The Card Is Masculine.
The term "charge" and Gigi information, not directly related phenomena. The term "charge" is simply the most primitive, clear, close, but not completely reflecting the essence of the phenomena.
In "Gigi" unique data in detail it was studied by people in the year 2013 in the subject test broadcasts, when it was clearly shown that even sophisticated instruments can be used "virtually" through the system viewtopic.php?f=31&t=5362
And even more, as I said, studied the optional on a club PA level. There is a theory and technique are discussed. There are plenty of people who are in the subject. I'm sorry that specify this information (about the gigs in particular) in public, relying mainly on the attention to these data that part of the audience, which has long been well aware of the principles and physical and information used in this case.
And of course it is not "empty data" as it is known, some information can be the key and the key can be very simple but succinct (for the links leading from it), but it is possible to make the key unique and succinct many times more due to the fact that it is not simple and is not actually a key but the streaming resonance to the complex information object. Broadcast is designed so that can affect the object passing the transmission through the physical world, getting "inside" of the object. I showed some examples at the early stage of this discussion (translation) themes. When using broadcast not for man but for "charging" (better is in quotes, there is a different process) of the subject, an irreversible change in the properties of an object in the world. (unlike items where the information is applied in the form of some sort of energy/thought forms do not flush change occurs). Technology is such that an information component corresponds to the component data (unique). And it's not just cards but all products in my section. Just maps this component was larger and richer than the most screwed in this regard products from the line (AMB).
This is offtopic about the amount of data used will consider this topic closed. Extended information there are sections about broadcast, as well as at club level.<
Re: Map Of Male.
By the way I am once again too lazy to pay attention to the male aspect of the creative components in the map
described in the description. I mean, creativity in the conditions of society may partially turn into "military", reinforced card, this aspect may not be peculiar to You (or Vice versa tend to, but to become stronger). This property is hard to maintain "how to" in the conceptual system of the man.
It somehow manifests itself in different cultural and social strata and sometimes the one-sidedness is related to the fact that this is only a projection of the creative component on the social plane.
So what I'm saying? carefully with this option. Observe its manifestation, and if you want to "turn down the volume"...
Re: Map Of Male.
Yes you can, it is possible that someone was missing. Just in this state in the ordinary society man to start in the name of the correct/desired order and state of things something slightly rebellious to do, rebuild together with the destruction of the old, and begin, of course, with the destruction
well, not necessarily right here with the destruction in the truest sense of the word, but the meaning in trends. Obviously, in a real society and family is not always completely appropriate option
Re: Map Of Male.
I mean that it is better to warn and people will go on a milder scenario than it entering into the taste of something it was not enough ( and someone else is there karmic and other resonances climb with militarily-minded individuals), breaking anything
Re: Map Of Male.
The options are:
1) women's card needs to soften, so maybe its enough.... well, its function is to activate those traits in women that are associated with soft female forms...
2) if this is an old study of male incarnations, it is possible to be male for balance "in cash"...
3) accordingly, if option 1, it might be two....
in other words, not digging in the past and not knowing the reaction on the female map can't answer for sure, or-or-or.
Probably logical to just start with a female and see how it will become.
Re: Map Of Male.
I've talked on the phone with a lady
which the military clearly manifested traits
and she had a rough night yesterday
in terms of the desire of some to smother
says just WOMEN's card just "on the forehead" she is very, very helpful.... so probably you should start with her, although men can "tap" on to tweak the quality of the wrap (but I'm not sure it will remove problemo if it is more historical and karmic).
Re: Map Of Male.
And I how down. Card (Male) for almost four days. Sleep 5-6 hours and Wake up. And then during the day (I work three more weeks at home and the apartment I'm one) are still asleep 3-4 times. Yesterday woke up at 11.30. And then went to sleep again at 2pm. Very strange, especially considering the fact that, apparently, should dream dreams - during the night, Wake up, awake and out. But dreams do not remember absolutely. And a day significant manifestations not. And to the girls until it was cooler to be
Re: Map Of Male.
