the network there are many videos on his method of learning self-regulation.нева wrote:For this purpose, what to do?..Усова Людмила wrote:I also practiced giving volume to the outside world
There is a yogic practice of disclosure of swarmcast, concentration on the tip of the nose, tongue, etc.
These methods are taught to control your attention.
But need to find its own unique method of psychological self-regulation.
Practice will give you exactly your method.
For example, "visual" is able to "see". Is it lilirose sense and it is easier develops.
And to see sound?
When feelings are mutually reinforcing and all elements of the game.
That's what we were taught in childhood, during the game.
Have fun, but no disappointments from temporary setbacks.
Good luck!
