The danger of using SP.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Sep 06, 2010 12:34
Again appeal to Sator'have:
General information about getting energy
For the production of magical effects needed excess energy which can be used to implement them. Any work, including magic, is primarily a work in the sense of physics. It is impossible to do without the appropriate amount of energy. If in physics, in the simplest case, the work is the sum of elementary displacements something with the application of some force of Magic work considering a few wider, work is just an action which requires energy. The engine of any process is always the difference of the energies.
To expend energy you need to have it. The human body receives energy in two ways (which can be reduced to one) - by processing food in the food process, and directly from the Earth as a large organism.
In the process of nutrition in the human body is a complex chain of chemical reactions in which the body replenishes energy reserves. In this case, man destroys nearby low cells (plants, animals), digesting them and extracting from them the energy. Man, as a cell of the body of the Earth corresponds to at least the nervous system, located in a privileged position relative to other body systems, so such actions easily go with it.
At the same time, man is a separate cell of a large body - the body of the Earth, which is supposed to food. In this body there are cells involved in the production of energy, there are cells that distribute this energy, has cells of only consuming it. A person fit invisible energy channels, through which it is synchronized with the organism of the Earth and nourished. To this way of eating applies a set of energy in places of Power, which is simply the bioactive points on the body of the Earth.
In the process of his spiritual evolution, man uses both of these ways of producing energy in a different way. So, at the beginning of the evolution, man is a mere cell of the nervous system, the loss of which does not threaten the body of the Earth as a whole, so the body is not in a hurry to feed him. As its development, a person acquires a higher status (and importance) in the body of the Earth, gets extra energy. The food intake is significantly reduced. The body of the Earth is simply not profitable to make so valuable a cage to look for food, much more profitable to use for the solution of any problem. The human body and consciousness are interrelated. The operating mode of the organism depends on the state of consciousness and Vice versa.
The process of digestion requires significant amounts of energy. Therefore, to maintain some of its surplus that you can use to make magic actions, you must only eat certain foods. But only in the initial stages. Starting from a certain level, the food you eat no longer has a significant impact on your consciousness, but then certain foods must be avoided, otherwise there may be severe consequences for the organism.
In the process of spiritual development, the digestive system is undergoing significant changes associated with the redistribution of the amounts of energy entering the body when powered directly from the body of the Earth. If you're seriously pursue Magic, you will feel the changes in your body.
When fasting, the energy intake from food stops, and stops the digestive process, reducing energy consumption. The body begins to metabolize body fat at the same time trying to make up for the lack of energy by the organism of the Earth and (slightly) organisms others. During fasting the human diet, as the body cells of Land may increase substantially, but only if the person is on a sufficient level of development (quite valuable as a cell).
The accumulation of energy to practice magical practices is not confined to food. You must maintain a certain lifestyle.
Sincerely, MAG.no<
Смелый
Has thanked: 2 times
Been thanked: 79 times
Post by Смелый » Mon Sep 06, 2010 12:38
Forgot to add. The flow of energy in the etheric body of a person selected by the crystal only goes through one chakra. The crystal selected, depends on the through which of the chakras is energy. He (crystal) it doesn't choose. They are in their properties joined. Better of course, if involved will be one of the top chakra, or Anahata, which actually is a control valve energy.
Good luck to everyone!
Post by Маг.нет » Mon Sep 06, 2010 12:43
[quote="Bold"]so I want to understand what it is, "naturally harmonizes and energizes our gross and subtle bodies?"
this phrase consists of 2 steps:
1. Naturally harmonizes - "balances" at the expense of the principles projected on the object is balanced in the crystal lattice.
2. Feeds - feeds it (nourishes), due to the above-described basic properties - Quartz is able to structure, store, amplify, focus, transmit and transform energy.
Sincerely, MAG.no
Post by Михаил_ » Mon Sep 06, 2010 12:46
1. for the construction of the cells only a small portion of energy comes from food and may not be used. General native is the purpose of food was different, but it's far from the topic.
2. About crystals to better visualize differently. In your text there are the analogy of a plumber - flows-flows of chakra into the chakra into the body from the body, the hole of....