About the dream and the strange state of "down"
- this is normal
over in the next branch (female) you can read about "gelatinous state" and idleness as a transitional state
and study dream and conscious work with the map. Although it is not necessary that dreams should be remembered at the same time. And you are trying to somehow consciously use the map to work with any modules, set "loudness", to carry out some mini-psychological work?
do you work with a map of what?
Re: Map Of Male.
This is partly what I wrote. In the next branch. Just decided to go in "male" - and then all in another. Yes, I try. But not clearly - so I want to study a particular problem - and more generally - want to do so-and-so in a General sense.
Re: Map Of Male.
Clear. If I understand correctly, you like to include more powerful
therefore, you have the processes may rapidly occur at the subconscious level and at the level of consciousness you just blacked out into sleep. At the same time, as work is largely on an emotional level, you may experience changes in mood. It is desirable to try to track the position of observer,allow it to happen and as the girl in the next branch, to Express the intention to work with intermediate uncomfortable States, if they happen. Also, there are times when "chronicle treated through the aggravation".
Re: Map Of Male.
You know, just for another month I would be on forced paid leave - the only thing - I don't have to go anywhere, so at sea or abroad to fail. Sitting, doing nothing. But until recently, I usually fell asleep in 3-4 hours of the night. Last night with a Map is not always up to 12. And if earlier a deep sleep, but now sleep surface with frequent awakenings. But on the level of consciousness almost nothing comes. So, the individual echoes.
Re: Map Of Male.
There in the women's branch is the opinion of BasilАстероид wrote:....
Is that it, indirectly, it follows that the process of "normalization" in this area (he still broadcasts insex felt club, I had them before at the club included), may be a kind of.... hmmmm ... selectivity, in other words really attract women will be not on the external parameter (body/appearance/clothes/behaviour), and on energy, the inner world of the individual.
And then there is pleasant, and for someone may be an unpleasant surprise, which seems to be on the surface, but for someone not obvious - these women in some parts of the world very little or not very much....
And the rest (with the appearance/body/clothes in which everything seems to be OK) - in the sense of energy and empty inside everything is veeeery ...
Unless of course they are on the map
Well, to make it sound correctly symmetrically - men actually have the same problem
This I mean that there is a real problem and it can be actualized when using the card - there is a much greater selectivity towards the person with whom there is real resonance and the desire to have at least at the level of communication intimacy.
Re: Map Of Male.
Well, that is until consciousness reached, can more consciously to work with her as a psychologist. In meditation, for example, by specifying the work vector, and keep track of what happens to you if you want a quick effects (all sorts of programs/units/injuries etc during the week worked and sometimes for many lives
). Using sleep is more passive mode, though, of course, a lot of things individually, and the process can occur in different ways.
In my example, I can say that I usually sleep 5-6 hours and Wake up itself in awake state, but if I take the card and covered with her, you can sleep for 8-9 hours, with dreams, with her dream of a very bright usually, and the body "wander" some pain (for example, in the left knee, then right hand, then somewhere else, a feeling that where energy bad passed, she begins to "push"). Now I have it separate from me, and I don't work with it, sleep again decreased. But this is my feeling. I can recommend you, if you want some sharper effects, more cherko to formulate a goal (to put, perhaps, more short-term and intermediate) and to work with certain modules in a meditative state, trying partially to track what is happening to you at this moment. You also have the experience of deep psychological work, as I understand it. Either work propassive, but not to expect immediate effects. In fact the problem may have old roots, to be a complex intertwining of different causes and factors, and their "unraveling" takes time, to each his own. If you sleep will need to cut, then put the map on pause. If you want to use the card for filling energy, a psychological study it is possible to pause and try to separate modules like "sources" and "dolphins" with the intention to recover and napitsa energy. Good luck
Re: Map Of Male.
