Inner Pulse: first impressions and questions
Любознательная
- Been thanked: 7 times
Why you need MM? I became interested in the inner!
Re: the Inner Pulse: first impressions and questions
Любознательная wrote:Why you need MM? I became interested in the inner!
Full response and the video on this page http://www.mindmachine.ru/about.htm .
Popular answers and questions viewtopic.php?f=9&t=1184
Ашот Васильевич
- Has thanked: 2 times
- Been thanked: 1 time
Hello!
Unfortunately I have lost the user manual to inner Pulse...
I can send an electronic version of the user?
Since no instructions difficult to use the machine.
Thank you.
Thank you.
Игорь Геннадьевич
Hello. I have a machine Inner Pulse, the glasses, the standard red led. Acquired recently. On the forum I read that it is desirable to set the minimum (or close to minimum) brightness. But at minimum brightness (when the glow is only just noticeable through the eyelid) blinks only the left side. And just adding starts working the right side and blink seems to be the same, but not the minimum brightness... basically, it's not really annoying, but is in a glasses case or on the unit itself? For example, if I buy Premium glasses or Colortrak would be regulated to the minimum? Can anyone tell?
Igor G.
Hello.
If the brightness at which the SD as a flash in both eyes, comfortable, all right, if it's too bright, it is possible in the settings to adjust the balance.
Hello.
Игорь Геннадьевич
So comfortable, not annoying... There's a balance setting so... I Will study, can and will correct. Thank you.
Алексей Швец
Hello. Would like to clarify a few questions.
1) the stimulation of beta waves occurs sometimes drowsiness. This is the way it is written in the book you have on the site about AVS. What is the reason? Whether the brain is not used to synchronize with the supplied frequency. Whether the load for him in the early stages of a big that causes fatigue?
2) the stimulation of beta waves(14 Hz) there are visual effects, like some tunnels, savarina and balls scattering in different directions? What is it?
Why are alpha waves, these effects are less or not appear?? How to use this to develop visualization??
Alexey Shvets
visual effects.
Options: large collection sleep (any rhythm causes drowsiness); exceeding the optimum time of stimulation; excess optimal brightness or(and) volume.Алексей Швец wrote:1) the stimulation of beta waves occurs sometimes drowsiness. This is the way it is written in the book you have on the site about AVS. What is the reason? Whether the brain is not used to synchronize with the supplied frequency. Whether the load for him in the early stages of a big that causes fatigue?
This, as You correctly wrote,Алексей Швец wrote:2) the stimulation of beta waves(14 Hz) there are visual effects, like some tunnels, savarina and balls scattering in different directions? What is it?
Who can know - Why You alpha waves these effects are less or not appear??Алексей Швец wrote:Why are alpha waves, these effects are less or not appear??
To develop visualization, it is necessary to do the visualization.Алексей Швец wrote:How to develop visualization??
Алексей Швец
That is, the mind machine does not develop the capacity for independent visualization? She seems to like this part of the brain stimulates?
Алексей Швец
"Alex Shvets wrote(a):
Who can know Why You do on alpha waves, these effects are less or not appear?? "
Maybe I'm stuck somewhere in the low frequencies( it should be electroencephalogram brain to do). And beta stimulation pulls my lazy brain up to a maximum of alpha waves.
Alexey Shvets
Kind of food also stimulates the production of gastric juice...
Алексей Швец
Clear. We are not looking for easy ways. Let's go random.
Everyone is different... Why steam when you can just use it?...Алексей Швец wrote:Maybe I'm stuck somewhere in the low frequencies( it should be electroencephalogram brain to do). And beta stimulation pulls my lazy brain up to a maximum of alpha waves.
Самаритянен
Re: 1. The period of adaptation.
Good evening all! Acquired InnerPulse! I want to ask, can not absolutely in a subject how to start? Can tell you or send detailed instructions? The first thing that I'm interested in this period of adaptation, what programs to use and where to throw to listen? thanks in advance!
Health.Самаритянен wrote:good evening All! Acquired InnerPulse! I want to ask, can not absolutely in a subject how to start? Can tell you or send detailed instructions? The first thing that I'm interested in this period of adaptation, what programs to use and where to throw to listen? thanks in advance!
Moved Your message here (a section of the workshop is exclusively for its members.). Suggest to read this topic and even the forum (the topic of many useful links) - all You are asking was discussed on the forum repeatedly.
Sincerely, Roman.
PS: by the Way, recently I noticed that in my new innerpulse with the purchase (almost a year) are the batteries of 2.5 Ah, and I still never got to charge... And use every day mode AuS (15-25 minutes right after work on minimum brightness). And Navigator with more modest use (2-3 times a week wife listens to half an hour) you have to charge once a month, and ACC.the batteries are the same (I from 10 Grand bought - in inner pasted in the Navigator and changed the 2 into a flashlight on the bike).
Recall, please, how exactly to change the settings to improve the session in the Inner Pulse( frequency of change of portions of the session)
It was somewhere on the forum but can't find it.
Probably due to the involuntarily nachinayuschego feelings of anxiety.
In General, to vibration, to me personally, to walk is not easy, and they are extremely rare.
______________
posanski of cutie
______________
posanski of cutie
Любознательная
people tell us whether mindmachine such a cool thing that it worth to buy?
Keeper
It's in the instructions there.
Curious
Worth a lot.
Worth a lot.
Любознательная
yesterday I bought a inner plus red LEDs in the glasses, yesterday tried with her husband for the first session (relaxation), I did it before bed, I love super easy, and I have to work wait for projects nervyak solid, and then come home for a long time can not calm down, and falling asleep, too, have some problem, ctco if nervous,then at least akaya fatigue and can't sleep, and so yesterday I just passed out, still drives bought audiostrobe but not yet listened decided recommended that the first programs to work, then others will try. And Yes super, and later still to buy glasses color that were colored and listening experience finally bright. But so happy as an elephant. Ogoromnoe thanks for the advice Andrei Patrushev and Lilies-R, PTS helped me understand what I need!!!!!!THANK you
Good evening! can you tell me where can I download the manual enerplus?
or even the names sesi and what they mean? I lost the instruction...
Cayman If live in Moscow , then in the office to take if far .you can forward with another order. Although I think in electronic form can also be mailed. Recall on Monday call, to come up with something.
And I please email you send.ЛИЛИЯ-Р wrote:Cayman If live in Moscow , then in the office to take if far .you can forward with another order. Although I think in electronic form can also be mailed. Recall on Monday call, to come up with something.