To describe the same processes can be greatly different. Actually energy is only in the subjective perception flows and flows. Looking from another level, you can say that it can generally increase and decrease with no apparent source. How? Man is not confined to a closed system and does not know (perceive) all the laws of conversion.
Speaking of crystals, we say that two objects - man and crystal are geographically close.
(in the case of SP it can be secured direct placement in the pocket, but the operation of the device, but it doesn't matter). This ensures some REPLACEMENT of mental resonance that could occur at a distance.
In fact we are talking about attunement.
After this you need to understand that man is just a cell in a greater organism of the planet and the energy it feeds not so much the food or the space forces or the air as the WORLD in the large sense of the word.
Stones is part of tuning forks world.
And the impossibility to extract energy in any desired quantities directly from the world is the process of disharmony of man-world, the violation of attunement between alien objects.
The placement of stone in a private field of the person restoring the configuration "on TV", though usually only one or part of the parameters.
On the other hand, it is sometimes dangerous because a good setup of one channel, can score a signal from an ill-minded others, creating a bias.
So you need to listen to yourself.
Here Is The Magician.no said above that the quartz in this sense is rather universal stone - configures a lot at once.
You can say a dozen other ways, but to help to help only their own reading process, as it look from outside. Logical reasoning - will not help.
here the logic is not applicable, since in the graft model of the world there are not many processes are really running in it.<
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Mon Sep 06, 2010 12:51
Смелый wrote:Releases a cloud of energy, which like a cloud of smoke absorbed all the essential body?
I would have spent an analogy with the electro-magnetic field
Imagine that SP generates around itself a field,
when you make a structural link, then SP starts to "resonate" with You "generare" (projecting) this field is for You.
This is a very exaggerated, especially taking into account neg-entropy is the essence of orgone energy, however on my personal feelings this is the closest to me personally analogy.
Maybe someone will help. :?
Post by Маг.нет » Mon Sep 06, 2010 12:52
Смелый wrote:, the Flow of energy in the etheric body of a person selected by the crystal only goes through one chakra. The crystal selected, depends on the through which of the chakras is energy. He (crystal) it doesn't choose.
In the case of SP, the energy will go through the "activated" via transmitted vibrations chakra (which track to turn). Therefore, the "universal" quartz (works with all chakras) ... with such spins, it is possible to strengthen (increase the channel) using a "stone+" and interpret as energy.
Sincerely, MAG.no
Been thanked: 21 times
Post by Логик » Mon Sep 06, 2010 13:01
Михаил_ wrote:General native is the purpose of food was different, but it's far from the topic.
But you can, certainly me more!
Post by Михаил_ » Mon Sep 06, 2010 13:47
not - in. The situation with crystals about. It's more of a feedback tool for attunement with the world.
I.e., the setting item on lokalnoy point of the biosphere.
The perversity of the current situation you cannot imagine. A repair is even more difficult....
A simple example - one of our friend in the summer found out I was pregnant the second. After a short time she began to have very strong toxicity, in spite of more or less normal diet(often and usually it's contrary to stereotypes and the only disposable cause) and a number of other favorable factors.
Went to the cottage, not very far from the metropolis, a diet not much changed, but every day fresh berries from your site from morning to evening. On the second day morning sickness was gone and no longer bothered.
No other action is taken. Just the person returned to a normal setting to the place where even the rest of the "wrong" part of food is not interrupted, the body began to function normally in unison with the world.
Post by Маг.нет » Mon Sep 06, 2010 22:51
Found another variety of quartz - AGAT. Property to resonate with the vibrations of all the seven chakrasmakes it "universal" for use in conjunction (and use in the manufacture of) with SP.
And the history and characteristics of...
Famous scientist of antiquity Pliny the Elder believed that the name comes from the river Achates (al-Greek. Ἀχάτης) in Sicily (perhaps modern Karabi or Dirillo), another interpretation — from the Greek "ἀγαθός" — good, good, happy. Most often, the pattern resembles agate eyes. According to one ancient legend, is the eye of heaven white eagle, which after a battle with a black sorcerer fell to the Ground and began to stone. And his eyes continued to look at people, separating the good works from evil. Agate is also called the Eye of the Creator.
