Club
- Маг.нет
- Has thanked: 24 times
- Been thanked: 142 times
Very(!) a rickety suspension bridge, underneath the bubbling water. You think you could have done differently, but not everyone needs to get there, who will handle it - no longer afraid of heights. And a lot of internal trepidation that one leads, the other stops, the third expands. Look at more pictures, maybe tomorrow the topic "INTERESTING PLACES of RUSSIA" will spread, to describe the place. And power... it's there, I don't know why I think so, "noise" is very strong - hit. Fear of places, probably not, that's awe - YES!
Sincerely, MAG.no
Sincerely, MAG.no
- Маг.нет
There "the apartment looked...
THIS is the ENTRANCE of the nursery "baby" - the facade of the caves of ancient man
![Image](http://img33.imageshack.us/img33/7703/dsc02926zy.jpg)
Uploaded with ImageShack.us
In the cave seen "unique" effect, authorized the experiment, the ventilation system of the cave.
Experiment:
Place hearth removed hundreds of meters from the surface and from the input / output. Received permission to smoke a cigarette in the "room" of the home. And what I saw. Smoke curled in the straw "clockwise" (look at the filter) and goes for an interesting trajectory with strictly direct refraction at an angle of 90°, go "beyond the smoke" - breaking direct distribution occurs as left-right and up-down(!). That's ancient man...
Sincerely, MAG.no
Experiment:
Sincerely, MAG.no
- Маг.нет
FINISH TO START
leave You just for a moment
:oops::oops::oops::oops::oops::oops:
Sincerely, MAG.no![Surprised :o](./images/smilies/icon_surprised.gif)
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Sincerely, MAG.no
- Маг.нет
ГОРОДСКОЙ СУМАСШЕДШИЙ wrote:53. The egregor control - allows you to encapsulate egregor that unites people on some symptom of a new kind of motivation, if the result will generate a positive emotional response of participants, i.e. the change is for the better, it will catch on. If for the worse, then almost immediately die, though perhaps some action, but very limited.Here is almost the principle of the "virus" - it is possible to install something that will cause positive changes, it will create a community of people with a positive response and cause a power surge that would short-circuit the process of positive feedback.
Naturally from the work of this module should not expect immediate effects, the process is inertial, but in small communities, for example, a small workforce, change can be quite rapid.
An interesting property...
With respect the Magician.no
- Маг.нет
Смелый wrote:with little experience in the club will take
Андрей Кабанков wrote:Want to study the effects of the operation of the N-th number of Radionics and their owners for the same goal.Goals can be any,either your own or shared.Everything is in our hands.
Rather, more important is not the experience...Андрей Кабанков wrote:in the club I think to take people who already proved himself on the forum
Sincerely, MAG.no
- Маг.нет
In the meantime:
Remember, all in one.
spend "tuning" through the air, as the environment of all...ГОРОДСКОЙ СУМАСШЕДШИЙ wrote:18. The Air passage - way goal, the "left" of probability. This module creates the possibility of implementation of absolutely not likely of probabilities. Like the fall of a sandwich on the side and hold in this form. Ie in principle, such probabilities are, but extremely small and usually not implemented. Using them you can achieve is not achievable goals. When activated, you need to focus on the target and activate the module.
The goal may not necessarily be "global", and you tube to disperse on the road. Some have tried people from a crowded place so to remove unnecessary people from the negotiations.
37. Transmutation of air - creates an opportunity to transform an object, situation by working with probabilities, affects both the personal future and the future of the world, which means working in different frequency bands.
- Маг.нет
Academician G. I. Shipov's thoughts says: “the Thoughts and feelings emitted by each of us, is the torsion bars, because the matter of thoughts and feelings there is an element of torsion fields. The equations describing the idea of non-linear. This suggests that thought can influence on itself, i.e. it is a self-organized structure able to live my life."
Sincerely, MAG.no♆
Sincerely, MAG.no♆
