Mask for meditation and ESP "Palantir"
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Re: Mask for meditation and ESP "Palantir"
Post by Ростислав » Wed Feb 05, 2014 20:15
What is the difference of the former from the latter?
Been thanked: 182 times
Post by Андрей Кабанков » Wed Feb 05, 2014 20:43
Changed Konstrukcija the masks became more comfortable and opaque.
Владимир Никонов 2
Has thanked: 20 times
Post by Владимир Никонов 2 » Thu Feb 06, 2014 18:28
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Thu Feb 06, 2014 19:28
I tried to make obvious from the mask and mirror something like the palantir. Made the mask as pictured palantir II, two mirrors separateing the beauticians, the structure of the mask "obviously"- and the effect I did not like was the strong energy pressure on the eye, was perceived almost physically... the orgone accumulator was not doing or hands are not reached, the reverse mirrors organic to do with the drag of metal :)
Post by Андрей Патрушев » Thu Feb 06, 2014 19:32
dimych
Yes, I also tried (with similar feelings) - apparently, the glass gives this effect... :?
Ерлан
Post by Ерлан » Thu Feb 06, 2014 22:34
in functionality, the capabilities of Palantir-2 is different from the first mask ? or just easier ?
Владимир Никонов 2
Post by Владимир Никонов 2 » Fri Feb 07, 2014 19:08
Ерлан wrote:functionality, the capabilities of Palantir-2 is different from the first mask ? or just easier ?
The functionality is unchanged. The mask became better and softer to sit on my face. And it completely eliminates the penetration of light.
Иррина
Post by Иррина » Sat Feb 08, 2014 15:55
Andrei Patrushev.
Purpose:
— to improve vision;
— to work with psychoactive audio programs;
— for the development of alternative visions, clairvoyance, psychometry;
for autopsychological;
— for programming the desired reality.[/quote]
All good day :)
And about more? Particularly interested in: "for the development of alternative visions, clairvoyance, psychometry" :oops:
Post by Андрей Патрушев » Sun Feb 09, 2014 21:09
Irrina
What exactly?
Иррина
Post by Иррина » Mon Feb 10, 2014 13:11
The clairvoyance and psychometry :)
Post by Андрей Патрушев » Mon Feb 10, 2014 13:35
Irrina
Sorry if did not understand, and that it is in vision and psychometrics?
димыч
Post by димыч » Mon Feb 10, 2014 19:12
Andrei Patrushev seems to start at least something to take, and the nuances later :)
Иррина
Post by Иррина » Sat Feb 15, 2014 23:05
Andrei Patrushev
the foresight in my understanding-is the ability to perceive visual information about interest place, man. And psychometry -the ability to see the history of the subject person. Here I am interested: how to use masks to develop these skills?))
Andrew, what in vision and psychometrics, there are other possibilities? :oops:
Иррина
Post by Иррина » Sat Feb 15, 2014 23:06
dimych
))) You're probably right :?
Post by Андрей Патрушев » Sat Feb 15, 2014 23:15
Irrina
The question You have not been formulated. :?
Psychometrics in addition to Your language has many more apps (read Leadbeater, for example).
To learn something really need to do it for real - that's the whole secret. :?
Иррина
Post by Иррина » Sun Feb 16, 2014 22:45
Andrei Patrushev
And which book of Leadbeater? :)
And how to use masks to improve vision?
Really -it's great :ay only not always it turns out))
Владимир Никонов 2
Post by Владимир Никонов 2 » Thu Feb 20, 2014 0:19
How good is "Palantir" with "ALTARIA"!
Post by Андрей Патрушев » Thu Feb 20, 2014 10:50
Иррина wrote:And what is the book of Leadbeater?
Yes, the same Chakras much has been written about it.
Иррина
Post by Иррина » Sat Feb 22, 2014 22:17
Vladimir Nikonov
Interesting, be sure to read about Alfario. At the time I bought Interpuls with colorstream, and it turned out that when heart problems do not use points. On Alfaria I did not pay attention. And are using the same disks Andrew, when I have free time. Thanks for the tip :)
Иррина
Post by Иррина » Sat Feb 22, 2014 22:21
Andrei Patrushev
The book was found. I started to read. Thank you.
Акела
Has thanked: 28 times
Been thanked: 64 times
Post by Акела » Tue Mar 18, 2014 14:10
Comrades! Like a mask, not accucies Lee and I went there the growth of "vision", etc. from this work, I mean that there is a desire to buy, but does the possibility of "proprety"...
Oooo :wiz :)
Акела
Post by Акела » Sat Mar 22, 2014 19:05
Clearly, the lack of reviews better than a long explanation... 8)
димыч
Post by димыч » Sat Mar 22, 2014 22:33
well, as you say - there has already been written about the long-term training with a mask to show results.
I have a mask for about a month palantir first version - I even made a foam pad with holes for eyes
to exclude the lateral flare...and I honestly do not understand yet the effect.
and I have a homemade mask, with the structures from the mask obviously, if I wear them both you will feel some intoxication, an altered state of consciousness, closer to mild euphoria. This mask is made of black plastic if I wear it on top of the palantir - complete darkness, and if after half an hour of such training to remove improvised, there is a feeling of light.
I have the impression that through the fabric of the mask breaks the light. I see the shadows from their hands, while trying to isolate the location of the lumen is obtained that the light shines in the center of the nose, and in the lower left corner of the field of view. But I have a fairly weak lamp on the table and light coming from him on the wall absent-minded. And the mask I see that double thick fabric+ my black thick foam, so it still a vision?? everything was well fitted so nothing shone!
To sleep in this mask as problematic, there is some tension in the head, which does not sleep. It happened once but the sleep was restless.
Акела
Post by Акела » Wed Mar 26, 2014 11:57
Thank you for your response, but You describe the constructive particularities of the mask and I would like to understand its functionality. And you probably want to try yourself, thanks again!
ААААА
Post by ААААА » Wed May 14, 2014 1:00
Good day! Or rather night.)
Mask of Palantir 2 , 10 sessions with her, there is no result yet . Previously studied alia on the Navigator and wild Andera Vadimovich. Ie that there's a mask that no. Question, can someone tell me what I do wrong or maybe the mask of marriage? All previously described here on the use of Palantir in my case was not observed, tried together with ALTARIA the same thing.
With respect
