StopMagic. My Experience of manufacture and use.
Has thanked: 24 times
Been thanked: 142 times
Re: StopMagic. My Experience of manufacture and use.
Post by Маг.нет » Mon Sep 26, 2011 8:00
Hello!
Originally StopMagic is software for a device called the Stabilizer, but having the opportunity to work outside, directly with the Operator (the User), after the product appeared under the same title, in the form of a set of programs (stop magic 1-2; protection; stabilizer optional) recorded on a material carrier.
Mandalas (pictures) "was calculated" as effective as counter User "magic strain", with "team" (or multiple approaches one of the developers to the state, algorithms) that are available in these States/the algorithms, after the allocated "shared" (essence), thereby cutting off from the "individual" each of the group, then it's a condition/algorithm fixed defined methods, including in the form of a figure (of the mandala). In the General case.
Can be done simply by printing out a drawing, a mandala, and it will be a "how to" to work, but can also complicate the process of "drawing" the hologram more carefully, applying (or not applying) the additional energy of the recording process on the object and methods of fixation of the hologram in the object.
When you use the "drying" (crystallizing process) item, Yes, the structure of the mandala is additionally fixed in a more dense and solid (the paper) object.
stop магия1-2 - a ban on deformatio the world is not material ways, temporarily suspends any external influences and / or other artifacts on the territory of the described stabilizer. Of course there's nothing absolute. But it's a working object.
Taken from the description of the device Stabilizerbut can work without it.
The easiest option is to make a printout of mandalas picture, but you can complicate "copying holograms" (thus, better and her "drawing"), for example by printing out the number and glue "stack" into a single object. The printout will go with an inkjet printer, but laser is better, and even better professional photo printing.
The nuances of the programs and their production you can also read on the forum thread "Stabilizer".
Successful research.......
Sincerely, MAG.no<
MagicianII
Post by MagicianII » Mon Sep 26, 2011 12:37
MAG.no thank you! Stabilizer, as I understand it you can create it manually. And the charger, which has a jar with water and put headphones with a condom dipped, you can do yourself? Or even, any player? From where you can take the records that you need to charge the object and what they are?
Post by Маг.нет » Mon Sep 26, 2011 12:50
The stabilizer can be done manually, you can simply "draw", well it is a "light".
Charger, probably meaning BJ 1.0but it is in the Stabilizer applies only to "cleanse" the Druze from adhering distortions read more about BJ 1.0 can be read on the link. Any player, entries represent some of the resonances of a planet in audiozapisey, the essence of which it is possible to obtain information of the names of the tracks and discussions on the same link.
Sincerely, MAG.no
Post by Михаил_ » Mon Sep 26, 2011 12:53
In General, MAG.not everything is described in detail.
Stabilizer can make your own, but its impact is quite strong... do not pursue this right please don't just.
The charging system described in the BZ openmagic.org a Bank of water - the usual. audio is there on the links. Stoppage safe program and can be also made without the manufacture of the stabilizer. In General it's better after the BJ, he would be the Normalizer for the man in attunement with nature.
By the way is the case here, since it reminded gave the keychain and then drive to a friend. he sent the family to which the target impacts have long relatives are not good (and it happens), then a reference to the files sent, they printed out stoppage leaves just. For reviews - much better. Similarly from the use of N1 previously, it really is not until the end ( well, he and the other tasks were set originally ), and as far as I understand, BJ is the family does not use, for whatever their reasons, probably not them, but who they passed on(the person is simply their designs are different). But not sure exactly. This is not in response to a question, just observe. Generally, for a stationary object (house, apartment) printout works very, very well. Use - free and effectively.
Well, in connection with the continued receipt of positive feedback - will probably make another stop magic in glass 3D past heavier (and more powerful resp.).
MagicianII
Post by MagicianII » Mon Sep 26, 2011 14:05
Thank You! Like begin to understand what is what:) Anyone heard about Manasova? He had these drawings of all his inventions. For example, "generic magic wand," he says that you must turn on the player when using it, inviting a corresponding force. Each audio in his case, as he says, corresponds to a specific Arcana of the Tarot deck.
Post by Маг.нет » Mon Sep 26, 2011 15:25
Like for Ohr use a different audio device on the element, the Magician Arcana is taken.
