About money
Reflexes at having fun, work, but the aspect is a little different - to relieve some of psihologov embedded education.
These signs can also be references to functional rituals (informational mechanisms), so that we actually are different, thus one can complement the other, especially if you look in detail the whole mechanism of human interaction with the Egregore of Money. And since the details of this mechanism are several, the important thing may be to each his own....... Someone psychology the way, anyone to engage the structures to be broken, someone thrust a little weak, have someone to hold, someone threading is not enough.......
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: About money
Totally agree with You. We are talking about different things, but illuminated the same thing, but from different sides. And both can complement each other. And maybe for the individual, work will be one of them, but he uses both. And which one will work - who cares. If only the benefits were.Маг.нет wrote:Reflexes at having fun, work, but the aspect is a little different - to relieve some of psihologov embedded education.
Sincerely, MAG.no 〠
Because, as You rightly point out, the problems everyone has enough. Different, and the worst thing is, I don't know what problems there are inside and that prevents to be successful and prosperous.
Re: About money
So with that, you can try to understand....... Most often affected is psychology (relevant, which reduces the activity of some of the details of this mechanism), and that they "dig" you can see how and where this mechanism they are reflected, it is useful to understand the mechanism of interaction in detail and the structure of the personality (behaviors), which in this interaction involved. When the mechanism is working, he working whole, when fails or reduced capacity, then probably not working correctly an individual part, causes can be deformed (corrected), and malicious filters of consciousness (demand destruction).
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: About money
Fortunately, there is a path when there is no need with what the deal. Not very difficult, somewhat difficult in execution. Since you have to popehat. But with obstinacy and hard work - the results will exceed any expectations.
Re: About money
But this way is intuitive. Almost did it, just intuition refused, and here the subject neponyatkah. How he got here?Маг.нет wrote:there are other, not all have to plow and stretch, and so happy, and life processes are simpler, effortlessly.......
Sincerely, MAG.no 〠
I'm talking about the way conscious. When you know what you are doing and know where you're going. Constantly and in this way adjust themselves.
Re: About money
I do not quite know, but certainly to feel of probability and to follow the path of least resistance that effectively. Meant another.
Bold knowing that You are a car enthusiast and some of my mental constructs especially recently miraculously implemented, so not to "direct" will introduce a bit of abstraction and compare the two motorists under the aliases X and y, the X driver maintained vehicle, serviced, always seasoned with a good fuel, and the motorist Have....... well, he likes to overcome and the suspension tapping until you collapse and oil topped up gallons instead of the engine to service, fuel is refilled without hesitation and when the tank is almost empty, what will fall, the fuel system is not adjusted, the nozzles clogged, and that takes more fuel, because the cleaning and setup is costly, and they are stretched in time, etc., etc., i.e., until the problem arose, why to think about it, all the problems are solved on a rolling basis. So there is a need - motorist X sat in the car and go, nothing to overcome, got to the destination more often than not thinking what a happiness it is to get without any problems (that's always the way), and our enthusiast know Have something to compare, because if he got to the place the lowest cost and without damage is happiness and if along the way something failed and was repaired, then each such event is overcome, the result of which can bring a feeling of happiness (that never happened - did it!) and one of them is happier than X, which pays no attention to it, believing that it should be or Have received a lot of pleasant emotions, from the fact that no matter what coped with this task, so was a very happy day for him.......
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: About money
A third motorist, under the name "Z".Маг.нет wrote:I do not quite know, but certainly to feel of probability and to follow the path of least resistance that effectively. Meant another.
Sincerely, MAG.no 〠
His priorities shifted somewhat. He knows his ultimate goal. End! In the intermediate stages of the path, they don't care. The car will be comfortable, or to rattle. Be the road smooth or bumpy. Will the on-road obstacles, accidents, floods, thunder, lightning, happiness, unhappiness and so on. He doesn't care. Has an endpoint and it will definitely come back. Having demolished all the obstacles on your way and not confused about the joy of movement without damage and costs.
