The development of the mind of the machine Navigator.
Post by Андрей Патрушев » Tue Jun 14, 2011 17:13
Тоха wrote:what about FLAC and APE I was joking, wav reads and that's good. Well wait car)) Hope, Andrew, Your session will be included?)
All sessions are written by me. 8) :) Under the agreement, there are sessions, Nova Pro 100, plus our (I mean mine), but you understand that machine on the possibilities of stimulation are very different, so the session had to manually score. In principle, the frequency and pattern of sessions, in most cases, close to the original, but still follow the original boring, so possible deviations, sometimes significant... :oops: By the way, places for sessions in machine not just a lot, and sooo many (you can download all sessions all available Masin and still remain :)), so that the new session will appear and be added to the website for free download...
Ростислав
Post by Ростислав » Tue Jun 14, 2011 20:22
Very cool that there are also drives Andrew's on the drive! Although I have the whole CD collection, plus inner pulse but such a tempting offer I will never refuse!(I'm certainly the first application filed!)
well, if in fact audiostrobe supposed to be better than iner the pulse with the color of the track?
Тоха
Post by Тоха » Tue Jun 14, 2011 23:35
Andrew, and will be session type i on innerpulse? So always generated not similar to each other?
Post by Андрей Патрушев » Wed Jun 15, 2011 8:22
Тоха wrote:Andrew, and will be session type i on innerpulse? So always generated not similar to each other?
Many of the settings in the sessions for the Navigator in the programming to put on "automatic", then they will change during the session at random (and some rigidly specified) law. Thus, almost all the session in one way or another similar to session "i".
Post by Андрей Патрушев » Wed Jun 15, 2011 8:28
Ростислав wrote:well, if in fact audiostrobe supposed to be better than iner the pulse with the color of the track?
Audiostrobe in the Navigator can now be set for sensitivity (unfortunately, just before the session) that provides an opportunity to overcome the conflict between the threshold and comfortable loudness.
Тоха
Post by Тоха » Wed Jun 15, 2011 10:03
It was just a dream!!! :D :D
Ашот
Post by Ашот » Wed Jun 15, 2011 11:27
Tell me, nalichae isochronic tones, allows to do without the use of headphones to obtain the effect. That is, the machine can be connected to speakers?
As I understand it the headphones with the stereo is only needed for binaural beats.
But there is a program allowing to impose rhythms, and while listening to these audio programs through the speakers. (For example, Lifeflow Meditation) as far As I understand, they just use so-called isochronic tones.
Ашот
Post by Ашот » Wed Jun 15, 2011 11:32
there is the convenience of it. And diversity of experience is useful. So the effect is not reduced.
Ашот
Post by Ашот » Wed Jun 15, 2011 11:39
And another question:
What is the "built-in piezodynamic (for tone)"?
What are those tones? To what effect?
Is that some kind of vibration sensor to obtain tactile sensations? Or is it to machine vypolnyali the functions of Echofon (that would be fiction)? Or I confuse something.
Post by Михаил_ » Wed Jun 15, 2011 14:30
I think (not know, but suspect) that tone is just a response to the inclusion of certain modes - i.e., feedback control, because the headphones can be charged on or off and so on
In General, being one of the oldest user of innerpulse (and active to this day, though not as often as the first time), I'm certainly also interested in testing the Navigator.
Particularly interesting is the point that there can be a qualitative leap efficiency. For the time I use innerpulse, I had changed myself and the opportunity to obtain a more effective instrument of tempting.
So at the first opportunity will be engaged in active exploration of new horizons.
In General, thanks to innerpulse and generally mindmachines, I got on this website :) for a long time being primarily by the user. Many recommended that to follow this path (and many I know did just that-bought mindmachine and-or disks Patrushev).
It is very interesting that the flexibility is significantly higher - there is much to invent and test in a more advanced platform, hands already itching to integrate some of their ideas and developments.