But unlike the products presented in this site, just to have to turn audio to work effectively with the Department of internal policy is not enough, you also need to have a certain level of development, ability to take the arcane and knowledge management. Here is easier, all devices working and effect can be obtained even from the technologies present in the free (without charge) access, virtually anyone (the level of development and availability of knowledge are not a restriction).
Well, the approach to the World through "directly opposite the door," settings DIP through the creation of some of the World deformation (distortion of the reference signal by the superimposition of structures) and resonance with her, tuning products BJ, through the removal of existing strains of the World (structural modulations) and resonance with the reference (original) signal, in principle, work with him.
Sincerely, MAG.no
MagicianII
Post by MagicianII » Mon Sep 26, 2011 17:15
Thank you very much for the answer! Wanted to understand what a UVP, but I don't really understand until you hold it in your hands or until I understand the principle of operation...
On the website I saw information about Radionics, I was wondering, can I use them, for example the power of thought + radionic to rotate the turntable to the needle?
I thought that all these drawings for StopMagic need to encrypt the main code, right?
Post by Маг.нет » Mon Sep 26, 2011 17:50
Yes, the SHEMA is often difficult to obtain some complete information, you need to learn yourself, usually by "trial and error", and in principle often (but not in all cases) is a "cheat sheet" to develop their skills (algorithms) Work, through the "structural modulation". UVP using "natural modulation" resonates with a certain area of "structural abnormalities" (element), inside which there are characteristic sets of algorithms ("fingerprints" of the Minds of Mages, skills, and abilities), but to use them you need the accumulated level ("pass" of Consciousness in this area for effective work in it), but if the level of the unavailable, alas... just have to learn and evolve otherwise the result is difficult to obtain.
:) Why do You need to rotate the turntable to the needle? This device is not for display of tricks and stunts, and the mental Machine to saturate/seals mental field (as a source), as well as modulating structures within it, due to the broadcast of an external Trend (algorithm), of course this is only in General and not completely. To work with your Mind, not enough to have only one of its parameters - the strength, but also need and algorithms (working structures) to work with the mechanics of the process. If You know how to rotate the turntable to the needle (or correctly and fully describe the real mechanics of the process), Radionic can help to do better, by increasing the supplied power (if the algorithm describes the translation of a Trend).
StopMagic carries the algorithm to the reflection of active structural modulations in the area of external interactions, what is the basic code I don't know.
Sincerely, MAG.no
MagicianII
Post by MagicianII » Mon Sep 26, 2011 18:12
MAG.no, less now began to understand the system these artifacts, thank you! :)
I've thought that radionic is for saturation/seal mental field, is there a machine for saturation/seal of the etheric field or what is the workout?
Someone said that all these tricks with telekinesis - is the allocation of a powerful beam of air, but it's hard to do, because not enough energy and strength and here it is possible to make contact with the Arcana of the Tarot, in order to take power from there. In fact it is the use of a specific egregor of Tarot cards, I correctly think?
MagicianII
Post by MagicianII » Mon Sep 26, 2011 18:20
Just for a month and want to learn to spin turn, but for now, own it only twitches sometimes (perhaps even from the wind), although perhaps not.
I understand that to twist the chopper (telekinesis) is possible in 2 ways - using PSI energy, where do you imagine what position should take the spinner and try to implement it and the 2nd way is by allocating the broadcast, but there is a reduced distance. With all methods must shift the assemblage point, if it has not been shifted to the desired position. Correct me if wrong.
Post by Маг.нет » Mon Sep 26, 2011 18:20
Маг.нет wrote:it is only in General and not completely
It also works with the etheric field and Arcana of the Tarot, but that's a topic for another branch - Radionic.
Sincerely, MAG.no
MagicianII
Post by MagicianII » Tue Sep 27, 2011 1:07
I wonder who else tried Stopmail in active testing. For example a person that has telekinesis or pyrokinesis, levitation, reducing the weight, and so forth anywhere near this Stoppage and he failed to include its ability? Or Stoppage designed only for mental magic?
Post by Маг.нет » Tue Sep 27, 2011 7:00
StopMagic prevents direct impact to the Operator (User).
These superpowers are triggered in humans in the range of mental.
Often superpowers are not the deformation of the World, and Vice versa - "the awakening".
Sincerely, MAG.no
Post by Михаил_ » Tue Sep 27, 2011 12:23
While the actions of a third-party person will not harm the operator wearing stopmail she can "block" will not. In fact, there is no lock, and the divorce of the operator and the fakor impact phase so that they do not touch. in fact two actions in different worlds. The "hit" gets a boost, despite the fact that there are no "mirrors" and other shields are placed. Tangible. The reason for it is that the return comes from the world because of proletaria deformation of the target.
