Air ionizer
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Fri Dec 24, 2010 20:21
This ionizer I got:
<object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=""type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Fri Dec 24, 2010 20:46
...a clean sheet or a glitch?
Sincerely, MAG.no
Экко
Post by Экко » Fri Dec 24, 2010 21:46
the fleshpleera renew
Post by Маг.нет » Fri Dec 24, 2010 21:56
Экко wrote:the fleshpleera renew
I have Adobe Flash Plaer 10 ActiveX update 26.09.10 G., like all opens normally, but here I see a white sheet...
Sincerely, MAG.no
Post by Маг.нет » Fri Dec 24, 2010 21:57
Should write... and a picture appeared, miracles and only!
Sincerely, MAG.no
Post by Маг.нет » Fri Dec 24, 2010 22:05
:)Cool "svarochnik":) And how the effects of ionization? How long can I stay nearby? Different ionizers used, some are well-toned, but... long a number of not comfortable. Now I use the built in vozdukhoochistka and work visible and persistent presence near comfortable.
Sincerely, MAG.no
Экко
Post by Экко » Fri Dec 24, 2010 22:16
I will raise the voltage. While that smell "after a thunderstorm" only if you breathe near the arc.
Post by Маг.нет » Fri Dec 24, 2010 23:22
That which is not comfortable too "thunderstorm smell", if enabled, then immediately kind of just there, and if will work, then all the space. Vozdukhoochistka enabled ionizer is also a little smelly, but as it is not so, and there's this "high tone".
Sincerely, MAG.no
+ангел
Post by +ангел » Sat Dec 25, 2010 16:08
yeah ECCO have something to strive for
+ангел
Post by +ангел » Sat Dec 25, 2010 16:33
ECCO - 15000 volts is a normal voltage, nothing we are to raise the solder to the exit needle from a medical syringe and put her( why the needle of a medical syringe -steel she is good) should feel palm ion breeze 3 to 10 inches from the tip
and on the high-voltage unit can accumulate the charges it is better to fill with epoxy
MAG.there is a smell of rain is the smell of the Ozone from which the head hurts :) :) :) :)
Post by Маг.нет » Sat Dec 25, 2010 18:27
+ангел wrote:and the smell of rain is the smell of the Ozone from which the head hurts :):):):)
And I have this ionizer not pitied threw when compared with others guests.
Sincerely, MAG.no
Экко
Post by Экко » Sun Dec 26, 2010 13:51
Increased naprugu to 25kV. As I understand it if you place the insights in the distance, a little more for the formation of spark discharge, a corona occurs, it is dark blue stream and the glow of the ends of the wires.
Plans to make a Tesla coil, see what happens
p.s. if breathing ozone for a long time, then you do not want to breathe in 2 minutes
Post by Андрей Патрушев » Sun Dec 26, 2010 15:24
Экко wrote:if breathing ozone for a long time, then you do not want to breathe in 2 minutes
And pneumonia guaranteed... :wink:
Экко
Post by Экко » Sun Dec 26, 2010 15:37
did I have the right ionizer: to a corona discharge. Hmm, a smell specific, but pleasant, fascinating what is. That's just hot MOSFET, which radiator should I need to do something :roll:
Post by Маг.нет » Sun Dec 26, 2010 15:52
Экко wrote:Hmm, the smell is peculiar but pleasant, fascinating what is.
that's fascinating...
Sincerely, MAG.no
Экко
Post by Экко » Sun Dec 26, 2010 15:54
right now, the hand held the wire, and it is true: a chill does not weak
And pneumonia guaranteed... Wink
and how to find the room after quartz treatment?
Post by Маг.нет » Sun Dec 26, 2010 16:09
Экко wrote:hand right now, held the wire, and it is true: a chill does not weak
After prolonged use not just the chill but there is a cool (compared to the environment temperature) wind, which can not just to feel, and to fully observe such as bringing a piece of thin paper or something on lightness and flexibility like.
Sincerely, MAG.no
Экко
Post by Экко » Sun Dec 26, 2010 16:15
they say that the wool should be attracted, but I have the opposite :roll:
Post by Андрей Патрушев » Sun Dec 26, 2010 16:18
Экко wrote:and how to find the room after quartz treatment?
There are not so much typed as possible with ionizer the pump... :?
In addition, at a certain voltage and are located in close proximity to walls and objects and even nitrogen oxides rod like a gun - all you can skate to drop.
Post by Маг.нет » Sun Dec 26, 2010 16:23
Экко wrote:they say that the wool should be attracted, but I have the opposite
me too... especially Now rechecked, and wool and smoke are different, the smoke is pulled (curled into a funnel), wool proceeds.
Sincerely, MAG.no
Экко
Post by Экко » Sun Dec 26, 2010 16:23
scaring the young experimentalists, comrade Andrei :(
Экко
Post by Экко » Sun Dec 26, 2010 16:27
smoke also try: beef, smoke just seem to refers to the side
Post by Маг.нет » Sun Dec 26, 2010 16:35
Экко wrote:neponyatki, the smoke seems to just carry away
I have one of the electrodes "letter T" with a connection to the middle of the two needles, so that side of the needle where you can see the category there and notice the breeze, the opposite (directed outside) on itself "collapses" the smoke is very thin stream and pulls greatly on himself, after pushing myself to the other electrode (made of a spring).
Sincerely, MAG.no
Post by Андрей Патрушев » Sun Dec 26, 2010 16:36
Экко wrote:frighten the young experimentalists, comrade Andrei :(
What's the point to scare You? :) "Forewarned is forearmed"
Экко
Post by Экко » Sun Dec 26, 2010 16:37
the output of the multiplier " + " means a positive voltage, and must be negative. Turns out all wrong?
