KV - clasterization water - a product for structuring of water.
Re: KV - clasterization water - a product for structuring in
Post by Михаил_ » Fri Oct 07, 2011 20:05
A panacea, because of increased abilities be programmed easily will go for a good emulator itself.
Витал
Post by Витал » Sat Oct 08, 2011 14:10
Good time of day. I tried to combine the KV and the matrix cures, so to speak, two in one, personal feelings on SQ still has a stronger impact on water than the matrix.
Did the following. Poured in a bottle of water and put a matrix Panacea, two hours later put on HF for the night, get something in between, again at the sensations and not SQ and not a Panacea, I think that the water is obtained, on the average, health status to determine need time.
sincerely Vital.
Post by Михаил_ » Sat Oct 08, 2011 14:23
Try differently. The water charge on SQ, and then pour in a bottle of panacea, and it is desirable a matrix not to glue and glass to put a marker in several places(so a little more effective at the time of processing the bottles will be) and both times it is desirable to use glass as a vessel.
Витал
Post by Витал » Sat Oct 08, 2011 14:41
Glass only due to the quickness of cooking time or even better quality compared to plastic two Litovko?
sincerely Vital.
Post by Михаил_ » Sat Oct 08, 2011 15:16
plastic - PTS. bad for water.
Post by bofara » Sat Oct 08, 2011 22:09
ЛИЛИЯ-Р wrote:is Clear. I thought that there is a matrix KV.
Михаил_ wrote:Panacea, because of increased abilities be programmed easily will go for a good emulator itself.
:D Well, folks, IMHO, would not mind if a certain matrix that transforms the Panacea light in the SQUARE to see the "white light". :D
Post by Михаил_ » Sat Oct 08, 2011 22:22
I'm not going to publish this.
Post by Михаил_ » Sat Oct 08, 2011 22:38
For one very simple reason - matrix effective in the area of the basic properties of a Panacea, and serious reprogramming is needed, or a programmer or sensible operator. Latest absolutely for free. BUT maybe not for everyone.
Тяфа
Post by Тяфа » Mon Dec 26, 2011 21:03
Михаил_ wrote:Feature of SQ is that recorded information has a number of features that make it valuable.
And you can specify what kind of FEATURES? Very interesting...
Тяфа
Post by Тяфа » Mon Dec 26, 2011 21:04
Михаил_ wrote:Temperature regimes will be clarified.
Have something to say on this issue?
Post by Михаил_ » Tue Dec 27, 2011 2:58
Yet. How to enter for a standardized test procedure structures, so to say. While I want some equipment. But so far only want.
Тяфа
Post by Тяфа » Tue Dec 27, 2011 12:12
It was a response to which of the two questions? :roll:
Post by Михаил_ » Tue Dec 27, 2011 13:12
On the second one. On the first one is answered in the basic description. There is a reasonable optimum concerning public detail features of the products. Some properties in clear language can not describe. They are useful.
Тяфа
Post by Тяфа » Tue Dec 27, 2011 16:18
Thank you, will test the usefulness of :?
Тяфа
Post by Тяфа » Wed Dec 28, 2011 8:29
Michael_and if SQ put the jug with hot liquid to cool and recharge (for example compote) that won't hurt the washer or it can crack?
Post by Михаил_ » Wed Dec 28, 2011 11:17
Not tested. It is better to use a thermal layer. Still in the glass internal stresses after laser engraving can be.
Тяфа
Post by Тяфа » Wed Dec 28, 2011 16:55
:D Urya! Now I have it!!!!!!! :D
Тяфа
Post by Тяфа » Sun Jan 01, 2012 15:53
Special properties of Holy water is that, even added in small quantities to normal water, it tells fertile properties, and it, therefore in case of shortage of Holy water can be diluted simple.
To understand why the Baptism of water becomes bioactive, scientist Mikhail couric began to collect water samples from 22 December – winter solstice, to more accurately track why and how water changes its structure on January 18-19.
And came to the conclusion that the properties of water influence the energy field of the Earth, the moon, the Sun, fields of the planets of the Solar system, different cosmic radiation.
