Lord, are you discussing the nodes on generator"mana")
I hasten to remind you that this is just a colossal library of knowledge in the field of symbols, including spirals) If fumbled on the Internet it is easy to find information) should Not outright reject the knowledge of their ancestors. Though they were limited technically, but the head they were thinking.
For example, if my memory serves me, take Tibet. According to esoteric ideas there, spiral-clockwise-concentrates energy in the heart and makes it quicker to achieve enlightenment. A counter-clockwise spiral are also valued but less than hour.
In other cultures you will find similar performance.
Also refer to physics: everything I hope you know what an electric current and the "rule" of the right hand?about a gimlet?))) who does not know Google)
Assuming that the torsion field is at least something similar to magnetic (such as the fact that you can create with wire
) we get a very intelligible reason to do a spiral clockwise.
So I ran the main theme to something someone says in a clockwise and counterclockwise twist is similar to the principle of Yin and Yang.....vacuum pressure...not exactly but very close) I would, on the basis of the esoterics, called it concentration and radiation..
in the first case, all of the plane is concentrated in the center and radiates out,in most cases, to the bottom, and so the flow comes from the top
..I do not know why esoteric so..for me so in both directions goes...
in the second case there is a dispersion in the plane, and the energy is drawn from the top and bottom in the center..
just want to add that it is better to use copper and silver(ideally) because of their conductivity, not gold. Gold on the physical and other properties inferior of both.
Even if we consider gold as a symbol of the sun(Yang) and silver as the symbol of the moon(Yin), then gold and then not pull as easily replaceable by copper(Yang) which by the way is often added to the impurity to gold. The effect is the same if not more.
Glad if my information was not just consumer goods.
Sincerely, Glitch.<
