Question a newcomer on the bracelets(confused)
Владимир Ш.
- Has thanked: 19 times
- Been thanked: 34 times
The entire set of modules is present in all versions of the bracelets of life, starting with the first.
Владимир Ш.
Re: Question of the beginner on bracelets(confused)
Yes, you can; however, efficiency is influenced by another version of the bracelet - maybe it makes sense to do a free panacea? If there is a bounce, it is possible to switch 2.9 - and succeed gently and quite effectively.
Good luck!
Good luck!
Yes, I sidle up to that, deal thanks, and if not it is difficult how to activate them. I myself with the site ANS, SANA'a, ie worked with a pendulum, work on yourself, work through the pendulum with the PS-the same type of right hemisphere brain function. Thanks again to d bone. The plans BJ 3.0, panacea, Ah on all the lights. Thanks again. It's so important.
In 3.0 there are no modulesВладимир Ш. wrote:the Whole set of modules present in all versions of the bracelets of life, starting with the first.
Question. Made a bracelet out of wood, struck a matrix, panacea light, and wrapped the bracelet and charged it at the charging system B. J. 1.0 used tracks: chistkakrovi, etalon_m, ozon, probiotik, prognoz_obshnost, prorok_fast, prorok_sl, stabil (no Mandal) plus 4 tracks to record BJ 1.0, all of them track Shoe 1 hour. Of course skhimichil that I have interesting work-"P" as was the matrix light is written with a Sharpie, or something, and modules "P"is the same as versions of the BJ line (excl. BJ 3.0.). How to launch the command on matrix "P", mentally, installation, etc. without installation (command) matrix light "P"-not working? If I have currently no opportunity to purchase stickers of the matrix "P", then just draw and place around the house and auto with the software on (what overlap-i.e. for rehabilitation, protection, etc.-in which spectrum operates.) Turned to another bracelet with the matrix "P" in the digital matrix switch to condition 2.9 (but in my output 1.0 and if it comes out that ( as I understand TO not pass) Or "N" TO her? Can you help? Made myself a RANGE of wooden bracelet (irradiated with a range of video matrix-2 and matrix pokadrovaya the Spektr-1. As the special did not feel, all tested by myself, I think any changes there, such as confidence appeared, the wife got pregnant (baby will be 3)-she dreamt that her Falcon flew up and sat NARUC-she told me to pregnancy dream or bird or fish). And in situations OGE figured out(chattering as I understand the impact of the outside world to your "changes". (I work in the Ministry of the interior private security) There is still I read the thread about the panacea, written for the beautification of the city, I sit and think is a good thing, if it be so crime will drop-so I will not work, i.e., the rod system was not abolished, I will demand and to identify for example, I can't, then punish me as not coping with their work(job descriptions). If I use for example the search Range in a situation where I will be able to identify the offence or a crime which I can disclose that I was held in high esteem(because it is necessary to feed the family) or BJ I will not allow (ie is my PS-I do not violate any negative impact on "call" for such work.) Like this. Thank you if you give me a detailed answer.<
Hello Dmitryko,
I think as a start you got the bracelet a Panacea through the application of the matrix. Well as far as a quality Panacea, I can tell. Had to wait a while.
Panacea is controlled mentally.
After applying the matrix a Panacea, charging system BJ 1.0 no longer plays a role.
chistkakrovi, ozon, probiotik, prognoz_obshnost, prorok_fast, prorok_sl, stabil - these audio files are not used for charging bracelets.
Only etalon_m can be used as the fifth track when charging BJ 1.0 ( if not confusing sequence ). Then get a BJ 1.0 more pronounced quality Etalon.
Clear out light panacea, the management of the mental is necessary to visualize the result or enough of a command to it, i.e. PS itself knows how to start the process. Recently did one thing: created using a certain program thought forms some kind of energy structure in the shape of a pyramid Mosolov (like NEP-14)i.e. the energy frame, and an inverted pyramid, in General, the figure of a rhombus, i.e., how to represent the shape of a pyramid fractal produces a field of thought that if you create and place this piece of energy into the "space" of the chakras, energy points, slim body. I don't have the vision fields, but my subconscious can create such, made the chakras of the hands and feet, anahata and the spiritual his subtle body, is the fusion of this structure with a given energy system of the body. I tried to gain the type of lenses I called it Fraktalnaja crystal energy lens(structure) is working, but what is happening in the energy sector is not yet very clear. Tested using the pendulum increases efficiency by 30-40 percent. One man tried on the other forum where I have corresponded with him, but he then got a headache, he annihilated-passed. By itself did a special Overdrive was not subject to later made BJ 1.0 (it relieves strain around the cocoon-regulates excess). My point is that you can collapse it due to not needed, i.e. off, and you can activate automatically a team-although prescribed in the installation of automatic control in space and size safe for the body. And another caveat in the areas of power lines (the intersection of frame) you can install the same lens of order 2, 3, 4, etc. As the principle of nesting dolls. Sorry off topic-pent. So how to give commands. And if I BJ 1.0. modules I can run, but it depends on my strength. So. Thank you.