By the way another interesting point - it is not a coincidence for such a powerful and sophisticated products were selected these two (well, it was possible something else to study in great detail) for their components of the root mass of the other is not contiguous like with this sphere of problems in our life, in other words there are growing legs
most of our problems/blocks/old karmic injuries and so forth, and work with the cards can pull and update well, a very fanciful aspects of life, but impact it will be back to repair the "base" through which we build our relationship with the world.
Re: Map Of Male.
Start with the last message. This morning was a considerable pain in the right pectoral muscle. Although neither yesterday nor the day before yesterday at all did not train. And this is in the right, but not in both.
But if about and for women and men? Yes, most nothing inside. Well, almost nothing. And I realize that my life could be different.
And probably all do in relation to external and internal. I don't know, maybe in some kind of monastery is still a large crowd of eligible women (let's leave aside the fact that most likely they don't want to associate with the opposite sex). And so, in everyday life? Personally, I experience this difficulty. To find one that internally was really good and looks though not ugly.
I know that there are. But damn, it is so rare. (Men too, not a fountain)
Re: Map Of Male.
The asteroid, Yes, this plan (to meet the "resonant" partner) in the current sostoyainii world and society can be difficulties in addition to their own psychological aspects. But really it's not so bad
and in order to attract the right person you can create a trend
for example, it is possible to use such a thing discussed in the thread about the deck (the"Cheshire Cat Smile") is a Solitaire Medici. It is used for formirovaniya for specific events and goals. And I have real examples where it was successfully used for attraction into your life relationship. There came to the ridiculous - the person who pulled the card, then told me that he didn't plan to go to that place, but something was "pulled", and he was there exactly at the moment the target card
And solitaire is the sort of thing that even if not "realized" event on the target map, still leads you in the right direction, reconstructing the event stream. It can be repeated to obtain the effect, or sometimes the goal may not be realized during the unfolding of solitaire, and after some time. For example, I once indulged in them for the purpose of meeting a particular person, who had not seen in a particular place. On the target card, when I came to this place, I haven't met him, but after a month we ran into him at exactly this place
and yesterday, just a opinion from a person came to pasjanso-Kolodny thread about how he met a man who has long wanted to meet, during of solitaire (as a side effect).
In this case, when in modern society there is a problem finding the right energy and level of consciousness of the partner, such methods create a trend can be very effective. As people are still there, just you and them do not intersect, and so you can create an "anomaly", "event-driven shake-up" that you can "reduce" with the right person
PS If you are interested in the solitaire deck is not necessary to have a commercial, you can make a home-made, which according to reviews, is also powerfully works well, or you can do without the deck.<
Re: Map Of Male.
Well, just read about solitaire, how it unfolds. I mean not on the table to spread out
but in real life - you do something, the world will somehow respond, it becomes a "conversation with reality." In this topic you need to understand. You can also topic branches to read information about the solitaire game on the web, in particular a passage about him from the book "Hackers dreams". And the deck you can just print out yourself (I've posted photos of the cards) and laminate if desired. Well, in General can an ordinary deck of cards to use.
Re: Map Of Male.
In the same issue of creating trends is another tool (the same deck, and it can also be done in a makeshift free version to try): viewtopic.php?f=31&t=5559
Re: Map Of Male.
Michael_ I have a few questions.
Simple. Map of Pandora is worth 10 thousand. The card is Male or Female - 9. Although her stuffing has a map of Pandora + much more. It is connected to something else or just particular pricing?
And second. What I wrote Basil - I understand that previously there were other products for men and women related to sex-role behavior. The current map is the most current offer now in this direction? Or are there other, more effective proposals that are likely to cost more?
Question just. And what about the men and women who are focused on the same floor as them homosexuals? (me is only interested in girls, but really these people a lot and many people like their gender)
And one more question. Let's say I use this card not for a few days and much longer and the changes within me are already visible for me. What happens with the opposite sex? They will begin to see, most likely unconsciously, that something inside me is likely the current good communication between men and women? Of course I'm not asking here whether me throw the crowd of girls - I have realized that this will never happen. Will there be a change in the perception of me opposite sex?