We have learnt a basic life principle:
"EXCESS RESOURCES - CORRUPTS! ONLY POVERTY MAKES US DO THE THINGS TAUGHT BY THE PHILOSOPHY"!<
Re: About money
What is not psiholog? Poverty is a good motivator, if motivation "to" (the carrot), at some stage, for some reason does not work, subconsciously there is a motivation "from" (whip) as a strong on perception (less abstract) and effectiveness, but that this motivator was filled with more strength, originally should is him greater satisfaction. And the scale is distorted, with hunger a piece of bread and the achievement of....... and if not one, then life for some time almost succeeded. When full and purpose can be other.
As for the Z car enthusiast, it is the same as X and y will reach the goal, but in my opinion he is very still like motorist Do.......
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: About money
It is not in the fullness or poverty. It's the movement. Fed will not go far. It is oversaturated and there is only a new sensation. Plus the energy required for digestion. Get different kinds of pleasures.Маг.нет wrote:What is not psiholog? Poverty is a good motivator, if motivation "to" (the carrot), at some stage, for some reason does not work, subconsciously there is a motivation "from" (whip) as a strong on perception (less abstract) and effectiveness, but that this motivator was filled with more strength, originally should is him greater satisfaction. And the scale is distorted, with hunger a piece of bread and the achievement of....... and if not one, then life for some time almost succeeded. When full and purpose can be other.
As for the Z car enthusiast, it is the same as X and y will reach the goal, but Calais. I think he really still looks like a car enthusiast At.......
Sincerely, MAG.no 〠
Hungry need less energy to digest. He does not need intermediate steps - fun. He only knows his ultimate goal and he's interested in nothing. Everything else is only auxiliary means.
Because he knows the next moves and only this:
"LIFE is ONLY ONE, REALLY the MAIN PURPOSE of RESIDING ON the BORDER of the conscious AND SUBCONSCIOUS"!
Re: About money
Again psychology, satiety is no limit in setting goals, but can affect the magnitude of these objectives and the presence of the need for pleasures and luxuries not necessarily those requirements characteristics condition (of satiety or hunger), and personality (such are the algorithms of interaction with the world). As for the "main goal", then it is realizable in various States of satiety and hunger, a desire, but the hungry are often not up to her to eat something for starters, and there about the great you can think of.......
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: About money
Psychology everyone has. Satiety a loose concept. But brake. Since prefer to spread and not to move in the same direction.Маг.нет wrote:Again psychology, satiety is no limit in setting goals, but can affect the magnitude of these objectives and the presence of the need for pleasures and luxuries not necessarily those requirements characteristics condition (of satiety or hunger), and personality (such are the algorithms of interaction with the world). As for the "main goal", then it is realizable in various States of satiety and hunger, a desire, but the hungry are often not up to her to eat something for starters, and there about the great you can think of.......
Sincerely, MAG.no 〠
Hungry, the same loose concept. Because I mean, the hunger just for one thing. This driver constant hunger only in one direction. He is always short only of a single, quality, subject or purpose. And because of this feature, it constantly hungry state, he doesn't so much pay attention to everything else.
He didn't even care if he'll reach his one and only goal. He just moves on track.
"EVEN IF IT FAIL IN ANY CASE, IT shall come upon HIM WHEN HE TOOK the liberty to DO GREAT THINGS, AND therefore IT will NEVER SUFFER the same FATE, the COLD AND TIMID SOULS who did NOT know NEITHER VICTORIES, NOR DEFEATS"!
Franklin Delano Roosevelt
Re: About money
Knowledge of the wins and losses are not necessarily attained in the way of the pass that is great, that for one event for another can be quite ordinary and insignificant, i.e. the greatness of the deeds, or rather such a subjective attitude, is largely dependent on the scale of the individual, if you go back to the money, some measures for example their financial needs and goals of tens to hundreds of thousands of rubles, others millions, others operate on even large sums, solve global problems, and so all people are the same.......