Like from a rock.
We tried with a group of 12 people. I beat. The group was from memory from an engraved serial program to the stabilizer (I have one in a circle allowed before). Me I can not upset (well trained group and I hit the floor forces, not a toy).
Can we assume that they are somewhat strengthened the effect of his mental hold of the object, but in General - so.
Well, you have to understand that the factor of harm to the operator is that breaks through its picture of the world. Ie if telekinetic in his picture of the world is, and he will gladly ponablyudat everything will be fine with telekinetic. And if he does not believe in him - the ability telekinetika pabloneruda in a given place at a given time, for it is the breaking of the world picture of the operator. Or not pabloneruda, but will not cause direct harm to the operator (for example, he will not see what is happening) and telekinetic would be in a more rigid interaction with the world than usual. In General, it will look as if they're in different places and at different times, and from the other not know.
Post by Михаил_ » Tue Sep 27, 2011 12:25
Yes, the product serial 3D stick and CD "stoppage" is also included supplementary programme protection and stabilize, besides stoppage. They are also effective and do not contradict stoppage. In serial product stoppage for stabilizer (plastic version) - only stoppage, as is software to the device there and "interfere" together the lot of the operator.
Post by Маг.нет » Tue Sep 27, 2011 12:35
MagicianII wrote:I understand that to twist the chopper (telekinesis) is possible in 2 ways - using PSI energy, where do you imagine what position should take the spinner and try to implement it and the 2nd way is by allocating the broadcast, but there is a reduced distance. With all methods must shift the assemblage point, if it has not been shifted to the desired position. Correct me if wrong.
Actually (in my opinion) described one way, just different approaches.
This effect can be obtain essential working field (as the most dense of the fields of man) discharging/compacting it into a focused zone, directing the flow, but the methods, or the direct control of the energy (flows) that the essential range, then TS is high and not required, this low band, you can work sensations, or modulating the etheric field mental (PSY), in this case TS need to lift in the HF range and out to produce (an idea) in principle the same actions with the etheric field, or have a very dense mind, well, this is even higher level (not the vehicle, and the Power of Thought - field density).
Sincerely, MAG.no
Post by Михаил_ » Tue Sep 27, 2011 12:45
about the turntable: http://www.001-lab.com/001lab/index.php?topic=339.0
there is a video there... the question is in the right postavene experience :)
MagicianII
Post by MagicianII » Tue Sep 27, 2011 17:27
My turntable is on the shelf of the Cabinet and sides of the boom. Generally she is not spinning, if not to blow, and the power of thought, maybe just a little wobble here and there, barely noticeable, sometimes half a turn makes.
One visitor to the forum ariom.ru said can to rotate the turntable, even looking at her image in the monitor, through the web camera, he said that it is difficult to rotate when it is covered with a glass cover, and when covered with a plastic cover - even almost impossible. According to him there is some sort of communication from the coating material.
I do not understand how to increase the power of thought for a short time..
What do you think about VP Monosov? Do they know how do for example: to increase the strength of the wind, if you stay on the street or to increase the power of telekinesis? this is essentially the same Radionics?
Post by Маг.нет » Tue Sep 27, 2011 18:45
VP is nothing she will not do, it is a tool sign-in status (if available, read magic level development position of the vehicle) and trapping him inside algorithms for possible structural changes. Usually the wind power is not specifically changed, but it may change (and the wind is calm, to appear) for some practices with the element of Air, due to the "stratification of space" to the parts that are different over time. Need a level, and he does not appear, it is possible to produce. In the SHEMA answers stop, it is still correct in the "2 lines" to write (to come to the realization and management of the elements - learn over the years), and difficult (without an understanding of the paradigm) will be aware, and "in General" is so vague it.
The power of thoughts significantly in a short time it is impossible to change, and it is dangerous, and therefore learn more than one year, to only come in "small steps" to the possibilities, although one is "awakened" self, but not in time, and there depends on the willingness (real, not just a desire) to understand it and to use it, either the Creators, or in the loony bin (which is almost rare if not to follow abnormal paths, and the inner defender of the body - the subconscious mind protects you from such "cataclysms", pushes out "hazardous conditions", but apparently not all....).