Processed in the shape of the eye, agate was placed in the eye sockets of the statues, and served to repel dark forces.
Pliny the Elder mentioned that the use of agate can — "add person of eloquence and mind, to avert the storm, to help the sport, to pacify anger". In ancient times believed that agate is a stone of health, prosperity and longevity.
Such a "universal" useful stone... AGATE.
Sincerely, MAG.no
Post by Маг.нет » Mon Sep 06, 2010 23:08
And another list of stones...
(it is worth to note that some of the stones resonate with 2 or more chakras).
the Stones affect chakra.
The most active centers located along the spine are seven so-called chakras. They consist of nerve nodes, blood and lymph vessels. Chakra - a kind of batteries and at the same time generators of bioenergy. Each chakra corresponds to a certain vibration; for example, the color (wavelength) or the sound of a particular mantra (sound vibrations). The lower chakras (one through three) resonate with the low frequencies of the Earth, and the top (with the fourth to seventh) respond to high-frequency vibrations of the Cosmos.
Thus, the human body is considered as an open system, part of the General energy system of the Earth-to-Space. Indian healers could influence the chakras with using gems, which also have defined frequency characteristics. The sick organ, the points or corresponding chakra put either "Yin stones", "pulling" pain and debilitating excess energy, or stones "Yang", which can "feed" energy to excite and stimulate. In this regard, people are often unaware that they are unwell due to improperly chosen decorations.
Sahasrara (in parietal area): agate, diamond, anhydrite, rock crystal, pearls, cacholong, calcite, quartz, Topaz, fluorite, zircon, charoite.
ajna (at the level of the middle of the forehead): agate, azurite, amethyst, quartz, malachite, sapphire, fluorite.
Vishuddha (near the throat): agate, azurite, aquamarine, amazonite, Apatite, turquoise, pearls, cats eye, chalcedony, charoite.
Anahata (heart): aventurine, agate, actinolite, alexandrite, moonstone, beryl, Bloodstone, emerald, diopside, dioptase, jade, serpentine, calcite, moonstone, malachite, jade, rhodonite, rhodochrosite, rubellite, ruby, agilit, serafinite, chrysoberyl, chrysoprase, charoite.
Manipur (near solar plexus): agate, Apatite, beryl, jadeite, serpentine, flint, malachite, jade, onyx, tiger's eye, peridot, citrine.
Swadhisthana (sacred, below the navel): agate, almandine, hematite, Bloodstone, ruby, spinel.
Muladhara (bottom, in the sacrum area): agate, actinolite, jet, hematite, garnet, obsidian, Topaz.
Sincerely, MAG.no<
_Алекс_
Post by _Алекс_ » Tue Sep 07, 2010 3:23
Sincerely, MAG.no
Agate I look in all the chakras present) Good pebble!
Смелый
Post by Смелый » Tue Sep 07, 2010 4:20
Маг.нет wrote:
Смелый wrote:so I want to understand what it is, "naturally harmonizes and energizes our gross and subtle bodies?"
Sincerely, MAG.no
Naturally harmonizes, balances, etc. It's all words. Explaining nothing and giving no practical use.
Let's look at what I say from the point of view of the plumber, if someone want to.
Here is often mentioned the word "sausage". Got a new product began to be used, the beginning of the sausage. Why?
We have the etheric body.It repeats the physical body, but a few more. The physical body is permeated with a huge number of trunks of veins, arteries, lymphatic system, etc., which is constantly served or given. Life support and disposal. Solid pipeline, from the point of view of the plumber.
The etheric body is also permeated the entire number of energy channels. If someone thinks that the energy inside the person is moving and is distributed freely as she pleases, it is not so. Energy moves inside the etheric body (etheric, and physical) ONLY ON a DENSE network of energy channels. But almost all of us have energy blocks in the energy channels in different quantities. The energy on the channel is suitable to the block and rests in him. It would be easier go around this block a "natural" way. But no. Only the channel. And energy starts to squeeze, seep through this and other energy obstacles. This is the process that we call "us sausage". Energy presses in one other place, here we are and warps. It was not blocks from the Buddhas, so it is even the flow of energy not felt since the free movement of energy is not felt. Is felt only when the energy touches the obstacle.