Of course I understand that I will gradually begin to see the other in the opposite field (I can see it now, but will be more significant reorientation of what I "see"). Will start much more to look "inside, inside" and not on the fact that they have "outside".
Or will change the fact that the girls see I have only those units that are "deeply related" to me and treat me well like before?
Question men and women not associated purely with sex. Inner strength and charisma largely overlaps with the inner masculine power. Whether growth in this direction? And notice it from the side? Just symptoms "of inner strength and charisma" is very important and related to what is happening inside. And without symptoms, only one inner growth impossible. As it is impossible to grow in this direction outwardly and does not change internally.<
Re: Map Of Male.
Ответ1. This is a features pricing. We have a more complex product - AMB, in the stuffing of which is "much more", and it is sold in multiples of 2pcs or 4pcs with a price of 60 and 100 respectively. I recently beheld as one man put it on himself 4амб are different and.... I did not shoot
refused
well, he was really quite high personal sensitivity.
But it was funny
So, the complexity of the product/time it was necessary to put his value of not less than AMB. But in the current situation it would make it a piece for those who can afford this.
While on many of the products we have a reasonable solution to "this", namely the free homemade.
You can make a homemade СК1М, Stabilizer (won in the next thread someone makes a huge concrete), Panacea, БЖ1.0, stoppage, 3.0, card Vх for the development of the astral and other vision/perception, and so on and so forth.... Lots of things can. Actually, as You recently reminded the same decks "Cheshire Cat" and "alpha-Vit"- you can also make the homemade products and they are in this form working and functional products that are tested by many and many. And then - well, there is no possibility to make these cards in a well working "Lite" versions for homemade.
So the dilemma was either to evaluate their work according to an adequate scale, or to make the product popular and accessible. Well, since were doing it in the first place because it people NEED, then the choice has fallen on the availability and complexity of products does not affect the pricing policy.
It just needed.
The second question. Basil mentioned the BROADCAST (and the club), they are now and they are pretty powerful, but the club in General to go after the 2nd month of the broadcast PC. The theme of the broadcasts separately here and will not disclose about this enough on the forum. Broadcasts related to psychology/sexuality multiple (see description for example in a private office - registration is free, or just in the list of the broadcasts, I'm not sure what is actually in the theme of "price" then the information is up-to-date. T/e/ there is broadcast of the General and club access.
Actually the contents of the maps will be available separately in the broadcasts, it is more powerful but more expensive ( 100 to include components separately is not enough ...)
Were there cards m/f normalization, which I discussed in the webinar Pro card Male/Female; Older cards are cheaper, weaker and not as complex, but I don't think their age was in the light of new. They're just somewhat different in nature.
Question three about the orientation of the sexes. There are different reasons for this. This was discussed once. We are struggling with what we have in the country is the cause of this due to propaganda (this really is still). Well, there are not that because of propaganda and such due to the fact that people in the last incarnation was of the other sex or even falsely encarnival this floor. It happens but rarely. With the consequences. There is no problem, the cards with them adequately will work. In all senses.
well, maybe someone will need BOTH or the other (but not sure), but it is not a problem as such. When the reason is that the past incarnation was the other sex, it's usually just for the next "bias" is removed gradually. It is only in psychology without communication with specialiatatea.
As for the attitude of girls in the study according to the scope they usually "stick"begin - ask the same of Basil, he's really here rarely radishes happen. It's a little ... jealous ... on this account
T/e/ Yes it attracts, because the energy he has rebuilt. But he started to work with him Oh so long ago and with the basis (well, if my products with the same basic BJ from 1.0 that was then, now it really possible or panaceia 2.2).
About charisma and others like her, Yes of course it is connected. And Yes, of course it will be, but to ensure that soon - I can't.
I here a lot of people watching, many for more than 10 years probably. There were those who despite all the opportunities and now in the same Joe....<
But it was funny
It just needed.
