![Confused :?](./images/smilies/icon_confused.gif)
Water purifier "BSL-MED-1"
Andrei Patrushevyou know what , I actually bought this filter because it You and Michael are, so do not carp ![Confused :?](./images/smilies/icon_confused.gif)
Re: water Purifier "BSL-MED-1"
But if raised above Your questions will be competently answered manufacturers, that would be wonderful, I am definitely interested, and also all those who are just thinking about purchasing this miracle ![Wink :wink:](./images/smilies/icon_wink.gif)
Yes, and it is strong.Владимирович wrote:And after processing in BSL water boiling in the kettle gives the scale?
- Contact:
Do not even think to complain about.Тяфа wrote:, Andrei Patrushev, you know what, I actually bought this filter because it You and Michael are, so do not carp
![Embarassed :oops:](./images/smilies/icon_redface.gif)
And after aquafor no no scale in the kettle or the iron...in like So before BSL water probably should be filtered.Тяфа wrote:Yes, and it is strong
Well then do a lot of time to get there and so with all sorts of assemblies, perelivami, flushes have something to doДимас wrote:So before BSL water probably should be filtered.
![Sad :(](./images/smilies/icon_sad.gif)
Practices
Yes, I will be testing in the office, according to the results accomplish your goal. For me the main criterion - a delicious tea
If the water is of high quality, fine Chinese tea will be delicious (and I'm a big fan and longtime admirer of this case). Here are today brought to the office a package with samples of different varieties, mostly autumn collection, let's see ![Smile :)](./images/smilies/icon_smile.gif)
Andrey Kabanovand expenditure materialist BSL you, too, can be purchased?
- Has thanked: 1 time
- Been thanked: 182 times
- Contact:
Tea with the water brewing will not work...turns out you can't heat it, more heat can be, but all the beneficial properties of water will be lost ![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Data from the patent owner Gorshkov A. S., electrochemistry too tricky a thing to read on the website http://www.bsl-med.ru in the folder "Articles" -"the Life - movement of water in the body" , there are many answers to the questions, because it was written by the developers of this device, which actually came up with this purification technology at the Military medical Academy in St. Petersburg in a closed NIL-7 from 1967 to 1992. It is quite different from the technology receive live and dead water (as it was the previous step in electrochemistry), and BSL issues always pH neutral or very slightly alkaline (7-8). In addition to this improves still the whole heap of options water. I advise everyone to read who is interested in "BSL-Med-1".Андрей Патрушев wrote:Water passed through magnetic funnel changes its structure and it is necessary only to make it easier to remove the mud all the excess water
Very interesting - why??? As I wrote above, it's exactly the opposite...
Димас wrote:Tea with the water brewing will not work...turns out you can't heat it, more heat can be, but all the beneficial properties of water will be lost
Just the tea is brewed perfectly!!! Only water no need to boil, and bring to a boil (not the "white" key, 90-95°). in this case, water remains a potential of -70 mV, i.e. all properties of water remain. By the way, the tea companies that use this water delighted with the taste of the tea. They say that when the conventional welding (any) water goes into a tea per cent max.60-70 percent. enzymes and when Bolnoy to 90 percent.!!! So you can brew tea, coffee, herbs ......
vagavita
Well, fine, green, white and yellow tea can be brewed 85-87 degrees...Now preparing for the first trial batch of water. After the reactor, the water became opaque and serotoninto in appearance. Skip it through the filter, it flows quite slowly. Tried to set fire to the foam on the surface of the water, it explodes very funny claps
Hmm..don't really imagine a tea company (more tea club), which for their guests preparing this water. There is the Strait of water per day...is too big the Reactor should be 200 litres ![Cool 8)](./images/smilies/af.gif)
After the reactor water is always transparent, the sludge at the top. Much "donut" it is not necessary to tighten and when it is preparing (boiling) do not bareboat "lemon", not more than one third of a teaspoon and then carefully and repeatedly(10-15 times), rinse ,squeeze. This in order to rinse out the rest of "lemon". The first water should be drained, or water your flowers.Димас wrote:Well, fine, green, white and yellow tea can be brewed 85-87 degrees...Now preparing for the first trial batch of water. After the reactor, the water became opaque and serotoninto in appearance. Skip it through the filter, flows quite slowly
And what is the cost of consumables with BSL ?
to this question the answer thereводавита wrote:Andrei Patrushev wrote(a):Water passed through magnetic funnel changes its structure and it is necessary only to make it easier to remove the mud from all the extra videocan I wonder - what??? As I wrote above, it turns out the exact opposite... the Data from the patent owner Gorshkov A. S., electrochemistry too tricky a thing to read on the website http://www.bsl-med.ru in the folder "Articles" -"the Life - movement of water in the body" , there are many answers to the questions
Tell me, and a bagel after use can simply be washed in running water and set into place, or it must be in the water until the next use (taking into account that the filter I use every day)?
You can, but then every day you need to boil the bagel at least 5-10 minutes just in water, and once a week, always with pineapples. The cleaning cycle is 20 minutes, so boil for 5-10 min no problem.Тяфа wrote:Tell me, and a bagel after use can simply be washed in running water and set into place, or it must be in the water until the next use (taking into account that the filter I use every day)?
Awesome...I have 3 mugs vykoukal.водавита wrote:First obtained the water should be drained, or water your flowers
![Shocked :shock:](./images/smilies/icon_eek.gif)
- Contact:
It we was not about electrochemistry and the electrochemistry magnievye before - does this make sense, and what is it - maybe even harm...водавита wrote:Data from the patent owner Gorshkov A. S., electrochemistry too tricky a thing
Of course, I have read it all before you buy, vagavita, BSL-MED. These questions I asked in the email to the developer but received no response, so I was hoping that he's got something we weakned,
By the way, the first idea of this water treatment was used by the British - they of the Thames its so clean - put in a few rows of metal chain, to which one serves the appropriate voltage...
vagavitaon the first page of this topic, Logik posted a video in BSL (I think it was competing with your company), so here they are on video saying that this bagel you can just wash before using and the water, like she is a sanitizer, you are saying that it is necessary to boil, the instruments themselves are the same..... unclear....
- Ланцелот
- Has thanked: 33 times
- Been thanked: 11 times
IMHO too much. If glass teapot on a spirit lamp, the gurgling, you can define different types of gurgling. If electric, the better the controller 80 degrees.водавита wrote:Only water no need to boil, and bring to a boil (not the "white" key, 90-95 deg.)
vagavita And You have heated water with a negative ORP
or heard somewhere?this case remains in the water potential of -70 mV
perhaps there is still a difference with what potential it began to heat up???....
On the website www.bsl-med.ru on chapters.str. about conquer. the firm is a patent holder of video, listen to what he says. And about the filter, they are unable to steal, complete bullshit. It will be in any case to collect and including dead organic matter in treated water indicator - permanganate oxidation will be higher than the MPC. Therefore, the "teacher" of kankariya of the company that is now engaged in the FAS , was novotels tops and teaching the people to gargle, but do not boil (that should be). And about the Thames - that's what distinguishes electrochemistry: you can take the two electrodes and drop into the water and put it in the socket or will a managed process according to the incorporated program.Тяфа wrote:on the first page of this topic, Logik posted a video in BSL (I think it was competing with your company), so here they are on video saying that this bagel you can just wash before using and the water, like she is a sanitizer, you are saying that it is necessary to boil, the instruments themselves are the same..... unclear....
vagavitathank you , will boil.