So, from the point of view of the plumber, the energy moves only in the energy channels, encounters an obstacle, it stops and if the pressure continues to slowly starts to corrode the unit. As long as you do not remove and will not have the opportunity to move freely.
Energy comes to us only through the chakras. (There are opinions that there are many more than seven). But chakras are not only getting the energy they have and give. A sort of two-way radio. It is at the level of the chakras where contacts between people. Have met two people, both the active one and the same chakra. Nice talking and parted satisfied with each other. No matter what nonsense while in words they did not carry, was the energy exchange at the level of the same currently active chakras. And they are happy with each other. This is with regard to just socializing. In relation to business meetings, everything is different. Chakra Svadhisthana, is programming. That is, it assumes a programming effect on another person. And the more outgoing flow, the greater the likelihood that the interviewee will have you convinced. But the host of the source chakra is ajna. That is, one tries to convince the other, makes the various arguments, increasing outgoing flow of Svadhisthana, increasing the pressure at the entrance to the Ajna and the mind of the interlocutor. Ultimately, this pressure pressing the various buttons in the head of assure, he creates the illusion of independent decision-making. Are the arguments and reasons of why you need to agree. The deed is done. Best sellers - children. When they begin to demand some sort of regular, eighteenth designer, you know. Enough is enough. These are not plays, and give him more. But the child moan, brings new arguments. Pressure in the head increases, the impact on the need for a decision in favor of the child buttons. And in your head thoughts like: "I was going to buy five loaves of bread. Why do I need five, I'll buy two. And ten bottles of milk I do not need. Yes and no pineapples tangerines you can do". And, lo and behold! The required amount to buy the eighteenth designer found. And try during such pressure to lie quietly on the couch, put on the forehead mirror reflecting the party from itself. And thoughts will flow in the other direction. May be in your head and you will save some money, but spend it you want for yourself. On a blouse, on a new carb for the car.
So, from the point of view of the plumber (and not only because of the knowledge I shared, were not created by me, and more reputable people), energy system up and running pipelines on principle, but more difficult.
Now about the SP. Once again a big "red army" thanks to the Humpty. Very high quality made product. Yesterday, lying in the evening I started again to experiment with his power system, to reflect and this morning everything fell into place. A lot of what previously was thought and eksperimentirovat connected. Probably just now had enough energy. Don Juan is a phrase: "Everything starts with one particular action, which is repeating continuously, constantly, day in and day allows to achieve a desired state. And once it is achieved - the way is open". The rights of don Juan. I did a lot of things on ourselves. And now, really - the way is open.
Good luck to everyone!<
Смелый
Post by Смелый » Tue Sep 07, 2010 6:31
Маг.нет wrote:Again turn to Sator'have:
Sincerely, MAG.no
In addition to these two types of energy production (from digestion, and from Earth), the person receives it from a third source - surrounding space, or Space. The earth also receives energy from Space. But here's the problem. She can't get it directly from Space. She gets her indirectly, just as passing through living beings: people, animals, insects, plants. And in turn, the transfer of energy from Earth to Space occurs only by passing it through living beings. That is, if tomorrow the earth all living things (people, animals, plants) will disappear, the energy exchange between the Earth and the Cosmos will cease. And from this point of view, humanity has been a useless and a direct threat to the existence of the Earth. Almost useless, as our energy channels clogged with long units and its role in mediating the energy exchange between Earth and Space we perform poorly. On the other hand, as a result of human activity, destroyed those creatures that perfectly fulfill their functions for the implementation of the energy exchange between Earth and Space. Plus the result of many years of human life that surrounds the Earth space, is filled with clots emotional outbursts of humanity, which are not always positive.<
Post by Маг.нет » Tue Sep 07, 2010 11:10
Properties of energy - potential difference than the difference between the higher, the more energy is manifested.
There is no separate Earth energy and the energy of the Cosmos is an energy field interaction between the two voltages (potentials) Earth and Space (of course if you remove the interaction with other fields). People in this scheme, the filter, the point of intersection and the node of interaction with other energy fields (including the inner potential of the person).
Briefly so, formulate a more clear - describe.