Oh. So, in order.
1. You bloat is not clear why not clear why. Tell me, what was the meaning of all these successive treatments all in a row? In fact, obviously, you've done it a Panacea Lite as the younger version may be overwritten with older, but not Vice versa.
2. When charging 1.0 (which, however, you still wasted) is only used tracks for recording BJ, everything else you listed there is not needed and interferes.
3. Mental command is the Panacea given mentally. As you wish, and do it. In the simple case, just a mental command. All this mass of information on the forum, in particular, in the specialized topic of Panacea.
4. If wrapped in a matrix switch to 2.9, got a 2.9. As I explained above, 1.0 on top of the Panacea to be prescribed not.
Overall, I suggest you first understand what you are doing, and to decide what result you want to achieve and then something to do. Your approach is to "treat everyone" is absolutely inappropriate. So you need to do.
Further.
5. Panacea always harmonizes processes. Your same social-psychological distortions is another matter. You seriously wrote that "it's better that the crime is not decreasing, and that my work will not and I will not be held in high esteem"? Sorry, but you, in this case, obviously does not prevent a psychologist. And it's not going to hurt you, and real advice. Such an attitude indicates a serious internal problem.
6. BJ can't afford or not afford. The subconscious mind can. Many, however, trying to deal with it
The result the result is deplorable. In the case of a criminal investigation (I correctly understood the situation?) see no such problem, but how do I know that you got there and how, I'm not your subconscious.
7. The use of the Spectrum, apparently, can help in such work, but not the fact that you have something. Range - the product is not for beginners.
8. Pyramid (any) is a very specific thing. Not is offtopic here on this topic.
9. The modules can be run on any version of BJ. The result depends on many parameters, including, Yes, from personal power.<
Further.
Andrew S. wrote. You seriously wrote that "it's better that the crime is not decreasing, and that my work will not and I will not be held in high esteem"? Sorry, but you, in this case, obviously does not prevent a psychologist. And it's not going to hurt you, and real advice. Such an attitude indicates a serious internal problem.
That's it I want to get rid of, about the crime of course we want to reduce the system (egregor) is not beneficial that crime has decreased, and why the hell the government feeds us is in General. Want to contribute your positive, at best.
The panacea will deal. Thank you for everything. And another question-the "pulsar"-what is it. I will do everything sequentially.
Sort it out
Tip - take your time. All information on the forum is, do not grab everything at once, it's not going anywhere
I've read in the thread about the panacea that pyramid MOSOLOV harmful, it is true, and the one I have is in the car. explain to me please about it or just do not all clearly so.
Questions:
1. About the Panacea light in the form of letters start module( this is the same as in the line BJ), and its modes of mental team? 2 Nansena P matrix on the bracelet with a clean slate has its KO or not-needed basis from 2.0...?
3 And the digital panacea is written on the bracelet links in place(as well?), or the column itself or just for some time these digital matrix Clause?
4. Is it possible to put a digital version of P on the one hand, and on the other for example bukinoy.? What will come of this?
5. For a bunch of P with me how much time is going to adapt ( i.e. incl. in work). Thanks until such issues not obessudte.
Questions:
1. Yes, Panacea Lite full BJ, and, accordingly, has all the same modules.
2. Yes, Panacea Lite has (creates) its own KO.
3. You and so and so. It is better to write the links, following "the matrix", i.e. the 9 letters in the link, but there's 3 on link. Can and wrap, but will be weaker.