Often more valued is not something that is really valuable and something that gets harder, which is a subjective distortion.
Bold, very nice to communicate with You, but let's wrap it up, you need to do great things)))))))
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
Re: About money
Thank you very much, MAG. no, for Your posts!
Re: About money
Tell me, do you "instantly evolved"? Already more half a year has passed since then, as you wrote, something interesting happened in your life, thanks to this program?Смелый wrote: 4. Very useful this program. http://youryoga.org/med/evolution_program.htm However, the time factor. Not everyone has the time to do so much. Directly to money the program does not apply. But to development more than. I last 40 minutes with her working in front of the computer and headphones. Involved all of the "energy bows" really includes all the chakras, legs in the bath so not warming up.
Re: About money
Happened. I am a third month developing in the right direction. Moreover, without the use of devices and various programs. But if I did not at the time used devices and programs - there would be no evolution now. The use of programs and devices rocked the situation and was allowed to stand. 8 Feb understanding which has enabled to make a qualitative leap in my development and now allows to do without programs and with virtually no devices (allow yourself to use only in a specific situation). To talk about practical benefits from the use of specific programs - is meaningless.Любимая wrote:Tell me, do you "instantly evolved"? Already more half a year has passed since then, as you wrote, something interesting happened in your life, thanks to this program?Смелый wrote: 4. Very useful this program. http://youryoga.org/med/evolution_program.htm However, the time factor. Not everyone has the time to do so much. Directly to money the program does not apply. But to development more than. I last 40 minutes with her working in front of the computer and headphones. Involved all of the "energy bows" really includes all the chakras, legs in the bath so not warming up.
Re: About money
Now I read in one of the posts the thought of that man using some device, have started to see the situation, if necessary, corrects the course, etc. It is all about the desire and ability to achieve a perfect result in the shortest way and with the least amount of energy.
On the forum in the course and accepted the idea:
"Why walk when you can drive on esake"?
All x needs to disappoint.
This pernicious path of travel dead-end.
- Malvina
- Сотрудник mindmachine.ru
- Has thanked: 5 times
- Been thanked: 12 times
Re: About money
Don't understand.
It was so.
It was so.
And in two days already.Смелый wrote:. I am a third month developing in the right direction. Moreover, without the use of devices and various programs. But if I did not at the time used devices and programs - there would be no evolution now. The use of programs and devices rocked the situation and was allowed to stand. 8 Feb understanding which has enabled to make a qualitative leap in my development and now allows to do without programs and with virtually no devices (allow yourself to use only in a specific situation).
Смелый wrote: All x needs to disappoint.
Re: About money
No two days or three. There is a continuous period of continuous evolution. Which starts on 8 February this year. Through this evolution I say. The development path of intuition, the development of abilities to see your own path for dvijenia to the goal on the shortest path with minimum energy consumption is a dead end.Malvina wrote:don't understand.
It was so.And in two days already.Смелый wrote:. I am a third month developing in the right direction. Moreover, without the use of devices and various programs. But if I did not at the time used devices and programs - there would be no evolution now. The use of programs and devices rocked the situation and was allowed to stand. 8 Feb understanding which has enabled to make a qualitative leap in my development and now allows to do without programs and with virtually no devices (allow yourself to use only in a specific situation).Смелый wrote: All x needs to disappoint.
Now called his home in Vladivostok.I already have a student conscientiously perform recommendations. Over time I start to generalize the results to expand the circle of followers. Moreover, to impose something to someone - is not possible. Because of the need to do certain actions "from today until the end of days".
- Malvina
Re: About money
That is the moment You abandon that phrase?Смелый wrote:But if I did not at the time used devices and programs - there would be no evolution now.
Something has changed in your life?
Re: About money
No. On the contrary confirm. There would be devices and programs - it would not be itogo round of evolution.Malvina wrote:That is the moment You abandon that phrase?Смелый wrote:But if I did not at the time used devices and programs - there would be no evolution now.