All due to the laws of nature, – says Mikhail. Every year on 19 January, the Solar system in Space passes through the particular rays irradiation, resulting in all life on Earth comes to life, including growing bio-energy of all waters of the Earth. Exactly on January 18-19, the water gets additional energy due to changes of the gravitational field in the galactic space. Why? It's simple! After all, spring is approaching, and all living things need energy to be born anew.
But the results of the research of Russian physicist Anton Bielski, in the space in front of 19 January a number of years was recorded intense bursts of neutron flux above background levels 100-200 times. The highs had on the 18-th and 17-th, but sometimes exactly on the 19th, and sterilizing the role of the intensive neutron fluxes is well known.
"Space" theory of the origin of the baptismal water is held and astrologers.
– This day the water becomes pure, it carries the charge of Holiness and rejuvenation. And it's not just so, says Paul michlin, Ph. D., is an astrologer.
It is believed that the Sun, Earth, and the galactic center are arranged so that on January 18-19 open line of communication between our planet and the center of the galaxy, it begins to interact. The land falls under the energy channel that structures all, and in particular the water on Earth. Besides, Baptism is usually they are cold, and the water in a frozen state absorbs and "cans" positive energy during services and prayers. And during the consecration the people themselves charge your water with positive energy, because I believe that water should be healing, sanctified.<
Post by Михаил_ » Sun Jan 01, 2012 15:57
Well, somewhere somehow something near that... but these scientists, they are scientists - it would be important under a picture of the world to get any strange.
I suspect that water after HF also can be diluted. But with sq why do it - I don't know.
Тяфа
Post by Тяфа » Sun Jan 01, 2012 16:08
Михаил_ wrote:Well, somewhere somehow something near that... but these scientists, they are scientists - it would be important under a picture of the world to get any strange.
that's for sure... :? I mean that now more often began to say that it is not only and not so much the effect of religious rites :? "We can assume that in ancient times the priests empirically found this effect and started to use it to their advantage, -concludes A. Belsky. - Of course, likewise valid and the effect of the silver cross."
And to dilute the water after KV may not need, I just in home use, because if the stand charges the water which is 2 hours, such as vanee volume is much more, it turns out that Q must lie almost a week to confer certain properties of water, but I think that the water when HF still carries obtained the old ordinary water. About the other properties is difficult to judge, but if you put q in the tub and pour it to half the required volume, the water is very soft to the touch with a higher density. After take out the KV and fill to the desired volume properties do not change! :wink:
Тяфа
Post by Тяфа » Mon Jan 02, 2012 11:10
Another interesting property is found: put on KV a pitcher of fresh and forgotten, stood for 1.5 days (holidays still :? ). Today still decided to try, pretty well, similar to only squeezed! Not at zachys!
Артур888
Has thanked: 7 times
Been thanked: 5 times
Post by Артур888 » Thu Jan 26, 2012 4:17
And the puck charging water "KV" works, if a person does not have BJ ? Just it is in the section "System extension 2.0 Ah 2.0 with a base at" and it says that All devices of this series are the extension of Life Bracelet 2.0-2.x and interact by working "cell" information technologies implemented in the BZ 2.0-2.x how TO.
Post by Михаил_ » Thu Jan 26, 2012 12:31
Yes, the washer works perfectly independently, well, in the presence of at maybe slightly faster (she has the power substation then its there for work).
СтАвР
Post by СтАвР » Thu Jan 26, 2012 12:56
and the water after the KV really tasty and I would say even sweeter :ay
ДМИТРИЙ Ч.
Post by ДМИТРИЙ Ч. » Fri Feb 03, 2012 17:56
I want to give the familiar KV. But as it is in some way a fan of Christianity , not to mention the link with religion, with the aim of belonging of this "sacred" subject to the Church, I want to name him as the first name - "clusterization water". But searching on "Google" more comprehensive, scientific description of the actions, nothing the shelter links on this forum is not found. In this regard, I want to ask if the name written is true, will explain please that it means, or give a link? Thank you.