4. Digital powerful letter, it's going to be about the same as what would happen if you just apply digital.
5. To work the Cure begins at once. How many of you will go to adaptation depends only on you.
Today night watch-didn't sleep a wink, was that night. Maybe it was the bounce. My companion began to jump, he worked with others to leave also. And with me that constant fire, the chase, or something else. Directly to me a negative is nothing. Here for example night today was the pursuit of a drunk driver, we further defined the boundaries of the route the patrols leave, the traffic police after them. In the end, the autopatrol of traffic police stuck in the mud( villages), followed by the duty vehicle (UAZ) is that the shift on the day in the police-also there gets near, send help to pull the car of MOE and ....it is there. Soon found a driver to help those who are stuck on the Kirovets, though he all pulled out okay.
Morality is a crook somewhere in the forest, too stuck. Only we on the left post for a certain time and then we pulled, well, worked all night to complete the program. Partner says you're baptized well, etc.- go to Church. And think to myself "P" this gave.
PS in Karaman matrix letter "P" I had before the video Panacea 2 reviewed several times. Well 2.1. And Yes, even thought to reduce the chatter on the events said to command mode "stabilization." I will continue to watch. And bracelet N moved before work on the left ankle, the Range was removed. The rest will observe. Became really fun.
There probably should add that now is not very stable the world itself, and it has an impact on events. This including the impact of the problems with the geomagnetic environment ; - the frequency of the Schumann that... Tomsk station April 4th, public monitoring of closed, generally after a month of anomalies in the data. Social influence is huge.
This question is epoxy varnish, you can use the Glue "Liquid glass"(sodium) is to enhance for example, when a dry layer on BJ when you run video or a Panacea on this very capacity to project that would be right with svoistvami "P" and then just process. You can?
Don't know where to write.
1. You can picture the stop-magic-1.2 save format and pasted in the car, at home, on the street. If you can where, how, and where?
2. So the question is, can I use the image of a "standard" laminate(glue tape) and place in the fridge (stick to wall)?
3. What is the difference pana2.avi? if I charge a panacea matrix to a new object I have the cure TO, right? How to transfer the modes of cure 2.5,2.6, etc. Mental command like "Activate the subconscious(translate) the panacea to the mode of such-and-so? And back? These modes are available if I charge the panacea for the video file system as a panacea.wmv, and system pana2.avi? If I loaded the bare subject of a panacea which version I have panacea 2.0? Or is it only prescribed to version 2.X?
4. Can I use copies of maps for example of transfer posted on the website, if you can it will be a weak light version, or not, i.e., closed. If possible can you put the image in the form of bonus like me for example because of not having to buy at the moment, the original. And while all will not understand. Thank you. Waiting for an answer.
You would still have bothered to learn the forum. All your questions have long answers and very detailed, and completely unreasonable to waste the time of members of the forum on the repetition of the same it is not clear what time.
1. See the topic about the production of Stop magic from masters of the TAO in the section "the AVR and СК1М".
2. Can.
3. You have not understood that 2.x and a Panacea. Reread basic description.
4. Don't understand what you mean by "copies of maps of migration", I is unknown. There are cards transfer, which are sold - they create a full version of the BZ.
2. Can.
protection another way to put it, well, or armor
the vest
Sorry again for this question misunderstood. For free use(manufacture) is not available BJ 2.0, 2.5, 2.6 etc. And why BJ panacea available switching modes 2.5, 2.6, 2.7, 2.8, 2.9 with your CO? These modes of cure are the same as if I had a commercial version of BJ 2.x or do they differ (i.e., version 2 of the BZ.x openzine, that is.)
And if it turns out to be they are the same as BJ 2.x and BJ P 2.x-there it was impossible to produce(for a number of these on the forum reasons), and panacea can you? How such a "gift." It is a universal panacea?
Information components for example medications some programming on some items, and not only to water and fluids? This can be applied to any subject matrix "P" and set the program to copy the properties (and next to keep some sort of link(photo, picture, slice, etc.), so it is possible without causing if I have to hand BJ "P"-and so, work can? Thanks for the replies.
- Has thanked: 1 time
- Been thanked: 10 times
Dmitryko, once you have all messy
let's order:
Panacea mode 2.0, 2.5, 2.6, etc. to switch can.
These modes of cure are the same as if you had a commercial version of BJ 2.x - software emulation works somewhat tougher than physical products.
ie version BJ 2.x openzine or what- not, BJ 2.I have my x TO 2.0
Yes, the universal Panacea.
Information components for example medications some programming on some items - Yes you can, just across the water, obviously, will be more effective.
Okay, thank you. Yesterday tried to work with the program openlogic and with special equipment. Processed your house, a garbage dump, otherwise I will continue to try.