Смелый wrote:, "it All begins with a single action, which is repeating continuously, constantly, day in and day allows to achieve a desired state. And once it is achieved - the way is open"
And you know how much time is the minimum "day by day" - more than 40 (45) days. Understand why energy field/aura/cocoon (will consider from this point of view) stores the "information fingerprint" of the pulse during this time (the period of the decay momentum in the field). When you repeat day in and day 40 (45) days, the same impulse, the World receives information about the stability of this field structure (fixing structure). May climbed into the jungle, but this explanation in my opinion is close to fact. The repetition of "day by day" - more than 40 (45) days of the Trend, we get the habit (by the way, the reverse process of eliminating the Trend in this period helps to get rid of habits).
Later I will continue this topic...
Sincerely, MAG.no
Post by Маг.нет » Tue Sep 07, 2010 11:37
Смелый wrote:naturally harmonizes, balances, etc
The analogy with electricity, it's like a filter (voltage regulator) additionally connected in the chain. The benefits of such a stabilizer I think is understandable. Now depart from the power supply, as this filter is not suitable 2-3, and a lot of wires, here is included the principle of "redistribution" (again a redistribution of current within a multidimensional energy system, for example city, state... day, night...).
Something like this.
Sincerely, MAG.no
Post by Михаил_ » Tue Sep 07, 2010 12:12
1. the perception of energy and / or move depends on currently level of perception.
2. energy can flow and take in different frequency ranges, not only in the range of the etheric body, but most importantly, that she can BE. Ie can change potential is not due to the "swap" of reserves, but by leaps and bounds-the quantum system state changes (either by humans or the outside world)
3. only in "regular" mode, passive body work energy is given and passes through the chakras, and using the fact that the Pak Jae Woo is an external chakra.
4. the energy exchange for the "inner chakra" is associated with the activity of man as self-conscious units, otherwise zero. Ie is subject to change depending on creative and other activity and relationships in society.
5. modulating the properties of the stones or any other items located geographically near (inside the cocoon) are not using chakra, but on the principle of diffusion through the structure - drip a drop of ink in water.... if the diffusion through the channels is slightly faster, but not only there.
6. "sausage" people can not from the blocks in the body, they often occur naturally pain with a strong influx of energy. "Sausage" due to simple changes of state when the mind is not able to treat him and most importantly detects the difference from the usual norm. This was related to intoxication (the mechanisms are very similar on the principle of action).
But without the side effects usually.
Then the mind writes a new "norm" in the list of known States and increases the experience to the ability to operate with a new level of energy all goes in the usual sense, but different from the past status.
as for the stones (but not only them), then there is another point. It is associated with what is more or less well included in the society, which is very much off from the real world (e.g. look at the advertising, media and so on - promoted and embedded in the consciousness of something real, i.e. not in the real world too). Because of this shutdown, most of the people are misaligned with the planet and does not receive much natural energopaek, which run anywhere is not necessary - simply plug fell out of the socket.
Here rocks and the elements of wildlife and restore the matching, that automatically repairs the human to the level of normal operation of the system.
Hence, the described MAG.net hotfix behavioural patterns in some cases is directly due to the inclusion in a real or virtual structure information. Rather to engage with the real world or its virtual neighbor.
