Already active in 12 days, with no gaps, 2 times a day sessions on relaxation and 2 days of 3 try to do "Explorer"
Yet mixed experience... I feel good, optimistic attitude to everything, there is a surge of strength... then comes the irritability, or Blues even.
Sverhestestvennoe or at least sensitive to the effects on the perception of\behavior yet...
Please tell me how can interact with the "disk Explorer" and "Healing"? From the description and topics for the drives, I realized just what "Healing" is aimed at a General therapeutic effect, but also a "Conductor" in the description of the "expected effect" is similar to "Healing". Also "Healing" is recommended as a preparation before the "Journey through inner worlds". Is it possible to listen in parallel to "Explorer" and "Healing"?! What is the fundamental difference between them? Drives cycles such as: 15-15-15, or 21-21-21?
On the "Ultramesh", so it's all the tracks except the last one to listen to, without limitation, the total time per day, but with reasonable breaks, the last track ("star wanderer") to listen better in the morning and no more than 45 minutes a day, right?! Also from our previous correspondence, I realized that basically, this disc is recommended for listening without a "Navigator," i.e. the second main track is at minimum volume and while it is necessary to try to study a material that requires understanding i.e. sitetemplate through the glasses here as it electives is (at first glance it seems that the flashing glasses will distract from the learning material, although wav rip of the disc to write to memory "Navigator" I still did just in case).
So, confirmed, or still with the "light" effectively?!
Another global issue: all of the products i.e. drives, session "Navigator" before the release was tested on volunteers?! You do it been doing?!
