Neurofen
Post by Андрей Патрушев » Tue Jul 20, 2010 20:15
Yes, Echofon works perfectly without headphones.
There, by the way, seem especially sucky earphones. I tried with Ultrasone - no difference felt.
Г0сть
Post by Г0сть » Wed Jul 21, 2010 11:48
Андрей Патрушев wrote:Pomeroy and Echofon and Neurofen - I also wonder...
Andreaus,You have Neurofen? What generation?
Тапка
Post by Тапка » Sat Sep 04, 2010 2:25
Something we sucked homemade neurofen, Senya bought detalhe - 82 RUB out))) schA in the layout will gather will unsubscribe ,yet over the throttle 2Гн to find.
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Mon Sep 06, 2010 11:14
so what's with neuroform that??? that it came out???
Тапка
Post by Тапка » Tue Sep 28, 2010 0:29
Collected on the model...checked...nothing....(((((
At the output there is no signal generator, no signal PPC.
Thursday it will give MWS check customera that there is a 40kHz oscillator and the amplifier stage .
As the throttle 2 GN - 2 took the throttle from the lights and photosonic 3P-3. we razbiraetsa in General - narion PTS hotstsa to try..
Экко
Post by Экко » Tue Sep 28, 2010 3:26
Sneaker
oscilla died
Тапка
Post by Тапка » Tue Sep 28, 2010 4:35
Still at the limit of 0.01 volts some incomprehensible signal results ,the interference I think
Экко
Post by Экко » Tue Sep 28, 2010 12:16
so there generator 40kHz? The shape of the pulse is what? And how a sound signal is connected, AM modulation? I think to do everything yourself, not to repeat those foreign schemes that are not okay then, why there is something not working.
Тапка
Post by Тапка » Fri Oct 01, 2010 23:18
Gave the breadboard with neuroform Leader - he will look at the signals and they will send nah transistors and the unfinished shemy and build Nurofen on dsp processor ( very much he loves them))).
Экко
Post by Экко » Sun Oct 03, 2010 11:30
will send tries transistors and the unfinished shemy
right :) But ask him to explain the principle, I want an analog circuit to do.
Тапка
Post by Тапка » Tue Oct 05, 2010 2:07
Anyways - in my scheme MWS found about 6 ( !!!!!) errors ( Fox) and noise generator 2 transit is not a generator of ultrasound, there it is necessary to submit already amplified signal.....work....
And here is the guys did Neurofen - usually all in secret.....
http://community.livejournal.com/vetvi_ ... tml#cutid1
Экко
Post by Экко » Tue Nov 09, 2010 19:22
there's a photo pitici strangely connected to each and only one wire connected. Is this going to work? They all have 2 wires.
Тапка
Post by Тапка » Tue Nov 09, 2010 21:35
kanesh will - there is a direct piezoelectric effect and the reverse piezoelectric effect - like so
Экко
Post by Экко » Wed Nov 10, 2010 9:31
Тапка wrote:kanesh will - there is a direct piezoelectric effect and the reverse piezoelectric effect - like so
hmm. Reverse piezoelectric effect: the occurrence of a current in the piezoelectric element due to vibration thereof. The number of conductors is not relevant, as neurophone actually.
Well, how's your narion???
Тапка
Post by Тапка » Wed Nov 10, 2010 16:44
Our narion is embedded in a large platform - so all in processees)))
Экко
Post by Экко » Tue Nov 16, 2010 11:20
It seems to me that the action of neurophone based on the transmission vibratii bones of the skull, otherwise why pieski must be fastened only on the forehead???
Экко
Post by Экко » Sat Dec 04, 2010 16:49
I read about echofon, I think there is AM modulation of the ultrasound, going to repeat this device in the near future I will lay out a scheme that will gather and kill. Do not understand really what it means:
- auto tuning of frequencies, organized according to the principle of compensated bridge load
Instead, it will adjust the carrying from 30 to 100 KHz.
I think this will be enough to modulate a little less than 30 kHz, and 40 KHz uses neurofen, echofon think in a similar way works.
AndrewYou promised to measure the parameters of echofon may have forgotten? And there you have this device?
How to gather, describe his work, I want you to say right or wrong works.
Post by Андрей Патрушев » Sat Dec 04, 2010 19:05
Экко wrote:Andrew, You promised to measure the parameters of echofon may have forgotten? And there you have this device?
Remember, but all the time for routine forget... :)
Николай3003
Post by Николай3003 » Thu Jan 06, 2011 0:50
Hello !!! Can someone write what is the difference between neuroform and echofone ??? In the presence of echofon but to say that great effects don't know. So I think maybe there something to add ?
Экко
Post by Экко » Fri Jan 07, 2011 20:53
well, my opinion echofon affects the bones of the skull, but neurofen "magic" way transmits sound through vibration of the skin, which is more interesting
Звяга
Post by Звяга » Fri Jan 07, 2011 21:39
in the pictures I realized that it was actually the headphone cord, and in it each with two wires going :)
Николай3003
Post by Николай3003 » Sat Jan 08, 2011 1:59
so maybe it makes sense to add or apgrejdit echofon to the level of neurophone I just don't know what output echofon and neurophone and if the principle of them are the same !!!
Николай3003
Post by Николай3003 » Sat Jan 08, 2011 2:01
but I fished from the net all that is found on echofone and neurophone scheme and those data will give elektroniku he sound operator and see if that will let you know if there is something on the principle of work or schemes let me know
Николай3003
Post by Николай3003 » Sat Jan 08, 2011 2:08
and again, there would even be data that the output of neurophone it would be much more fun as well
or let's say the first circuit where the voltage in the region of 3,000 volts was used at all prekrastno
Экко
Post by Экко » Sat Jan 08, 2011 11:19
articles about neurophone somewhat controversial, or maybe just neurophone there are different.