Post by Андрей Патрушев » Wed Jun 15, 2011 14:32
Ashot
Amplitude modulation is in Nova and About in Innerpulse (that is without the headphones listening). Although a requirement of headphones really are BB, but in headphones it is better to listen both that and another (in order to avoid multiple reflections from the walls).
Built-in piezodynamic is only required for the timer/alarm.
Post by Михаил_ » Wed Jun 15, 2011 14:33
and you can put it in a separate file, synchronized with the audio? well, that is the figure? ie if I do my gate-entry, and the machine still has the stick and runs with it, not easier in some individual cases, let go from the standard format and put the two files will sound and the strobe just separately so as not to set the sensitivity.
Post by Андрей Патрушев » Wed Jun 15, 2011 14:36
Михаил_ wrote:and you can put it in a separate file, synchronized with the audio? well, that is the figure? ie if I do my gate-entry, and the machine still has the stick and runs with it, not easier in some individual cases, let go from the standard format and put the two files will sound and the strobe just separately so as not to set the sensitivity.
This is called session... :)
Standard signal audiostrobe the spectrum analyzer in Adobe Audishn after mixing the audio needs to have a level of -36dB (up to mixing about-12dB). The secret is that to have a good signal on the glasses and a comfortable sound level main file should be put under the standard of CD: -0.5 dB and -3(-4)dB.
Post by Андрей Патрушев » Wed Jun 15, 2011 14:50
By the way, another little amenity in the Navigator - ability to preset to swap left and right margins, as for glasses and headphones - for those who have a hemisphere inverted.
Post by Маг.нет » Wed Jun 15, 2011 14:57
Михаил_ wrote:Actually, it is thanks to innerpulse and generally mindmachines, I got on this website
:) Me too, and I became an interesting statistic, what percentage of buyers mindmachine was the first acquisition in the Psychotronics and what percentage of buyers then made subsequent purchases from the current range?
Perhaps this question is more addressed to Andrew Kabankova.
Sincerely, MAG.no
Тоха
Post by Тоха » Wed Jun 15, 2011 15:33
Yes, I too started with mm). Then we looked at other products on the website. Of course after verify the effectiveness of the cars on the experience.
Post by Андрей Кабанков » Wed Jun 15, 2011 16:33
Final version.
Post by Маг.нет » Wed Jun 15, 2011 16:55
:ay :ay :ay
Sincerely, MAG.no
Тоха
Post by Тоха » Wed Jun 15, 2011 17:06
Looks stilnenko. Well, I hope the results will be.Well done!
Post by Андрей Кабанков » Wed Jun 15, 2011 20:41
Ростислав
Post by Ростислав » Wed Jun 15, 2011 22:13
And how much will it cost the second set of points with headphones????
Post by Андрей Кабанков » Wed Jun 15, 2011 22:18
Маг.нет wrote: A successful way NAVIGATOR! Let it be so! ➳➳➳
Sincerely, MAG.no :o
Thank you!!!
Navigator is the result of years of experience of Andrey Patrushev,embodied in our Navigator product engineer Alexey Kryachko.
The development of the device took three years.
Post by Андрей Кабанков » Wed Jun 15, 2011 22:22
Ростислав wrote:And how much will it cost the second set of points with headphones????
Glasses will cost about 3000 rubles,headphones 500-1000 RUB. (depending on the model,where we will stop for komplektacii).
Ростислав
Post by Ростислав » Wed Jun 15, 2011 22:25
:ay
Ланцелот
Post by Ланцелот » Wed Jun 15, 2011 23:07
MAG.no
me too, and I became an interesting statistic, what percentage of buyers mindmachine was the first acquisition in the Psychotronics and what percentage of buyers then made subsequent purchases from the current range?
Take me in the statistics.
1. NovaPro 100 + ColorTrack
2. Mind lamp and Psyleron about.
3. Manifestation (I want to enjoy at the end of June) complete (one courier) with the Navigator.
4. Radionic. I don't like the free test, and buy a pig in a poke the toad strangles, so use homemade.
5. There's not much BJ (converted), but almost don't use them.
Andrey Kabanov
Thanks for the Navigator.
