Choose the session letter "r" at the end.Владимир Никонов wrote:Brightness sessions is enough, but sometimes you want brighter, as audiostrobe.
Navigator. Experience.
Since last Tuesday and until Saturday the Navigator is not included, decided to rest.
On Saturday I spent the session comparing R02N "Relax and back" in the browser and translated to wav in the session of the Nova Pro 100, running on the same Navigator.
Session Navigator was heard in a version with a square wave. Again I can not pass by too dim flicker points. And like still the effect is there, but in the second half of the session, the LEDs started to flicker so much that is already accustomed to the dim light of the eye pierced by a sharp pain from the light.
In a variant of the Nova Pro 100 I was not able to adjust points to end at a comfortable brightness level. Even diminished to a minimum glasses shone brightly! By the end of the session my eyes are tired. The effect of session was different. Of lightness after a session was not, the body was relaxed and limp.
On Sunday I decided to try an alpha session from the program Neuro-Programmer 3. The Navigator worked in the strobe mode of the decoder.
The program has set the level of audiostrobe and brightness points. Setting the program and the Navigator, has included the 30 minute alpha session.
Relaxation came in the first 2 minutes. A feeling of lightness and euphoria spread right throughout the body. The level of light I put average. The brightness change was, but when the LEDs flashed at full power the eye does not cut it.
After the session within 2 hours in the body was the ease and relaxed. At night put another alpha session from Neuro-Programmer 3. Interestingly, woke up this morning with the same sense of ease and relaxed, as if just listened to the session.
In Neuro-Programmer 3 now you can see what is in the session and edit it to fit your needs.
In the middle of the sessions we stimulated at a single frequency, without any changes for more than 2 minutes. The idea is n no Gud, but not the estate, the effect of the sessions is, and I like it.
Логик wrote:Session Navigator was heard in a version with a square wave. Again I can not pass by too dim flicker points. And like still the effect is there, but in the second half of the session, the LEDs started to flicker so much that is already accustomed to the dim light of the eye pierced by a sharp pain from the light.
Yes I had this on a session. Quiet sound comfortable light and suddenly as the noise and flashes as bright points I podskachila. All relaxation was gone. What was not understood?
Because all the senses are working we have a logarithmic law, in the TOR was written a task to make the adjustment of sound and light so that small values of the intensity and volume had more gradations, and at large - less to provide the smoothest possible ride for the eyes to change the brightness.Логик wrote:but in the second half of the session, the LEDs started to flicker so much that is already accustomed to the dim light of the eye pierced by a sharp pain from the light.
Session R02 consists of segments in which there is alternation of 70 and 100% intensity all the way through, i.e. it should not be in the second half there are no surprises. Thus, there is reason to assume that the device works incorrectly (unless it's not related to the individual characteristics of perception, for example, color - there, in the second half, the green color).
Алексей Крячко__
It is clear that the brightness of each individually, then you need to configure.
in General, I think a compromise would be along with the color for the points to make a separate setting and the brightness, if the brightness inherent in the sessions to someone is not enough.
In addition there will be an option and lowering the brightness (there were complaints that it is a lot). In the next firmware version brightness will expand.
I wish these settings were preserved, and in the personal profile. Let's say I have a Navigator uses three people and all have different preferences. But they are quite stable in time. I would like it is comfortable to consider. From the point of view of implementation - quite simple. To fix settings for each session, named with a profile name of one of the users of the device. When opening sessions that were not previously tapped, offer to pick up the default settings for this user device.
Everyone will be very comfortable, I think.
Алексей Крячко__
Well then, it is not only sessions should apply to and other modes of audiostrobe for example.
any settings stored in nonvolatile memory and can be uploaded to a profile on the memory card and load from it, and in the memory of the same mark under a user now settings. And to do when provided that device more than 1 user.
Here I read reviews and don't know, maybe I have another Navigator???
I've tried to work with several disks within the set, and copied independently:
Healing;
Explorer;
-Journey through the inner worlds;
Massage of the brain;
-Concentration;
-Deconcentration;
The solar wind;
Endogeny;
Always on a single setting of the 4th level (which is the default), the signal 33-40 at startup, optionally reduced to 30, 43-47 volume and light and sound (though audiopodcast 3.0, it's a little volume, spreads) in "the times" already and not worried with the settings. And brightness can add (or subtract current changes) as you want. Battery was enough for a long time.
Ile because it is not cupisnique we just became friends???
Only on some discs, the light after 1-2 seconds start. Firmware 1.10 and.
Appeared wish - soft (rag) points. In General, very satisfied! Thank you!
Sincerely, MAG.no
Healing;
Explorer;
-Concentration;
-Deconcentration;
The solar wind;
Endogeny;
Sincerely, MAG.no
Are you sure you understand what you read?Маг.нет wrote:Here I read reviews and don't know, maybe I have another Navigator???
And how did you find audiostrobe where there is none?Маг.нет wrote:Massage of the brain;
-Concentration;
-Deconcentration;
Yes I know you have another Navigator. My not allows you to set the volume above 40.Маг.нет wrote: volume 43-47
So in your opinion here someone is naughty? Oh well...Маг.нет wrote:And the brightness can add (or subtract current changes) as you want. Battery was enough for a long time.
Read carefully and you will see that complaints on the brightness
associated with the inner core sessions, not disks.
Understanding normal
and exactly not take....
Arrows.... Probably still another Navigator (individual)
or:
And with the sessions while in timeprobably until the end of August.
Carefully.......
Sincerely, MAG.no
That's the fact of the matter is that I havewithout a separate signal, but the decoder worksЛогик wrote:And how did you find audiostrobe where there is none?
Логик wrote:Yes I know you have another Navigator. My not allows you to set the volume above 40. How are you worthy?
About whims, no need to try, I'm only about myself...Маг.нет wrote:Il because they do not cupisnique we just became friends???![]()
Carefully.......
Sincerely, MAG.no
Here Andrei Patrushev will be surprised....Маг.нет wrote:that's the fact of the matter is that there may be no specific signal
If you have flash points high-frequency component of a signal does not mean that this audiostrobe.
From the instructions of the NavigatorМаг.нет wrote:Probably still another Navigator
That Alexey Kryachko__ be glad you have some other Navigator.When performing session work as control keys (see figure 1) :
K1, K2 – increase and decrease the sound volume. Adjustment range 0...40recommended
the value 28...35.
I wouldn't be so sure. Programming the controller to some parameters, and get other... is there any developer technology surprised such anomalies.Маг.нет wrote:Alex, and Andrew would not be surprised.
If you begin a sentence. be so kind as to finish it. :If cogeco want to understand you.Маг.нет wrote: Careful....