For the mental there is no distance, this is only a structural difference, with which to work. Yes, polyethylene and plastic in some cases there may be "insulating element" is a structural property of the material, which can be overcome.
The object can be put into your mental space there to work with him, or move the space to the object, but the result largely depends on the density of the mental in this moment. Density can be increased by practitioners and some mental Cars, but not as much so in small steps, otherwise the subconscious mind will include their protection....
Sincerely, MAG.no
MagicianII
Post by MagicianII » Tue Sep 27, 2011 22:56
Thank You MAG.no! What are some small steps you can increase your training? It is possible for example by the technique of "Fireball" is described by Monosomy or the other one?
Heard that twisting clockwise 100-400 revolutions per day thicken the etheric body or something like that, right?
Post by Маг.нет » Tue Sep 27, 2011 23:35
Talking about twisting don't know, but any practice with the etheric body can develop, including seal and enhance its capabilities, as the floor lifting dumbbells for the body.
The path of development ("steps") can be different in different directions. Using a variety of Technologies and approaches that BJ is also developing Operator, over time, allowing you to raise the level of operating frequencies in the HF range, but as above indicated, this other "door". So that narrows it down a bit to "get" to the level of the mental is possible to build a new road through the "key points", or clear previously existing - line.
Sincerely, MAG.no
Post by Михаил_ » Tue Sep 27, 2011 23:48
1. I'm not welcome here discussing the equipment and systems SHEMA, because I think it potentially dangerous to use and the world (although for some time he studied and used a number of artifacts that can be used safely and they work for everything of course, but people very often do not understand the theory and paradigms of a particular school wrong to interpret the possible applications and consequences as well as effects, coming up with something there and not knowing that is).
On the other hand I have great respect for the founder of the school, simply because few people are sufficiently adequate such and it is quite natural that views on life may be different. It would be foolish to encourage all of you to line up :) Ie I absolutely do not advocate to deal with the negative publicity SHEMA. Just my understanding is better for a person of any more reasons to follow natural techniques. For example AI Goltis along with other recommendations, although it is a complex physical body workout (senior levels only), but obviously would prostroit and energy.
By the way Monosov this, too, says, calling his disciples not only fireball twist, but Taichi exercise, and so on. I.e. not to forget about the body. This is correct and very true. Because often come to some lovers of the esoteric, which would have some effects, and harmonious build yourself to do not leisure. Such you know, a kind of personality, which right now, for there is something to satisfy the CDA and that, of course, "I azhno MAG"....
2. You need to understand why and what You want to achieve. Your message is not clear. There is a feeling that you also want something to not fully understand why. In humans the special ability "charge" the subconscious mind, and it has much in common experience than the current person, wanted to put on "I want a paper pinwheel twist". It tend to listen to the true desires and their adequacy. Such man - "want money", but in fact he wants is not money, but the fact that they can buy (not eat well he will be?). Therefore, in order to answer your questions, you need to understand what it is You want.
3. I just brought a video with a turntable. There are special conditions created to facilitate twisting it, if you carefully read the. But in itself, this exercise quickly You get bored. The etheric body can be pumped for example to effectively and persistently performing Exercises Hermes on the rise. But other than that you need to do passive or active exercises of consciousness and subconscious and their friendship. And methods there can be a lot. For example I was close to those described on this website. For example, the disks of Andrey Patrushev, like "Star Wanderer" and other - very effective for many.
To the topic in which the question is not irrelevant, and thus You add me extra work to delete or transfer messages then. Because those who will be looking for useful information on the topic, this correspondence will not be apparently useful.<
MagicianII
Post by MagicianII » Wed Sep 28, 2011 0:07
I already set a goal to learn magic in all its manifestations, gradually. But I can't just learn and not to see results, so I decided to find out what exercise equipment is better:) I definitely do not bend and set a goal to learn any (which it will) first visible magical effects and others, whenever possible, as well as protection.
As it is, through the key points? Heard that's another way in atsral strengthens the etheric body. But there also needs to be able. to lull the body with a working brain.
Post by Маг.нет » Wed Sep 28, 2011 0:15
Probably better which is safer/greener processes and consequences.
Sincerely, MAG.no
MagicianII
Post by MagicianII » Wed Sep 28, 2011 0:19
I think so too) But of course the astral is considered a unique tool for recruitment experience, although there were fully only once and then not for long.., the other times was the OS.
Now read about Ginastica Hermes, the first time I hear it.
