About the players, soundcards and other Goodies...
Алексей К
Post by Алексей К » Thu Feb 22, 2007 21:10
Very convenient to store and preclusive Audiostrobe the drive with the computer. With MP3 everything is clear. At the moment I ispolo WMA Lossless. As it is, with no losses, has the greatest compatibility. FLAC and APE are small (2-7%) advantage in size. However, the size of compressed files is too big. I would like to know whether it is possible to use the high bitrate audio codecs (OGG/MusePack) at maximum bitrates?
Post by Андрей Патрушев » Sat Feb 24, 2007 16:36
All these formats are cut high. Listen of course you can, but nothing will. :wink:
вероника
Post by вероника » Mon May 07, 2007 0:14
Hello! This is probably a question of A. Patrushev. Bought MP3 player supports WAV and copied from the computer 3 track Ultra Brain, to test the bells. By ear it sounds fine, but those. har-th player says that the frequency range of 20Hz – 20kHz. Enough this range for the desired effect?
Post by Андрей Патрушев » Mon May 07, 2007 10:12
Yes, the range is sufficient if you play it in wav format. mp3 format still cut high and efficiency will be lost.
вероника
Post by вероника » Mon May 07, 2007 13:14
Thank you, and it was decided, once copied in WAV and sounds good, then everything is fine.
Post by Андрей Патрушев » Mon May 07, 2007 13:32
вероника wrote:Thank you, and it was decided, once copied in WAV and sounds good, then everything is fine.
Duck, the way it is, if you're listening to in wav format. :P
вероника
Post by вероника » Wed May 09, 2007 22:08
Misunderstood. Will listen. There are still questions, but there are in other branches. Thank you.
Post by Андрей Патрушев » Thu May 10, 2007 10:13
Well, Your player, despite the fact that it's called mp3 player can play wav and mp3 formats (right?).
So, wav format could provide a decent quality. So if You copied to the player the tracks to wav format, and they normally sound, it is true that everything is in order. :P
Post by Dimas » Thu May 10, 2007 11:37
WAV but takes up space (memory) kind of a lot!!! 8)
вероника
Post by вероника » Thu May 10, 2007 17:53
Thanks, already figured out. The player I have on 1Gb and ROM enough, and took it solely for this purpose. Of course, it would be nice to fit something else, but to find more memory and a DVD burner failed.
Карил
Post by Карил » Thu May 10, 2007 18:23
Well, of course, and i-pod?
Apple iPod Nano 4GB, Apple iPod Nano 8GB, Apple iPod 30GB, Apple iPod 80GB
File format:
AAC (16 - 320кбит/s), Protected AAC (from iTunes Music Store, M4A, M4B, M4P), MP3 (16 - 320кбит/s), MP3 VBR, Audible (formats 2, 3 and 4), Apple Lossless, AIFF and WAV
From 6780 RUB to RUB 13770
Post by Dimas » Thu May 10, 2007 18:54
Карил wrote:Well, of course, and i-pod?
File format:
The last line of your message speaks for itself..hanged himself,but didn't buy that crap even for 5000...Divorce people for money..he's not worth it,pay for the firm...the memory is now cheaper...
Карил
Post by Карил » Thu May 10, 2007 19:19
Then you certainly 1000 times right :) but Veronica no player couldn't find, so I called first.
Post by Dimas » Fri May 11, 2007 11:23
I would have chosen cheaper,Karil! :lol: :wink: Now on the market a lot of offers...
индеец
Post by индеец » Tue May 15, 2007 23:42
Peace to all! :)
Colleagues, as I already know a large effect from listening to a CD on a laptop does not have to wait... Right? Even if you purchase a headphone 6Гц-20kHz.
I personally more interested in alpha-state, i.e., the frequency of 8-12hz. Does this mean that you need to look for a CD player with the same range at lower levels? Ie, for example, Panasonic from 20Hz-20kHz will not give the desired effect?
Dima
Post by Dima » Wed May 16, 2007 9:39
вероника wrote:hi All! This is probably a question of A. Patrushev. Bought MP3 player supports WAV and copied from the computer 3 track Ultra Brain, to test the bells. By ear it sounds fine, but those. har-th player says that the frequency range of 20Hz – 20kHz. Enough this range for the desired effect?
Veronica, what kind of player? I Transcend that the passport reads .Vav, but really doesn't want to lose none of the tracks Patrushev.
Or someone tell me more what model will surely play .Vav-disk files Patrushev ?
Post by Андрей Патрушев » Wed May 16, 2007 11:10
Индеец wrote:Peace to all! :)
The ability of the player to play the alpha frequency have nothing to do with playback range player. Any player with a playback range 20Hz-20kHz is quite suitable.
By the way, the laptop seems to work well. When playing audiostrobe can cause problems, because it is often embedded (and most cheap) sound cards are not balanced for the volume, channels and heavily littered with high frequency.
вероника
Post by вероника » Wed May 16, 2007 15:31
"Veronica, what kind of player?"
I have a SAMSUNG YP-U2 All normal reads, but I took it the second time. In the first bought the player also turned out to be WAV, despite the fact that the price tag with the characteristics you specify it. When I returned it, we went through all the seller, where they were given support WAV (just checked it on the computer) and the result was that only reads one, but in Moscow, probably, more choice. Only need to check then not to fool with a return. Is 3700р.
Dima
Post by Dima » Wed May 16, 2007 16:01
Thank you.Only to Moscow us km thousand)..well, to Kiev a bit less then..
One pleased that I have not one such problem with these players..)
вероника
Post by вероника » Wed May 16, 2007 18:02
For some reason I decided that You from Moscow. :)
Dima
Post by Dima » Wed May 16, 2007 18:48
вероника wrote:for some reason decided that You from Moscow. :)
the accent probably gives...;)
And headphones You left standard?
вероника
Post by вероника » Wed May 16, 2007 20:06
Not-e-e... Capital outfit... :lol:
Standard ear – atikaki, I don't like them. Took the other, passing behind the ear – hold and closed. Sounds better and convenient.
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Fri Jun 01, 2007 1:22
Received the disks.
Was prososal on different CD players (iriver, pictures)
I have the feeling that high cut.
Here are scratching their heads.. whether to take one of the disks and dopati shopping, through CD players, whether it is..
Been thanked: 182 times
Post by Андрей Кабанков » Fri Jun 01, 2007 21:24
Евгений Кош wrote:Received the disks.
Disks all as is necessary,all that should be there - all there, nothing cut.
Евгений Кош
Post by Евгений Кош » Sat Jun 02, 2007 0:13
OK.
Maybe my demands are too high..
simple audio CDs with Russian musicians at a high sound "cooler". well, okay.. if there is anything.. so there .. :)