All of the above is undoubtedly my personal opinion, which could be wrong :) do not take as dogma.<
Смелый
Post by Смелый » Wed Sep 08, 2010 2:46
Шалтай Балтай wrote: I would have spent an analogy with the electro-magnetic field
Please accept my congratulations. The feeling of analogy with the electromagnetic field means that Your shell has considerably increased and condensed. That is, You have a perfect tight cocoon. But this is likely to have increased Your sensitivity. You started to feel in my physical body (which many people do not feel), that is, began to develop a feeling of "Here and now". Now you have reached a stage when in connection with a constant flow of energy of Your cocoon was tight and perfect, Your mind begins to flow into the shell. (Hence the feeling of the cloud that does not negate the presence within the energy channels and chakras, since the body has an internal organs the internal organs in turn have their own energoblock or auras, as well as their own consciousness, and therefore the energy recharge they always need) Is the expansion of consciousness and You are like I used to feel in my body, now You feel in its shell. So now You start to feel your shell. Hence the indispensable attributes - the development of intuition, foresight, awareness, etc. In the future there will be feeling a cloud or a balloon and in it (in it) the physical body. Well, then further extension of consciousness. So, everything is fine! We can only understand that the way to use SP (and other products) in terms of personal improvement faithful, to continue to move in this direction. At the same time increasing personal charisma, You yourself may have noticed a change in the attitude of the people around You for the better. (This does not mean that it was worse than before, but now the process is still improvement to be noticeable). So get ready, it will be in the future to do with the signs symptoms others manifestations of respect and even love. Since charisma is a technique of influence, you need to be poakuratnee because much of what You speak, others will just accept on faith. And one more aspect. If You in something in the material world could help egregors, now for word, You are not reachable. Your consciousness at this stage is higher egregorial. And then there are no limits in the expansion of consciousness. About the expansion of consciousness writes well of the Maharishi in the book: "Seven stages of consciousness." The book is rare in paper, on the Internet looking, but can be. I am glad for You.
Смелый
Post by Смелый » Wed Sep 08, 2010 3:01
Михаил_ wrote:1. the perception of energy and / or move depends on currently level of perception.
Totally agree with You. Especially in different frequency ranges. Possibly (probably?) different frequency bands belong to the various Subtle Bodies of man. And more perfect is the etheric body, on the one hand gives more possibilities to the physical body, on the other hand probably has an impact on the perfection of the Subtle Bodies - mental and astral for example. Because visual images are born in the mental body, the astral body travelling. That, and the other is not possible without a strong personal energy. My opinion may be incorrect. But by and large, all of the above, both by You and me, much of anything is not affected. If the process of self-improvement with the help of the products presented on this site (including You invented) is running, it will go. None of us that use these products, they will not refuse. on the contrary, will be purchased new. But we want or do not want, we have to admit. These products primarily improve and strengthen the personal power of the person. Everything else, as a result of increased personal energy.
Post by Шалтай Балтай » Wed Sep 08, 2010 10:23
Смелый wrote:congratulations
Hmm... to be honest many of the attributes that You saw in me I clearly don't deserve, but what You say resonates clearly. There are still a lot of work to do
Thank you!
Новик
Post by Новик » Wed Sep 15, 2010 11:07
Merkaba
I watched as you described its possible side effect from SP....
Turned out to go back to normal?
And if so in what way?
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Wed Sep 15, 2010 11:16
Novik
No, not back yet. Sometimes there are improvements, sometimes they are not. Drives Patrushev help, but temporarily. However, I decided to continue the study of the joint venture, for many reasons.
Новик
Post by Новик » Thu Sep 16, 2010 11:33
Merkaba
Cool! This researcher :ay
PS.
The road by walking
МерКаБа
Post by МерКаБа » Thu Sep 16, 2010 13:05
Novik
Thanks for the support! az
Post by Шалтай Балтай » Thu Sep 16, 2010 13:18
Merkaba
"Are you there that... that... not very...." (C) :)
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Sat Oct 02, 2010 14:41
Decided and your experience to publish.
It all started here with this couple - http://www.mindmachine.ru/viewtopic.php?p=52034#52034
As soon as made, just as something bad for the soul, but I didn't pay much attention to it. When connected to the player with the session(don't remember the frequency), was not really a weakness of some kind in the body, even dizzy... turned Off. For a couple of days left(I think from habit, to get used to, adapt), but noticed that the bruises and grazes(I'm a blacksmith, I have my own family workshop at home - a piece of iron around, often something catchy or failed to catch...) that used to heal in a day or two now hardly heal, and minor scratches all began to fester... I Realized that this couple is not from the air, and my energy sucks, and indiscriminately... Consulted here-there are many confirmed my assumption. Once altered, everything again returned to normal, even a bit improved))) could not understand what was wrong, while the same kit is not set incorrectly-wound coil, even without compression of the crystal, epoxy the device is turned "suck" more than "donating"... Yes, crystal is my first time not cleaned up... So in the Assembly are to be adhered to very very careful - a mistake can cost far more than separtately material(one of the crystals I when disassembling crumbled, then had him pour a little passive mud pies)...
